RTEMS  5.1
ambapp_bus.h
1 /* General part of a AMBA Plug & Play bus driver.
2  *
3  * COPYRIGHT (c) 2008.
4  * Cobham Gaisler AB.
5  *
6  * This is the general part of the different AMBA Plug & Play
7  * drivers. The drivers are wrappers around this driver, making
8  * the code size smaller for systems with multiple AMBA Plug &
9  * Play buses.
10  *
11  * The license and distribution terms for this file may be
12  * found in the file LICENSE in this distribution or at
13  * http://www.rtems.org/license/LICENSE.
14  */
15
16 #ifndef __AMBAPP_BUS_H__
17 #define __AMBAPP_BUS_H__
18
19 #include <drvmgr/drvmgr.h>
20 #include "ambapp.h"
21
22 #ifdef __cplusplus
23 extern "C" {
24 #endif
25
26 /* GRLIB AMBA Plug&Play Driver ID generation */
27 #define DRIVER_AMBAPP_ID(vendor, device) \
28  DRIVER_ID(DRVMGR_BUS_TYPE_AMBAPP, ((((vendor) & 0xff) << 16) | ((device) & 0xfff)))
29
30 /*** Gaisler Hardware Device Driver IDs ***/
31 #define DRIVER_AMBAPP_GAISLER_AHBSTAT_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_AHBSTAT)
32 #define DRIVER_AMBAPP_GAISLER_APBUART_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_APBUART)
33 #define DRIVER_AMBAPP_GAISLER_B1553BRM_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_B1553BRM)
34 #define DRIVER_AMBAPP_GAISLER_B1553RT_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_B1553RT)
35 #define DRIVER_AMBAPP_GAISLER_GPTIMER_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GPTIMER)
36 #define DRIVER_AMBAPP_GAISLER_GR1553B_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GR1553B)
37 #define DRIVER_AMBAPP_GAISLER_GRADCDAC_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRADCDAC)
38 #define DRIVER_AMBAPP_GAISLER_GRAES_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRAESDMA)
39 #define DRIVER_AMBAPP_GAISLER_GRCAN_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRCAN)
40 #define DRIVER_AMBAPP_GAISLER_GRCTM_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRCTM)
41 #define DRIVER_AMBAPP_GAISLER_GRETH_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_ETHMAC)
42 #define DRIVER_AMBAPP_GAISLER_GRGPIO_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GPIO)
43 #define DRIVER_AMBAPP_GAISLER_GRPCI2_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRPCI2)
44 #define DRIVER_AMBAPP_GAISLER_GRIOMMU_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRIOMMU)
45 #define DRIVER_AMBAPP_GAISLER_GRPCI_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_PCIFBRG)
46 #define DRIVER_AMBAPP_GAISLER_GRPWM_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRPWM)
47 #define DRIVER_AMBAPP_GAISLER_GRPWRX_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_PW2APB)
48 #define DRIVER_AMBAPP_GAISLER_GRSPW_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_SPW)
49 #define DRIVER_AMBAPP_GAISLER_GRSPW2_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_SPW2)
50 #define DRIVER_AMBAPP_GAISLER_GRTC_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRTC)
51 #define DRIVER_AMBAPP_GAISLER_GRTM_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRTM)
52 #define DRIVER_AMBAPP_GAISLER_I2CMST_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_I2CMST)
53 #define DRIVER_AMBAPP_GAISLER_OCCAN_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_CANAHB)
54 #define DRIVER_AMBAPP_GAISLER_PCIF_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_PCIF)
55 #define DRIVER_AMBAPP_GAISLER_PCITRACE_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_PCITRACE)
56 #define DRIVER_AMBAPP_GAISLER_SPICTRL_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_SPICTRL)
57 #define DRIVER_AMBAPP_GAISLER_SPWCUC_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_SPWCUC)
58 #define DRIVER_AMBAPP_GAISLER_SPW_ROUTER_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_SPW_ROUTER)
