RTEMS  5.1
bat.h
1 /*
2  * bat.h
3  *
4  * This file contains declaration of C function to
5  * Instantiate 60x/7xx ppc Block Address Translation (BAT) registers.
6  * More detailed information can be found on motorola
7  * site and more precisely in the following book :
8  *
9  * MPC750
10  * Risc Microporcessor User's Manual
11  * Motorola REF : MPC750UM/AD 8/97
12  *
13  * Copyright (C) 1999 Eric Valette (valette@crf.canon.fr)
14  * Canon Centre Recherche France.
15  *
16  * The license and distribution terms for this file may be
17  * found in the file LICENSE in this distribution or at
18  * http://www.rtems.org/license/LICENSE.
19  */
20
21 #ifndef _LIBCPU_BAT_H
22 #define _LIBCPU_BAT_H
23
24 #include <libcpu/mmu.h>
25 #include <libcpu/pgtable.h>
26
27 #define IO_PAGE (_PAGE_NO_CACHE | _PAGE_GUARDED | _PAGE_RW)
28
29 #ifndef ASM
30 /* Take no risks -- the essential parts of this routine run with
31  * interrupts disabled!
32  *
33  * The routine does basic parameter checks:
34  * - Index must be 0..3 (0..7 on 7455, 7457).
35  * If an index > 3 is requested the 745x is
36  * programmed to enable the higher BATs.
37  * - Size must be a power of two and <= 1<<28
38  * (<=1<<31 on 7455, 7457. Also, on these processors
39  * the special value 0xffffffff is allowed which stands
40  * for 1<<32).
41  * If a size > 1<<28 is requested, the 745x is
42  * programmed to enable the larger block sizes.
43  * - Bat ranges must not overlap.
44  * - Physical & virtual addresses must be aligned
45  * to the size.
46  *
47  * RETURNS: zero on success, nonzero on failure.
48  */
49 extern int setdbat(int bat_index, unsigned long virt, unsigned long phys,
50  unsigned int size, int flags);
51
52 /* Same as setdbat but sets IBAT */
53 extern int setibat(int bat_index, unsigned long virt, unsigned long phys,
54  unsigned int size, int flags);
55
56 /* read DBAT # 'idx' into *pu / *pl. NULL pointers may be passed.
57  * If pu and pl are NULL, the bat contents are dumped to the console (printk).
58  *
59  * RETURNS: upper BAT contents or (-1) if index is invalid
60  */
61 extern int getdbat(int bat_index, unsigned long *pu, unsigned long *pl);
62
63 /* Same as getdbat but reads IBAT */
64 extern int getibat(int bat_index, unsigned long *pu, unsigned long *pl);
65
66 /* Do not use the asm-routines; they are obsolete; use setdbat() instead */
67 extern void asm_setdbat0(unsigned int uperPart, unsigned int lowerPart);
68 extern void asm_setdbat1(unsigned int uperPart, unsigned int lowerPart);
69 extern void asm_setdbat2(unsigned int uperPart, unsigned int lowerPart);
70 extern void asm_setdbat3(unsigned int uperPart, unsigned int lowerPart);
71 #else
72
73 /* Initialize all bats (upper and lower) to zero. This routine should *only*
74  * be called during early BSP initialization when no C-ABI is available
75  * yet.
76  * This routine clobbers r3 and r4.
77  * NOTE: on 7450 CPUs all 8 dbat/ibat units are cleared. On 601 CPUs only
78  * 4 ibats.
79  */
80  .globl CPU_clear_bats_early
81  .type CPU_clear_bats_early,@function
82
83 #endif
84
85 #endif /* _LIBCPU_BAT_H */
unsigned size
Definition: tte.h:74
