RTEMS  5.1
at91rm9200_dbgu.h
1
9 /*
10  * Atmel AT91RM9200_DBGU Register definitions
11  *
12  * Copyright (c) 2003 by Cogent Computer Systems
13  * Written by Mike Kelly <mike@cogcomp.com>
14  *
15  * The license and distribution terms for this file may be
16  * found in the file LICENSE in this distribution or at
17  * http://www.rtems.org/license/LICENSE.
18  */
19 #ifndef __AT91RM9200_DBGU_H__
20 #define __AT91RM9200_DBGU_H__
21
22 #include "bits.h"
23
24 /* Register Offsets */
25 #define DBGU_CR 0x00 /* Control Register */
26 #define DBGU_MR 0x04 /* Mode Register */
27 #define DBGU_IER 0x08 /* Interrupt Enable Register */
28 #define DBGU_IDR 0x0C /* Interrupt Disable Register */
29 #define DBGU_IMR 0x10 /* Interrupt Mask Register */
30 #define DBGU_SR 0x14 /* Channel Status Register */
31 #define DBGU_RHR 0x18 /* Receiver Holding Register */
32 #define DBGU_THR 0x1C /* Transmitter Holding Register */
33 #define DBGU_BRGR 0x20 /* Baud Rate Generator Register */
34 #define DBGU_C1R 0x40 /* Chip ID1 Register */
35 #define DBGU_C2R 0x44 /* Chip ID2 Register */
36 #define DBGU_FNTR 0x48 /* Force NTRST Register */
37
38 /* Bit Defines */
39 /* Control Register, DBGU_CR, Offset 0x00 */
40 #define DBGU_CR_RSTRX BIT2 /* 1 = Reset and disable receiver */
41 #define DBGU_CR_RSTTX BIT3 /* 1 = Reset and disable transmitter */
42 #define DBGU_CR_RXEN BIT4 /* 1 = Receiver enable */
43 #define DBGU_CR_RXDIS BIT5 /* 1 = Receiver disable */
44 #define DBGU_CR_TXEN BIT6 /* 1 = Transmitter enable */
45 #define DBGU_CR_TXDIS BIT7 /* 1 = Transmitter disable */
46 #define DBGU_CR_RSTSTA BIT8 /* 1 = Reset PARE, FRAME and OVRE in DBGU_SR. */
47
48 /* Mode Register. DBGU_MR. Offset 0x04 */
49 #define DBGU_MR_PAR_EVEN (0x0 << 9) /* Even Parity */
50 #define DBGU_MR_PAR_ODD (0x1 << 9) /* Odd Parity */
51 #define DBGU_MR_PAR_SPACE (0x2 << 9) /* Parity forced to 0 (Space) */
52 #define DBGU_MR_PAR_MARK (0x3 << 9) /* Parity forced to 1 (Mark) */
53 #define DBGU_MR_PAR_NONE (0x4 << 9) /* No Parity */
54 #define DBGU_MR_PAR_MDROP (0x6 << 9) /* Multi-drop mode */
55 #define DBGU_MR_CHMODE_NORM (0x0 << 14) /* Normal Mode */
56 #define DBGU_MR_CHMODE_AUTO (0x1 << 14) /* Auto Echo: RXD drives TXD */
57 #define DBGU_MR_CHMODE_LOC (0x2 << 14) /* Local Loopback: TXD drives RXD */
58 #define DBGU_MR_CHMODE_REM (0x3 << 14) /* Remote Loopback: RXD pin connected to TXD pin. */
59
60 /* Interrupt Enable Register, DBGU_IER, Offset 0x08 */
61 /* Interrupt Disable Register, DBGU_IDR, Offset 0x0C */
62 /* Interrupt Mask Register, DBGU_IMR, Offset 0x10 */
63 /* Channel Status Register, DBGU_SR, Offset 0x14 */
64 #define DBGU_INT_RXRDY BIT0 /* RXRDY Interrupt */
65 #define DBGU_INT_TXRDY BIT1 /* TXRDY Interrupt */
66 #define DBGU_INT_ENDRX BIT3 /* End of Receive Transfer Interrupt */
67 #define DBGU_INT_ENDTX BIT4 /* End of Transmit Interrupt */
68 #define DBGU_INT_OVRE BIT5 /* Overrun Interrupt */
69 #define DBGU_INT_FRAME BIT6 /* Framing Error Interrupt */
70 #define DBGU_INT_PARE BIT7 /* Parity Error Interrupt */
71 #define DBGU_INT_TXEMPTY BIT9 /* TXEMPTY Interrupt */
72 #define DBGU_INT_TXBUFE BIT11 /* TXBUFE Interrupt */
73 #define DBGU_INT_RXBUFF BIT12 /* RXBUFF Interrupt */
74 #define DBGU_INT_COMM_TX BIT30 /* COMM_TX Interrupt */
75 #define DBGU_INT_COMM_RX BIT31 /* COMM_RX Interrupt */
76 #define DBGU_INT_ALL 0xC0001AFB /* all assigned bits */
77
78 /* FORCE_NTRST Register, DBGU_FNTR, Offset 0x48 */
79 #define DBGU_FNTR_NTRST BIT0 /* 1 = Force NTRST low in JTAG */
80
81 typedef struct {
82  volatile uint32_t cr;
83  volatile uint32_t mr;
84  volatile uint32_t ier;
85  volatile uint32_t idr;
86  volatile uint32_t imr;
87  volatile uint32_t sr;
88  volatile uint32_t rhr;
89  volatile uint32_t thr;
90  volatile uint32_t brgr;
91  volatile uint32_t _res0[7];
92  volatile uint32_t cidr;
93  volatile uint32_t exid;
94  volatile uint32_t fnr;
96
97 #endif /* __AT91RM9200_DBGU_H__ */
Definition: at91rm9200_dbgu.h:81
Contains Defined Bits.
