RTEMS  5.1
alt_uart.h
1
7 /*******************************************************************************
8 * *
9 * Copyright 2013 Altera Corporation. All Rights Reserved. *
10 * *
11 * Redistribution and use in source and binary forms, with or without *
12 * modification, are permitted provided that the following conditions are met: *
13 * *
14 * 1. Redistributions of source code must retain the above copyright notice, *
15 * this list of conditions and the following disclaimer. *
16 * *
17 * 2. Redistributions in binary form must reproduce the above copyright notice, *
18 * this list of conditions and the following disclaimer in the documentation *
19 * and/or other materials provided with the distribution. *
20 * *
21 * 3. The name of the author may not be used to endorse or promote products *
22 * derived from this software without specific prior written permission. *
23 * *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR *
25 * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
26 * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO *
27 * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, *
28 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, *
29 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; *
30 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, *
31 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR *
32 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF *
33 * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. *
34 * *
35 *******************************************************************************/
36
37 /* Altera - ALT_UART */
38
39 #ifndef __ALTERA_ALT_UART_H__
40 #define __ALTERA_ALT_UART_H__
41
42 #ifdef __cplusplus
43 extern "C"
44 {
45 #endif /* __cplusplus */
46
47 /*
48  * Component : UART Module - ALT_UART
49  * UART Module
50  *
51  * Registers in the UART module
52  *
53  */
54 /*
55  * Register : Rx Buffer, Tx Holding, and Divisor Latch Low - rbr_thr_dll
56  *
57  * This is a multi-function register. This register holds receives and transmit
58  * data and controls the least-signficant 8 bits of the baud rate divisor.
59  *
60  * Register Layout
61  *
62  * Bits | Access | Reset | Description
63  * :-------|:-------|:------|:------------
64  * [7:0] | RW | 0x0 | Value
65  * [31:8] | ??? | 0x0 | *UNDEFINED*
66  *
67  */
68 /*
69  * Field : Value - value
70  *
71  * Receive Buffer Register:
72  *
73  * This register contains the data byte received on the serial input port
74  * (uart_rxd). The data in this register is valid only if the Data Ready ( bit [0]
75  * in the Line Status Register(LSR)) is set to 1. If FIFOs are disabled(bit[0] of
76  * Register FCR is set to 0) the data in the RBR must be read before the next data
77  * arrives, otherwise it will be overwritten, resulting in an overrun error. If
78  * FIFOs are enabled(bit [0] of Register FCR is set to 1) this register accesses
79  * the head of the receive FIFO. If the receive FIFO is full, and this register is
80  * not read before the next data character arrives, then the data already in the
81  * FIFO will be preserved but any incoming data will be lost. An overrun error will
82  * also occur.
83  *
84  * Transmit Holding Register:
85  *
86  * This register contains data to be transmitted on the serial output port. Data
87  * should only be written to the THR when the THR Empty bit [5] of the LSR Register
88  * is set to 1. If FIFOs are disabled (bit [0] of Register FCR) is set to 0 and
89  * THRE is set to 1, writing a single character to the THR clears the THRE. Any
90  * additional writes to the THR before the THRE is set again causes the THR data to
91  * be overwritten. If FIFO's are enabled bit [0] of Register FCR is set to 1 and
92  * THRE is set up to 128 characters of data may be written to the THR before the
93  * FIFO is full. Any attempt to write data when the FIFO is full results in the
94  * write data being lost.
95  *
96  * Divisor Latch Low:
97  *
98  * This register makes up the lower 8-bits of a 16-bit, Read/write, Divisor Latch
99  * register that contains the baud rate divisor for the UART. This register may
100  * only be accessed when the DLAB bit [7] of the LCR Register is set to 1. The
101  * output baud rate is equal to the serial clock l4_sp_clk frequency divided by
102  * sixteen times the value of the baud rate divisor, as follows:
103  *
104  * baud rate = (serial clock freq) / (16 * divisor)
105  *
106  * Note that with the Divisor Latch Registers (DLL and DLH) set to zero, the baud
107  * clock is disabled and no serial communications will occur. Also, once the DLL is
108  * set, at least 8 l4_sp_clk clock cycles should be allowed to pass before
109  * transmitting or receiving data.
110  *
111  * Field Access Macros:
112  *
113  */
114 /* The Least Significant Bit (LSB) position of the ALT_UART_RBR_THR_DLL_VALUE register field. */
115 #define ALT_UART_RBR_THR_DLL_VALUE_LSB 0
116 /* The Most Significant Bit (MSB) position of the ALT_UART_RBR_THR_DLL_VALUE register field. */
117 #define ALT_UART_RBR_THR_DLL_VALUE_MSB 7
118 /* The width in bits of the ALT_UART_RBR_THR_DLL_VALUE register field. */
119 #define ALT_UART_RBR_THR_DLL_VALUE_WIDTH 8
120 /* The mask used to set the ALT_UART_RBR_THR_DLL_VALUE register field value. */
121 #define ALT_UART_RBR_THR_DLL_VALUE_SET_MSK 0x000000ff
122 /* The mask used to clear the ALT_UART_RBR_THR_DLL_VALUE register field value. */
123 #define ALT_UART_RBR_THR_DLL_VALUE_CLR_MSK 0xffffff00
124 /* The reset value of the ALT_UART_RBR_THR_DLL_VALUE register field. */
125 #define ALT_UART_RBR_THR_DLL_VALUE_RESET 0x0
126 /* Extracts the ALT_UART_RBR_THR_DLL_VALUE field value from a register. */
127 #define ALT_UART_RBR_THR_DLL_VALUE_GET(value) (((value) & 0x000000ff) >> 0)
128 /* Produces a ALT_UART_RBR_THR_DLL_VALUE register field value suitable for setting the register. */
129 #define ALT_UART_RBR_THR_DLL_VALUE_SET(value) (((value) << 0) & 0x000000ff)
130
131 #ifndef __ASSEMBLY__
132 /*
133  * WARNING: The C register and register group struct declarations are provided for
134  * convenience and illustrative purposes. They should, however, be used with
135  * caution as the C language standard provides no guarantees about the alignment or
136  * atomicity of device memory accesses. The recommended practice for writing
137  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
138  * alt_write_word() functions.
139  *
140  * The struct declaration for register ALT_UART_RBR_THR_DLL.
141  */
143 {
144  uint32_t value : 8; /* Value */
145  uint32_t : 24; /* *UNDEFINED* */
146 };
147
148 /* The typedef declaration for register ALT_UART_RBR_THR_DLL. */
149 typedef volatile struct ALT_UART_RBR_THR_DLL_s ALT_UART_RBR_THR_DLL_t;
150 #endif /* __ASSEMBLY__ */
151
152 /* The byte offset of the ALT_UART_RBR_THR_DLL register from the beginning of the component. */
153 #define ALT_UART_RBR_THR_DLL_OFST 0x0
154 /* The address of the ALT_UART_RBR_THR_DLL register. */
155 #define ALT_UART_RBR_THR_DLL_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_RBR_THR_DLL_OFST))
156
157 /*
158  * Register : Interrupt Enable and Divisor Latch High - ier_dlh
159  *
160  * This is a multi-function register. This register enables/disables receive and
161  * transmit interrupts and also controls the most-significant 8-bits of the baud
162  * rate divisor.
163  *
164  * Divisor Latch High Register:
165  *
166  * This register is accessed when the DLAB bit [7] of the LCR Register is set to
167  * 1.Bits[7:0] contain the high order 8-bits of the baud rate divisor.The output
168  * baud rate is equal to the serial clock l4_sp_clk frequency divided by sixteen
169  * times the value of the baud rate divisor, as follows:
170  *
171  * baud rate = (serial clock freq) / (16 * divisor):
172  *
173  * Note that with the Divisor Latch Registers (DLLand DLH) set to zero, the baud
174  * clock is disabled and no serial communications will occur. Also, once the DLL is
175  * set, at least 8 l4_sp_clk clock cycles should be allowed to pass before
176  * transmitting or receiving data.
177  *
178  * Interrupt Enable Register:
179  *
180  * This register may only be accessed when the DLAB bit [7] of the LCR Register is
181  * set to 0.Allows control of the Interrupt Enables for transmit and receive
182  * functions.
183  *
184  * Register Layout
185  *
186  * Bits | Access | Reset | Description
187  * :-------|:-------|:------|:--------------------------------------------
188  * [0] | RW | 0x0 | DLH[0] and Receive Data Interrupt Enable
189  * [1] | RW | 0x0 | DLH[1] and Transmit Data Interrupt Control
190  * [2] | RW | 0x0 | DLH[2] and Enable Receiver Line Status
191  * [3] | RW | 0x0 | DLH[3] and Enable Modem Status Interrupt
192  * [4] | RW | 0x0 | DLH[4]
193  * [5] | RW | 0x0 | DLH[5]
194  * [6] | RW | 0x0 | DLH[6]
195  * [7] | RW | 0x0 | DLH[7] and PTIME THRE Interrupt Mode Enable
196  * [31:8] | ??? | 0x0 | *UNDEFINED*
197  *
198  */
199 /*
200  * Field : DLH[0] and Receive Data Interrupt Enable - erbfi_dlh0
201  *
202  * Divisor Latch High Register:
203  *
204  * Bit 0 of DLH value.
205  *
206  * Interrupt Enable Register:
207  *
208  * Used to enable/disable the generation of the Receive Data Available Interrupt
209  * and the Character Timeout Interrupt(if FIFO's enabled). These are the second
210  * highest priority interrupts.
211  *
212  * Field Enumeration Values:
213  *
214  * Enum | Value | Description
215  * :-----------------------------------|:------|:------------------
216  * ALT_UART_IER_DLH_ERBFI_DLH0_E_DISD | 0x0 | Interrupt Disable
217  * ALT_UART_IER_DLH_ERBFI_DLH0_E_END | 0x1 | Interrupt Enable
218  *
219  * Field Access Macros:
220  *
221  */
222 /*
223  * Enumerated value for register field ALT_UART_IER_DLH_ERBFI_DLH0
224  *
225  * Interrupt Disable
226  */
227 #define ALT_UART_IER_DLH_ERBFI_DLH0_E_DISD 0x0
228 /*
229  * Enumerated value for register field ALT_UART_IER_DLH_ERBFI_DLH0
230  *
231  * Interrupt Enable
232  */
233 #define ALT_UART_IER_DLH_ERBFI_DLH0_E_END 0x1
234
235 /* The Least Significant Bit (LSB) position of the ALT_UART_IER_DLH_ERBFI_DLH0 register field. */
236 #define ALT_UART_IER_DLH_ERBFI_DLH0_LSB 0
237 /* The Most Significant Bit (MSB) position of the ALT_UART_IER_DLH_ERBFI_DLH0 register field. */
238 #define ALT_UART_IER_DLH_ERBFI_DLH0_MSB 0
239 /* The width in bits of the ALT_UART_IER_DLH_ERBFI_DLH0 register field. */
240 #define ALT_UART_IER_DLH_ERBFI_DLH0_WIDTH 1
241 /* The mask used to set the ALT_UART_IER_DLH_ERBFI_DLH0 register field value. */
242 #define ALT_UART_IER_DLH_ERBFI_DLH0_SET_MSK 0x00000001
243 /* The mask used to clear the ALT_UART_IER_DLH_ERBFI_DLH0 register field value. */
244 #define ALT_UART_IER_DLH_ERBFI_DLH0_CLR_MSK 0xfffffffe
245 /* The reset value of the ALT_UART_IER_DLH_ERBFI_DLH0 register field. */
246 #define ALT_UART_IER_DLH_ERBFI_DLH0_RESET 0x0
247 /* Extracts the ALT_UART_IER_DLH_ERBFI_DLH0 field value from a register. */
248 #define ALT_UART_IER_DLH_ERBFI_DLH0_GET(value) (((value) & 0x00000001) >> 0)
249 /* Produces a ALT_UART_IER_DLH_ERBFI_DLH0 register field value suitable for setting the register. */
250 #define ALT_UART_IER_DLH_ERBFI_DLH0_SET(value) (((value) << 0) & 0x00000001)
251
252 /*
253  * Field : DLH[1] and Transmit Data Interrupt Control - etbei_dlhl
254  *
255  * Divisor Latch High Register:
256  *
257  * Bit 1 of DLH value.
258  *
259  * Interrupt Enable Register:
260  *
261  * Enable Transmit Holding Register Empty Interrupt. This is used to enable/disable
262  * the generation of Transmitter Holding Register Empty Interrupt. This is the
263  * third highest priority interrupt.
264  *
265  * Field Enumeration Values:
266  *
267  * Enum | Value | Description
268  * :-----------------------------------|:------|:------------
269  * ALT_UART_IER_DLH_ETBEI_DLHL_E_DISD | 0x0 | Tx disable
270  * ALT_UART_IER_DLH_ETBEI_DLHL_E_END | 0x1 | Tx enable
271  *
272  * Field Access Macros:
273  *
274  */
275 /*
276  * Enumerated value for register field ALT_UART_IER_DLH_ETBEI_DLHL
277  *
278  * Tx disable
279  */
280 #define ALT_UART_IER_DLH_ETBEI_DLHL_E_DISD 0x0
281 /*
282  * Enumerated value for register field ALT_UART_IER_DLH_ETBEI_DLHL
283  *
284  * Tx enable
285  */
286 #define ALT_UART_IER_DLH_ETBEI_DLHL_E_END 0x1
287
288 /* The Least Significant Bit (LSB) position of the ALT_UART_IER_DLH_ETBEI_DLHL register field. */
289 #define ALT_UART_IER_DLH_ETBEI_DLHL_LSB 1
290 /* The Most Significant Bit (MSB) position of the ALT_UART_IER_DLH_ETBEI_DLHL register field. */
291 #define ALT_UART_IER_DLH_ETBEI_DLHL_MSB 1
292 /* The width in bits of the ALT_UART_IER_DLH_ETBEI_DLHL register field. */
293 #define ALT_UART_IER_DLH_ETBEI_DLHL_WIDTH 1
294 /* The mask used to set the ALT_UART_IER_DLH_ETBEI_DLHL register field value. */
295 #define ALT_UART_IER_DLH_ETBEI_DLHL_SET_MSK 0x00000002
296 /* The mask used to clear the ALT_UART_IER_DLH_ETBEI_DLHL register field value. */
297 #define ALT_UART_IER_DLH_ETBEI_DLHL_CLR_MSK 0xfffffffd
298 /* The reset value of the ALT_UART_IER_DLH_ETBEI_DLHL register field. */
299 #define ALT_UART_IER_DLH_ETBEI_DLHL_RESET 0x0
300 /* Extracts the ALT_UART_IER_DLH_ETBEI_DLHL field value from a register. */
301 #define ALT_UART_IER_DLH_ETBEI_DLHL_GET(value) (((value) & 0x00000002) >> 1)
302 /* Produces a ALT_UART_IER_DLH_ETBEI_DLHL register field value suitable for setting the register. */
303 #define ALT_UART_IER_DLH_ETBEI_DLHL_SET(value) (((value) << 1) & 0x00000002)
304
305 /*
306  * Field : DLH[2] and Enable Receiver Line Status - elsi_dhl2
307  *
308  * Divisor Latch High Register:
309  *
310  * Bit 2 of DLH value.
311  *
312  * Interrupt Enable Register:
313  *
314  * This is used to enable/disable the generation of Receiver Line Status Interrupt.
315  * This is the highest priority interrupt.
316  *
317  * Field Enumeration Values:
318  *
319  * Enum | Value | Description
320  * :----------------------------------|:------|:----------------------------
321  * ALT_UART_IER_DLH_ELSI_DHL2_E_DISD | 0x0 | Disable interrupt line stat
322  * ALT_UART_IER_DLH_ELSI_DHL2_E_END | 0x1 | Enable interrupt line stat
323  *
324  * Field Access Macros:
325  *
326  */
327 /*
328  * Enumerated value for register field ALT_UART_IER_DLH_ELSI_DHL2
329  *
330  * Disable interrupt line stat
331  */
332 #define ALT_UART_IER_DLH_ELSI_DHL2_E_DISD 0x0
333 /*
334  * Enumerated value for register field ALT_UART_IER_DLH_ELSI_DHL2
335  *
336  * Enable interrupt line stat
337  */
338 #define ALT_UART_IER_DLH_ELSI_DHL2_E_END 0x1
339
340 /* The Least Significant Bit (LSB) position of the ALT_UART_IER_DLH_ELSI_DHL2 register field. */
341 #define ALT_UART_IER_DLH_ELSI_DHL2_LSB 2
342 /* The Most Significant Bit (MSB) position of the ALT_UART_IER_DLH_ELSI_DHL2 register field. */
343 #define ALT_UART_IER_DLH_ELSI_DHL2_MSB 2
344 /* The width in bits of the ALT_UART_IER_DLH_ELSI_DHL2 register field. */
345 #define ALT_UART_IER_DLH_ELSI_DHL2_WIDTH 1
346 /* The mask used to set the ALT_UART_IER_DLH_ELSI_DHL2 register field value. */
347 #define ALT_UART_IER_DLH_ELSI_DHL2_SET_MSK 0x00000004
348 /* The mask used to clear the ALT_UART_IER_DLH_ELSI_DHL2 register field value. */
349 #define ALT_UART_IER_DLH_ELSI_DHL2_CLR_MSK 0xfffffffb
350 /* The reset value of the ALT_UART_IER_DLH_ELSI_DHL2 register field. */
351 #define ALT_UART_IER_DLH_ELSI_DHL2_RESET 0x0
352 /* Extracts the ALT_UART_IER_DLH_ELSI_DHL2 field value from a register. */
353 #define ALT_UART_IER_DLH_ELSI_DHL2_GET(value) (((value) & 0x00000004) >> 2)
354 /* Produces a ALT_UART_IER_DLH_ELSI_DHL2 register field value suitable for setting the register. */
355 #define ALT_UART_IER_DLH_ELSI_DHL2_SET(value) (((value) << 2) & 0x00000004)
356
357 /*
358  * Field : DLH[3] and Enable Modem Status Interrupt - edssi_dhl3
359  *
360  * Divisor Latch High Register:
361  *
362  * Bit 3 of DLH value.
363  *
364  * Interrupt Enable Register:
365  *
366  * This is used to enable/disable the generation of Modem Status Interrupts. This
367  * is the fourth highest priority interrupt.
368  *
369  * Field Enumeration Values:
370  *
371  * Enum | Value | Description
372  * :-----------------------------------|:------|:-------------------------------
373  * ALT_UART_IER_DLH_EDSSI_DHL3_E_DISD | 0x0 | disable modem status interrupt
374  * ALT_UART_IER_DLH_EDSSI_DHL3_E_END | 0x1 | enable modem status interrupt
375  *
376  * Field Access Macros:
377  *
378  */
379 /*
380  * Enumerated value for register field ALT_UART_IER_DLH_EDSSI_DHL3
381  *
382  * disable modem status interrupt
383  */
384 #define ALT_UART_IER_DLH_EDSSI_DHL3_E_DISD 0x0
385 /*
386  * Enumerated value for register field ALT_UART_IER_DLH_EDSSI_DHL3
387  *
388  * enable modem status interrupt
389  */
390 #define ALT_UART_IER_DLH_EDSSI_DHL3_E_END 0x1
391
392 /* The Least Significant Bit (LSB) position of the ALT_UART_IER_DLH_EDSSI_DHL3 register field. */
393 #define ALT_UART_IER_DLH_EDSSI_DHL3_LSB 3
394 /* The Most Significant Bit (MSB) position of the ALT_UART_IER_DLH_EDSSI_DHL3 register field. */
395 #define ALT_UART_IER_DLH_EDSSI_DHL3_MSB 3
396 /* The width in bits of the ALT_UART_IER_DLH_EDSSI_DHL3 register field. */
397 #define ALT_UART_IER_DLH_EDSSI_DHL3_WIDTH 1
398 /* The mask used to set the ALT_UART_IER_DLH_EDSSI_DHL3 register field value. */
399 #define ALT_UART_IER_DLH_EDSSI_DHL3_SET_MSK 0x00000008
400 /* The mask used to clear the ALT_UART_IER_DLH_EDSSI_DHL3 register field value. */
401 #define ALT_UART_IER_DLH_EDSSI_DHL3_CLR_MSK 0xfffffff7
402 /* The reset value of the ALT_UART_IER_DLH_EDSSI_DHL3 register field. */
403 #define ALT_UART_IER_DLH_EDSSI_DHL3_RESET 0x0
404 /* Extracts the ALT_UART_IER_DLH_EDSSI_DHL3 field value from a register. */
405 #define ALT_UART_IER_DLH_EDSSI_DHL3_GET(value) (((value) & 0x00000008) >> 3)
406 /* Produces a ALT_UART_IER_DLH_EDSSI_DHL3 register field value suitable for setting the register. */
407 #define ALT_UART_IER_DLH_EDSSI_DHL3_SET(value) (((value) << 3) & 0x00000008)
408
409 /*
410  * Field : DLH[4] - dlh4
411  *
412  * Bit 4 of DLH value.
