RTEMS  5.1
arm-a9mpcore-start.h
1
9 /*
10  * Copyright (c) 2013-2014 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Dornierstr. 4
14  * 82178 Puchheim
15  * Germany
16  * <info@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef LIBBSP_ARM_SHARED_ARM_A9MPCORE_START_H
24 #define LIBBSP_ARM_SHARED_ARM_A9MPCORE_START_H
25
26 #include <rtems/score/smpimpl.h>
27
28 #include <libcpu/arm-cp15.h>
29
30 #include <bsp.h>
31 #include <bsp/start.h>
32 #include <bsp/arm-a9mpcore-regs.h>
33 #include <bsp/arm-errata.h>
34 #include <bsp/arm-gic-irq.h>
35
36 #ifdef __cplusplus
37 extern "C" {
38 #endif /* __cplusplus */
39
40 BSP_START_TEXT_SECTION static inline void
41 arm_a9mpcore_start_set_vector_base(void)
42 {
43  /*
44  * Do not use bsp_vector_table_begin == 0, since this will get optimized away.
45  */
46  if (bsp_vector_table_end != bsp_vector_table_size) {
47  uint32_t ctrl;
48
49  /*
50  * For now we assume that every Cortex-A9 MPCore has the Security Extensions.
51  * Later it might be necessary to evaluate the ID_PFR1 register.
52  */
53  arm_cp15_set_vector_base_address(bsp_vector_table_begin);
54
55  ctrl = arm_cp15_get_control();
56  ctrl &= ~ARM_CP15_CTRL_V;
57  arm_cp15_set_control(ctrl);
58  }
59 }
60
61 BSP_START_TEXT_SECTION static inline void arm_a9mpcore_start_scu_invalidate(
62  volatile a9mpcore_scu *scu,
63  uint32_t cpu_id,
64  uint32_t ways
65 )
66 {
67  scu->invss = (ways & 0xf) << ((cpu_id & 0x3) * 4);
68 }
69
70 BSP_START_TEXT_SECTION static inline void
71 arm_a9mpcore_start_errata_764369_handler(volatile a9mpcore_scu *scu)
72 {
73  if (arm_errata_is_applicable_processor_errata_764369()) {
74  scu->diagn_ctrl |= A9MPCORE_SCU_DIAGN_CTRL_MIGRATORY_BIT_DISABLE;
75  }
76 }
77
78 BSP_START_TEXT_SECTION static inline void
79 arm_a9mpcore_start_scu_enable(volatile a9mpcore_scu *scu)
80 {
81  scu->ctrl |= A9MPCORE_SCU_CTRL_SCU_EN;
82  arm_a9mpcore_start_errata_764369_handler(scu);
83 }
84
85 #ifdef RTEMS_SMP
86 BSP_START_TEXT_SECTION static inline void
87 arm_a9mpcore_start_on_secondary_processor(void)
88 {
89  uint32_t ctrl;
90
91  arm_a9mpcore_start_set_vector_base();
92
93  arm_gic_irq_initialize_secondary_cpu();
94
95  ctrl = arm_cp15_start_setup_mmu_and_cache(
96  0,
97  ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_Z
98  );
99
100  arm_cp15_set_domain_access_control(
101  ARM_CP15_DAC_DOMAIN(ARM_MMU_DEFAULT_CLIENT_DOMAIN, ARM_CP15_DAC_CLIENT)
102  );
103
104  /* FIXME: Sharing the translation table between processors is brittle */
105  arm_cp15_set_translation_table_base(
106  (uint32_t *) bsp_translation_table_base
107  );
108
109  ctrl |= ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M;
110  arm_cp15_set_control(ctrl);
111
112  _SMP_Start_multitasking_on_secondary_processor(_Per_CPU_Get());
113 }
114
115 BSP_START_TEXT_SECTION static inline void
116 arm_a9mpcore_start_enable_smp_in_auxiliary_control(void)
117 {
118  /*
119  * Enable cache coherency support and cache/MMU maintenance broadcasts for
120  * this processor.
121  */
122  uint32_t actlr = arm_cp15_get_auxiliary_control();
123  actlr |= ARM_CORTEX_A9_ACTL_SMP | ARM_CORTEX_A9_ACTL_FW;
124  arm_cp15_set_auxiliary_control(actlr);
125 }
126 #endif
127
128 BSP_START_TEXT_SECTION static inline void arm_a9mpcore_start_hook_0(void)
129 {
130  volatile a9mpcore_scu *scu =
131  (volatile a9mpcore_scu *) BSP_ARM_A9MPCORE_SCU_BASE;
132  uint32_t cpu_id = arm_cortex_a9_get_multiprocessor_cpu_id();
133
134  arm_cp15_branch_predictor_invalidate_all();
135
136  if (cpu_id == 0) {
137  arm_a9mpcore_start_scu_enable(scu);
138  }
139
140 #ifdef RTEMS_SMP
141  arm_a9mpcore_start_enable_smp_in_auxiliary_control();
142 #endif
143
144  arm_a9mpcore_start_scu_invalidate(scu, cpu_id, 0xf);
145
146 #ifdef RTEMS_SMP
147  if (cpu_id != 0) {
148  arm_a9mpcore_start_on_secondary_processor();
149  }
150 #endif
151 }
152
153 BSP_START_TEXT_SECTION static inline void arm_a9mpcore_start_global_timer(void)
154 {
155  volatile a9mpcore_gt *gt = (volatile a9mpcore_gt *) BSP_ARM_A9MPCORE_GT_BASE;
156
157  gt->ctrl = 0;
158  gt->cntrlower = 0;
159  gt->cntrupper = 0;
160  gt->ctrl = A9MPCORE_GT_CTRL_TMR_EN;
161 }
162
163 BSP_START_TEXT_SECTION static inline void arm_a9mpcore_start_hook_1(void)
164 {
165  arm_a9mpcore_start_global_timer();
166  arm_a9mpcore_start_set_vector_base();
167 }
168
169 #ifdef __cplusplus
170 }
171 #endif /* __cplusplus */
172
173 #endif /* LIBBSP_ARM_SHARED_ARM_A9MPCORE_START_H */
ARM co-processor 15 (CP15) API.
Definition: arm-a9mpcore-regs.h:75
Create #defines which state which erratas shall get applied.
ARM_A9MPCORE_REGS Support.
Definition: arm-a9mpcore-regs.h:28
ARM GIC IRQ.
SuperCore SMP Implementation.
