RTEMS
5.1
bsps
arm
lpc24xx
include
bsp.h
1
9
10
* Copyright (c) 2008-2014 embedded brains GmbH. All rights reserved.
11
12
* embedded brains GmbH
13
* Dornierstr. 4
14
* 82178 Puchheim
15
* Germany
16
* <rtems@embedded-brains.de>
17
18
* The license and distribution terms for this file may be
19
* found in the file LICENSE in this distribution or at
20
* http://www.rtems.org/license/LICENSE.
21
22
23
#ifndef LIBBSP_ARM_LPC24XX_BSP_H
24
#define LIBBSP_ARM_LPC24XX_BSP_H
25
36
#include <bspopts.h>
37
38
#define BSP_FEATURE_IRQ_EXTENSION
39
40
#define LPC24XX_PCLK (LPC24XX_CCLK / LPC24XX_PCLKDIV)
41
42
#define LPC24XX_EMCCLK (LPC24XX_CCLK / LPC24XX_EMCCLKDIV)
43
44
#define LPC24XX_MPU_REGION_COUNT 8
45
46
#define BSP_ARMV7M_IRQ_PRIORITY_DEFAULT (29 << 3)
47
48
#define BSP_ARMV7M_SYSTICK_PRIORITY (30 << 3)
49
50
#define BSP_ARMV7M_SYSTICK_FREQUENCY LPC24XX_CCLK
51
52
#ifndef ASM
53
54
rtems.h
55
56
bsp/default-initial-extension.h
57
58
#ifdef __cplusplus
59
extern
"C"
60
#endif
/* __cplusplus */
61
62
struct
rtems_bsdnet_ifconfig;
63
64
struct
rtems_termios_device_context
65
69
int
lpc_eth_attach_detach
70
struct
rtems_bsdnet_ifconfig *
config
71
int
attaching
72
73
77
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH lpc_eth_attach_detach
78
82
#define RTEMS_BSP_NETWORK_DRIVER_NAME "eth0"
83
104
void
bsp_idle_thread
(uintptr_t ignored);
105
106
#ifdef ARM_MULTILIB_ARCH_V4
107
#define BSP_CONSOLE_UART_BASE 0xe000c000
108
#else
109
#define BSP_CONSOLE_UART_BASE 0x4000c000
110
#endif
111
112
void
bsp_restart
void
*addr);
113
114
bool
lpc24xx_uart_probe_1(
struct
context
115
116
bool
lpc24xx_uart_probe_2(
struct
context
117
118
bool
lpc24xx_uart_probe_3(
struct
context
119
120
#ifdef __cplusplus
121
122
#endif
/* __cplusplus */
123
124
#endif
/* ASM */
125
128
#endif
/* LIBBSP_ARM_LPC24XX_BSP_H */
config_s
Definition:
deflate.c:115
Termios device context.
Definition:
termiostypes.h:75
int lpc_eth_attach_detach(struct rtems_bsdnet_ifconfig *config, int attaching)
Network driver attach and detach function.
Definition:
lpc-ethernet.c:1827
DEFAULT_INITIAL_EXTENSION Support.
rtems.h
bsp_idle_thread
void * bsp_idle_thread(uintptr_t ignored)
Optimized idle task.
Definition:
bspidle.c:26
context
unsigned context
Definition:
tlb.h:108
bsp_restart
void bsp_restart(const void *addr)
Restarts the bsp with "addr" address.
Definition:
restart.c:25
