RTEMS  5.1
at91rm9200_pmc.h
1
9 /*
10  * AT91RM9200 Power Management and Clock definitions
11  *
12  * Copyright (c) 2002 by Cogent Computer Systems
13  * Written by Mike Kelly <mike@cogcomp.com>
14  *
15  * The license and distribution terms for this file may be
16  * found in the file LICENSE in this distribution or at
17  * http://www.rtems.org/license/LICENSE.
18  */
19 #ifndef __AT91RM9200_PMC_H__
20 #define __AT91RM9200_PMC_H__
21
22 #include <bits.h>
23
24 /***********************************************************************
25  * Power Management and Clock Control Register Offsets
26  ***********************************************************************/
27 int at91rm9200_get_mainclk(void);
28 int at91rm9200_get_slck(void);
29 int at91rm9200_get_mck(void);
30
31
32 #define PMC_SCER 0x00 /* System Clock Enable Register */
33 #define PMC_SCDR 0x04 /* System Clock Disable Register */
34 #define PMC_SCSR 0x08 /* System Clock Status Register */
35 #define PMC_PCER 0x10 /* Peripheral Clock Enable Register */
36 #define PMC_PCDR 0x14 /* Peripheral Clock Disable Register */
37 #define PMC_PCSR 0x18 /* Peripheral Clock Status Register */
38 #define PMC_MOR 0x20 /* Main Oscillator Register */
39 #define PMC_MCFR 0x24 /* Main Clock Frequency Register */
40 #define PMC_PLLAR 0x28 /* PLL A Register */
41 #define PMC_PLLBR 0x2C /* PLL B Register */
42 #define PMC_MCKR 0x30 /* Master Clock Register */
43 #define PMC_PCKR0 0x40 /* Programmable Clock Register 0 */
44 #define PMC_PCKR1 0x44 /* Programmable Clock Register 1 */
45 #define PMC_PCKR2 0x48 /* Programmable Clock Register 2 */
46 #define PMC_PCKR3 0x4C /* Programmable Clock Register 3 */
47 #define PMC_PCKR4 0x50 /* Programmable Clock Register 4 */
48 #define PMC_PCKR5 0x54 /* Programmable Clock Register 5 */
49 #define PMC_PCKR6 0x58 /* Programmable Clock Register 6 */
50 #define PMC_PCKR7 0x5C /* Programmable Clock Register 7 */
51 #define PMC_IER 0x60 /* Interrupt Enable Register */
52 #define PMC_IDR 0x64 /* Interrupt Disable Register */
53 #define PMC_SR 0x68 /* Status Register */
54 #define PMC_IMR 0x6C /* Interrupt Mask Register */
55
56 /* Bit Defines */
57
58 /* PMC_SCDR - System Clock Disable Register */
59 /* PMC_SCSR - System Clock Status Register */
60 /* PMC_SCER - System Clock Enable Register */
61 #define PMC_SCR_PCK7 BIT15
62 #define PMC_SCR_PCK6 BIT14
63 #define PMC_SCR_PCK5 BIT13
64 #define PMC_SCR_PCK4 BIT12
65 #define PMC_SCR_PCK3 BIT11
66 #define PMC_SCR_PCK2 BIT10
67 #define PMC_SCR_PCK1 BIT9
68 #define PMC_SCR_PCK0 BIT8
69 #define PMC_SCR_UHP BIT4
70 #define PMC_SCR_MCKUDP BIT2
71 #define PMC_SCR_UDP BIT1
72 #define PMC_SCR_PCK BIT0
73
74 /* PMC_PCER - Peripheral Clock Enable Register */
75 /* PMC_PCDR - Peripheral Clock Disable Register */
76 /* PMC_PCSR - Peripheral Clock Status Register */