413  *
414  * Field Access Macros:
415  *
416  */
417 /* The Least Significant Bit (LSB) position of the ALT_UART_IER_DLH_DLH4 register field. */
418 #define ALT_UART_IER_DLH_DLH4_LSB 4
419 /* The Most Significant Bit (MSB) position of the ALT_UART_IER_DLH_DLH4 register field. */
420 #define ALT_UART_IER_DLH_DLH4_MSB 4
421 /* The width in bits of the ALT_UART_IER_DLH_DLH4 register field. */
422 #define ALT_UART_IER_DLH_DLH4_WIDTH 1
423 /* The mask used to set the ALT_UART_IER_DLH_DLH4 register field value. */
424 #define ALT_UART_IER_DLH_DLH4_SET_MSK 0x00000010
425 /* The mask used to clear the ALT_UART_IER_DLH_DLH4 register field value. */
426 #define ALT_UART_IER_DLH_DLH4_CLR_MSK 0xffffffef
427 /* The reset value of the ALT_UART_IER_DLH_DLH4 register field. */
428 #define ALT_UART_IER_DLH_DLH4_RESET 0x0
429 /* Extracts the ALT_UART_IER_DLH_DLH4 field value from a register. */
430 #define ALT_UART_IER_DLH_DLH4_GET(value) (((value) & 0x00000010) >> 4)
431 /* Produces a ALT_UART_IER_DLH_DLH4 register field value suitable for setting the register. */
432 #define ALT_UART_IER_DLH_DLH4_SET(value) (((value) << 4) & 0x00000010)
433
434 /*
435  * Field : DLH[5] - dlh5
436  *
437  * Bit 5 of DLH value.
438  *
439  * Field Access Macros:
440  *
441  */
442 /* The Least Significant Bit (LSB) position of the ALT_UART_IER_DLH_DLH5 register field. */
443 #define ALT_UART_IER_DLH_DLH5_LSB 5
444 /* The Most Significant Bit (MSB) position of the ALT_UART_IER_DLH_DLH5 register field. */
445 #define ALT_UART_IER_DLH_DLH5_MSB 5
446 /* The width in bits of the ALT_UART_IER_DLH_DLH5 register field. */
447 #define ALT_UART_IER_DLH_DLH5_WIDTH 1
448 /* The mask used to set the ALT_UART_IER_DLH_DLH5 register field value. */
449 #define ALT_UART_IER_DLH_DLH5_SET_MSK 0x00000020
450 /* The mask used to clear the ALT_UART_IER_DLH_DLH5 register field value. */
451 #define ALT_UART_IER_DLH_DLH5_CLR_MSK 0xffffffdf
452 /* The reset value of the ALT_UART_IER_DLH_DLH5 register field. */
453 #define ALT_UART_IER_DLH_DLH5_RESET 0x0
454 /* Extracts the ALT_UART_IER_DLH_DLH5 field value from a register. */
455 #define ALT_UART_IER_DLH_DLH5_GET(value) (((value) & 0x00000020) >> 5)
456 /* Produces a ALT_UART_IER_DLH_DLH5 register field value suitable for setting the register. */
457 #define ALT_UART_IER_DLH_DLH5_SET(value) (((value) << 5) & 0x00000020)
458
459 /*
460  * Field : DLH[6] - dlh6
461  *
462  * Bit 6 of DLH value.
463  *
464  * Field Access Macros:
465  *
466  */
467 /* The Least Significant Bit (LSB) position of the ALT_UART_IER_DLH_DLH6 register field. */
468 #define ALT_UART_IER_DLH_DLH6_LSB 6
469 /* The Most Significant Bit (MSB) position of the ALT_UART_IER_DLH_DLH6 register field. */
470 #define ALT_UART_IER_DLH_DLH6_MSB 6
471 /* The width in bits of the ALT_UART_IER_DLH_DLH6 register field. */
472 #define ALT_UART_IER_DLH_DLH6_WIDTH 1
473 /* The mask used to set the ALT_UART_IER_DLH_DLH6 register field value. */
474 #define ALT_UART_IER_DLH_DLH6_SET_MSK 0x00000040
475 /* The mask used to clear the ALT_UART_IER_DLH_DLH6 register field value. */
476 #define ALT_UART_IER_DLH_DLH6_CLR_MSK 0xffffffbf
477 /* The reset value of the ALT_UART_IER_DLH_DLH6 register field. */
478 #define ALT_UART_IER_DLH_DLH6_RESET 0x0
479 /* Extracts the ALT_UART_IER_DLH_DLH6 field value from a register. */
480 #define ALT_UART_IER_DLH_DLH6_GET(value) (((value) & 0x00000040) >> 6)
481 /* Produces a ALT_UART_IER_DLH_DLH6 register field value suitable for setting the register. */
482 #define ALT_UART_IER_DLH_DLH6_SET(value) (((value) << 6) & 0x00000040)
483
484 /*
485  * Field : DLH[7] and PTIME THRE Interrupt Mode Enable - ptime_dlh7
486  *
487  * Divisor Latch High Register:
488  *
489  * Bit 7 of DLH value.
490  *
491  * Interrupt Enable Register:
492  *
493  * This is used to enable/disable the generation of THRE Interrupt.
494  *
495  * Field Enumeration Values:
496  *
497  * Enum | Value | Description
498  * :-----------------------------------|:------|:------------------------------------
499  * ALT_UART_IER_DLH_PTIME_DLH7_E_DISD | 0x0 | disable tx-hold-reg-empty interrupt
500  * ALT_UART_IER_DLH_PTIME_DLH7_E_END | 0x1 | enable tx-hold-reg-empty interrupt
501  *
502  * Field Access Macros:
503  *
504  */
505 /*
506  * Enumerated value for register field ALT_UART_IER_DLH_PTIME_DLH7
507  *
508  * disable tx-hold-reg-empty interrupt
509  */
510 #define ALT_UART_IER_DLH_PTIME_DLH7_E_DISD 0x0
511 /*
512  * Enumerated value for register field ALT_UART_IER_DLH_PTIME_DLH7
513  *
514  * enable tx-hold-reg-empty interrupt
515  */
516 #define ALT_UART_IER_DLH_PTIME_DLH7_E_END 0x1
517
518 /* The Least Significant Bit (LSB) position of the ALT_UART_IER_DLH_PTIME_DLH7 register field. */
519 #define ALT_UART_IER_DLH_PTIME_DLH7_LSB 7
520 /* The Most Significant Bit (MSB) position of the ALT_UART_IER_DLH_PTIME_DLH7 register field. */
521 #define ALT_UART_IER_DLH_PTIME_DLH7_MSB 7
522 /* The width in bits of the ALT_UART_IER_DLH_PTIME_DLH7 register field. */
523 #define ALT_UART_IER_DLH_PTIME_DLH7_WIDTH 1
524 /* The mask used to set the ALT_UART_IER_DLH_PTIME_DLH7 register field value. */
525 #define ALT_UART_IER_DLH_PTIME_DLH7_SET_MSK 0x00000080
526 /* The mask used to clear the ALT_UART_IER_DLH_PTIME_DLH7 register field value. */
527 #define ALT_UART_IER_DLH_PTIME_DLH7_CLR_MSK 0xffffff7f
528 /* The reset value of the ALT_UART_IER_DLH_PTIME_DLH7 register field. */
529 #define ALT_UART_IER_DLH_PTIME_DLH7_RESET 0x0
530 /* Extracts the ALT_UART_IER_DLH_PTIME_DLH7 field value from a register. */
531 #define ALT_UART_IER_DLH_PTIME_DLH7_GET(value) (((value) & 0x00000080) >> 7)
532 /* Produces a ALT_UART_IER_DLH_PTIME_DLH7 register field value suitable for setting the register. */
533 #define ALT_UART_IER_DLH_PTIME_DLH7_SET(value) (((value) << 7) & 0x00000080)
534
535 #ifndef __ASSEMBLY__
536 /*
537  * WARNING: The C register and register group struct declarations are provided for
538  * convenience and illustrative purposes. They should, however, be used with
539  * caution as the C language standard provides no guarantees about the alignment or
540  * atomicity of device memory accesses. The recommended practice for writing
541  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
542  * alt_write_word() functions.
543  *
544  * The struct declaration for register ALT_UART_IER_DLH.
545  */
547 {
548  uint32_t erbfi_dlh0 : 1; /* DLH[0] and Receive Data Interrupt Enable */
549  uint32_t etbei_dlhl : 1; /* DLH[1] and Transmit Data Interrupt Control */
550  uint32_t elsi_dhl2 : 1; /* DLH[2] and Enable Receiver Line Status */
551  uint32_t edssi_dhl3 : 1; /* DLH[3] and Enable Modem Status Interrupt */
552  uint32_t dlh4 : 1; /* DLH[4] */
553  uint32_t dlh5 : 1; /* DLH[5] */
554  uint32_t dlh6 : 1; /* DLH[6] */
555  uint32_t ptime_dlh7 : 1; /* DLH[7] and PTIME THRE Interrupt Mode Enable */
556  uint32_t : 24; /* *UNDEFINED* */
557 };
558
559 /* The typedef declaration for register ALT_UART_IER_DLH. */
560 typedef volatile struct ALT_UART_IER_DLH_s ALT_UART_IER_DLH_t;
561 #endif /* __ASSEMBLY__ */
562
563 /* The byte offset of the ALT_UART_IER_DLH register from the beginning of the component. */
564 #define ALT_UART_IER_DLH_OFST 0x4
565 /* The address of the ALT_UART_IER_DLH register. */
566 #define ALT_UART_IER_DLH_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_IER_DLH_OFST))
567
568 /*
569  * Register : Interrupt Identity Register (when read) - iir
570  *
571  * Returns interrupt identification and FIFO enable/disable when read.
572  *
573  * Register Layout
574  *
575  * Bits | Access | Reset | Description
576  * :-------|:-------|:------|:-------------
577  * [3:0] | R | 0x1 | Interrupt ID
578  * [5:4] | ??? | 0x0 | *UNDEFINED*
579  * [7:6] | R | 0x0 | FIFO Enabled
580  * [31:8] | ??? | 0x0 | *UNDEFINED*
581  *
582  */
583 /*
584  * Field : Interrupt ID - id
585  *
586  * This indicates the highest priority pending interrupt.
587  *
588  * Field Enumeration Values:
589  *
590  * Enum | Value | Description
591  * :---------------------------------|:------|:-----------------------
592  * ALT_UART_IIR_ID_E_MODMSTAT | 0x0 | Modem status
593  * ALT_UART_IIR_ID_E_NOINTRPENDING | 0x1 | No Interrupt pending
594  * ALT_UART_IIR_ID_E_THREMPTY | 0x2 | THR empty
595  * ALT_UART_IIR_ID_E_RXDATAVAILABLE | 0x4 | Receive data available
596  * ALT_UART_IIR_ID_E_RXLINESTAT | 0x6 | Receive line status
597  * ALT_UART_IIR_ID_E_CHARTMO | 0xc | Character timeout
598  *
599  * Field Access Macros:
600  *
601  */
602 /*
603  * Enumerated value for register field ALT_UART_IIR_ID
604  *
605  * Modem status
606  */
607 #define ALT_UART_IIR_ID_E_MODMSTAT 0x0
608 /*
609  * Enumerated value for register field ALT_UART_IIR_ID
610  *
611  * No Interrupt pending
612  */
613 #define ALT_UART_IIR_ID_E_NOINTRPENDING 0x1
614 /*
615  * Enumerated value for register field ALT_UART_IIR_ID
616  *
617  * THR empty
618  */
619 #define ALT_UART_IIR_ID_E_THREMPTY 0x2
620 /*
621  * Enumerated value for register field ALT_UART_IIR_ID
622  *
623  * Receive data available
624  */
625 #define ALT_UART_IIR_ID_E_RXDATAVAILABLE 0x4
626 /*
627  * Enumerated value for register field ALT_UART_IIR_ID
628  *
629  * Receive line status
630  */
631 #define ALT_UART_IIR_ID_E_RXLINESTAT 0x6
632 /*
633  * Enumerated value for register field ALT_UART_IIR_ID
634  *
635  * Character timeout
636  */
637 #define ALT_UART_IIR_ID_E_CHARTMO 0xc
638
639 /* The Least Significant Bit (LSB) position of the ALT_UART_IIR_ID register field. */
640 #define ALT_UART_IIR_ID_LSB 0
641 /* The Most Significant Bit (MSB) position of the ALT_UART_IIR_ID register field. */
642 #define ALT_UART_IIR_ID_MSB 3
643 /* The width in bits of the ALT_UART_IIR_ID register field. */
644 #define ALT_UART_IIR_ID_WIDTH 4
645 /* The mask used to set the ALT_UART_IIR_ID register field value. */
646 #define ALT_UART_IIR_ID_SET_MSK 0x0000000f
647 /* The mask used to clear the ALT_UART_IIR_ID register field value. */
648 #define ALT_UART_IIR_ID_CLR_MSK 0xfffffff0
649 /* The reset value of the ALT_UART_IIR_ID register field. */
650 #define ALT_UART_IIR_ID_RESET 0x1
651 /* Extracts the ALT_UART_IIR_ID field value from a register. */
652 #define ALT_UART_IIR_ID_GET(value) (((value) & 0x0000000f) >> 0)
653 /* Produces a ALT_UART_IIR_ID register field value suitable for setting the register. */
654 #define ALT_UART_IIR_ID_SET(value) (((value) << 0) & 0x0000000f)
655
656 /*
657  * Field : FIFO Enabled - fifoen
658  *
659  * This is used to indicate whether the FIFO's are enabled or disabled.
660  *
661  * Field Enumeration Values:
662  *
663  * Enum | Value | Description
664  * :---------------------------|:------|:--------------
665  * ALT_UART_IIR_FIFOEN_E_DISD | 0x0 | FIFO disabled
666  * ALT_UART_IIR_FIFOEN_E_END | 0x3 | FIFO enabled
667  *
668  * Field Access Macros:
669  *
670  */
671 /*
672  * Enumerated value for register field ALT_UART_IIR_FIFOEN
673  *
674  * FIFO disabled
675  */
676 #define ALT_UART_IIR_FIFOEN_E_DISD 0x0
677 /*
678  * Enumerated value for register field ALT_UART_IIR_FIFOEN
679  *
680  * FIFO enabled
681  */
682 #define ALT_UART_IIR_FIFOEN_E_END 0x3
683
684 /* The Least Significant Bit (LSB) position of the ALT_UART_IIR_FIFOEN register field. */
685 #define ALT_UART_IIR_FIFOEN_LSB 6
686 /* The Most Significant Bit (MSB) position of the ALT_UART_IIR_FIFOEN register field. */
687 #define ALT_UART_IIR_FIFOEN_MSB 7
688 /* The width in bits of the ALT_UART_IIR_FIFOEN register field. */
689 #define ALT_UART_IIR_FIFOEN_WIDTH 2
690 /* The mask used to set the ALT_UART_IIR_FIFOEN register field value. */
691 #define ALT_UART_IIR_FIFOEN_SET_MSK 0x000000c0
692 /* The mask used to clear the ALT_UART_IIR_FIFOEN register field value. */
693 #define ALT_UART_IIR_FIFOEN_CLR_MSK 0xffffff3f
694 /* The reset value of the ALT_UART_IIR_FIFOEN register field. */
695 #define ALT_UART_IIR_FIFOEN_RESET 0x0
696 /* Extracts the ALT_UART_IIR_FIFOEN field value from a register. */
697 #define ALT_UART_IIR_FIFOEN_GET(value) (((value) & 0x000000c0) >> 6)
698 /* Produces a ALT_UART_IIR_FIFOEN register field value suitable for setting the register. */
699 #define ALT_UART_IIR_FIFOEN_SET(value) (((value) << 6) & 0x000000c0)
700
701 #ifndef __ASSEMBLY__
702 /*
703  * WARNING: The C register and register group struct declarations are provided for
704  * convenience and illustrative purposes. They should, however, be used with
705  * caution as the C language standard provides no guarantees about the alignment or
706  * atomicity of device memory accesses. The recommended practice for writing
707  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
708  * alt_write_word() functions.
709  *
710  * The struct declaration for register ALT_UART_IIR.
711  */
713 {
714  const uint32_t id : 4; /* Interrupt ID */
715  uint32_t : 2; /* *UNDEFINED* */
716  const uint32_t fifoen : 2; /* FIFO Enabled */
717  uint32_t : 24; /* *UNDEFINED* */
718 };
719
720 /* The typedef declaration for register ALT_UART_IIR. */
721 typedef volatile struct ALT_UART_IIR_s ALT_UART_IIR_t;
722 #endif /* __ASSEMBLY__ */
723
724 /* The byte offset of the ALT_UART_IIR register from the beginning of the component. */
725 #define ALT_UART_IIR_OFST 0x8
726 /* The address of the ALT_UART_IIR register. */
727 #define ALT_UART_IIR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_IIR_OFST))
728
729 /*
730  * Register : FIFO Control (when written) - fcr
731  *
732  * Controls FIFO Operations when written.
733  *
734  * Register Layout
735  *
736  * Bits | Access | Reset | Description
737  * :-------|:-------|:--------|:-----------------------
738  * [0] | W | Unknown | FIFO Enable
739  * [1] | W | Unknown | Rx FIFO Reset
740  * [2] | W | Unknown | Tx FIFO Reset
741  * [3] | W | Unknown | DMA Mode
742  * [5:4] | W | Unknown | Tx Empty Trigger Level
743  * [7:6] | W | Unknown | Rx Trigger Level
744  * [31:8] | ??? | 0x0 | *UNDEFINED*
745  *
746  */
747 /*
748  * Field : FIFO Enable - fifoe
749  *
750  * Enables/disables the transmit (Tx) and receive (Rx ) FIFO's. Whenever the value
751  * of this bit is changed both the Tx and Rx controller portion of FIFO's will be
752  * reset.
