RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
bsps
arm
include
bsp
arm-pl011.h
1
9
10
* Copyright (c) 2013-2014 embedded brains GmbH. All rights reserved.
11
12
* embedded brains GmbH
13
* Dornierstr. 4
14
* 82178 Puchheim
15
* Germany
16
* <info@embedded-brains.de>
17
18
* The license and distribution terms for this file may be
19
* found in the file LICENSE in this distribution or at
20
* http://www.rtems.org/license/LICENSE.
21
22
23
#ifndef LIBBSP_ARM_SHARED_ARM_PL011_H
24
#define LIBBSP_ARM_SHARED_ARM_PL011_H
25
26
rtems/termiostypes.h
27
28
bsp/arm-pl011-regs.h
29
30
#ifdef __cplusplus
31
extern
"C"
32
#endif
/* __cplusplus */
33
34
typedef
struct
35
rtems_termios_device_context
base;
36
volatile
pl011
*regs;
37
rtems_vector_number
irq;
38
uint32_t initial_baud;
39
arm_pl011_context
40
41
bool
arm_pl011_probe(
*base);
42
43
void
arm_pl011_write_polled(
*base,
char
c);
44
45
extern
const
rtems_termios_device_handler
arm_pl011_fns;
46
47
#ifdef __cplusplus
48
49
#endif
/* __cplusplus */
50
51
#endif
/* LIBBSP_ARM_SHARED_ARM_PL011_H */
arm-pl011-regs.h
ARM PL011 Register definitions.
Termios device context.
Definition:
termiostypes.h:75
termiostypes.h
rtems_vector_number
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition:
intr.h:47
arm_pl011_context
Definition:
arm-pl011.h:34
pl011
Definition:
arm-pl011-regs.h:28
Termios device handler.
Definition:
termiostypes.h:141
