RTEMS  5.1
bootldr.h
1 /*
2  * bootldr.h -- Include file for bootloader.
3  */
4
5 /*
6  * Copyright (C) 1998, 1999 Gabriel Paubert, paubert@iram.es
7  *
8  * Modified to compile in RTEMS development environment
9  * by Eric Valette
10  *
11  * Copyright (C) 1999 Eric Valette. valette@crf.canon.fr
12  *
13  * The license and distribution terms for this file may be
14  * found in the file LICENSE in this distribution or at
15  * http://www.rtems.org/license/LICENSE.
16  */
17
18 #ifndef _PPC_BOOTLDR_H
19 #define _PPC_BOOTLDR_H
20
21 #ifndef ASM
22 #include <stdint.h>
23 #include <bsp/residual.h>
24 #include <bsp/consoleIo.h>
25 #include "pci.h"
26
27 #define abs __builtin_abs
28
29 #define PTE_REFD 0x100
30 #define PTE_CHNG (0x80|PTE_REFD) /* Modified implies referenced */
31 #define PTE_WTHR 0x040
32 #define PTE_CINH 0x020
33 #define PTE_COHER 0x010
34 #define PTE_GUAR 0x008
35 #define PTE_RO 0x003
36 #define PTE_RW 0x002
37
38 #define PTE_RAM (PTE_CHNG|PTE_COHER|PTE_RW)
39 #define PTE_ROM (PTE_REFD|PTE_RO)
40 #define PTE_IO (PTE_CHNG|PTE_CINH|PTE_GUAR|PTE_RW)
41
42 typedef struct {}opaque;
43
44 /* The context passed during MMU interrupts. */
45 typedef struct _ctxt {
46  u_long lr, ctr;
47  u_int cr, xer;
48  u_long nip, msr;
49  u_long regs[32];
50 } ctxt;
51
52 /* The main structure which is pointed to permanently by r13. Things
53  * are not separated very well between parts because it would cause
54  * too much code bloat for such a simple program like the bootloader.
55  * The code is designed to be compiled with the -m relocatable option and
56  * tries to minimize the number of relocations/fixups and the number of
57  * functions who have to access the .got2 sections (this increases the
58  * size of the prologue in every function).
59  */
60 typedef struct _boot_data {
61  RESIDUAL *residual;
62  void *load_address;
63  void *of_entry;
64  void *r6, *r7, *r8, *r9, *r10;
65  u_long cache_lsize;
66  void *image; /* Where to copy ourselves */
67  void *stack;
68  void *mover; /* where to copy codemove to avoid overlays */
69  u_long o_msr, o_hid0, o_r31;
70  opaque * mm_private;
71  const struct pci_bootloader_config_access_functions* pci_functions;
72  opaque * pci_private;
73  struct pci_dev * pci_devices;
74  opaque * v86_private;
75  char cmd_line[256];
76 } boot_data;
77
78 register boot_data *bd __asm__("r13");
79
80 static inline int
81 pcibios_read_config_byte(u_char bus, u_char dev_fn,
82  u_char where, uint8_t *val) {
83  return bd->pci_functions->read_config_byte(bus, dev_fn, where, val);
84 }
85
86 static inline int
87 pcibios_read_config_word(u_char bus, u_char dev_fn,
88  u_char where, uint16_t *val) {
89  return bd->pci_functions->read_config_word(bus, dev_fn, where, val);
90 }
91
92 static inline int
93 pcibios_read_config_dword(u_char bus, u_char dev_fn,
94  u_char where, uint32_t *val) {
95  return bd->pci_functions->read_config_dword(bus, dev_fn, where, val);
96 }
97
98 static inline int
99 pcibios_write_config_byte(u_char bus, u_char dev_fn,
100  u_char where, uint8_t val) {
101  return bd->pci_functions->write_config_byte(bus, dev_fn, where, val);
102 }
103
104 static inline int
105 pcibios_write_config_word(u_char bus, u_char dev_fn,
106  u_char where, uint16_t val) {
107  return bd->pci_functions->write_config_word(bus, dev_fn, where, val);
108 }
109
110 static inline int
111 pcibios_write_config_dword(u_char bus, u_char dev_fn,
112  u_char where, uint32_t val) {
113  return bd->pci_functions->write_config_dword(bus, dev_fn, where, val);
114 }
115
116 static inline int
117 pci_bootloader_read_config_byte(struct pci_dev *dev, u_char where, uint8_t *val) {
118  return bd->pci_functions->read_config_byte(dev->bus->number,
119  dev->devfn,
120  where, val);
121 }
122
123 static inline int
124 pci_bootloader_read_config_word(struct pci_dev *dev, u_char where, uint16_t *val) {
125  return bd->pci_functions->read_config_word(dev->bus->number,
126  dev->devfn,
127  where, val);
128 }
129
130 static inline int
131 pci_bootloader_read_config_dword(struct pci_dev *dev, u_char where, uint32_t *val) {
132  return bd->pci_functions->read_config_dword(dev->bus->number,
133  dev->devfn,
134  where, val);
135 }
136
137 static inline int
138 pci_bootloader_write_config_byte(struct pci_dev *dev, u_char where, uint8_t val) {
139  return bd->pci_functions->write_config_byte(dev->bus->number,
140  dev->devfn,
141  where, val);
142 }
143
144 static inline int
145 pci_bootloader_write_config_word(struct pci_dev *dev, u_char where, uint16_t val) {
146  return bd->pci_functions->write_config_word(dev->bus->number,
147  dev->devfn,
148  where, val);
149 }
150
151 static inline int
152 pci_bootloader_write_config_dword(struct pci_dev *dev, u_char where, uint32_t val) {
153  return bd->pci_functions->write_config_dword(dev->bus->number,
154  dev->devfn,
155  where, val);
156 }
157
158 /* codemove is like memmove, but it also gets the cache line size
159  * as 4th parameter to synchronize them. If this last parameter is
160  * zero, it performs more or less like memmove. No copy is performed if
161  * source and destination addresses are equal. However the caches
162  * are synchronized. Note that the size is always rounded up to the
163  * next mutiple of 4.
