RTEMS  5.1
cacheimpl.h
1 /*
2  * Cache Manager
3  *
4  * Copyright (C) 2014, 2018 embedded brains GmbH
5  *
6  * COPYRIGHT (c) 1989-1999.
7  * On-Line Applications Research Corporation (OAR).
8  *
9  * The license and distribution terms for this file may be
10  * found in the file LICENSE in this distribution or at
11  * http://www.rtems.org/license/LICENSE.
12  */
13
14 /*
15  * The functions in this file implement the API to the RTEMS Cache Manager.
16  * This file is intended to be included in a cache implemention source file
17  * provided by the architecture or BSP, e.g.
18  *
19  * - bsps/${RTEMS_CPU}/shared/cache/cache.c
20  * - bsps/${RTEMS_CPU}/${RTEMS_BSP_FAMILY}/start/cache.c
21  *
22  * In this file a couple of defines and inline functions may be provided and
23  * afterwards this file is included, e.g.
24  *
25  * #define CPU_DATA_CACHE_ALIGNMENT XYZ
26  * ...
27  * #include "../../../bsps/shared/cache/cacheimpl.h"
28  *
29  * The cache implementation source file shall define
30  *
31  * #define CPU_DATA_CACHE_ALIGNMENT <POSITIVE INTEGER>
32  *
33  * to enable the data cache support.
34  *
35  * The cache implementation source file shall define
36  *
37  * #define CPU_INSTRUCTION_CACHE_ALIGNMENT <POSITIVE INTEGER>
38  *
39  * to enable the instruction cache support.
40  *
41  * The cache implementation source file shall define
42  *
43  * #define CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS
44  *
45  * if it provides cache maintenance functions which operate on multiple lines.
46  * Otherwise a generic loop with single line operations will be used. It is
47  * strongly recommended to provide the implementation in terms of static inline
48  * functions for performance reasons.
49  *
50  * The cache implementation source file shall define
51  *
52  * #define CPU_CACHE_SUPPORT_PROVIDES_CACHE_SIZE_FUNCTIONS
53  *
54  * if it provides functions to get the data and instruction cache sizes by
55  * level.
56  *
57  * The cache implementation source file shall define
58  *
59  * #define CPU_CACHE_SUPPORT_PROVIDES_INSTRUCTION_SYNC_FUNCTION
60  *
61  * if special instructions must be used to synchronize the instruction caches
62  * after a code change.
63  *
64  * The cache implementation source file shall define
65  *
66  * #define CPU_CACHE_SUPPORT_PROVIDES_DISABLE_DATA
67  *
68  * if an external implementation of rtems_cache_disable_data() is provided,
69  * e.g. as an implementation in assembly code.
70  *
71  * The cache implementation source file shall define
72  *
73  * #define CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING
74  *
75  * if the hardware provides no instruction cache snooping and the instruction
76  * cache invalidation needs software support.
77  *
78  * The functions below are implemented with inline routines found in the cache
79  * implementation source file for each architecture or BSP. In the event that
80  * not support for a specific function for a cache is provided, the API routine
81  * does nothing (but does exist).
82  */
83
84 #include <rtems.h>
85
86 #if defined(RTEMS_SMP) && defined(CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING)
87 #include <rtems/score/smpimpl.h>
89 #endif
90
91 #if CPU_DATA_CACHE_ALIGNMENT > CPU_CACHE_LINE_BYTES
92 #error "CPU_DATA_CACHE_ALIGNMENT is greater than CPU_CACHE_LINE_BYTES"
93 #endif
94
95 #if CPU_INSTRUCTION_CACHE_ALIGNMENT > CPU_CACHE_LINE_BYTES
96 #error "CPU_INSTRUCTION_CACHE_ALIGNMENT is greater than CPU_CACHE_LINE_BYTES"
97 #endif
98
99 /*
100  * THESE FUNCTIONS ONLY HAVE BODIES IF WE HAVE A DATA CACHE
101  */
102
103 /*
104  * This function is called to flush the data cache by performing cache
105  * copybacks. It must determine how many cache lines need to be copied
106  * back and then perform the copybacks.
107  */
108 void
109 rtems_cache_flush_multiple_data_lines( const void * d_addr, size_t n_bytes )
110 {
111 #if defined(CPU_DATA_CACHE_ALIGNMENT)
112 #if defined(CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS)
113  _CPU_cache_flush_data_range( d_addr, n_bytes );
114 #else
115  const void * final_address;
116
117  /*
118  * Set d_addr to the beginning of the cache line; final_address indicates
119  * the last address_t which needs to be pushed. Increment d_addr and push
120  * the resulting line until final_address is passed.