753  *
754  * Field Enumeration Values:
755  *
756  * Enum | Value | Description
757  * :--------------------------|:------|:---------------
758  * ALT_UART_FCR_FIFOE_E_DISD | 0x0 | FIFOs disabled
759  * ALT_UART_FCR_FIFOE_E_END | 0x1 | FIFOs enabled
760  *
761  * Field Access Macros:
762  *
763  */
764 /*
765  * Enumerated value for register field ALT_UART_FCR_FIFOE
766  *
767  * FIFOs disabled
768  */
769 #define ALT_UART_FCR_FIFOE_E_DISD 0x0
770 /*
771  * Enumerated value for register field ALT_UART_FCR_FIFOE
772  *
773  * FIFOs enabled
774  */
775 #define ALT_UART_FCR_FIFOE_E_END 0x1
776
777 /* The Least Significant Bit (LSB) position of the ALT_UART_FCR_FIFOE register field. */
778 #define ALT_UART_FCR_FIFOE_LSB 0
779 /* The Most Significant Bit (MSB) position of the ALT_UART_FCR_FIFOE register field. */
780 #define ALT_UART_FCR_FIFOE_MSB 0
781 /* The width in bits of the ALT_UART_FCR_FIFOE register field. */
782 #define ALT_UART_FCR_FIFOE_WIDTH 1
783 /* The mask used to set the ALT_UART_FCR_FIFOE register field value. */
784 #define ALT_UART_FCR_FIFOE_SET_MSK 0x00000001
785 /* The mask used to clear the ALT_UART_FCR_FIFOE register field value. */
786 #define ALT_UART_FCR_FIFOE_CLR_MSK 0xfffffffe
787 /* The reset value of the ALT_UART_FCR_FIFOE register field is UNKNOWN. */
788 #define ALT_UART_FCR_FIFOE_RESET 0x0
789 /* Extracts the ALT_UART_FCR_FIFOE field value from a register. */
790 #define ALT_UART_FCR_FIFOE_GET(value) (((value) & 0x00000001) >> 0)
791 /* Produces a ALT_UART_FCR_FIFOE register field value suitable for setting the register. */
792 #define ALT_UART_FCR_FIFOE_SET(value) (((value) << 0) & 0x00000001)
793
794 /*
795  * Field : Rx FIFO Reset - rfifor
796  *
797  * Resets the control portion of the receive FIFO and treats the FIFO as empty.
798  * This will also de-assert the DMA Rxrequest and single signals. Note that this
799  * bit is self-clearing' and it is not necessary to clear this bit.
800  *
801  * Field Enumeration Values:
802  *
803  * Enum | Value | Description
804  * :----------------------------|:------|:----------------------------
805  * ALT_UART_FCR_RFIFOR_E_NORST | 0x0 | No Reset of Rx FIFO Control
806  * ALT_UART_FCR_RFIFOR_E_RST | 0x1 | Resets of Rx FIFO Control
807  *
808  * Field Access Macros:
809  *
810  */
811 /*
812  * Enumerated value for register field ALT_UART_FCR_RFIFOR
813  *
814  * No Reset of Rx FIFO Control
815  */
816 #define ALT_UART_FCR_RFIFOR_E_NORST 0x0
817 /*
818  * Enumerated value for register field ALT_UART_FCR_RFIFOR
819  *
820  * Resets of Rx FIFO Control
821  */
822 #define ALT_UART_FCR_RFIFOR_E_RST 0x1
823
824 /* The Least Significant Bit (LSB) position of the ALT_UART_FCR_RFIFOR register field. */
825 #define ALT_UART_FCR_RFIFOR_LSB 1
826 /* The Most Significant Bit (MSB) position of the ALT_UART_FCR_RFIFOR register field. */
827 #define ALT_UART_FCR_RFIFOR_MSB 1
828 /* The width in bits of the ALT_UART_FCR_RFIFOR register field. */
829 #define ALT_UART_FCR_RFIFOR_WIDTH 1
830 /* The mask used to set the ALT_UART_FCR_RFIFOR register field value. */
831 #define ALT_UART_FCR_RFIFOR_SET_MSK 0x00000002
832 /* The mask used to clear the ALT_UART_FCR_RFIFOR register field value. */
833 #define ALT_UART_FCR_RFIFOR_CLR_MSK 0xfffffffd
834 /* The reset value of the ALT_UART_FCR_RFIFOR register field is UNKNOWN. */
835 #define ALT_UART_FCR_RFIFOR_RESET 0x0
836 /* Extracts the ALT_UART_FCR_RFIFOR field value from a register. */
837 #define ALT_UART_FCR_RFIFOR_GET(value) (((value) & 0x00000002) >> 1)
838 /* Produces a ALT_UART_FCR_RFIFOR register field value suitable for setting the register. */
839 #define ALT_UART_FCR_RFIFOR_SET(value) (((value) << 1) & 0x00000002)
840
841 /*
842  * Field : Tx FIFO Reset - xfifor
843  *
844  * Resets the control portion of the transmit FIFO and treats the FIFO as empty.
845  * This will also de-assert the DMA Tx request and single signals when additional
846  * DMA handshaking is used.
847  *
848  * Note that this bit is 'self-clearing' and it is not necessary to clear this bit.
849  *
850  * Field Enumeration Values:
851  *
852  * Enum | Value | Description
853  * :----------------------------|:------|:----------------------------
854  * ALT_UART_FCR_XFIFOR_E_NORST | 0x0 | No Reset of Tx FIFO Control
855  * ALT_UART_FCR_XFIFOR_E_RST | 0x1 | Resets Tx FIFO Control
856  *
857  * Field Access Macros:
858  *
859  */
860 /*
861  * Enumerated value for register field ALT_UART_FCR_XFIFOR
862  *
863  * No Reset of Tx FIFO Control
864  */
865 #define ALT_UART_FCR_XFIFOR_E_NORST 0x0
866 /*
867  * Enumerated value for register field ALT_UART_FCR_XFIFOR
868  *
869  * Resets Tx FIFO Control
870  */
871 #define ALT_UART_FCR_XFIFOR_E_RST 0x1
872
873 /* The Least Significant Bit (LSB) position of the ALT_UART_FCR_XFIFOR register field. */
874 #define ALT_UART_FCR_XFIFOR_LSB 2
875 /* The Most Significant Bit (MSB) position of the ALT_UART_FCR_XFIFOR register field. */
876 #define ALT_UART_FCR_XFIFOR_MSB 2
877 /* The width in bits of the ALT_UART_FCR_XFIFOR register field. */
878 #define ALT_UART_FCR_XFIFOR_WIDTH 1
879 /* The mask used to set the ALT_UART_FCR_XFIFOR register field value. */
880 #define ALT_UART_FCR_XFIFOR_SET_MSK 0x00000004
881 /* The mask used to clear the ALT_UART_FCR_XFIFOR register field value. */
882 #define ALT_UART_FCR_XFIFOR_CLR_MSK 0xfffffffb
883 /* The reset value of the ALT_UART_FCR_XFIFOR register field is UNKNOWN. */
884 #define ALT_UART_FCR_XFIFOR_RESET 0x0
885 /* Extracts the ALT_UART_FCR_XFIFOR field value from a register. */
886 #define ALT_UART_FCR_XFIFOR_GET(value) (((value) & 0x00000004) >> 2)
887 /* Produces a ALT_UART_FCR_XFIFOR register field value suitable for setting the register. */
888 #define ALT_UART_FCR_XFIFOR_SET(value) (((value) << 2) & 0x00000004)
889
890 /*
891  * Field : DMA Mode - dmam
892  *
893  * This determines the DMA signalling mode used for the uart_dma_tx_req_n and
894  * uart_dma_rx_req_n output signals when additional DMA handshaking signals are not
895  * selected. DMA mode 0 supports single DMA data transfers at a time. In mode 0,
896  * the uart_dma_tx_req_n signal goes active low under the following conditions:
897  *
898  * * When the Transmitter Holding Register is empty in non-FIFO mode.
899  *
900  * * When the transmitter FIFO is empty in FIFO mode with Programmable THRE
901  * interrupt mode disabled.
902  *
903  * * When the transmitter FIFO is at or below the programmed threshold with
904  * Programmable THRE interrupt mode enabled.
905  *
906  * It goes inactive under the following conditions
907  *
908  * * When a single character has been written into the Transmitter Holding
909  * Register or transmitter FIFO with Programmable THRE interrupt mode disabled.
910  *
911  * * When the transmitter FIFO is above the threshold with Programmable THRE
912  * interrupt mode enabled.
913  *
914  * DMA mode 1 supports multi-DMA data transfers, where multiple transfers are made
915  * continuously until the receiver FIFO has been emptied or the transmit FIFO has
916  * been filled. In mode 1 the uart_dma_tx_req_n signal is asserted under the
917  * following conditions:
918  *
919  * * When the transmitter FIFO is empty with Programmable THRE interrupt mode
920  * disabled.
921  *
922  * * When the transmitter FIFO is at or below the programmed threshold with
923  * Programmable THRE interrupt mode enabled.
924  *
925  * Field Enumeration Values:
926  *
927  * Enum | Value | Description
928  * :---------------------------|:------|:---------------------------
929  * ALT_UART_FCR_DMAM_E_SINGLE | 0x0 | Single DMA Transfer Mode
930  * ALT_UART_FCR_DMAM_E_MULT | 0x1 | Multiple DMA Transfer Mode
931  *
932  * Field Access Macros:
933  *
934  */
935 /*
936  * Enumerated value for register field ALT_UART_FCR_DMAM
937  *
938  * Single DMA Transfer Mode
939  */
940 #define ALT_UART_FCR_DMAM_E_SINGLE 0x0
941 /*
942  * Enumerated value for register field ALT_UART_FCR_DMAM
943  *
944  * Multiple DMA Transfer Mode
945  */
946 #define ALT_UART_FCR_DMAM_E_MULT 0x1
947
948 /* The Least Significant Bit (LSB) position of the ALT_UART_FCR_DMAM register field. */
949 #define ALT_UART_FCR_DMAM_LSB 3
950 /* The Most Significant Bit (MSB) position of the ALT_UART_FCR_DMAM register field. */
951 #define ALT_UART_FCR_DMAM_MSB 3
952 /* The width in bits of the ALT_UART_FCR_DMAM register field. */
953 #define ALT_UART_FCR_DMAM_WIDTH 1
954 /* The mask used to set the ALT_UART_FCR_DMAM register field value. */
955 #define ALT_UART_FCR_DMAM_SET_MSK 0x00000008
956 /* The mask used to clear the ALT_UART_FCR_DMAM register field value. */
957 #define ALT_UART_FCR_DMAM_CLR_MSK 0xfffffff7
958 /* The reset value of the ALT_UART_FCR_DMAM register field is UNKNOWN. */
959 #define ALT_UART_FCR_DMAM_RESET 0x0
960 /* Extracts the ALT_UART_FCR_DMAM field value from a register. */
961 #define ALT_UART_FCR_DMAM_GET(value) (((value) & 0x00000008) >> 3)
962 /* Produces a ALT_UART_FCR_DMAM register field value suitable for setting the register. */
963 #define ALT_UART_FCR_DMAM_SET(value) (((value) << 3) & 0x00000008)
964
965 /*
966  * Field : Tx Empty Trigger Level - tet
967  *
968  * This is used to select the empty threshold level at which the THRE Interrupts
969  * will be generated when the mode is active. It also determines when the uart DMA
970  * transmit request signal uart_dma_tx_req_n will be asserted when in certain modes
971  * of operation.
972  *
973  * Field Enumeration Values:
974  *
975  * Enum | Value | Description
976  * :-------------------------------|:------|:-----------------------
977  * ALT_UART_FCR_TET_E_FIFOEMPTY | 0x0 | FIFO empty
978  * ALT_UART_FCR_TET_E_TWOCHARS | 0x1 | Two characters in FIFO
979  * ALT_UART_FCR_TET_E_QUARTERFULL | 0x2 | FIFO 1/4 full
980  * ALT_UART_FCR_TET_E_HALFFULL | 0x3 | FIFO 1/2 full
981  *
982  * Field Access Macros:
983  *
984  */
985 /*
986  * Enumerated value for register field ALT_UART_FCR_TET
987  *
988  * FIFO empty
989  */
990 #define ALT_UART_FCR_TET_E_FIFOEMPTY 0x0
991 /*
992  * Enumerated value for register field ALT_UART_FCR_TET
993  *
994  * Two characters in FIFO
995  */
996 #define ALT_UART_FCR_TET_E_TWOCHARS 0x1
997 /*
998  * Enumerated value for register field ALT_UART_FCR_TET
999  *
1000  * FIFO 1/4 full
1001  */
1002 #define ALT_UART_FCR_TET_E_QUARTERFULL 0x2
1003 /*
1004  * Enumerated value for register field ALT_UART_FCR_TET
1005  *
1006  * FIFO 1/2 full
1007  */
1008 #define ALT_UART_FCR_TET_E_HALFFULL 0x3
1009
1010 /* The Least Significant Bit (LSB) position of the ALT_UART_FCR_TET register field. */
1011 #define ALT_UART_FCR_TET_LSB 4
1012 /* The Most Significant Bit (MSB) position of the ALT_UART_FCR_TET register field. */
1013 #define ALT_UART_FCR_TET_MSB 5
1014 /* The width in bits of the ALT_UART_FCR_TET register field. */
1015 #define ALT_UART_FCR_TET_WIDTH 2
1016 /* The mask used to set the ALT_UART_FCR_TET register field value. */
1017 #define ALT_UART_FCR_TET_SET_MSK 0x00000030
1018 /* The mask used to clear the ALT_UART_FCR_TET register field value. */
1019 #define ALT_UART_FCR_TET_CLR_MSK 0xffffffcf
1020 /* The reset value of the ALT_UART_FCR_TET register field is UNKNOWN. */
1021 #define ALT_UART_FCR_TET_RESET 0x0
1022 /* Extracts the ALT_UART_FCR_TET field value from a register. */
1023 #define ALT_UART_FCR_TET_GET(value) (((value) & 0x00000030) >> 4)
1024 /* Produces a ALT_UART_FCR_TET register field value suitable for setting the register. */
1025 #define ALT_UART_FCR_TET_SET(value) (((value) << 4) & 0x00000030)
1026
1027 /*
1028  * Field : Rx Trigger Level - rt
1029  *
1030  * This register is configured to implement FIFOs. Bits[7:6], Rx Trigger (or RT):
1031  * This is used to select the trigger level in the receiver FIFO at which the
1032  * Received Data Available Interrupt will be generated. In auto flow control mode
1033  * it is used to determine when the uart_rts_n signal will be de-asserted. It also
1034  * determines when the uart_dma_rx_req_n signal will be asserted when in certain
1035  * modes of operation.
1036  *
1037  * Field Enumeration Values:
1038  *
1039  * Enum | Value | Description
1040  * :------------------------------|:------|:----------------------
1041  * ALT_UART_FCR_RT_E_ONECHAR | 0x0 | one character in fifo
1042  * ALT_UART_FCR_RT_E_QUARTERFULL | 0x1 | FIFO 1/4 full
1043  * ALT_UART_FCR_RT_E_HALFFULL | 0x2 | FIFO 1/2 full
1044  * ALT_UART_FCR_RT_E_FULLLESS2 | 0x3 | FIFO 2 less than full
1045  *
1046  * Field Access Macros:
1047  *
1048  */
1049 /*
1050  * Enumerated value for register field ALT_UART_FCR_RT
1051  *
1052  * one character in fifo
1053  */
1054 #define ALT_UART_FCR_RT_E_ONECHAR 0x0
1055 /*
1056  * Enumerated value for register field ALT_UART_FCR_RT
1057  *
1058  * FIFO 1/4 full
1059  */
1060 #define ALT_UART_FCR_RT_E_QUARTERFULL 0x1
1061 /*
1062  * Enumerated value for register field ALT_UART_FCR_RT
1063  *
1064  * FIFO 1/2 full
1065  */
1066 #define ALT_UART_FCR_RT_E_HALFFULL 0x2
1067 /*
1068  * Enumerated value for register field ALT_UART_FCR_RT
1069  *
1070  * FIFO 2 less than full
1071  */
1072 #define ALT_UART_FCR_RT_E_FULLLESS2 0x3
1073
1074 /* The Least Significant Bit (LSB) position of the ALT_UART_FCR_RT register field. */
1075 #define ALT_UART_FCR_RT_LSB 6
1076 /* The Most Significant Bit (MSB) position of the ALT_UART_FCR_RT register field. */
1077 #define ALT_UART_FCR_RT_MSB 7
1078 /* The width in bits of the ALT_UART_FCR_RT register field. */
1079 #define ALT_UART_FCR_RT_WIDTH 2
1080 /* The mask used to set the ALT_UART_FCR_RT register field value. */
1081 #define ALT_UART_FCR_RT_SET_MSK 0x000000c0
1082 /* The mask used to clear the ALT_UART_FCR_RT register field value. */
1083 #define ALT_UART_FCR_RT_CLR_MSK 0xffffff3f
1084 /* The reset value of the ALT_UART_FCR_RT register field is UNKNOWN. */
1085 #define ALT_UART_FCR_RT_RESET 0x0
1086 /* Extracts the ALT_UART_FCR_RT field value from a register. */
1087 #define ALT_UART_FCR_RT_GET(value) (((value) & 0x000000c0) >> 6)
1088 /* Produces a ALT_UART_FCR_RT register field value suitable for setting the register. */
1089 #define ALT_UART_FCR_RT_SET(value) (((value) << 6) & 0x000000c0)
1090
1091 #ifndef __ASSEMBLY__
1092 /*
1093  * WARNING: The C register and register group struct declarations are provided for
1094  * convenience and illustrative purposes. They should, however, be used with
1095  * caution as the C language standard provides no guarantees about the alignment or
1096  * atomicity of device memory accesses. The recommended practice for writing
1097  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1098  * alt_write_word() functions.
1099  *
1100  * The struct declaration for register ALT_UART_FCR.
1101  */
1103 {
1104  uint32_t fifoe : 1; /* FIFO Enable */
1105  uint32_t rfifor : 1; /* Rx FIFO Reset */
1106  uint32_t xfifor : 1; /* Tx FIFO Reset */
1107  uint32_t dmam : 1; /* DMA Mode */
1108  uint32_t tet : 2; /* Tx Empty Trigger Level */
1109  uint32_t rt : 2; /* Rx Trigger Level */
1110  uint32_t : 24; /* *UNDEFINED* */
1111 };
1112
1113 /* The typedef declaration for register ALT_UART_FCR. */
1114 typedef volatile struct ALT_UART_FCR_s ALT_UART_FCR_t;
1115 #endif /* __ASSEMBLY__ */
1116
1117 /* The byte offset of the ALT_UART_FCR register from the beginning of the component. */
1118 #define ALT_UART_FCR_OFST 0x8
1119 /* The address of the ALT_UART_FCR register. */
1120 #define ALT_UART_FCR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_FCR_OFST))
1121
1122 /*
1123  * Register : Line Control Register (When Written) - lcr
1124  *
1125  * Formats serial data.
1126  *
1127  * Register Layout
1128  *
1129  * Bits | Access | Reset | Description
1130  * :-------|:-------|:------|:-------------------------
1131  * [1:0] | RW | 0x0 | Data Length Select
1132  * [2] | RW | 0x0 | Stop Bits
1133  * [3] | RW | 0x0 | Parity Enable
1134  * [4] | RW | 0x0 | Even Parity Select
1135  * [5] | ??? | 0x0 | *UNDEFINED*
1136  * [6] | RW | 0x0 | Break Control Bit
1137  * [7] | RW | 0x0 | Divisor Latch Access Bit
1138  * [31:8] | ??? | 0x0 | *UNDEFINED*
1139  *
1140  */
1141 /*
1142  * Field : Data Length Select - dls
1143  *
1144  * Data Length Select.Selects the number of data bits per character that the
1145  * peripheral will transmit and receive.
