RTEMS  5.1
Macros | Typedefs | Functions | Variables
bsp.h File Reference
Global BSP definitions. More...
#include <bspopts.h>
#include <bsp/default-initial-extension.h>
#include <erc32.h>
#include <rtems/irq-extension.h>
#define BSP_IDLE_TASK_BODY   bsp_idle_thread
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "sonic1"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_erc32_sonic_driver_attach
typedef void(* bsp_shared_isr) (void *arg)
void * bsp_idle_thread (uintptr_t ignored)
 Optimized idle task. More...
int rtems_erc32_sonic_driver_attach (struct rtems_bsdnet_ifconfig *config)
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler. More...
void BSP_fatal_exit (uint32_t error)
void bsp_spurious_initialize (void)
void BSP_shared_interrupt_init (void)
void bsp_isr_handler (rtems_vector_number vector)
void BSP_shared_interrupt_clear (int irq)
void BSP_shared_interrupt_unmask (int irq)
void BSP_shared_interrupt_mask (int irq)
void rtems_bsp_delay (int usecs)
void console_outbyte_polled (int port, unsigned char ch)
int console_inbyte_nonblocking (int port)
int RAM_START
int RAM_END
int RAM_SIZE
int PROM_START
int PROM_END
int PROM_SIZE
int CLOCK_SPEED
int end