77 #define PMC_PCR_PID_EMAC BIT24 /* Ethernet Peripheral Clock */
78 #define PMC_PCR_PID_UHP BIT23 /* USB Host Ports Peripheral Clock */
79 #define PMC_PCR_PID_TC5 BIT22 /* Timer/Counter 5 Peripheral Clock */
80 #define PMC_PCR_PID_TC4 BIT21 /* Timer/Counter 4 Peripheral Clock */
81 #define PMC_PCR_PID_TC3 BIT20 /* Timer/Counter 3 Peripheral Clock */
82 #define PMC_PCR_PID_TC2 BIT19 /* Timer/Counter 2 Peripheral Clock */
83 #define PMC_PCR_PID_TC1 BIT18 /* Timer/Counter 1 Peripheral Clock */
84 #define PMC_PCR_PID_TC0 BIT17 /* Timer/Counter 0 Peripheral Clock */
85 #define PMC_PCR_PID_SSC2 BIT16 /* Synchronous Serial 2 Peripheral Clock */
86 #define PMC_PCR_PID_SSC1 BIT15 /* Synchronous Serial 1 Peripheral Clock */
87 #define PMC_PCR_PID_SSC0 BIT14 /* Synchronous Serial 0 Peripheral Clock */
88 #define PMC_PCR_PID_SPI BIT13 /* Serial Peripheral Interface Peripheral Clock */
89 #define PMC_PCR_PID_TWI BIT12 /* Two-Wire Interface Peripheral Clock */
90 #define PMC_PCR_PID_UDP BIT11 /* USB Device Port Peripheral Clock */
91 #define PMC_PCR_PID_MCI BIT10 /* MMC/SD Card Peripheral Clock */
92 #define PMC_PCR_PID_US3 BIT9 /* USART 3 Peripheral Clock */
93 #define PMC_PCR_PID_US2 BIT8 /* USART 2 Peripheral Clock */
94 #define PMC_PCR_PID_US1 BIT7 /* USART 1 Peripheral Clock */
95 #define PMC_PCR_PID_US0 BIT6 /* USART 0 Peripheral Clock */
96 #define PMC_PCR_PID_PIOD BIT5 /* Parallel I/O D Peripheral Clock */
97 #define PMC_PCR_PID_PIOC BIT4 /* Parallel I/O C Peripheral Clock */
98 #define PMC_PCR_PID_PIOB BIT3 /* Parallel I/O B Peripheral Clock */
99 #define PMC_PCR_PID_PIOA BIT2 /* Parallel I/O A Peripheral Clock */
100
101 /* PMC_MOR - Main Oscillator Register */
102 #define PMC_MOR_MOSCEN BIT0
103
104 /* PMC_MCFR - Main Clock Frequency Register */
105 #define PMC_MCFR_MAINRDY BIT16
106
107 /* PMC_PLLAR - PLL A Register */
108 #define PMC_PLLAR_MUST_SET BIT29 /* This bit must be set according to the docs */
109 #define PMC_PLLAR_MUL(_x_) ((_x_ & 0x7ff) << 16) /* Multiplier */
110 #define PMC_PLLAR_MUL_MASK (0x7ff << 16) /* Multiplier mask */
111
112 #define PMC_PLLAR_OUT_80_160 (0 << 14) /* select when PLL frequency is 80-160 Mhz */
113 #define PMC_PLLAR_OUT_150_240 (2 << 14) /* select when PLL frequency is 150-240 Mhz */
114 #define PMC_PLLAR_DIV(_x_) ((_x_ & 0xff) << 0) /* Divider */
115 #define PMC_PLLAR_DIV_MASK (0xff) /* Divider mask */
116
117 /* PMC_PLLBR - PLL B Register */
118 #define PMC_PLLBR_USB_96M BIT28 /* Set when PLL is 96Mhz to divide it by 2 for USB */
119 #define PMC_PLLBR_MUL(_x_) ((_x_ & 0x7ff) << 16) /* Multiplier */
120 #define PMC_PLLBR_MUL_MASK (0x7ff << 16) /* Multiplier mask */
121 #define PMC_PLLBR_OUT_80_160 (0 << 14) /* select when PLL frequency is 80-160 Mhz */
122 #define PMC_PLLBR_OUT_150_240 (2 << 14) /* select when PLL frequency is 150-240 Mhz */