1146  *
1147  * Field Enumeration Values:
1148  *
1149  * Enum | Value | Description
1150  * :------------------------|:------|:------------
1151  * ALT_UART_LCR_DLS_E_LEN5 | 0x0 | 5 bits
1152  * ALT_UART_LCR_DLS_E_LEN6 | 0x1 | 6 bits
1153  * ALT_UART_LCR_DLS_E_LEN7 | 0x2 | 7 bits
1154  * ALT_UART_LCR_DLS_E_LEN8 | 0x3 | 8 bits
1155  *
1156  * Field Access Macros:
1157  *
1158  */
1159 /*
1160  * Enumerated value for register field ALT_UART_LCR_DLS
1161  *
1162  * 5 bits
1163  */
1164 #define ALT_UART_LCR_DLS_E_LEN5 0x0
1165 /*
1166  * Enumerated value for register field ALT_UART_LCR_DLS
1167  *
1168  * 6 bits
1169  */
1170 #define ALT_UART_LCR_DLS_E_LEN6 0x1
1171 /*
1172  * Enumerated value for register field ALT_UART_LCR_DLS
1173  *
1174  * 7 bits
1175  */
1176 #define ALT_UART_LCR_DLS_E_LEN7 0x2
1177 /*
1178  * Enumerated value for register field ALT_UART_LCR_DLS
1179  *
1180  * 8 bits
1181  */
1182 #define ALT_UART_LCR_DLS_E_LEN8 0x3
1183
1184 /* The Least Significant Bit (LSB) position of the ALT_UART_LCR_DLS register field. */
1185 #define ALT_UART_LCR_DLS_LSB 0
1186 /* The Most Significant Bit (MSB) position of the ALT_UART_LCR_DLS register field. */
1187 #define ALT_UART_LCR_DLS_MSB 1
1188 /* The width in bits of the ALT_UART_LCR_DLS register field. */
1189 #define ALT_UART_LCR_DLS_WIDTH 2
1190 /* The mask used to set the ALT_UART_LCR_DLS register field value. */
1191 #define ALT_UART_LCR_DLS_SET_MSK 0x00000003
1192 /* The mask used to clear the ALT_UART_LCR_DLS register field value. */
1193 #define ALT_UART_LCR_DLS_CLR_MSK 0xfffffffc
1194 /* The reset value of the ALT_UART_LCR_DLS register field. */
1195 #define ALT_UART_LCR_DLS_RESET 0x0
1196 /* Extracts the ALT_UART_LCR_DLS field value from a register. */
1197 #define ALT_UART_LCR_DLS_GET(value) (((value) & 0x00000003) >> 0)
1198 /* Produces a ALT_UART_LCR_DLS register field value suitable for setting the register. */
1199 #define ALT_UART_LCR_DLS_SET(value) (((value) << 0) & 0x00000003)
1200
1201 /*
1202  * Field : Stop Bits - stop
1203  *
1204  * Number of stop bits. Used to select the number of stop bits per character that
1205  * the peripheral will transmit and receive.Note that regardless of the number of
1206  * stop bits selected the receiver will only check the first stop bit.
1207  *
1208  * Field Enumeration Values:
1209  *
1210  * Enum | Value | Description
1211  * :----------------------------------|:------|:------------------------------------------
1212  * ALT_UART_LCR_STOP_E_ONESTOP | 0x0 | one stop bit
1213  * ALT_UART_LCR_STOP_E_ONEPOINT5STOP | 0x1 | 1.5 stop bits when DLS (LCR[1:0]) is zero
1214  *
1215  * Field Access Macros:
1216  *
1217  */
1218 /*
1219  * Enumerated value for register field ALT_UART_LCR_STOP
1220  *
1221  * one stop bit
1222  */
1223 #define ALT_UART_LCR_STOP_E_ONESTOP 0x0
1224 /*
1225  * Enumerated value for register field ALT_UART_LCR_STOP
1226  *
1227  * 1.5 stop bits when DLS (LCR[1:0]) is zero
1228  */
1229 #define ALT_UART_LCR_STOP_E_ONEPOINT5STOP 0x1
1230
1231 /* The Least Significant Bit (LSB) position of the ALT_UART_LCR_STOP register field. */
1232 #define ALT_UART_LCR_STOP_LSB 2
1233 /* The Most Significant Bit (MSB) position of the ALT_UART_LCR_STOP register field. */
1234 #define ALT_UART_LCR_STOP_MSB 2
1235 /* The width in bits of the ALT_UART_LCR_STOP register field. */
1236 #define ALT_UART_LCR_STOP_WIDTH 1
1237 /* The mask used to set the ALT_UART_LCR_STOP register field value. */
1238 #define ALT_UART_LCR_STOP_SET_MSK 0x00000004
1239 /* The mask used to clear the ALT_UART_LCR_STOP register field value. */
1240 #define ALT_UART_LCR_STOP_CLR_MSK 0xfffffffb
1241 /* The reset value of the ALT_UART_LCR_STOP register field. */
1242 #define ALT_UART_LCR_STOP_RESET 0x0
1243 /* Extracts the ALT_UART_LCR_STOP field value from a register. */
1244 #define ALT_UART_LCR_STOP_GET(value) (((value) & 0x00000004) >> 2)
1245 /* Produces a ALT_UART_LCR_STOP register field value suitable for setting the register. */
1246 #define ALT_UART_LCR_STOP_SET(value) (((value) << 2) & 0x00000004)
1247
1248 /*
1249  * Field : Parity Enable - pen
1250  *
1251  * This bit is used to enable and disable parity generation and detection in a
1252  * transmitted and received data character.
1253  *
1254  * Field Enumeration Values:
1255  *
1256  * Enum | Value | Description
1257  * :------------------------|:------|:----------------
1258  * ALT_UART_LCR_PEN_E_DISD | 0x0 | parity disabled
1259  * ALT_UART_LCR_PEN_E_END | 0x1 | parity enabled
1260  *
1261  * Field Access Macros:
1262  *
1263  */
1264 /*
1265  * Enumerated value for register field ALT_UART_LCR_PEN
1266  *
1267  * parity disabled
1268  */
1269 #define ALT_UART_LCR_PEN_E_DISD 0x0
1270 /*
1271  * Enumerated value for register field ALT_UART_LCR_PEN
1272  *
1273  * parity enabled
1274  */
1275 #define ALT_UART_LCR_PEN_E_END 0x1
1276
1277 /* The Least Significant Bit (LSB) position of the ALT_UART_LCR_PEN register field. */
1278 #define ALT_UART_LCR_PEN_LSB 3
1279 /* The Most Significant Bit (MSB) position of the ALT_UART_LCR_PEN register field. */
1280 #define ALT_UART_LCR_PEN_MSB 3
1281 /* The width in bits of the ALT_UART_LCR_PEN register field. */
1282 #define ALT_UART_LCR_PEN_WIDTH 1
1283 /* The mask used to set the ALT_UART_LCR_PEN register field value. */
1284 #define ALT_UART_LCR_PEN_SET_MSK 0x00000008
1285 /* The mask used to clear the ALT_UART_LCR_PEN register field value. */
1286 #define ALT_UART_LCR_PEN_CLR_MSK 0xfffffff7
1287 /* The reset value of the ALT_UART_LCR_PEN register field. */
1288 #define ALT_UART_LCR_PEN_RESET 0x0
1289 /* Extracts the ALT_UART_LCR_PEN field value from a register. */
1290 #define ALT_UART_LCR_PEN_GET(value) (((value) & 0x00000008) >> 3)
1291 /* Produces a ALT_UART_LCR_PEN register field value suitable for setting the register. */
1292 #define ALT_UART_LCR_PEN_SET(value) (((value) << 3) & 0x00000008)
1293
1294 /*
1295  * Field : Even Parity Select - eps
1296  *
1297  * This is used to select between even and odd parity, when parity is enabled (PEN
1298  * set to one). If set to one, an even number of logic '1's is transmitted or
1299  * checked. If set to zero, an odd number of logic '1's is transmitted or checked.
1300  *
1301  * Field Enumeration Values:
1302  *
1303  * Enum | Value | Description
1304  * :---------------------------|:------|:------------
1305  * ALT_UART_LCR_EPS_E_ODDPAR | 0x0 | odd parity
1306  * ALT_UART_LCR_EPS_E_EVENPAR | 0x1 | even parity
1307  *
1308  * Field Access Macros:
1309  *
1310  */
1311 /*
1312  * Enumerated value for register field ALT_UART_LCR_EPS
1313  *
1314  * odd parity
1315  */
1316 #define ALT_UART_LCR_EPS_E_ODDPAR 0x0
1317 /*
1318  * Enumerated value for register field ALT_UART_LCR_EPS
1319  *
1320  * even parity
1321  */
1322 #define ALT_UART_LCR_EPS_E_EVENPAR 0x1
1323
1324 /* The Least Significant Bit (LSB) position of the ALT_UART_LCR_EPS register field. */
1325 #define ALT_UART_LCR_EPS_LSB 4
1326 /* The Most Significant Bit (MSB) position of the ALT_UART_LCR_EPS register field. */
1327 #define ALT_UART_LCR_EPS_MSB 4
1328 /* The width in bits of the ALT_UART_LCR_EPS register field. */
1329 #define ALT_UART_LCR_EPS_WIDTH 1
1330 /* The mask used to set the ALT_UART_LCR_EPS register field value. */
1331 #define ALT_UART_LCR_EPS_SET_MSK 0x00000010
1332 /* The mask used to clear the ALT_UART_LCR_EPS register field value. */
1333 #define ALT_UART_LCR_EPS_CLR_MSK 0xffffffef
1334 /* The reset value of the ALT_UART_LCR_EPS register field. */
1335 #define ALT_UART_LCR_EPS_RESET 0x0
1336 /* Extracts the ALT_UART_LCR_EPS field value from a register. */
1337 #define ALT_UART_LCR_EPS_GET(value) (((value) & 0x00000010) >> 4)
1338 /* Produces a ALT_UART_LCR_EPS register field value suitable for setting the register. */
1339 #define ALT_UART_LCR_EPS_SET(value) (((value) << 4) & 0x00000010)
1340
1341 /*
1342  * Field : Break Control Bit - break
1343  *
1344  * This is used to cause a break condition to be transmitted to the receiving
1345  * device. If set to one the serial output is forced to the spacing (logic 0)
1346  * state. When not in Loopback Mode, as determined by MCR[4], the sout line is
1347  * forced low until the Break bit is cleared. When in Loopback Mode, the break
1348  * condition is internally looped back to the receiver and the sir_out_n line is
1349  * forced low.
1350  *
1351  * Field Access Macros:
1352  *
1353  */
1354 /* The Least Significant Bit (LSB) position of the ALT_UART_LCR_BREAK register field. */
1355 #define ALT_UART_LCR_BREAK_LSB 6
1356 /* The Most Significant Bit (MSB) position of the ALT_UART_LCR_BREAK register field. */
1357 #define ALT_UART_LCR_BREAK_MSB 6
1358 /* The width in bits of the ALT_UART_LCR_BREAK register field. */
1359 #define ALT_UART_LCR_BREAK_WIDTH 1
1360 /* The mask used to set the ALT_UART_LCR_BREAK register field value. */
1361 #define ALT_UART_LCR_BREAK_SET_MSK 0x00000040
1362 /* The mask used to clear the ALT_UART_LCR_BREAK register field value. */
1363 #define ALT_UART_LCR_BREAK_CLR_MSK 0xffffffbf
1364 /* The reset value of the ALT_UART_LCR_BREAK register field. */
1365 #define ALT_UART_LCR_BREAK_RESET 0x0
1366 /* Extracts the ALT_UART_LCR_BREAK field value from a register. */
1367 #define ALT_UART_LCR_BREAK_GET(value) (((value) & 0x00000040) >> 6)
1368 /* Produces a ALT_UART_LCR_BREAK register field value suitable for setting the register. */
1369 #define ALT_UART_LCR_BREAK_SET(value) (((value) << 6) & 0x00000040)
1370
1371 /*
1372  * Field : Divisor Latch Access Bit - dlab
1373  *
1374  * Used to enable reading and writing of the Divisor Latch register (DLL and DLH)
1375  * to set the baud rate of the UART. This bit must be cleared after initial baud
1376  * rate setup in order to access other registers.
1377  *
1378  * Field Access Macros:
1379  *
1380  */
1381 /* The Least Significant Bit (LSB) position of the ALT_UART_LCR_DLAB register field. */
1382 #define ALT_UART_LCR_DLAB_LSB 7
1383 /* The Most Significant Bit (MSB) position of the ALT_UART_LCR_DLAB register field. */
1384 #define ALT_UART_LCR_DLAB_MSB 7
1385 /* The width in bits of the ALT_UART_LCR_DLAB register field. */
1386 #define ALT_UART_LCR_DLAB_WIDTH 1
1387 /* The mask used to set the ALT_UART_LCR_DLAB register field value. */
1388 #define ALT_UART_LCR_DLAB_SET_MSK 0x00000080
1389 /* The mask used to clear the ALT_UART_LCR_DLAB register field value. */
1390 #define ALT_UART_LCR_DLAB_CLR_MSK 0xffffff7f
1391 /* The reset value of the ALT_UART_LCR_DLAB register field. */
1392 #define ALT_UART_LCR_DLAB_RESET 0x0
1393 /* Extracts the ALT_UART_LCR_DLAB field value from a register. */
1394 #define ALT_UART_LCR_DLAB_GET(value) (((value) & 0x00000080) >> 7)
1395 /* Produces a ALT_UART_LCR_DLAB register field value suitable for setting the register. */
1396 #define ALT_UART_LCR_DLAB_SET(value) (((value) << 7) & 0x00000080)
1397
1398 #ifndef __ASSEMBLY__
1399 /*
1400  * WARNING: The C register and register group struct declarations are provided for
1401  * convenience and illustrative purposes. They should, however, be used with
1402  * caution as the C language standard provides no guarantees about the alignment or
1403  * atomicity of device memory accesses. The recommended practice for writing
1404  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1405  * alt_write_word() functions.
1406  *
1407  * The struct declaration for register ALT_UART_LCR.
1408  */
1410 {
1411  uint32_t dls : 2; /* Data Length Select */
1412  uint32_t stop : 1; /* Stop Bits */
1413  uint32_t pen : 1; /* Parity Enable */
1414  uint32_t eps : 1; /* Even Parity Select */
1415  uint32_t : 1; /* *UNDEFINED* */
1416  uint32_t break_ : 1; /* Break Control Bit */
1417  uint32_t dlab : 1; /* Divisor Latch Access Bit */
1418  uint32_t : 24; /* *UNDEFINED* */
1419 };
1420
1421 /* The typedef declaration for register ALT_UART_LCR. */
1422 typedef volatile struct ALT_UART_LCR_s ALT_UART_LCR_t;
1423 #endif /* __ASSEMBLY__ */
1424
1425 /* The byte offset of the ALT_UART_LCR register from the beginning of the component. */
1426 #define ALT_UART_LCR_OFST 0xc
1427 /* The address of the ALT_UART_LCR register. */
1428 #define ALT_UART_LCR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_LCR_OFST))
1429
1430 /*
1431  * Register : Modem Control Register - mcr
1432  *
1433  * Reports various operations of the modem signals
1434  *
1435  * Register Layout
1436  *
1437  * Bits | Access | Reset | Description
1438  * :-------|:-------|:------|:-------------------------
1439  * [0] | RW | 0x0 | Data Terminal Ready
1440  * [1] | RW | 0x0 | Request to Send
1441  * [2] | RW | 0x0 | Out1
1442  * [3] | RW | 0x0 | out2
1443  * [4] | RW | 0x0 | LoopBack Bit
1444  * [5] | RW | 0x0 | Auto Flow Control Enable
1445  * [31:6] | ??? | 0x0 | *UNDEFINED*
1446  *
1447  */
1448 /*
1449  * Field : Data Terminal Ready - dtr
1450  *
1451  * This is used to directly control the Data Terminal Ready output. The value
1452  * written to this location is inverted and driven out on uart_dtr_n, that is: The
1453  * Data Terminal Ready output is used to inform the modem or data set that the UART
1454  * is ready to establish communications.
1455  *
1456  * Note that Loopback mode bit [4] of MCR is set to one, the uart_dtr_n output is
1457  * held inactive high while the value of this location is internally looped back
1458  * to an input.
1459  *
1460  * Field Enumeration Values:
1461  *
1462  * Enum | Value | Description
1463  * :--------------------------|:------|:---------------------------------
1464  * ALT_UART_MCR_DTR_E_LOGIC1 | 0x0 | uart_dtr_n de-asserted (logic 1)
1465  * ALT_UART_MCR_DTR_E_LOGIC0 | 0x1 | uart_dtr_n asserted (logic 0)
1466  *
1467  * Field Access Macros:
1468  *
1469  */
1470 /*
1471  * Enumerated value for register field ALT_UART_MCR_DTR
1472  *
1473  * uart_dtr_n de-asserted (logic 1)
1474  */
1475 #define ALT_UART_MCR_DTR_E_LOGIC1 0x0
1476 /*
1477  * Enumerated value for register field ALT_UART_MCR_DTR
1478  *
1479  * uart_dtr_n asserted (logic 0)
1480  */
1481 #define ALT_UART_MCR_DTR_E_LOGIC0 0x1
1482
1483 /* The Least Significant Bit (LSB) position of the ALT_UART_MCR_DTR register field. */
1484 #define ALT_UART_MCR_DTR_LSB 0
1485 /* The Most Significant Bit (MSB) position of the ALT_UART_MCR_DTR register field. */
1486 #define ALT_UART_MCR_DTR_MSB 0
1487 /* The width in bits of the ALT_UART_MCR_DTR register field. */
1488 #define ALT_UART_MCR_DTR_WIDTH 1
1489 /* The mask used to set the ALT_UART_MCR_DTR register field value. */
1490 #define ALT_UART_MCR_DTR_SET_MSK 0x00000001
1491 /* The mask used to clear the ALT_UART_MCR_DTR register field value. */
1492 #define ALT_UART_MCR_DTR_CLR_MSK 0xfffffffe
1493 /* The reset value of the ALT_UART_MCR_DTR register field. */
1494 #define ALT_UART_MCR_DTR_RESET 0x0
1495 /* Extracts the ALT_UART_MCR_DTR field value from a register. */
1496 #define ALT_UART_MCR_DTR_GET(value) (((value) & 0x00000001) >> 0)
1497 /* Produces a ALT_UART_MCR_DTR register field value suitable for setting the register. */
1498 #define ALT_UART_MCR_DTR_SET(value) (((value) << 0) & 0x00000001)
1499
1500 /*
1501  * Field : Request to Send - rts
1502  *
1503  * This is used to directly control the Request to Send (uart_rts_n) output. The
1504  * Request to Send (uart_rts_n) output is used to inform the modem or data set that
1505  * the UART is ready to exchange data. When Auto RTS Flow Control is not enabled
1506  * (MCR[5] set to zero), the uart_rts_n signal is set low by programming MCR[1]
1507  * (RTS) to a high. If Auto Flow Control is active (MCR[5] set to one) and FIFO's
1508  * enable (FCR[0] set to one), the uart_rts_n output is controlled in the same way,
1509  * but is also gated with the receiver FIFO threshold trigger (uart_rts_n is
1510  * inactive high when above the threshold). The uart_rts_n signal will be de-
1511  * asserted when MCR[1] is set low.
1512  *
1513  * Note that in Loopback mode (MCR[4] set to one), the uart_rts_n output is held
1514  * inactive high while the value of this location is internally looped back to an
1515  * input.
