22 #ifndef LIBBSP_ARM_LPC176X_IO_H 23 #define LIBBSP_ARM_LPC176X_IO_H bool lpc176x_module_is_enabled(lpc176x_module module)
Checks if the current module is enabled or not.
Definition: io.c:332
void lpc176x_pin_select(uint32_t pin, lpc176x_pin_function function)
Sets pin to the selected function.
Definition: io.c:60
Input/output module definitions.
Information for the Assert Handler.
rtems_status_code
Classic API Status.
Definition: status.h:43
void lpc176x_pin_set_mode(const uint32_t pin, const lpc176x_pin_mode mode)
Sets pin to the selected mode.
Definition: io.c:74
Defines the functions according to the pin.
Definition: io-defs.h:68
rtems_status_code lpc176x_module_disable(lpc176x_module module)
Checks if the current module is turned off and disables a module.
Definition: io.c:325
lpc176x_module
lpc176x module representation.
Definition: common-types.h:44
lpc176x_module_clock
Defines all the clock modules.
Definition: common-types.h:78
rtems_status_code lpc176x_module_enable(lpc176x_module module, lpc176x_module_clock clock)
Enables the module power and clock.
Definition: io.c:317
lpc176x_pin_mode
Defines the pin modes.
Definition: io-defs.h:81