121  */
122
123  if( n_bytes == 0 )
124  /* Do nothing if number of bytes to flush is zero */
125  return;
126
127  final_address = (void *)((size_t)d_addr + n_bytes - 1);
128  d_addr = (void *)((size_t)d_addr & ~(CPU_DATA_CACHE_ALIGNMENT - 1));
129  while( d_addr <= final_address ) {
130  _CPU_cache_flush_1_data_line( d_addr );
131  d_addr = (void *)((size_t)d_addr + CPU_DATA_CACHE_ALIGNMENT);
132  }
133 #endif
134 #endif
135 }
136
137 /*
138  * This function is responsible for performing a data cache invalidate.
139  * It must determine how many cache lines need to be invalidated and then
140  * perform the invalidations.
141  */
142 void
143 rtems_cache_invalidate_multiple_data_lines( const void * d_addr, size_t n_bytes )
144 {
145 #if defined(CPU_DATA_CACHE_ALIGNMENT)
146 #if defined(CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS)
147  _CPU_cache_invalidate_data_range( d_addr, n_bytes );
148 #else
149  const void * final_address;
150
151  /*
152  * Set d_addr to the beginning of the cache line; final_address indicates
153  * the last address_t which needs to be invalidated. Increment d_addr and
154  * invalidate the resulting line until final_address is passed.
155  */
156
157  if( n_bytes == 0 )
158  /* Do nothing if number of bytes to invalidate is zero */
159  return;
160
161  final_address = (void *)((size_t)d_addr + n_bytes - 1);
162  d_addr = (void *)((size_t)d_addr & ~(CPU_DATA_CACHE_ALIGNMENT - 1));
163  while( final_address >= d_addr ) {
164  _CPU_cache_invalidate_1_data_line( d_addr );
165  d_addr = (void *)((size_t)d_addr + CPU_DATA_CACHE_ALIGNMENT);
166  }
167 #endif
168 #endif
169 }
170
171 /*
172  * This function is responsible for performing a data cache flush.
173  * It flushes the entire cache.
174  */
175 void
177 {
178 #if defined(CPU_DATA_CACHE_ALIGNMENT)
179  /*
180  * Call the CPU-specific routine
181  */
182  _CPU_cache_flush_entire_data();
183 #endif
184 }
185
186 /*
187  * This function is responsible for performing a data cache
188  * invalidate. It invalidates the entire cache.
189  */
190 void
192 {
193 #if defined(CPU_DATA_CACHE_ALIGNMENT)
194  /*
195  * Call the CPU-specific routine
196  */
197
198  _CPU_cache_invalidate_entire_data();
199 #endif
200 }
201
202 /*
203  * This function returns the data cache granularity.
204  */
205 size_t
207 {
208 #if defined(CPU_DATA_CACHE_ALIGNMENT)
210 #else
211  return 0;
212 #endif
213 }
214
215 size_t
217 {
218 #if defined(CPU_CACHE_SUPPORT_PROVIDES_CACHE_SIZE_FUNCTIONS)
219  return _CPU_cache_get_data_cache_size( level );
220 #else
221  return 0;
222 #endif
223 }
224
225 /*
226  * This function freezes the data cache; cache lines
227  * are not replaced.