1516  *
1517  * Field Enumeration Values:
1518  *
1519  * Enum | Value | Description
1520  * :--------------------------|:------|:---------------------------------
1521  * ALT_UART_MCR_RTS_E_LOGIC1 | 0x0 | uart_rts_n de-asserted (logic 1)
1522  * ALT_UART_MCR_RTS_E_LOGIC0 | 0x1 | uart_rts_n asserted (logic 0)
1523  *
1524  * Field Access Macros:
1525  *
1526  */
1527 /*
1528  * Enumerated value for register field ALT_UART_MCR_RTS
1529  *
1530  * uart_rts_n de-asserted (logic 1)
1531  */
1532 #define ALT_UART_MCR_RTS_E_LOGIC1 0x0
1533 /*
1534  * Enumerated value for register field ALT_UART_MCR_RTS
1535  *
1536  * uart_rts_n asserted (logic 0)
1537  */
1538 #define ALT_UART_MCR_RTS_E_LOGIC0 0x1
1539
1540 /* The Least Significant Bit (LSB) position of the ALT_UART_MCR_RTS register field. */
1541 #define ALT_UART_MCR_RTS_LSB 1
1542 /* The Most Significant Bit (MSB) position of the ALT_UART_MCR_RTS register field. */
1543 #define ALT_UART_MCR_RTS_MSB 1
1544 /* The width in bits of the ALT_UART_MCR_RTS register field. */
1545 #define ALT_UART_MCR_RTS_WIDTH 1
1546 /* The mask used to set the ALT_UART_MCR_RTS register field value. */
1547 #define ALT_UART_MCR_RTS_SET_MSK 0x00000002
1548 /* The mask used to clear the ALT_UART_MCR_RTS register field value. */
1549 #define ALT_UART_MCR_RTS_CLR_MSK 0xfffffffd
1550 /* The reset value of the ALT_UART_MCR_RTS register field. */
1551 #define ALT_UART_MCR_RTS_RESET 0x0
1552 /* Extracts the ALT_UART_MCR_RTS field value from a register. */
1553 #define ALT_UART_MCR_RTS_GET(value) (((value) & 0x00000002) >> 1)
1554 /* Produces a ALT_UART_MCR_RTS register field value suitable for setting the register. */
1555 #define ALT_UART_MCR_RTS_SET(value) (((value) << 1) & 0x00000002)
1556
1557 /*
1558  * Field : Out1 - out1
1559  *
1560  * The value written to this location is inverted and driven out on uart_out1_n
1561  * pin.
1562  *
1563  * Note that in Loopback mode (MCR[4] set to one), the uart_out1_n output is held
1564  * inactive high while the value of this location is internally looped back to an
1565  * input.
1566  *
1567  * Field Enumeration Values:
1568  *
1569  * Enum | Value | Description
1570  * :---------------------------|:------|:----------------------------------
1571  * ALT_UART_MCR_OUT1_E_LOGIC1 | 0x0 | uart_out1_n de-asserted (logic 1)
1572  * ALT_UART_MCR_OUT1_E_LOGIC0 | 0x1 | uart_out1_n asserted (logic 0)
1573  *
1574  * Field Access Macros:
1575  *
1576  */
1577 /*
1578  * Enumerated value for register field ALT_UART_MCR_OUT1
1579  *
1580  * uart_out1_n de-asserted (logic 1)
1581  */
1582 #define ALT_UART_MCR_OUT1_E_LOGIC1 0x0
1583 /*
1584  * Enumerated value for register field ALT_UART_MCR_OUT1
1585  *
1586  * uart_out1_n asserted (logic 0)
1587  */
1588 #define ALT_UART_MCR_OUT1_E_LOGIC0 0x1
1589
1590 /* The Least Significant Bit (LSB) position of the ALT_UART_MCR_OUT1 register field. */
1591 #define ALT_UART_MCR_OUT1_LSB 2
1592 /* The Most Significant Bit (MSB) position of the ALT_UART_MCR_OUT1 register field. */
1593 #define ALT_UART_MCR_OUT1_MSB 2
1594 /* The width in bits of the ALT_UART_MCR_OUT1 register field. */
1595 #define ALT_UART_MCR_OUT1_WIDTH 1
1596 /* The mask used to set the ALT_UART_MCR_OUT1 register field value. */
1597 #define ALT_UART_MCR_OUT1_SET_MSK 0x00000004
1598 /* The mask used to clear the ALT_UART_MCR_OUT1 register field value. */
1599 #define ALT_UART_MCR_OUT1_CLR_MSK 0xfffffffb
1600 /* The reset value of the ALT_UART_MCR_OUT1 register field. */
1601 #define ALT_UART_MCR_OUT1_RESET 0x0
1602 /* Extracts the ALT_UART_MCR_OUT1 field value from a register. */
1603 #define ALT_UART_MCR_OUT1_GET(value) (((value) & 0x00000004) >> 2)
1604 /* Produces a ALT_UART_MCR_OUT1 register field value suitable for setting the register. */
1605 #define ALT_UART_MCR_OUT1_SET(value) (((value) << 2) & 0x00000004)
1606
1607 /*
1608  * Field : out2 - out2
1609  *
1610  * This is used to directly control the user-designated uart_out2_n output. The
1611  * value written to this location is inverted and driven out on uart_out2_n
1612  *
1613  * Note: In Loopback mode bit 4 of the modem control register (MCR) is set to one,
1614  * the uart_out2_n output is held inactive high while the value of this location is
1615  * internally looped back to an input.
1616  *
1617  * Field Enumeration Values:
1618  *
1619  * Enum | Value | Description
1620  * :---------------------------|:------|:----------------------------------
1621  * ALT_UART_MCR_OUT2_E_LOGIC1 | 0x0 | uart_out2_n de-asserted (logic 1)
1622  * ALT_UART_MCR_OUT2_E_LOGIC0 | 0x1 | uart_out2_n asserted (logic 0)
1623  *
1624  * Field Access Macros:
1625  *
1626  */
1627 /*
1628  * Enumerated value for register field ALT_UART_MCR_OUT2
1629  *
1630  * uart_out2_n de-asserted (logic 1)
1631  */
1632 #define ALT_UART_MCR_OUT2_E_LOGIC1 0x0
1633 /*
1634  * Enumerated value for register field ALT_UART_MCR_OUT2
1635  *
1636  * uart_out2_n asserted (logic 0)
1637  */
1638 #define ALT_UART_MCR_OUT2_E_LOGIC0 0x1
1639
1640 /* The Least Significant Bit (LSB) position of the ALT_UART_MCR_OUT2 register field. */
1641 #define ALT_UART_MCR_OUT2_LSB 3
1642 /* The Most Significant Bit (MSB) position of the ALT_UART_MCR_OUT2 register field. */
1643 #define ALT_UART_MCR_OUT2_MSB 3
1644 /* The width in bits of the ALT_UART_MCR_OUT2 register field. */
1645 #define ALT_UART_MCR_OUT2_WIDTH 1
1646 /* The mask used to set the ALT_UART_MCR_OUT2 register field value. */
1647 #define ALT_UART_MCR_OUT2_SET_MSK 0x00000008
1648 /* The mask used to clear the ALT_UART_MCR_OUT2 register field value. */
1649 #define ALT_UART_MCR_OUT2_CLR_MSK 0xfffffff7
1650 /* The reset value of the ALT_UART_MCR_OUT2 register field. */
1651 #define ALT_UART_MCR_OUT2_RESET 0x0
1652 /* Extracts the ALT_UART_MCR_OUT2 field value from a register. */
1653 #define ALT_UART_MCR_OUT2_GET(value) (((value) & 0x00000008) >> 3)
1654 /* Produces a ALT_UART_MCR_OUT2 register field value suitable for setting the register. */
1655 #define ALT_UART_MCR_OUT2_SET(value) (((value) << 3) & 0x00000008)
1656
1657 /*
1658  * Field : LoopBack Bit - loopback
1659  *
1660  * This is used to put the UART into a diagnostic mode for test purposes. If UART
1661  * mode is NOT active, bit [6] of the modem control register MCR is set to zero,
1662  * data on the sout line is held high, while serial data output is looped back to
1663  * the sin line, internally. In this mode all the interrupts are fully functional.
1664  * Also, in loopback mode, the modem control inputs (uart_dsr_n, uart_cts_n,
1665  * uart_ri_n, uart_dcd_n) are disconnected and the modem control outputs
1666  * (uart_dtr_n, uart_rts_n, uart_out1_n, uart_out2_n) are loopedback to the inputs,
1667  * internally.
1668  *
1669  * Field Access Macros:
1670  *
1671  */
1672 /* The Least Significant Bit (LSB) position of the ALT_UART_MCR_LOOPBACK register field. */
1673 #define ALT_UART_MCR_LOOPBACK_LSB 4
1674 /* The Most Significant Bit (MSB) position of the ALT_UART_MCR_LOOPBACK register field. */
1675 #define ALT_UART_MCR_LOOPBACK_MSB 4
1676 /* The width in bits of the ALT_UART_MCR_LOOPBACK register field. */
1677 #define ALT_UART_MCR_LOOPBACK_WIDTH 1
1678 /* The mask used to set the ALT_UART_MCR_LOOPBACK register field value. */
1679 #define ALT_UART_MCR_LOOPBACK_SET_MSK 0x00000010
1680 /* The mask used to clear the ALT_UART_MCR_LOOPBACK register field value. */
1681 #define ALT_UART_MCR_LOOPBACK_CLR_MSK 0xffffffef
1682 /* The reset value of the ALT_UART_MCR_LOOPBACK register field. */
1683 #define ALT_UART_MCR_LOOPBACK_RESET 0x0
1684 /* Extracts the ALT_UART_MCR_LOOPBACK field value from a register. */
1685 #define ALT_UART_MCR_LOOPBACK_GET(value) (((value) & 0x00000010) >> 4)
1686 /* Produces a ALT_UART_MCR_LOOPBACK register field value suitable for setting the register. */
1687 #define ALT_UART_MCR_LOOPBACK_SET(value) (((value) << 4) & 0x00000010)
1688
1689 /*
1690  * Field : Auto Flow Control Enable - afce
1691  *
1692  * When FIFOs are enabled, the Auto Flow Control enable bits are active.
1693  *
1694  * Field Enumeration Values:
1695  *
1696  * Enum | Value | Description
1697  * :-------------------------|:------|:--------------------------------
1698  * ALT_UART_MCR_AFCE_E_DISD | 0x0 | Auto Flow Control Mode disabled
1699  * ALT_UART_MCR_AFCE_E_END | 0x1 | Auto Flow Control Mode enabled
1700  *
1701  * Field Access Macros:
1702  *
1703  */
1704 /*
1705  * Enumerated value for register field ALT_UART_MCR_AFCE
1706  *
1707  * Auto Flow Control Mode disabled
1708  */
1709 #define ALT_UART_MCR_AFCE_E_DISD 0x0
1710 /*
1711  * Enumerated value for register field ALT_UART_MCR_AFCE
1712  *
1713  * Auto Flow Control Mode enabled
1714  */
1715 #define ALT_UART_MCR_AFCE_E_END 0x1
1716
1717 /* The Least Significant Bit (LSB) position of the ALT_UART_MCR_AFCE register field. */
1718 #define ALT_UART_MCR_AFCE_LSB 5
1719 /* The Most Significant Bit (MSB) position of the ALT_UART_MCR_AFCE register field. */
1720 #define ALT_UART_MCR_AFCE_MSB 5
1721 /* The width in bits of the ALT_UART_MCR_AFCE register field. */
1722 #define ALT_UART_MCR_AFCE_WIDTH 1
1723 /* The mask used to set the ALT_UART_MCR_AFCE register field value. */
1724 #define ALT_UART_MCR_AFCE_SET_MSK 0x00000020
1725 /* The mask used to clear the ALT_UART_MCR_AFCE register field value. */
1726 #define ALT_UART_MCR_AFCE_CLR_MSK 0xffffffdf
1727 /* The reset value of the ALT_UART_MCR_AFCE register field. */
1728 #define ALT_UART_MCR_AFCE_RESET 0x0
1729 /* Extracts the ALT_UART_MCR_AFCE field value from a register. */
1730 #define ALT_UART_MCR_AFCE_GET(value) (((value) & 0x00000020) >> 5)
1731 /* Produces a ALT_UART_MCR_AFCE register field value suitable for setting the register. */
1732 #define ALT_UART_MCR_AFCE_SET(value) (((value) << 5) & 0x00000020)
1733
1734 #ifndef __ASSEMBLY__
1735 /*
1736  * WARNING: The C register and register group struct declarations are provided for
1737  * convenience and illustrative purposes. They should, however, be used with
1738  * caution as the C language standard provides no guarantees about the alignment or
1739  * atomicity of device memory accesses. The recommended practice for writing
1740  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1741  * alt_write_word() functions.
1742  *
1743  * The struct declaration for register ALT_UART_MCR.
1744  */
1746 {
1747  uint32_t dtr : 1; /* Data Terminal Ready */
1748  uint32_t rts : 1; /* Request to Send */
1749  uint32_t out1 : 1; /* Out1 */
1750  uint32_t out2 : 1; /* out2 */
1751  uint32_t loopback : 1; /* LoopBack Bit */
1752  uint32_t afce : 1; /* Auto Flow Control Enable */
1753  uint32_t : 26; /* *UNDEFINED* */
1754 };
1755
1756 /* The typedef declaration for register ALT_UART_MCR. */
1757 typedef volatile struct ALT_UART_MCR_s ALT_UART_MCR_t;
1758 #endif /* __ASSEMBLY__ */
1759
1760 /* The byte offset of the ALT_UART_MCR register from the beginning of the component. */
1761 #define ALT_UART_MCR_OFST 0x10
1762 /* The address of the ALT_UART_MCR register. */
1763 #define ALT_UART_MCR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_MCR_OFST))
1764
1765 /*
1766  * Register : Line Status Register - lsr
1767  *
1768  * Reports status of transmit and receive.
1769  *
1770  * Register Layout
1771  *
1772  * Bits | Access | Reset | Description
1773  * :-------|:-------|:------|:------------------------------------
1774  * [0] | R | 0x0 | Data Ready bit
1775  * [1] | R | 0x0 | Overrun error
1776  * [2] | R | 0x0 | Parity Error
1777  * [3] | R | 0x0 | Framing Error
1778  * [4] | R | 0x0 | Break Interrupt
1779  * [5] | R | 0x1 | Transmit Holding Register Empty bit
1780  * [6] | R | 0x1 | Transmitter Empty bit
1781  * [7] | R | 0x0 | Receiver FIFO Error bit
1782  * [31:8] | ??? | 0x0 | *UNDEFINED*
1783  *
1784  */
1785 /*
1786  * Field : Data Ready bit - dr
1787  *
1788  * This is used to indicate that the receiver contains at least one character in
1789  * the RBR or the receiver FIFO. This bit is cleared when the RBR is read in the
1790  * non-FIFO mode, or when the receiver FIFO is empty, in the FIFO mode.
1791  *
1792  * Field Enumeration Values:
1793  *
1794  * Enum | Value | Description
1795  * :----------------------------|:------|:--------------
1796  * ALT_UART_LSR_DR_E_NODATARDY | 0x0 | no data ready
1797  * ALT_UART_LSR_DR_E_DATARDY | 0x1 | data ready
1798  *
1799  * Field Access Macros:
1800  *
1801  */
1802 /*
1803  * Enumerated value for register field ALT_UART_LSR_DR
1804  *
1805  * no data ready
1806  */
1807 #define ALT_UART_LSR_DR_E_NODATARDY 0x0
1808 /*
1809  * Enumerated value for register field ALT_UART_LSR_DR
1810  *
1811  * data ready
1812  */
1813 #define ALT_UART_LSR_DR_E_DATARDY 0x1
1814
1815 /* The Least Significant Bit (LSB) position of the ALT_UART_LSR_DR register field. */
1816 #define ALT_UART_LSR_DR_LSB 0
1817 /* The Most Significant Bit (MSB) position of the ALT_UART_LSR_DR register field. */
1818 #define ALT_UART_LSR_DR_MSB 0
1819 /* The width in bits of the ALT_UART_LSR_DR register field. */
1820 #define ALT_UART_LSR_DR_WIDTH 1
1821 /* The mask used to set the ALT_UART_LSR_DR register field value. */
1822 #define ALT_UART_LSR_DR_SET_MSK 0x00000001
1823 /* The mask used to clear the ALT_UART_LSR_DR register field value. */
1824 #define ALT_UART_LSR_DR_CLR_MSK 0xfffffffe
1825 /* The reset value of the ALT_UART_LSR_DR register field. */
1826 #define ALT_UART_LSR_DR_RESET 0x0
1827 /* Extracts the ALT_UART_LSR_DR field value from a register. */
1828 #define ALT_UART_LSR_DR_GET(value) (((value) & 0x00000001) >> 0)
1829 /* Produces a ALT_UART_LSR_DR register field value suitable for setting the register. */
1830 #define ALT_UART_LSR_DR_SET(value) (((value) << 0) & 0x00000001)
1831
1832 /*
1833  * Field : Overrun error - oe
1834  *
1835  * This is used to indicate the occurrence of an overrun error. This occurs if a
1836  * new data character was received before the previous data was read. In the non-
1837  * FIFO mode, the OE bit is set when a new character arrives in the receiver before
1838  * the previous character was read from the RBR. When this happens, the data in the
1839  * RBR is overwritten. In the FIFO mode, an overrun error occurs when the FIFO is
1840  * full and new character arrives at the receiver. The data in the FIFO is retained
1841  * and the data in the receive shift register is lost.Reading the LSR clears the OE
1842  * bit.
1843  *
1844  * Field Enumeration Values:
1845  *
1846  * Enum | Value | Description
1847  * :----------------------------|:------|:-----------------
1848  * ALT_UART_LSR_OE_E_NOOVERRUN | 0x0 | no overrun error
1849  * ALT_UART_LSR_OE_E_OVERRUN | 0x1 | overrun error
1850  *
1851  * Field Access Macros:
1852  *
1853  */
1854 /*
1855  * Enumerated value for register field ALT_UART_LSR_OE
1856  *
1857  * no overrun error
1858  */
1859 #define ALT_UART_LSR_OE_E_NOOVERRUN 0x0
1860 /*
1861  * Enumerated value for register field ALT_UART_LSR_OE
1862  *
1863  * overrun error
1864  */
1865 #define ALT_UART_LSR_OE_E_OVERRUN 0x1
1866
1867 /* The Least Significant Bit (LSB) position of the ALT_UART_LSR_OE register field. */
1868 #define ALT_UART_LSR_OE_LSB 1
1869 /* The Most Significant Bit (MSB) position of the ALT_UART_LSR_OE register field. */
1870 #define ALT_UART_LSR_OE_MSB 1
1871 /* The width in bits of the ALT_UART_LSR_OE register field. */
1872 #define ALT_UART_LSR_OE_WIDTH 1
1873 /* The mask used to set the ALT_UART_LSR_OE register field value. */
1874 #define ALT_UART_LSR_OE_SET_MSK 0x00000002
1875 /* The mask used to clear the ALT_UART_LSR_OE register field value. */
1876 #define ALT_UART_LSR_OE_CLR_MSK 0xfffffffd
1877 /* The reset value of the ALT_UART_LSR_OE register field. */
1878 #define ALT_UART_LSR_OE_RESET 0x0
1879 /* Extracts the ALT_UART_LSR_OE field value from a register. */
1880 #define ALT_UART_LSR_OE_GET(value) (((value) & 0x00000002) >> 1)
1881 /* Produces a ALT_UART_LSR_OE register field value suitable for setting the register. */
1882 #define ALT_UART_LSR_OE_SET(value) (((value) << 1) & 0x00000002)
1883
1884 /*
1885  * Field : Parity Error - pe
1886  *
1887  * This is used to indicate the occurrence of a parity error in the receiver if the
1888  * Parity Enable (PEN) bit (LCR[3]) is set. Since the parity error is associated
1889  * with a character received, it is revealed when the character with the parity
1890  * error arrives at the top of the FIFO. It should be noted that the Parity Error
1891  * (PE) bit (LSR[2]) will be set if a break interrupt has occurred, as indicated by
1892  * Break Interrupt (BI) bit (LSR[4]). Reading the LSR clears the PE bit.