123 #define PMC_PLLBR_DIV(_x_) ((_x_ & 0xff) << 0) /* Divider */
124 #define PMC_PLLBR_DIV_MASK (0xff) /* Divider mask */
125
126 /* PMC_MCKR - Master Clock Register */
127 #define PMC_MCKR_MDIV_MASK (3 << 8) /* for masking out the MDIV field */
128 #define PMC_MCKR_MDIV_1 (0 << 8) /* MCK = Core/1 */
129 #define PMC_MCKR_MDIV_2 (1 << 8) /* MCK = Core/2 */
130 #define PMC_MCKR_MDIV_3 (2 << 8) /* MCK = Core/3 */
131 #define PMC_MCKR_MDIV_4 (3 << 8) /* MCK = Core/4 */
132 #define PMC_MCKR_PRES_MASK (7 << 2) /* for masking out the PRES field */
133 #define PMC_MCKR_PRES_1 (0 << 2) /* Core = CSS/1 */
134 #define PMC_MCKR_PRES_2 (1 << 2) /* Core = CSS/2 */
135 #define PMC_MCKR_PRES_4 (2 << 2) /* Core = CSS/4 */
136 #define PMC_MCKR_PRES_8 (3 << 2) /* Core = CSS/8 */
137 #define PMC_MCKR_PRES_16 (4 << 2) /* Core = CSS/16 */
138 #define PMC_MCKR_PRES_32 (5 << 2) /* Core = CSS/32 */
139 #define PMC_MCKR_PRES_64 (6 << 2) /* Core = CSS/64 */
140 #define PMC_MCKR_CSS_MASK (3 << 0) /* for masking out the CSS field */
141 #define PMC_MCKR_CSS_SLOW (0 << 0) /* Core Source = Slow Clock */
142 #define PMC_MCKR_CSS_MAIN (1 << 0) /* Core Source = Main Oscillator */
143 #define PMC_MCKR_CSS_PLLA (2 << 0) /* Core Source = PLL A */
144 #define PMC_MCKR_CSS_PLLB (3 << 0) /* Core Source = PLL B */
145
146 /* PMC_PCKR0 - 7 - Programmable Clock Register 0 */
147 #define PMC_PCKR_PRES_1 (0 << 2) /* Peripheral Clock = CSS/1 */
148 #define PMC_PCKR_PRES_2 (1 << 2) /* Peripheral Clock = CSS/2 */
149 #define PMC_PCKR_PRES_4 (2 << 2) /* Peripheral Clock = CSS/4 */
150 #define PMC_PCKR_PRES_8 (3 << 2) /* Peripheral Clock = CSS/8 */
151 #define PMC_PCKR_PRES_16 (4 << 2) /* Peripheral Clock = CSS/16 */
152 #define PMC_PCKR_PRES_32 (5 << 2) /* Peripheral Clock = CSS/32 */
153 #define PMC_PCKR_PRES_64 (6 << 2) /* Peripheral Clock = CSS/64 */
154 #define PMC_PCKR_CSS_SLOW (0 << 0) /* Peripheral Clock Source = Slow Clock */
155 #define PMC_PCKR_CSS_MAIN (1 << 0) /* Peripheral Clock Source = Main Oscillator */
156 #define PMC_PCKR_CSS_PLLA (2 << 0) /* Peripheral Clock Source = PLL A */
157 #define PMC_PCKR_CSS_PLLB (3 << 0) /* Peripheral Clock Source = PLL B */
158
159 /* PMC_IER - Interrupt Enable Register */
160 /* PMC_IDR - Interrupt Disable Register */
161 /* PMC_SR - Status Register */
162 /* PMC_IMR - Interrupt Mask Register */
163 #define PMC_INT_PCK7_RDY BIT15
164 #define PMC_INT_PCK6_RDY BIT14
165 #define PMC_INT_PCK5_RDY BIT13
166 #define PMC_INT_PCK4_RDY BIT12
167 #define PMC_INT_PCK3_RDY BIT11
168 #define PMC_INT_PCK2_RDY BIT10
169 #define PMC_INT_PCK1_RDY BIT9
170 #define PMC_INT_PCK0_RDY BIT8
171 #define PMC_INT_MCK_RDY BIT3
172 #define PMC_INT_LOCKB BIT2
173 #define PMC_INT_LCKA BIT1
174 #define PMC_INT_MOSCS BIT0
175
176
177 #endif
Contains Defined Bits.