228  */
229 void
231 {
232 #if defined(CPU_DATA_CACHE_ALIGNMENT)
233  _CPU_cache_freeze_data();
234 #endif
235 }
236
238 {
239 #if defined(CPU_DATA_CACHE_ALIGNMENT)
240  _CPU_cache_unfreeze_data();
241 #endif
242 }
243
244 void
246 {
247 #if defined(CPU_DATA_CACHE_ALIGNMENT)
248  _CPU_cache_enable_data();
249 #endif
250 }
251
252 #if !defined(CPU_CACHE_SUPPORT_PROVIDES_DISABLE_DATA)
253 void
255 {
256 #if defined(CPU_DATA_CACHE_ALIGNMENT)
257  _CPU_cache_disable_data();
258 #endif
259 }
260 #endif
261
262 /*
263  * THESE FUNCTIONS ONLY HAVE BODIES IF WE HAVE AN INSTRUCTION CACHE
264  */
265
266 #if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT) \
267  && defined(RTEMS_SMP) \
268  && defined(CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING)
269
270 typedef struct {
271  const void *addr;
272  size_t size;
273 } smp_cache_area;
274
275 static void smp_cache_inst_inv(void *arg)
276 {
277  smp_cache_area *area = arg;
278
279  _CPU_cache_invalidate_instruction_range(area->addr, area->size);
280 }
281
282 static void smp_cache_inst_inv_all(void *arg)
283 {
284  _CPU_cache_invalidate_entire_instruction();
285 }
286
287 static void smp_cache_broadcast( SMP_Action_handler handler, void *arg )
288 {
289  uint32_t isr_level;
290  Per_CPU_Control *cpu_self;
291
292  isr_level = _ISR_Get_level();
293
294  if ( isr_level == 0 ) {
295  cpu_self = _Thread_Dispatch_disable();
296  } else {
297  cpu_self = _Per_CPU_Get();
298  }
299
300  _SMP_Broadcast_action( handler, arg );
301
302  if ( isr_level == 0 ) {
303  _Thread_Dispatch_enable( cpu_self );
304  }
305 }
306
307 #endif
308
309 /*
310  * This function is responsible for performing an instruction cache
311  * invalidate. It must determine how many cache lines need to be invalidated
312  * and then perform the invalidations.
313  */
314 #if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT) \
315  && !defined(CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS)
316 static void
317 _CPU_cache_invalidate_instruction_range(
318  const void * i_addr,
319  size_t n_bytes
320 )
321 {
322  const void * final_address;
323
324  /*
325  * Set i_addr to the beginning of the cache line; final_address indicates
326  * the last address_t which needs to be invalidated. Increment i_addr and
327  * invalidate the resulting line until final_address is passed.
328  */
329
330  if( n_bytes == 0 )
331  /* Do nothing if number of bytes to invalidate is zero */
332  return;
333
334  final_address = (void *)((size_t)i_addr + n_bytes - 1);
335  i_addr = (void *)((size_t)i_addr & ~(CPU_INSTRUCTION_CACHE_ALIGNMENT - 1));
336  while( final_address >= i_addr ) {
337  _CPU_cache_invalidate_1_instruction_line( i_addr );
338  i_addr = (void *)((size_t)i_addr + CPU_INSTRUCTION_CACHE_ALIGNMENT);
339  }
340 }
341 #endif
342
343 void
345  const void * i_addr,
346  size_t n_bytes
347 )
348 {
349 #if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
350 #if defined(RTEMS_SMP) && defined(CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING)
351  smp_cache_area area = { i_addr, n_bytes };
352
353  smp_cache_broadcast( smp_cache_inst_inv, &area );
354 #else
355  _CPU_cache_invalidate_instruction_range( i_addr, n_bytes );
356 #endif
357 #endif
358 }
359
360 /*
361  * This function is responsible for performing an instruction cache
362  * invalidate. It invalidates the entire cache.
363  */
364 void
366 {
367 #if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
368 #if defined(RTEMS_SMP) && defined(CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING)
369  smp_cache_broadcast( smp_cache_inst_inv_all, NULL );
370 #else
371  _CPU_cache_invalidate_entire_instruction();
372 #endif
373 #endif
374 }
375
376 /*
377  * This function returns the instruction cache granularity.
378  */
379 size_t
381 {
382 #if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
383  return CPU_INSTRUCTION_CACHE_ALIGNMENT;
384 #else
385  return 0;
386 #endif
387 }
388
389 size_t
391 {
392 #if defined(CPU_CACHE_SUPPORT_PROVIDES_CACHE_SIZE_FUNCTIONS)
393  return _CPU_cache_get_instruction_cache_size( level );
394 #else
395  return 0;
396 #endif
397 }
398
399 /*
400  * This function freezes the instruction cache; cache lines
401  * are not replaced.