1893  *
1894  * Field Enumeration Values:
1895  *
1896  * Enum | Value | Description
1897  * :------------------------------|:------|:----------------
1898  * ALT_UART_LSR_PE_E_NOPARITYERR | 0x0 | no parity error
1899  * ALT_UART_LSR_PE_E_PARITYERR | 0x1 | no parity error
1900  *
1901  * Field Access Macros:
1902  *
1903  */
1904 /*
1905  * Enumerated value for register field ALT_UART_LSR_PE
1906  *
1907  * no parity error
1908  */
1909 #define ALT_UART_LSR_PE_E_NOPARITYERR 0x0
1910 /*
1911  * Enumerated value for register field ALT_UART_LSR_PE
1912  *
1913  * no parity error
1914  */
1915 #define ALT_UART_LSR_PE_E_PARITYERR 0x1
1916
1917 /* The Least Significant Bit (LSB) position of the ALT_UART_LSR_PE register field. */
1918 #define ALT_UART_LSR_PE_LSB 2
1919 /* The Most Significant Bit (MSB) position of the ALT_UART_LSR_PE register field. */
1920 #define ALT_UART_LSR_PE_MSB 2
1921 /* The width in bits of the ALT_UART_LSR_PE register field. */
1922 #define ALT_UART_LSR_PE_WIDTH 1
1923 /* The mask used to set the ALT_UART_LSR_PE register field value. */
1924 #define ALT_UART_LSR_PE_SET_MSK 0x00000004
1925 /* The mask used to clear the ALT_UART_LSR_PE register field value. */
1926 #define ALT_UART_LSR_PE_CLR_MSK 0xfffffffb
1927 /* The reset value of the ALT_UART_LSR_PE register field. */
1928 #define ALT_UART_LSR_PE_RESET 0x0
1929 /* Extracts the ALT_UART_LSR_PE field value from a register. */
1930 #define ALT_UART_LSR_PE_GET(value) (((value) & 0x00000004) >> 2)
1931 /* Produces a ALT_UART_LSR_PE register field value suitable for setting the register. */
1932 #define ALT_UART_LSR_PE_SET(value) (((value) << 2) & 0x00000004)
1933
1934 /*
1935  * Field : Framing Error - fe
1936  *
1937  * This is used to indicate the occurrence of a framing error in the receiver. A
1938  * framing error occurs when the receiver does not detect a valid STOP bit in the
1939  * received data. In the FIFO mode, since the framing error is associated with a
1940  * character received, it is revealed when the character with the framing error is
1941  * at the top of the FIFO. When a framing error occurs the UART will try to
1942  * resynchronize. It does this by assuming that the error was due to the start bit
1943  * of the next character and then continues receiving the other bit i.e. data,
1944  * and/or parity and stop. It should be noted that the Framing Error (FE)
1945  * bit(LSR[3]) will be set if a break interrupt has occurred, as indicated by a
1946  * Break Interrupt BIT bit (LSR[4]). Reading the LSR clears the FE bit.
1947  *
1948  * Field Enumeration Values:
1949  *
1950  * Enum | Value | Description
1951  * :---------------------------|:------|:-----------------
1952  * ALT_UART_LSR_FE_E_NOFRMERR | 0x0 | no framing error
1953  * ALT_UART_LSR_FE_E_FRMERR | 0x1 | framing error
1954  *
1955  * Field Access Macros:
1956  *
1957  */
1958 /*
1959  * Enumerated value for register field ALT_UART_LSR_FE
1960  *
1961  * no framing error
1962  */
1963 #define ALT_UART_LSR_FE_E_NOFRMERR 0x0
1964 /*
1965  * Enumerated value for register field ALT_UART_LSR_FE
1966  *
1967  * framing error
1968  */
1969 #define ALT_UART_LSR_FE_E_FRMERR 0x1
1970
1971 /* The Least Significant Bit (LSB) position of the ALT_UART_LSR_FE register field. */
1972 #define ALT_UART_LSR_FE_LSB 3
1973 /* The Most Significant Bit (MSB) position of the ALT_UART_LSR_FE register field. */
1974 #define ALT_UART_LSR_FE_MSB 3
1975 /* The width in bits of the ALT_UART_LSR_FE register field. */
1976 #define ALT_UART_LSR_FE_WIDTH 1
1977 /* The mask used to set the ALT_UART_LSR_FE register field value. */
1978 #define ALT_UART_LSR_FE_SET_MSK 0x00000008
1979 /* The mask used to clear the ALT_UART_LSR_FE register field value. */
1980 #define ALT_UART_LSR_FE_CLR_MSK 0xfffffff7
1981 /* The reset value of the ALT_UART_LSR_FE register field. */
1982 #define ALT_UART_LSR_FE_RESET 0x0
1983 /* Extracts the ALT_UART_LSR_FE field value from a register. */
1984 #define ALT_UART_LSR_FE_GET(value) (((value) & 0x00000008) >> 3)
1985 /* Produces a ALT_UART_LSR_FE register field value suitable for setting the register. */
1986 #define ALT_UART_LSR_FE_SET(value) (((value) << 3) & 0x00000008)
1987
1988 /*
1989  * Field : Break Interrupt - bi
1990  *
1991  * This is used to indicate the detection of a break sequence on the serial input
1992  * data. Set whenever the serial input, sin, is held in a logic 0 state for longer
1993  * than the sum of start time + data bits + parity + stop bits. A break condition
1994  * on serial input causes one and only one character, consisting of all zeros, to
1995  * be received by the UART. The character associated with the break condition is
1996  * carried through the FIFO and is revealed when the character is at the top of the
1997  * FIFO. Reading the LSR clears the BI bit.
1998  *
1999  * Field Access Macros:
2000  *
2001  */
2002 /* The Least Significant Bit (LSB) position of the ALT_UART_LSR_BI register field. */
2003 #define ALT_UART_LSR_BI_LSB 4
2004 /* The Most Significant Bit (MSB) position of the ALT_UART_LSR_BI register field. */
2005 #define ALT_UART_LSR_BI_MSB 4
2006 /* The width in bits of the ALT_UART_LSR_BI register field. */
2007 #define ALT_UART_LSR_BI_WIDTH 1
2008 /* The mask used to set the ALT_UART_LSR_BI register field value. */
2009 #define ALT_UART_LSR_BI_SET_MSK 0x00000010
2010 /* The mask used to clear the ALT_UART_LSR_BI register field value. */
2011 #define ALT_UART_LSR_BI_CLR_MSK 0xffffffef
2012 /* The reset value of the ALT_UART_LSR_BI register field. */
2013 #define ALT_UART_LSR_BI_RESET 0x0
2014 /* Extracts the ALT_UART_LSR_BI field value from a register. */
2015 #define ALT_UART_LSR_BI_GET(value) (((value) & 0x00000010) >> 4)
2016 /* Produces a ALT_UART_LSR_BI register field value suitable for setting the register. */
2017 #define ALT_UART_LSR_BI_SET(value) (((value) << 4) & 0x00000010)
2018
2019 /*
2020  * Field : Transmit Holding Register Empty bit - thre
2021  *
2022  * If THRE mode is disabled (IER[7] set to zero) this bit indicates that the THR or
2023  * Tx FIFO is empty. This bit is set whenever data is transferred from the THR or
2024  * Tx FIFO to the transmitter shift register and no new data has been written to
2025  * the THR or Tx FIFO. This also causes a THRE Interrupt to occur, if the THRE
2026  * Interrupt is enabled. If both THRE and FIFOs are enabled, both (IER[7] set to
2027  * one and FCR[0] set to one respectively), the functionality will indicate the
2028  * transmitter FIFO is full, and no longer controls THRE interrupts, which are then
2029  * controlled by the FCR[5:4] thresholdsetting.
2030  *
2031  * Field Access Macros:
2032  *
2033  */
2034 /* The Least Significant Bit (LSB) position of the ALT_UART_LSR_THRE register field. */
2035 #define ALT_UART_LSR_THRE_LSB 5
2036 /* The Most Significant Bit (MSB) position of the ALT_UART_LSR_THRE register field. */
2037 #define ALT_UART_LSR_THRE_MSB 5
2038 /* The width in bits of the ALT_UART_LSR_THRE register field. */
2039 #define ALT_UART_LSR_THRE_WIDTH 1
2040 /* The mask used to set the ALT_UART_LSR_THRE register field value. */
2041 #define ALT_UART_LSR_THRE_SET_MSK 0x00000020
2042 /* The mask used to clear the ALT_UART_LSR_THRE register field value. */
2043 #define ALT_UART_LSR_THRE_CLR_MSK 0xffffffdf
2044 /* The reset value of the ALT_UART_LSR_THRE register field. */
2045 #define ALT_UART_LSR_THRE_RESET 0x1
2046 /* Extracts the ALT_UART_LSR_THRE field value from a register. */
2047 #define ALT_UART_LSR_THRE_GET(value) (((value) & 0x00000020) >> 5)
2048 /* Produces a ALT_UART_LSR_THRE register field value suitable for setting the register. */
2049 #define ALT_UART_LSR_THRE_SET(value) (((value) << 5) & 0x00000020)
2050
2051 /*
2052  * Field : Transmitter Empty bit - temt
2053  *
2054  * If in FIFO mode and FIFO's enabled (FCR[0] set to one), this bit is set whenever
2055  * the Transmitter Shift Register and the FIFO are both empty. If FIFO's are
2056  * disabled, this bit is set whenever the Transmitter Holding Register and the
2057  * Transmitter Shift Register are both empty.
2058  *
2059  * Field Enumeration Values:
2060  *
2061  * Enum | Value | Description
2062  * :-----------------------------|:------|:-----------------------
2063  * ALT_UART_LSR_TEMT_E_NOTEMPTY | 0x0 | Transmit Empty not set
2064  * ALT_UART_LSR_TEMT_E_EMPTY | 0x1 | Transmit Empty set
2065  *
2066  * Field Access Macros:
2067  *
2068  */
2069 /*
2070  * Enumerated value for register field ALT_UART_LSR_TEMT
2071  *
2072  * Transmit Empty not set
2073  */
2074 #define ALT_UART_LSR_TEMT_E_NOTEMPTY 0x0
2075 /*
2076  * Enumerated value for register field ALT_UART_LSR_TEMT
2077  *
2078  * Transmit Empty set
2079  */
2080 #define ALT_UART_LSR_TEMT_E_EMPTY 0x1
2081
2082 /* The Least Significant Bit (LSB) position of the ALT_UART_LSR_TEMT register field. */
2083 #define ALT_UART_LSR_TEMT_LSB 6
2084 /* The Most Significant Bit (MSB) position of the ALT_UART_LSR_TEMT register field. */
2085 #define ALT_UART_LSR_TEMT_MSB 6
2086 /* The width in bits of the ALT_UART_LSR_TEMT register field. */
2087 #define ALT_UART_LSR_TEMT_WIDTH 1
2088 /* The mask used to set the ALT_UART_LSR_TEMT register field value. */
2089 #define ALT_UART_LSR_TEMT_SET_MSK 0x00000040
2090 /* The mask used to clear the ALT_UART_LSR_TEMT register field value. */
2091 #define ALT_UART_LSR_TEMT_CLR_MSK 0xffffffbf
2092 /* The reset value of the ALT_UART_LSR_TEMT register field. */
2093 #define ALT_UART_LSR_TEMT_RESET 0x1
2094 /* Extracts the ALT_UART_LSR_TEMT field value from a register. */
2095 #define ALT_UART_LSR_TEMT_GET(value) (((value) & 0x00000040) >> 6)
2096 /* Produces a ALT_UART_LSR_TEMT register field value suitable for setting the register. */
2097 #define ALT_UART_LSR_TEMT_SET(value) (((value) << 6) & 0x00000040)
2098
2099 /*
2100  * Field : Receiver FIFO Error bit - rfe
2101  *
2102  * This bit is only relevant when FIFO's are enabled (FCR[0] set to one). This is
2103  * used to indicate if there is at least one parity error, framing error, or break
2104  * indication in the FIFO. This bit is cleared when the LSR is read and the
2105  * character with the error is at the top of the receiver FIFO and there are no
2106  * subsequent errors in the FIFO.
2107  *
2108  * Field Enumeration Values:
2109  *
2110  * Enum | Value | Description
2111  * :-------------------------|:------|:--------------------
2112  * ALT_UART_LSR_RFE_E_NOERR | 0x0 | no error in Rx FIFO
2113  * ALT_UART_LSR_RFE_E_ERR | 0x1 | error in Rx FIFO
2114  *
2115  * Field Access Macros:
2116  *
2117  */
2118 /*
2119  * Enumerated value for register field ALT_UART_LSR_RFE
2120  *
2121  * no error in Rx FIFO
2122  */
2123 #define ALT_UART_LSR_RFE_E_NOERR 0x0
2124 /*
2125  * Enumerated value for register field ALT_UART_LSR_RFE
2126  *
2127  * error in Rx FIFO
2128  */
2129 #define ALT_UART_LSR_RFE_E_ERR 0x1
2130
2131 /* The Least Significant Bit (LSB) position of the ALT_UART_LSR_RFE register field. */
2132 #define ALT_UART_LSR_RFE_LSB 7
2133 /* The Most Significant Bit (MSB) position of the ALT_UART_LSR_RFE register field. */
2134 #define ALT_UART_LSR_RFE_MSB 7
2135 /* The width in bits of the ALT_UART_LSR_RFE register field. */
2136 #define ALT_UART_LSR_RFE_WIDTH 1
2137 /* The mask used to set the ALT_UART_LSR_RFE register field value. */
2138 #define ALT_UART_LSR_RFE_SET_MSK 0x00000080
2139 /* The mask used to clear the ALT_UART_LSR_RFE register field value. */
2140 #define ALT_UART_LSR_RFE_CLR_MSK 0xffffff7f
2141 /* The reset value of the ALT_UART_LSR_RFE register field. */
2142 #define ALT_UART_LSR_RFE_RESET 0x0
2143 /* Extracts the ALT_UART_LSR_RFE field value from a register. */
2144 #define ALT_UART_LSR_RFE_GET(value) (((value) & 0x00000080) >> 7)
2145 /* Produces a ALT_UART_LSR_RFE register field value suitable for setting the register. */
2146 #define ALT_UART_LSR_RFE_SET(value) (((value) << 7) & 0x00000080)
2147
2148 #ifndef __ASSEMBLY__
2149 /*
2150  * WARNING: The C register and register group struct declarations are provided for
2151  * convenience and illustrative purposes. They should, however, be used with
2152  * caution as the C language standard provides no guarantees about the alignment or
2153  * atomicity of device memory accesses. The recommended practice for writing
2154  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2155  * alt_write_word() functions.
2156  *
2157  * The struct declaration for register ALT_UART_LSR.
2158  */
2160 {
2161  const uint32_t dr : 1; /* Data Ready bit */
2162  const uint32_t oe : 1; /* Overrun error */
2163  const uint32_t pe : 1; /* Parity Error */
2164  const uint32_t fe : 1; /* Framing Error */
2165  const uint32_t bi : 1; /* Break Interrupt */
2166  const uint32_t thre : 1; /* Transmit Holding Register Empty bit */
2167  const uint32_t temt : 1; /* Transmitter Empty bit */
2168  const uint32_t rfe : 1; /* Receiver FIFO Error bit */
2169  uint32_t : 24; /* *UNDEFINED* */
2170 };
2171
2172 /* The typedef declaration for register ALT_UART_LSR. */
2173 typedef volatile struct ALT_UART_LSR_s ALT_UART_LSR_t;
2174 #endif /* __ASSEMBLY__ */
2175
2176 /* The byte offset of the ALT_UART_LSR register from the beginning of the component. */
2177 #define ALT_UART_LSR_OFST 0x14
2178 /* The address of the ALT_UART_LSR register. */
2179 #define ALT_UART_LSR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_LSR_OFST))
2180
2181 /*
2182  * Register : Modem Status Register - msr
2183  *
2184  * It should be noted that whenever bits 0, 1, 2 or 3 are set to logic one, to
2185  * indicate a change on the modem control inputs, a modem status interrupt will be
2186  * generated if enabled via the IER regardless of when the change occurred. Since
2187  * the delta bits (bits 0, 1, 3) can get set after a reset if their respective
2188  * modem signals are active (see individual bits for details), a read of the MSR
2189  * after reset can be performed to prevent unwanted interrupts.
2190  *
2191  * Register Layout
2192  *
2193  * Bits | Access | Reset | Description
2194  * :-------|:-------|:------|:--------------------------------
2195  * [0] | R | 0x0 | Delta Clear to Send
2196  * [1] | R | 0x0 | Delta Data Set Ready
2197  * [2] | R | 0x0 | Trailing Edge of Ring Indicator
2198  * [3] | R | 0x0 | Delta Data Carrier Detect
2199  * [4] | R | 0x0 | Clear to Send
2200  * [5] | R | 0x0 | Data Set Ready
2201  * [6] | R | 0x0 | Ring Indicator
2202  * [7] | R | 0x0 | Data Carrier Detect
2203  * [31:8] | ??? | 0x0 | *UNDEFINED*
2204  *
2205  */
2206 /*
2207  * Field : Delta Clear to Send - dcts
2208  *
2209  * This is used to indicate that the modem control line uart_cts_n has changed
2210  * since the last time the MSR was read. That is: Reading the MSR clears the DCTS
2211  * bit. In Loopback Mode bit [4] of MCR set to one, DCTS reflects changes on bit
2212  * [1] RTS of register MCR.
2213  *
2214  * Note: If the DCTS bit is not set and the uart_cts_n signal is asserted (low) and
2215  * a reset occurs (software or otherwise), then the DCTS bit will get set when the
2216  * reset is removed if the uart_cts_n signal remains asserted.
2217  *
2218  * Field Enumeration Values:
2219  *
2220  * Enum | Value | Description
2221  * :--------------------------|:------|:-----------------------------------------------
2222  * ALT_UART_MSR_DCTS_E_NOCHG | 0x0 | no change on uart_cts_n since last read of MSR
2223  * ALT_UART_MSR_DCTS_E_CHG | 0x1 | change on uart_cts_n since last read of MSR
2224  *
2225  * Field Access Macros:
2226  *
2227  */
2228 /*
2229  * Enumerated value for register field ALT_UART_MSR_DCTS
2230  *
2231  * no change on uart_cts_n since last read of MSR
2232  */
2233 #define ALT_UART_MSR_DCTS_E_NOCHG 0x0
2234 /*
2235  * Enumerated value for register field ALT_UART_MSR_DCTS
2236  *
2237  * change on uart_cts_n since last read of MSR
2238  */
2239 #define ALT_UART_MSR_DCTS_E_CHG 0x1
2240
2241 /* The Least Significant Bit (LSB) position of the ALT_UART_MSR_DCTS register field. */
2242 #define ALT_UART_MSR_DCTS_LSB 0
2243 /* The Most Significant Bit (MSB) position of the ALT_UART_MSR_DCTS register field. */
2244 #define ALT_UART_MSR_DCTS_MSB 0
2245 /* The width in bits of the ALT_UART_MSR_DCTS register field. */
2246 #define ALT_UART_MSR_DCTS_WIDTH 1
2247 /* The mask used to set the ALT_UART_MSR_DCTS register field value. */
2248 #define ALT_UART_MSR_DCTS_SET_MSK 0x00000001
2249 /* The mask used to clear the ALT_UART_MSR_DCTS register field value. */
2250 #define ALT_UART_MSR_DCTS_CLR_MSK 0xfffffffe
2251 /* The reset value of the ALT_UART_MSR_DCTS register field. */
2252 #define ALT_UART_MSR_DCTS_RESET 0x0
2253 /* Extracts the ALT_UART_MSR_DCTS field value from a register. */
2254 #define ALT_UART_MSR_DCTS_GET(value) (((value) & 0x00000001) >> 0)
2255 /* Produces a ALT_UART_MSR_DCTS register field value suitable for setting the register. */
2256 #define ALT_UART_MSR_DCTS_SET(value) (((value) << 0) & 0x00000001)
2257
2258 /*
2259  * Field : Delta Data Set Ready - ddsr
2260  *
2261  * This is used to indicate that the modem control line uart_dsr_n has changed
2262  * since the last time the MSR was read. Reading the MSR clears the DDSR bit.In
2263  * Loopback Mode (MCR[4] set to one), DDSR reflects changes on bit [0] DTR of
2264  * register MCR .