59 #define DRIVER_AMBAPP_GAISLER_L2CACHE_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_L2CACHE)
60 #define DRIVER_AMBAPP_GAISLER_MEMSCRUB_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_MEMSCRUB)
61 #define DRIVER_AMBAPP_GAISLER_L4STAT_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_L4STAT)
62 #define DRIVER_AMBAPP_GAISLER_SPWTDP_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_SPWTDP)
63
64 /*** ESA Hardware Device Driver IDs ***/
65 #define DRIVER_AMBAPP_ESA_MCTRL_ID DRIVER_AMBAPP_ID(VENDOR_ESA, ESA_MCTRL)
66 #define DRIVER_AMBAPP_MCTRL_ID DRIVER_AMBAPP_ESA_MCTRL_ID
67
68 struct amba_dev_id {
69  unsigned short vendor;
70  unsigned short device;
71  /* Version ? */
72 };
73
74 struct amba_drv_info {
75  struct drvmgr_drv general; /* General bus info */
76  /* AMBA specific bus information */
77  struct amba_dev_id *ids; /* Supported hardware */
78 };
79
80 struct amba_dev_info {
81  struct amba_dev_id id;
82  struct ambapp_core info;
83 };
84
85 struct ambapp_ops {
86  int (*int_register)
87  (struct drvmgr_dev *dev, int index, const char *info, drvmgr_isr isr, void *arg);
88  int (*int_unregister)
89  (struct drvmgr_dev *dev, int index, drvmgr_isr isr, void *arg);
90  int (*int_clear)(struct drvmgr_dev *dev, int index);
91  int (*int_mask)(struct drvmgr_dev *dev, int index);
92  int (*int_unmask)(struct drvmgr_dev *dev, int index);
93 #ifdef RTEMS_SMP
94  int (*int_set_affinity)(struct drvmgr_dev *dev, int index,
95  const Processor_mask *cpus);
96 #endif
97  int (*get_params)
98  (struct drvmgr_dev *, struct drvmgr_bus_params *);
99 };
100
102  struct ambapp_bus *abus; /* Prescanned AMBA PnP bus */
103  struct ambapp_ops *ops; /* AMBA bus operations */
104  struct drvmgr_map_entry *maps_up; /* Bus memory map up-stream towards CPU */
105  struct drvmgr_map_entry *maps_down; /* Bus memory map down-stream towards HW */
106  struct drvmgr_bus_res *resources; /* Driver Resources */
107  int bus_type; /* Set DRVMGR_BUS_TYPE_AMBAPP_DIST if distributed AMBA Bus */
108  struct drvmgr_func *funcs; /* Custom functions */
109 };
110
111 /*** Bus operations with READ/WRITE access operations ***
112  *
113  * The functions are implemented using the standard drvmgr RW interface
114  */
115 #define AMBAPP_R8 DRVMGR_RWFUNC(RW_SIZE_1|RW_READ|RW_REG)
116 #define AMBAPP_R16 DRVMGR_RWFUNC(RW_SIZE_2|RW_READ|RW_REG)
117 #define AMBAPP_R32 DRVMGR_RWFUNC(RW_SIZE_4|RW_READ|RW_REG)
118 #define AMBAPP_R64 DRVMGR_RWFUNC(RW_SIZE_8|RW_READ|RW_REG)
119 #define AMBAPP_W8 DRVMGR_RWFUNC(RW_SIZE_1|RW_WRITE|RW_REG)
120 #define AMBAPP_W16 DRVMGR_RWFUNC(RW_SIZE_2|RW_WRITE|RW_REG)
121 #define AMBAPP_W32 DRVMGR_RWFUNC(RW_SIZE_4|RW_WRITE|RW_REG)
122 #define AMBAPP_W64 DRVMGR_RWFUNC(RW_SIZE_8|RW_WRITE|RW_REG)
123 #define AMBAPP_RMEM DRVMGR_RWFUNC(RW_SIZE_ANY|RW_READ|RW_MEM)
124 #define AMBAPP_WMEM DRVMGR_RWFUNC(RW_SIZE_ANY|RW_WRITE|RW_MEM)
125 #define AMBAPP_MEMSET DRVMGR_RWFUNC(RW_SIZE_ANY|RW_SET|RW_MEM)
126 #define AMBAPP_RW_ARG DRVMGR_RWFUNC(RW_ARG)
127
128 /* Register an ambapp bus on-top of a device */
129 extern int ambapp_bus_register(
130  struct drvmgr_dev *dev,
131  struct ambapp_config *config
132  );
133
134 extern void ambapp_bus_freq_register(
135  struct drvmgr_dev *dev,
136  int amba_interface,
137  unsigned int freq_hz);
138
139 #ifdef __cplusplus
140 }
141 #endif
142
143 #endif
Definition: ambapp_bus.h:74
Definition: deflate.c:115
Definition: ambapp_bus.h:68
Definition: drvmgr.h:158
Definition: ambapp_bus.h:85
Definition: ambapp_bus.h:80
Definition: drvmgr.h:214
Definition: drvmgr.h:225
Definition: rtemscompat1.h:15
Definition: ambapp.h:126
Definition: drvmgr.h:275
Definition: ambapp.h:102
Definition: ambapp_bus.h:101
Definition: drvmgr.h:305
Definition: drvmgr.h:121