402  */
403 void
405 {
406 #if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
407  _CPU_cache_freeze_instruction();
408 #endif
409 }
410
412 {
413 #if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
414  _CPU_cache_unfreeze_instruction();
415 #endif
416 }
417
418 void
420 {
421 #if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
422  _CPU_cache_enable_instruction();
423 #endif
424 }
425
426 void
428 {
429 #if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
430  _CPU_cache_disable_instruction();
431 #endif
432 }
433
434 /* Returns the maximal cache line size of all cache kinds in bytes. */
436 {
437 #if defined(CPU_MAXIMAL_CACHE_ALIGNMENT)
438  return CPU_MAXIMAL_CACHE_ALIGNMENT;
439 #endif
440  size_t max_line_size = 0;
441 #if defined(CPU_DATA_CACHE_ALIGNMENT)
442  {
443  size_t data_line_size = CPU_DATA_CACHE_ALIGNMENT;
444  if ( max_line_size < data_line_size )
445  max_line_size = data_line_size;
446  }
447 #endif
448 #if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
449  {
450  size_t instruction_line_size = CPU_INSTRUCTION_CACHE_ALIGNMENT;
451  if ( max_line_size < instruction_line_size )
452  max_line_size = instruction_line_size;
453  }
454 #endif
455  return max_line_size;
456 }
457
458 /*
459  * Purpose is to synchronize caches after code has been loaded
460  * or self modified. Actual implementation is simple only
461  * but it can and should be repaced by optimized version
462  * which does not need flush and invalidate all cache levels
463  * when code is changed.
464  */
466  const void *code_addr,
467  size_t n_bytes
468 )
469 {
470 #if defined(CPU_CACHE_SUPPORT_PROVIDES_INSTRUCTION_SYNC_FUNCTION)
471  _CPU_cache_instruction_sync_after_code_change( code_addr, n_bytes );
472 #else
473  rtems_cache_flush_multiple_data_lines( code_addr, n_bytes );
475 #endif
476 }
void rtems_cache_enable_instruction(void)
Definition: cacheimpl.h:419
void rtems_cache_instruction_sync_after_code_change(const void *code_addr, size_t n_bytes)
Ensure necessary synchronization required after code changes.
Definition: cacheimpl.h:465
void rtems_cache_invalidate_entire_data(void)
Definition: cacheimpl.h:191
void rtems_cache_disable_instruction(void)
Definition: cacheimpl.h:427
void rtems_cache_freeze_data(void)
Definition: cacheimpl.h:230
Constants and Structures Related with Thread Dispatch.
void rtems_cache_enable_data(void)
Definition: cacheimpl.h:245
void rtems_cache_invalidate_multiple_instruction_lines(const void *i_addr, size_t n_bytes)
Invalidates multiple instruction cache lines.
Definition: cacheimpl.h:344
void rtems_cache_flush_multiple_data_lines(const void *d_addr, size_t n_bytes)
Flushes multiple data cache lines.
Definition: cacheimpl.h:109
#define _ISR_Get_level()
Return current interrupt level.
Definition: isrlevel.h:128
Per CPU Core Structure.
Definition: percpu.h:347
Cache definitions and functions.
Definition: cache-l2c-310.c:65
void rtems_cache_invalidate_multiple_data_lines(const void *d_addr, size_t n_bytes)
Invalidates multiple data cache lines.
Definition: cacheimpl.h:143
void rtems_cache_disable_data(void)
Definition: cacheimpl.h:254
void _Thread_Dispatch_enable(Per_CPU_Control *cpu_self)
Enables thread dispatching.
Definition: threaddispatch.c:362
size_t rtems_cache_get_data_cache_size(uint32_t level)
Returns the data cache size in bytes.
Definition: cacheimpl.h:216
size_t rtems_cache_get_data_line_size(void)
Returns the data cache line size in bytes.
Definition: cacheimpl.h:206
void rtems_cache_unfreeze_instruction(void)
Definition: cacheimpl.h:411
size_t rtems_cache_get_maximal_line_size(void)
Definition: cacheimpl.h:435
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Thread_Dispatch_disable(void)
Disables thread dispatching.
Definition: threaddispatch.h:191
void rtems_cache_freeze_instruction(void)
Definition: cacheimpl.h:404
void rtems_cache_unfreeze_data(void)
Definition: cacheimpl.h:237
size_t rtems_cache_get_instruction_line_size(void)
Returns the instruction cache line size in bytes.
Definition: cacheimpl.h:380
void rtems_cache_invalidate_entire_instruction(void)
Invalidates the entire instruction cache.
Definition: cacheimpl.h:365
void rtems_cache_flush_entire_data(void)
Flushes the entire data cache.
Definition: cacheimpl.h:176
unsigned size
Definition: tte.h:74
size_t rtems_cache_get_instruction_cache_size(uint32_t level)
Returns the instruction cache size in bytes.
Definition: cacheimpl.h:390
SuperCore SMP Implementation.
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