2265  *
2266  * Note, if the DDSR bit is not set and the uart_dsr_n signal is asserted (low) and
2267  * a reset occurs (software or otherwise), then the DDSR bit will get set when the
2268  * reset is removed if the uart_dsr_n signal remains asserted.
2269  *
2270  * Field Enumeration Values:
2271  *
2272  * Enum | Value | Description
2273  * :--------------------------|:------|:-----------------------------------------------
2274  * ALT_UART_MSR_DDSR_E_NOCHG | 0x0 | no change on uart_dsr_n since last read of MSR
2275  * ALT_UART_MSR_DDSR_E_CHG | 0x1 | change on uart_dsr_n since last read of MSR
2276  *
2277  * Field Access Macros:
2278  *
2279  */
2280 /*
2281  * Enumerated value for register field ALT_UART_MSR_DDSR
2282  *
2283  * no change on uart_dsr_n since last read of MSR
2284  */
2285 #define ALT_UART_MSR_DDSR_E_NOCHG 0x0
2286 /*
2287  * Enumerated value for register field ALT_UART_MSR_DDSR
2288  *
2289  * change on uart_dsr_n since last read of MSR
2290  */
2291 #define ALT_UART_MSR_DDSR_E_CHG 0x1
2292
2293 /* The Least Significant Bit (LSB) position of the ALT_UART_MSR_DDSR register field. */
2294 #define ALT_UART_MSR_DDSR_LSB 1
2295 /* The Most Significant Bit (MSB) position of the ALT_UART_MSR_DDSR register field. */
2296 #define ALT_UART_MSR_DDSR_MSB 1
2297 /* The width in bits of the ALT_UART_MSR_DDSR register field. */
2298 #define ALT_UART_MSR_DDSR_WIDTH 1
2299 /* The mask used to set the ALT_UART_MSR_DDSR register field value. */
2300 #define ALT_UART_MSR_DDSR_SET_MSK 0x00000002
2301 /* The mask used to clear the ALT_UART_MSR_DDSR register field value. */
2302 #define ALT_UART_MSR_DDSR_CLR_MSK 0xfffffffd
2303 /* The reset value of the ALT_UART_MSR_DDSR register field. */
2304 #define ALT_UART_MSR_DDSR_RESET 0x0
2305 /* Extracts the ALT_UART_MSR_DDSR field value from a register. */
2306 #define ALT_UART_MSR_DDSR_GET(value) (((value) & 0x00000002) >> 1)
2307 /* Produces a ALT_UART_MSR_DDSR register field value suitable for setting the register. */
2308 #define ALT_UART_MSR_DDSR_SET(value) (((value) << 1) & 0x00000002)
2309
2310 /*
2311  * Field : Trailing Edge of Ring Indicator - teri
2312  *
2313  * This is used to indicate that a change on the input uart_ri_n (from an active
2314  * low, to an inactive high state) has occurred since the last time the MSR was
2315  * read. Reading the MSR clears the TERI bit. In Loopback Mode bit [4] of register
2316  * MCR is set to one, TERI reflects when bit [2] of register MCR has changed state
2317  * from a high to a low.
2318  *
2319  * Field Enumeration Values:
2320  *
2321  * Enum | Value | Description
2322  * :--------------------------|:------|:----------------------------------------------
2323  * ALT_UART_MSR_TERI_E_NOCHG | 0x0 | no change on uart_ri_n since last read of MSR
2324  * ALT_UART_MSR_TERI_E_CHG | 0x1 | change on uart_ri_n since last read of MSR
2325  *
2326  * Field Access Macros:
2327  *
2328  */
2329 /*
2330  * Enumerated value for register field ALT_UART_MSR_TERI
2331  *
2332  * no change on uart_ri_n since last read of MSR
2333  */
2334 #define ALT_UART_MSR_TERI_E_NOCHG 0x0
2335 /*
2336  * Enumerated value for register field ALT_UART_MSR_TERI
2337  *
2338  * change on uart_ri_n since last read of MSR
2339  */
2340 #define ALT_UART_MSR_TERI_E_CHG 0x1
2341
2342 /* The Least Significant Bit (LSB) position of the ALT_UART_MSR_TERI register field. */
2343 #define ALT_UART_MSR_TERI_LSB 2
2344 /* The Most Significant Bit (MSB) position of the ALT_UART_MSR_TERI register field. */
2345 #define ALT_UART_MSR_TERI_MSB 2
2346 /* The width in bits of the ALT_UART_MSR_TERI register field. */
2347 #define ALT_UART_MSR_TERI_WIDTH 1
2348 /* The mask used to set the ALT_UART_MSR_TERI register field value. */
2349 #define ALT_UART_MSR_TERI_SET_MSK 0x00000004
2350 /* The mask used to clear the ALT_UART_MSR_TERI register field value. */
2351 #define ALT_UART_MSR_TERI_CLR_MSK 0xfffffffb
2352 /* The reset value of the ALT_UART_MSR_TERI register field. */
2353 #define ALT_UART_MSR_TERI_RESET 0x0
2354 /* Extracts the ALT_UART_MSR_TERI field value from a register. */
2355 #define ALT_UART_MSR_TERI_GET(value) (((value) & 0x00000004) >> 2)
2356 /* Produces a ALT_UART_MSR_TERI register field value suitable for setting the register. */
2357 #define ALT_UART_MSR_TERI_SET(value) (((value) << 2) & 0x00000004)
2358
2359 /*
2360  * Field : Delta Data Carrier Detect - ddcd
2361  *
2362  * This is used to indicate that the modem control line dcd_n has changed since the
2363  * last time the MSR was read. Reading the MSR clears the DDCD bit. In Loopback
2364  * Mode bit [4] of register MCR is set to one, DDCD reflects changes bit [3]
2365  * uart_out2 of register MCR.
2366  *
2367  * Note: If the DDCD bit is not set and the uart_dcd_n signal is asserted (low) and
2368  * a reset occurs (software or otherwise), then the DDCD bit will get set when the
2369  * reset is removed if the uart_dcd_n signal remains asserted.
2370  *
2371  * Field Enumeration Values:
2372  *
2373  * Enum | Value | Description
2374  * :--------------------------|:------|:-----------------------------------------------
2375  * ALT_UART_MSR_DDCD_E_NOCHG | 0x0 | no change on uart_dcd_n since last read of MSR
2376  * ALT_UART_MSR_DDCD_E_CHG | 0x1 | change on uart_dcd_n since last read of MSR
2377  *
2378  * Field Access Macros:
2379  *
2380  */
2381 /*
2382  * Enumerated value for register field ALT_UART_MSR_DDCD
2383  *
2384  * no change on uart_dcd_n since last read of MSR
2385  */
2386 #define ALT_UART_MSR_DDCD_E_NOCHG 0x0
2387 /*
2388  * Enumerated value for register field ALT_UART_MSR_DDCD
2389  *
2390  * change on uart_dcd_n since last read of MSR
2391  */
2392 #define ALT_UART_MSR_DDCD_E_CHG 0x1
2393
2394 /* The Least Significant Bit (LSB) position of the ALT_UART_MSR_DDCD register field. */
2395 #define ALT_UART_MSR_DDCD_LSB 3
2396 /* The Most Significant Bit (MSB) position of the ALT_UART_MSR_DDCD register field. */
2397 #define ALT_UART_MSR_DDCD_MSB 3
2398 /* The width in bits of the ALT_UART_MSR_DDCD register field. */
2399 #define ALT_UART_MSR_DDCD_WIDTH 1
2400 /* The mask used to set the ALT_UART_MSR_DDCD register field value. */
2401 #define ALT_UART_MSR_DDCD_SET_MSK 0x00000008
2402 /* The mask used to clear the ALT_UART_MSR_DDCD register field value. */
2403 #define ALT_UART_MSR_DDCD_CLR_MSK 0xfffffff7
2404 /* The reset value of the ALT_UART_MSR_DDCD register field. */
2405 #define ALT_UART_MSR_DDCD_RESET 0x0
2406 /* Extracts the ALT_UART_MSR_DDCD field value from a register. */
2407 #define ALT_UART_MSR_DDCD_GET(value) (((value) & 0x00000008) >> 3)
2408 /* Produces a ALT_UART_MSR_DDCD register field value suitable for setting the register. */
2409 #define ALT_UART_MSR_DDCD_SET(value) (((value) << 3) & 0x00000008)
2410
2411 /*
2412  * Field : Clear to Send - cts
2413  *
2414  * This is used to indicate the current state of the modem control line uart_cts_n.
2415  * That is, this bit is the complement uart_cts_n. When the Clear to Send input
2416  * (uart_cts_n) is asserted it is an indication that the modem or data set is ready
2417  * to exchange data with the uart. In Loopback Mode bit [4] of register MCR is set
2418  * to one, CTS is the same as bit [1] RTS of register MCR.
2419  *
2420  * Field Enumeration Values:
2421  *
2422  * Enum | Value | Description
2423  * :--------------------------|:------|:------------------------------------------
2424  * ALT_UART_MSR_CTS_E_LOGIC1 | 0x0 | uart_cts_n input is de-asserted (logic 1)
2425  * ALT_UART_MSR_CTS_E_LOGIC0 | 0x1 | uart_cts_n input is asserted (logic 0)
2426  *
2427  * Field Access Macros:
2428  *
2429  */
2430 /*
2431  * Enumerated value for register field ALT_UART_MSR_CTS
2432  *
2433  * uart_cts_n input is de-asserted (logic 1)
2434  */
2435 #define ALT_UART_MSR_CTS_E_LOGIC1 0x0
2436 /*
2437  * Enumerated value for register field ALT_UART_MSR_CTS
2438  *
2439  * uart_cts_n input is asserted (logic 0)
2440  */
2441 #define ALT_UART_MSR_CTS_E_LOGIC0 0x1
2442
2443 /* The Least Significant Bit (LSB) position of the ALT_UART_MSR_CTS register field. */
2444 #define ALT_UART_MSR_CTS_LSB 4
2445 /* The Most Significant Bit (MSB) position of the ALT_UART_MSR_CTS register field. */
2446 #define ALT_UART_MSR_CTS_MSB 4
2447 /* The width in bits of the ALT_UART_MSR_CTS register field. */
2448 #define ALT_UART_MSR_CTS_WIDTH 1
2449 /* The mask used to set the ALT_UART_MSR_CTS register field value. */
2450 #define ALT_UART_MSR_CTS_SET_MSK 0x00000010
2451 /* The mask used to clear the ALT_UART_MSR_CTS register field value. */
2452 #define ALT_UART_MSR_CTS_CLR_MSK 0xffffffef
2453 /* The reset value of the ALT_UART_MSR_CTS register field. */
2454 #define ALT_UART_MSR_CTS_RESET 0x0
2455 /* Extracts the ALT_UART_MSR_CTS field value from a register. */
2456 #define ALT_UART_MSR_CTS_GET(value) (((value) & 0x00000010) >> 4)
2457 /* Produces a ALT_UART_MSR_CTS register field value suitable for setting the register. */
2458 #define ALT_UART_MSR_CTS_SET(value) (((value) << 4) & 0x00000010)
2459
2460 /*
2461  * Field : Data Set Ready - dsr
2462  *
2463  * This is used to indicate the current state of the modem control line uart_dsr_n.
2464  * That is this bit is the complement f uart_dsr_n. When the Data Set Ready input
2465  * (uart_dsr_n) is asserted it is an indication that the modem or data set is ready
2466  * to establish communications with the uart. In Loopback Mode bit [4] of register
2467  * MCR is set to one, DSR is the same as bit [0] (DTR) of register MCR.
2468  *
2469  * Field Enumeration Values:
2470  *
2471  * Enum | Value | Description
2472  * :--------------------------|:------|:------------------------------------------
2473  * ALT_UART_MSR_DSR_E_LOGIC1 | 0x0 | uart_dsr_n input is de-asserted (logic 1)
2474  * ALT_UART_MSR_DSR_E_LOGIC0 | 0x1 | uart_dsr_n input is asserted (logic 0)
2475  *
2476  * Field Access Macros:
2477  *
2478  */
2479 /*
2480  * Enumerated value for register field ALT_UART_MSR_DSR
2481  *
2482  * uart_dsr_n input is de-asserted (logic 1)
2483  */
2484 #define ALT_UART_MSR_DSR_E_LOGIC1 0x0
2485 /*
2486  * Enumerated value for register field ALT_UART_MSR_DSR
2487  *
2488  * uart_dsr_n input is asserted (logic 0)
2489  */
2490 #define ALT_UART_MSR_DSR_E_LOGIC0 0x1
2491
2492 /* The Least Significant Bit (LSB) position of the ALT_UART_MSR_DSR register field. */
2493 #define ALT_UART_MSR_DSR_LSB 5
2494 /* The Most Significant Bit (MSB) position of the ALT_UART_MSR_DSR register field. */
2495 #define ALT_UART_MSR_DSR_MSB 5
2496 /* The width in bits of the ALT_UART_MSR_DSR register field. */
2497 #define ALT_UART_MSR_DSR_WIDTH 1
2498 /* The mask used to set the ALT_UART_MSR_DSR register field value. */
2499 #define ALT_UART_MSR_DSR_SET_MSK 0x00000020
2500 /* The mask used to clear the ALT_UART_MSR_DSR register field value. */
2501 #define ALT_UART_MSR_DSR_CLR_MSK 0xffffffdf
2502 /* The reset value of the ALT_UART_MSR_DSR register field. */
2503 #define ALT_UART_MSR_DSR_RESET 0x0
2504 /* Extracts the ALT_UART_MSR_DSR field value from a register. */
2505 #define ALT_UART_MSR_DSR_GET(value) (((value) & 0x00000020) >> 5)
2506 /* Produces a ALT_UART_MSR_DSR register field value suitable for setting the register. */
2507 #define ALT_UART_MSR_DSR_SET(value) (((value) << 5) & 0x00000020)
2508
2509 /*
2510  * Field : Ring Indicator - ri
2511  *
2512  * This bit is used to indicate the current state of the modem control line
2513  * uart_ri_n. That is this bit is the complement uart_ri_n. When the Ring Indicator
2514  * input (uart_ri_n) is asserted it is an indication that a telephone ringing
2515  * signal has been received by the modem or data set. In Loopback Mode bit [4] of
2516  * register MCR set to one, RI is the same as bit [2] uart_out1_n of register MCR.
2517  *
2518  * Field Enumeration Values:
2519  *
2520  * Enum | Value | Description
2521  * :-------------------------|:------|:-----------------------------------------
2522  * ALT_UART_MSR_RI_E_LOGIC1 | 0x0 | uart_ri_n input is de-asserted (logic 1)
2523  * ALT_UART_MSR_RI_E_LOGIC0 | 0x1 | uart_ri_n input is asserted (logic 0)
2524  *
2525  * Field Access Macros:
2526  *
2527  */
2528 /*
2529  * Enumerated value for register field ALT_UART_MSR_RI
2530  *
2531  * uart_ri_n input is de-asserted (logic 1)
2532  */
2533 #define ALT_UART_MSR_RI_E_LOGIC1 0x0
2534 /*
2535  * Enumerated value for register field ALT_UART_MSR_RI
2536  *
2537  * uart_ri_n input is asserted (logic 0)
2538  */
2539 #define ALT_UART_MSR_RI_E_LOGIC0 0x1
2540
2541 /* The Least Significant Bit (LSB) position of the ALT_UART_MSR_RI register field. */
2542 #define ALT_UART_MSR_RI_LSB 6
2543 /* The Most Significant Bit (MSB) position of the ALT_UART_MSR_RI register field. */
2544 #define ALT_UART_MSR_RI_MSB 6
2545 /* The width in bits of the ALT_UART_MSR_RI register field. */
2546 #define ALT_UART_MSR_RI_WIDTH 1
2547 /* The mask used to set the ALT_UART_MSR_RI register field value. */
2548 #define ALT_UART_MSR_RI_SET_MSK 0x00000040
2549 /* The mask used to clear the ALT_UART_MSR_RI register field value. */
2550 #define ALT_UART_MSR_RI_CLR_MSK 0xffffffbf
2551 /* The reset value of the ALT_UART_MSR_RI register field. */
2552 #define ALT_UART_MSR_RI_RESET 0x0
2553 /* Extracts the ALT_UART_MSR_RI field value from a register. */
2554 #define ALT_UART_MSR_RI_GET(value) (((value) & 0x00000040) >> 6)
2555 /* Produces a ALT_UART_MSR_RI register field value suitable for setting the register. */
2556 #define ALT_UART_MSR_RI_SET(value) (((value) << 6) & 0x00000040)
2557
2558 /*
2559  * Field : Data Carrier Detect - dcd
2560  *
2561  * This is used to indicate the current state of the modem control line uart_dcd_n.
2562  * That is this bit is the complement uart_dcd_n. When the Data Carrier Detect
2563  * input (uart_dcd_n) is asserted it is an indication that the carrier has been
2564  * detected by the modem or data set. In Loopback Mode (MCR[4] set to one), DCD is
2565  * the same as MCR[3] (uart_out2).
2566  *
2567  * Field Enumeration Values:
2568  *
2569  * Enum | Value | Description
2570  * :--------------------------|:------|:------------------------------------------
2571  * ALT_UART_MSR_DCD_E_LOGIC1 | 0x0 | uart_dcd_n input is de-asserted (logic 1)
2572  * ALT_UART_MSR_DCD_E_LOGIC0 | 0x1 | uart_dcd_n input is asserted (logic 0)
2573  *
2574  * Field Access Macros:
2575  *
2576  */
2577 /*
2578  * Enumerated value for register field ALT_UART_MSR_DCD
2579  *
2580  * uart_dcd_n input is de-asserted (logic 1)
2581  */
2582 #define ALT_UART_MSR_DCD_E_LOGIC1 0x0
2583 /*
2584  * Enumerated value for register field ALT_UART_MSR_DCD
2585  *
2586  * uart_dcd_n input is asserted (logic 0)
2587  */
2588 #define ALT_UART_MSR_DCD_E_LOGIC0 0x1
2589
2590 /* The Least Significant Bit (LSB) position of the ALT_UART_MSR_DCD register field. */
2591 #define ALT_UART_MSR_DCD_LSB 7
2592 /* The Most Significant Bit (MSB) position of the ALT_UART_MSR_DCD register field. */
2593 #define ALT_UART_MSR_DCD_MSB 7
2594 /* The width in bits of the ALT_UART_MSR_DCD register field. */
2595 #define ALT_UART_MSR_DCD_WIDTH 1
2596 /* The mask used to set the ALT_UART_MSR_DCD register field value. */
2597 #define ALT_UART_MSR_DCD_SET_MSK 0x00000080
2598 /* The mask used to clear the ALT_UART_MSR_DCD register field value. */
2599 #define ALT_UART_MSR_DCD_CLR_MSK 0xffffff7f
2600 /* The reset value of the ALT_UART_MSR_DCD register field. */
2601 #define ALT_UART_MSR_DCD_RESET 0x0
2602 /* Extracts the ALT_UART_MSR_DCD field value from a register. */
2603 #define ALT_UART_MSR_DCD_GET(value) (((value) & 0x00000080) >> 7)
2604 /* Produces a ALT_UART_MSR_DCD register field value suitable for setting the register. */
2605 #define ALT_UART_MSR_DCD_SET(value) (((value) << 7) & 0x00000080)
2606
2607 #ifndef __ASSEMBLY__
2608 /*
2609  * WARNING: The C register and register group struct declarations are provided for
2610  * convenience and illustrative purposes. They should, however, be used with
2611  * caution as the C language standard provides no guarantees about the alignment or
2612  * atomicity of device memory accesses. The recommended practice for writing
2613  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2614  * alt_write_word() functions.
