#define | DBGU_CR 0x00 /* Control Register */ |
#define | DBGU_MR 0x04 /* Mode Register */ |
#define | DBGU_IER 0x08 /* Interrupt Enable Register */ |
#define | DBGU_IDR 0x0C /* Interrupt Disable Register */ |
#define | DBGU_IMR 0x10 /* Interrupt Mask Register */ |
#define | DBGU_SR 0x14 /* Channel Status Register */ |
#define | DBGU_RHR 0x18 /* Receiver Holding Register */ |
#define | DBGU_THR 0x1C /* Transmitter Holding Register */ |
#define | DBGU_BRGR 0x20 /* Baud Rate Generator Register */ |
#define | DBGU_C1R 0x40 /* Chip ID1 Register */ |
#define | DBGU_C2R 0x44 /* Chip ID2 Register */ |
#define | DBGU_FNTR 0x48 /* Force NTRST Register */ |
#define | DBGU_CR_RSTRX BIT2 /* 1 = Reset and disable receiver */ |
#define | DBGU_CR_RSTTX BIT3 /* 1 = Reset and disable transmitter */ |
#define | DBGU_CR_RXEN BIT4 /* 1 = Receiver enable */ |
#define | DBGU_CR_RXDIS BIT5 /* 1 = Receiver disable */ |
#define | DBGU_CR_TXEN BIT6 /* 1 = Transmitter enable */ |
#define | DBGU_CR_TXDIS BIT7 /* 1 = Transmitter disable */ |
#define | DBGU_CR_RSTSTA BIT8 /* 1 = Reset PARE, FRAME and OVRE in DBGU_SR. */ |
#define | DBGU_MR_PAR_EVEN (0x0 << 9) /* Even Parity */ |
#define | DBGU_MR_PAR_ODD (0x1 << 9) /* Odd Parity */ |
#define | DBGU_MR_PAR_SPACE (0x2 << 9) /* Parity forced to 0 (Space) */ |
#define | DBGU_MR_PAR_MARK (0x3 << 9) /* Parity forced to 1 (Mark) */ |
#define | DBGU_MR_PAR_NONE (0x4 << 9) /* No Parity */ |
#define | DBGU_MR_PAR_MDROP (0x6 << 9) /* Multi-drop mode */ |
#define | DBGU_MR_CHMODE_NORM (0x0 << 14) /* Normal Mode */ |
#define | DBGU_MR_CHMODE_AUTO (0x1 << 14) /* Auto Echo: RXD drives TXD */ |
#define | DBGU_MR_CHMODE_LOC (0x2 << 14) /* Local Loopback: TXD drives RXD */ |
#define | DBGU_MR_CHMODE_REM (0x3 << 14) /* Remote Loopback: RXD pin connected to TXD pin. */ |
#define | DBGU_INT_RXRDY BIT0 /* RXRDY Interrupt */ |
#define | DBGU_INT_TXRDY BIT1 /* TXRDY Interrupt */ |
#define | DBGU_INT_ENDRX BIT3 /* End of Receive Transfer Interrupt */ |
#define | DBGU_INT_ENDTX BIT4 /* End of Transmit Interrupt */ |
#define | DBGU_INT_OVRE BIT5 /* Overrun Interrupt */ |
#define | DBGU_INT_FRAME BIT6 /* Framing Error Interrupt */ |
#define | DBGU_INT_PARE BIT7 /* Parity Error Interrupt */ |
#define | DBGU_INT_TXEMPTY BIT9 /* TXEMPTY Interrupt */ |
#define | DBGU_INT_TXBUFE BIT11 /* TXBUFE Interrupt */ |
#define | DBGU_INT_RXBUFF BIT12 /* RXBUFF Interrupt */ |
#define | DBGU_INT_COMM_TX BIT30 /* COMM_TX Interrupt */ |
#define | DBGU_INT_COMM_RX BIT31 /* COMM_RX Interrupt */ |
#define | DBGU_INT_ALL 0xC0001AFB /* all assigned bits */ |
#define | DBGU_FNTR_NTRST BIT0 /* 1 = Force NTRST low in JTAG */ |