164  */
165 extern void * codemove(void *, const void *, size_t, unsigned long);
166
167 /* The physical memory allocator allows to align memory by
168  * powers of 2 given by the lower order bits of flags.
169  * By default it allocates from higher addresses towrds lower ones,
170  * setting PA_LOW reverses this behaviour.
171  */
172
173 #define palloc(size) __palloc(size,0)
174
175 #define isa_io_base (bd->io_base)
176
177 void * __palloc(u_long, int);
178 void pfree(void *);
179
180 #define PA_LOW 0x100
181 #define PA_PERM 0x200 /* Not freeable by pfree */
182 #define PA_SUBALLOC 0x400 /* Allocate for suballocation by salloc */
183 #define PA_ALIGN_MASK 0x1f
184
185 void * valloc(u_long size);
186 void vfree(void *);
187
188 int vmap(void *, u_long, u_long);
189 void vunmap(void *);
190
191 void * salloc(u_long size);
192 void sfree(void *);
193
194 void pci_init(void);
195
196 void * memset(void *p, int c, size_t n);
197
198 void gunzip(void *, int, unsigned char *, int *);
199
200 void print_all_maps(const char *);
201 void print_hash_table(void);
202 void MMUon(void);
203 void MMUoff(void);
204 void hang(const char *, u_long, ctxt *) __attribute__((noreturn));
205
206 int init_v86(void);
207 void cleanup_v86_mess(void);
208 void em86_main(struct pci_dev *);
209 int find_max_mem(struct pci_dev *);
210
211 /*
212  * Prototypes for calls from assembly and across files.
213  */
214 typedef struct _x86 x86;
215
216 int em86_trap(x86 *p);
217 void decompress_kernel(int kernel_size, void * zimage_start, int len,
218  void * initrd_start, int initrd_len );
219 void boot_udelay(uint32_t _microseconds);
220 void setup_hw(void);
221 void _handler(int vec, ctxt *p);
222 int early_setup(u_long image_size);
223 void mm_init(u_long image_size);
224 #endif
225
226 #ifdef ASM
227 /* These definitions simplify the ugly declarations necessary for
228  * GOT definitions.
229  */
230
231 #define GOT_ENTRY(NAME) .L_ ## NAME = . - .LCTOC1 ; .long NAME
232 #define GOT(NAME) .L_ ## NAME (r30)
233
234 #define START_GOT \
235  .section ".got2","aw"; \
236 .LCTOC1 = .+ 0x8000
237
238 #define END_GOT \
239  .text
240
241 #define GET_GOT \
242  bl 1f; \
243  .text 2; \
244 0: .long .LCTOC1-1f; \
245  .text ; \
246 1: mflr r30; \
247  lwz r0,0b-1b(r30); \
248  add r30,r0,r30
249
250 #define bd r13
251 #define cache_lsize 32 /* Offset into bd area */
252 #define image 36
253 #define stack 40
254 #define mover 44
255 #define o_msr 48
256 #define o_hid0 52
257 #define o_r31 56
258 /* Stack offsets for saved registers on exceptions */
259 #define save_lr 8(r1)
260 #define save_ctr 12(r1)
261 #define save_cr 16(r1)
262 #define save_xer 20(r1)
263 #define save_nip 24(r1)
264 #define save_msr 28(r1)
265 #define save_r(n) 32+4*n(r1)
266 #endif
267
268 #endif
Definition: em86.c:52
unsigned p
Definition: tte.h:90
Definition: bootldr.h:45
Definition: mongoose.c:437
Definition: bootldr.h:60
typedef __attribute__
Disable IRQ Interrupts.
Definition: cmsis_gcc.h:69
Definition: bootldr.h:42
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
Definition: pci.h:41
Definition: residual.h:294
unsigned size
Definition: tte.h:74