2615  *
2616  * The struct declaration for register ALT_UART_MSR.
2617  */
2619 {
2620  const uint32_t dcts : 1; /* Delta Clear to Send */
2621  const uint32_t ddsr : 1; /* Delta Data Set Ready */
2622  const uint32_t teri : 1; /* Trailing Edge of Ring Indicator */
2623  const uint32_t ddcd : 1; /* Delta Data Carrier Detect */
2624  const uint32_t cts : 1; /* Clear to Send */
2625  const uint32_t dsr : 1; /* Data Set Ready */
2626  const uint32_t ri : 1; /* Ring Indicator */
2627  const uint32_t dcd : 1; /* Data Carrier Detect */
2628  uint32_t : 24; /* *UNDEFINED* */
2629 };
2630
2631 /* The typedef declaration for register ALT_UART_MSR. */
2632 typedef volatile struct ALT_UART_MSR_s ALT_UART_MSR_t;
2633 #endif /* __ASSEMBLY__ */
2634
2635 /* The byte offset of the ALT_UART_MSR register from the beginning of the component. */
2636 #define ALT_UART_MSR_OFST 0x18
2637 /* The address of the ALT_UART_MSR register. */
2638 #define ALT_UART_MSR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_MSR_OFST))
2639
2640 /*
2641  * Register : Scratchpad Register - scr
2642  *
2643  * Scratchpad Register
2644  *
2645  * Register Layout
2646  *
2647  * Bits | Access | Reset | Description
2648  * :-------|:-------|:------|:--------------------
2649  * [7:0] | RW | 0x0 | Scratchpad Register
2650  * [31:8] | ??? | 0x0 | *UNDEFINED*
2651  *
2652  */
2653 /*
2654  * Field : Scratchpad Register - scr
2655  *
2656  * This register is for programmers to use as a temporary storage space.
2657  *
2658  * Field Access Macros:
2659  *
2660  */
2661 /* The Least Significant Bit (LSB) position of the ALT_UART_SCR_SCR register field. */
2662 #define ALT_UART_SCR_SCR_LSB 0
2663 /* The Most Significant Bit (MSB) position of the ALT_UART_SCR_SCR register field. */
2664 #define ALT_UART_SCR_SCR_MSB 7
2665 /* The width in bits of the ALT_UART_SCR_SCR register field. */
2666 #define ALT_UART_SCR_SCR_WIDTH 8
2667 /* The mask used to set the ALT_UART_SCR_SCR register field value. */
2668 #define ALT_UART_SCR_SCR_SET_MSK 0x000000ff
2669 /* The mask used to clear the ALT_UART_SCR_SCR register field value. */
2670 #define ALT_UART_SCR_SCR_CLR_MSK 0xffffff00
2671 /* The reset value of the ALT_UART_SCR_SCR register field. */
2672 #define ALT_UART_SCR_SCR_RESET 0x0
2673 /* Extracts the ALT_UART_SCR_SCR field value from a register. */
2674 #define ALT_UART_SCR_SCR_GET(value) (((value) & 0x000000ff) >> 0)
2675 /* Produces a ALT_UART_SCR_SCR register field value suitable for setting the register. */
2676 #define ALT_UART_SCR_SCR_SET(value) (((value) << 0) & 0x000000ff)
2677
2678 #ifndef __ASSEMBLY__
2679 /*
2680  * WARNING: The C register and register group struct declarations are provided for
2681  * convenience and illustrative purposes. They should, however, be used with
2682  * caution as the C language standard provides no guarantees about the alignment or
2683  * atomicity of device memory accesses. The recommended practice for writing
2684  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2685  * alt_write_word() functions.
2686  *
2687  * The struct declaration for register ALT_UART_SCR.
2688  */
2690 {
2691  uint32_t scr : 8; /* Scratchpad Register */
2692  uint32_t : 24; /* *UNDEFINED* */
2693 };
2694
2695 /* The typedef declaration for register ALT_UART_SCR. */
2696 typedef volatile struct ALT_UART_SCR_s ALT_UART_SCR_t;
2697 #endif /* __ASSEMBLY__ */
2698
2699 /* The byte offset of the ALT_UART_SCR register from the beginning of the component. */
2700 #define ALT_UART_SCR_OFST 0x1c
2701 /* The address of the ALT_UART_SCR register. */
2702 #define ALT_UART_SCR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_SCR_OFST))
2703
2704 /*
2705  * Register : Shadow Receive Buffer Register - srbr
2706  *
2707  * Used to accomadate burst accesses from the master.
2708  *
2709  * Register Layout
2710  *
2711  * Bits | Access | Reset | Description
2712  * :-------|:-------|:------|:----------------------
2713  * [7:0] | RW | 0x0 | Shadow Receive Buffer
2714  * [31:8] | ??? | 0x0 | *UNDEFINED*
2715  *
2716  */
2717 /*
2718  * Field : Shadow Receive Buffer - srbr
2719  *
2720  * This is a shadow register for the RBR and has been allocated one 32-bit location
2721  * so as to accommodate burst accesses from the master.This register contains the
2722  * data byte received on the serial input port (sin). The data in this register is
2723  * valid only if the Data Ready (DR) bit in the Line status Register (LSR) is set.
2724  * If FIFOs are disabled, bit [0] of register FCR set to zero, the data in the RBR
2725  * must be read before the next data arrives, otherwise it will be overwritten,
2726  * resulting in an overrun error. If FIFOs are enabled (FCR[0] set to one), this
2727  * register accesses the head of the receive FIFO. If the receive FIFO is full and
2728  * this register is not read before the next data character arrives, then the data
2729  * already in the FIFO will be preserved but any incoming data will be lost. An
2730  * overrun error will also occur.
2731  *
2732  * Field Access Macros:
2733  *
2734  */
2735 /* The Least Significant Bit (LSB) position of the ALT_UART_SRBR_SRBR register field. */
2736 #define ALT_UART_SRBR_SRBR_LSB 0
2737 /* The Most Significant Bit (MSB) position of the ALT_UART_SRBR_SRBR register field. */
2738 #define ALT_UART_SRBR_SRBR_MSB 7
2739 /* The width in bits of the ALT_UART_SRBR_SRBR register field. */
2740 #define ALT_UART_SRBR_SRBR_WIDTH 8
2741 /* The mask used to set the ALT_UART_SRBR_SRBR register field value. */
2742 #define ALT_UART_SRBR_SRBR_SET_MSK 0x000000ff
2743 /* The mask used to clear the ALT_UART_SRBR_SRBR register field value. */
2744 #define ALT_UART_SRBR_SRBR_CLR_MSK 0xffffff00
2745 /* The reset value of the ALT_UART_SRBR_SRBR register field. */
2746 #define ALT_UART_SRBR_SRBR_RESET 0x0
2747 /* Extracts the ALT_UART_SRBR_SRBR field value from a register. */
2748 #define ALT_UART_SRBR_SRBR_GET(value) (((value) & 0x000000ff) >> 0)
2749 /* Produces a ALT_UART_SRBR_SRBR register field value suitable for setting the register. */
2750 #define ALT_UART_SRBR_SRBR_SET(value) (((value) << 0) & 0x000000ff)
2751
2752 #ifndef __ASSEMBLY__
2753 /*
2754  * WARNING: The C register and register group struct declarations are provided for
2755  * convenience and illustrative purposes. They should, however, be used with
2756  * caution as the C language standard provides no guarantees about the alignment or
2757  * atomicity of device memory accesses. The recommended practice for writing
2758  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2759  * alt_write_word() functions.
2760  *
2761  * The struct declaration for register ALT_UART_SRBR.
2762  */
2764 {
2765  uint32_t srbr : 8; /* Shadow Receive Buffer */
2766  uint32_t : 24; /* *UNDEFINED* */
2767 };
2768
2769 /* The typedef declaration for register ALT_UART_SRBR. */
2770 typedef volatile struct ALT_UART_SRBR_s ALT_UART_SRBR_t;
2771 #endif /* __ASSEMBLY__ */
2772
2773 /* The byte offset of the ALT_UART_SRBR register from the beginning of the component. */
2774 #define ALT_UART_SRBR_OFST 0x30
2775 /* The address of the ALT_UART_SRBR register. */
2776 #define ALT_UART_SRBR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_SRBR_OFST))
2777
2778 /*
2779  * Register : Shadow Transmit Buffer Register - sthr
2780  *
2781  * Used to accomadate burst accesses from the master.
2782  *
2783  * Register Layout
2784  *
2785  * Bits | Access | Reset | Description
2786  * :-------|:-------|:------|:-----------------------
2787  * [7:0] | RW | 0x0 | Shadow Transmit Buffer
2788  * [31:8] | ??? | 0x0 | *UNDEFINED*
2789  *
2790  */
2791 /*
2792  * Field : Shadow Transmit Buffer - sthr
2793  *
2794  * This is a shadow register for the THR and has been allocated sixteen 32-bit
2795  * locations so as to accommodate burst accesses from the master. This register
2796  * contains data to be transmitted on the serial output port (sout). Data should
2797  * only be written to the THR when the THR Empty (THRE) bit (LSR[5]) is set. If
2798  * FIFO's are disabled bit [0] of register FCR set to zero and THRE is set, writing
2799  * a single character to the THR clears the THRE. Any additional writes to the THR
2800  * before the THRE is set again causes the THR data to be overwritten. If FIFO's
2801  * are enabled bit [0] of register FCR set to one and THRE is set, 128 characters
2802  * of data may be written to the THR before the FIFO is full. The UART FIFO depth
2803  * is configured for 128 characters. Any attempt to write data when the FIFO is
2804  * full results in the write data being lost.
2805  *
2806  * Field Access Macros:
2807  *
2808  */
2809 /* The Least Significant Bit (LSB) position of the ALT_UART_STHR_STHR register field. */
2810 #define ALT_UART_STHR_STHR_LSB 0
2811 /* The Most Significant Bit (MSB) position of the ALT_UART_STHR_STHR register field. */
2812 #define ALT_UART_STHR_STHR_MSB 7
2813 /* The width in bits of the ALT_UART_STHR_STHR register field. */
2814 #define ALT_UART_STHR_STHR_WIDTH 8
2815 /* The mask used to set the ALT_UART_STHR_STHR register field value. */
2816 #define ALT_UART_STHR_STHR_SET_MSK 0x000000ff
2817 /* The mask used to clear the ALT_UART_STHR_STHR register field value. */
2818 #define ALT_UART_STHR_STHR_CLR_MSK 0xffffff00
2819 /* The reset value of the ALT_UART_STHR_STHR register field. */
2820 #define ALT_UART_STHR_STHR_RESET 0x0
2821 /* Extracts the ALT_UART_STHR_STHR field value from a register. */
2822 #define ALT_UART_STHR_STHR_GET(value) (((value) & 0x000000ff) >> 0)
2823 /* Produces a ALT_UART_STHR_STHR register field value suitable for setting the register. */
2824 #define ALT_UART_STHR_STHR_SET(value) (((value) << 0) & 0x000000ff)
2825
2826 #ifndef __ASSEMBLY__
2827 /*
2828  * WARNING: The C register and register group struct declarations are provided for
2829  * convenience and illustrative purposes. They should, however, be used with
2830  * caution as the C language standard provides no guarantees about the alignment or
2831  * atomicity of device memory accesses. The recommended practice for writing
2832  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2833  * alt_write_word() functions.
2834  *
2835  * The struct declaration for register ALT_UART_STHR.
2836  */
2838 {
2839  uint32_t sthr : 8; /* Shadow Transmit Buffer */
2840  uint32_t : 24; /* *UNDEFINED* */
2841 };
2842
2843 /* The typedef declaration for register ALT_UART_STHR. */
2844 typedef volatile struct ALT_UART_STHR_s ALT_UART_STHR_t;
2845 #endif /* __ASSEMBLY__ */
2846
2847 /* The byte offset of the ALT_UART_STHR register from the beginning of the component. */
2848 #define ALT_UART_STHR_OFST 0x34
2849 /* The address of the ALT_UART_STHR register. */
2850 #define ALT_UART_STHR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_STHR_OFST))
2851
2852 /*
2853  * Register : FIFO Access Register - far
2854  *
2855  * This register is used in FIFO access testing.
2856  *
2857  * Register Layout
2858  *
2859  * Bits | Access | Reset | Description
2860  * :-------|:-------|:------|:----------------
2861  * [0] | RW | 0x0 | FIFO ACCESS Bit
2862  * [31:1] | ??? | 0x0 | *UNDEFINED*
2863  *
2864  */
2865 /*
2866  * Field : FIFO ACCESS Bit - srbr_sthr
2867  *
2868  * This register is used to enable a FIFO access mode for testing, so that the
2869  * receive FIFO can be written by the master and the transmit FIFO can be read by
2870  * the master when FIFO's are enabled. When FIFO's are not enabled it allows the
2871  * RBR to be written by the master and the THR to be read by the master
2872  *
2873  * Note: That when the FIFO access mode is enabled/disabled, the control portion of
2874  * the receive FIFO and transmit FIFO is reset and the FIFO's are treated as empty.
2875  *
2876  * Field Enumeration Values:
2877  *
2878  * Enum | Value | Description
2879  * :------------------------------|:------|:--------------------------
2880  * ALT_UART_FAR_SRBR_STHR_E_DISD | 0x0 | FIFO access mode disabled
2881  * ALT_UART_FAR_SRBR_STHR_E_END | 0x1 | FIFO access mode enabled
2882  *
2883  * Field Access Macros:
2884  *
2885  */
2886 /*
2887  * Enumerated value for register field ALT_UART_FAR_SRBR_STHR
2888  *
2889  * FIFO access mode disabled
2890  */
2891 #define ALT_UART_FAR_SRBR_STHR_E_DISD 0x0
2892 /*
2893  * Enumerated value for register field ALT_UART_FAR_SRBR_STHR
2894  *
2895  * FIFO access mode enabled
2896  */
2897 #define ALT_UART_FAR_SRBR_STHR_E_END 0x1
2898
2899 /* The Least Significant Bit (LSB) position of the ALT_UART_FAR_SRBR_STHR register field. */
2900 #define ALT_UART_FAR_SRBR_STHR_LSB 0
2901 /* The Most Significant Bit (MSB) position of the ALT_UART_FAR_SRBR_STHR register field. */
2902 #define ALT_UART_FAR_SRBR_STHR_MSB 0
2903 /* The width in bits of the ALT_UART_FAR_SRBR_STHR register field. */
2904 #define ALT_UART_FAR_SRBR_STHR_WIDTH 1
2905 /* The mask used to set the ALT_UART_FAR_SRBR_STHR register field value. */
2906 #define ALT_UART_FAR_SRBR_STHR_SET_MSK 0x00000001
2907 /* The mask used to clear the ALT_UART_FAR_SRBR_STHR register field value. */
2908 #define ALT_UART_FAR_SRBR_STHR_CLR_MSK 0xfffffffe
2909 /* The reset value of the ALT_UART_FAR_SRBR_STHR register field. */
2910 #define ALT_UART_FAR_SRBR_STHR_RESET 0x0
2911 /* Extracts the ALT_UART_FAR_SRBR_STHR field value from a register. */
2912 #define ALT_UART_FAR_SRBR_STHR_GET(value) (((value) & 0x00000001) >> 0)
2913 /* Produces a ALT_UART_FAR_SRBR_STHR register field value suitable for setting the register. */
2914 #define ALT_UART_FAR_SRBR_STHR_SET(value) (((value) << 0) & 0x00000001)
2915
2916 #ifndef __ASSEMBLY__
2917 /*
2918  * WARNING: The C register and register group struct declarations are provided for
2919  * convenience and illustrative purposes. They should, however, be used with
2920  * caution as the C language standard provides no guarantees about the alignment or
2921  * atomicity of device memory accesses. The recommended practice for writing
2922  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2923  * alt_write_word() functions.
2924  *
2925  * The struct declaration for register ALT_UART_FAR.
2926  */
2928 {
2929  uint32_t srbr_sthr : 1; /* FIFO ACCESS Bit */
2930  uint32_t : 31; /* *UNDEFINED* */
2931 };
2932
2933 /* The typedef declaration for register ALT_UART_FAR. */
2934 typedef volatile struct ALT_UART_FAR_s ALT_UART_FAR_t;
2935 #endif /* __ASSEMBLY__ */
2936
2937 /* The byte offset of the ALT_UART_FAR register from the beginning of the component. */
2938 #define ALT_UART_FAR_OFST 0x70
2939 /* The address of the ALT_UART_FAR register. */
2940 #define ALT_UART_FAR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_FAR_OFST))
2941
2942 /*
2943  * Register : Transmit FIFO Read Register - tfr
2944  *
2945  * Used in FIFO Access test mode.
2946  *
2947  * Register Layout
2948  *
2949  * Bits | Access | Reset | Description
2950  * :-------|:-------|:------|:-------------------
2951  * [7:0] | R | 0x0 | Transmit FIFO Read
2952  * [31:8] | ??? | 0x0 | *UNDEFINED*
2953  *
2954  */
2955 /*
2956  * Field : Transmit FIFO Read - tfr
2957  *
2958  * These bits are only valid when FIFO access mode is enabled (FAR[0] is set to
2959  * one). When FIFO's are enabled, reading this register gives the data at the top
2960  * of the transmit FIFO. Each consecutive read pops the transmit FIFO and gives the
2961  * next data value that is currently at the top of the FIFO. When FIFO's are not
2962  * enabled, reading this register gives the data in the THR.
2963  *
2964  * Field Access Macros:
2965  *
2966  */
2967 /* The Least Significant Bit (LSB) position of the ALT_UART_TFR_TFR register field. */
2968 #define ALT_UART_TFR_TFR_LSB 0
2969 /* The Most Significant Bit (MSB) position of the ALT_UART_TFR_TFR register field. */
2970 #define ALT_UART_TFR_TFR_MSB 7
2971 /* The width in bits of the ALT_UART_TFR_TFR register field. */
2972 #define ALT_UART_TFR_TFR_WIDTH 8
2973 /* The mask used to set the ALT_UART_TFR_TFR register field value. */
2974 #define ALT_UART_TFR_TFR_SET_MSK 0x000000ff
2975 /* The mask used to clear the ALT_UART_TFR_TFR register field value. */
2976 #define ALT_UART_TFR_TFR_CLR_MSK 0xffffff00
2977 /* The reset value of the ALT_UART_TFR_TFR register field. */
2978 #define ALT_UART_TFR_TFR_RESET 0x0
2979 /* Extracts the ALT_UART_TFR_TFR field value from a register. */
2980 #define ALT_UART_TFR_TFR_GET(value) (((value) & 0x000000ff) >> 0)
2981 /* Produces a ALT_UART_TFR_TFR register field value suitable for setting the register. */
2982 #define ALT_UART_TFR_TFR_SET(value) (((value) << 0) & 0x000000ff)
2983
2984 #ifndef __ASSEMBLY__
2985 /*
2986  * WARNING: The C register and register group struct declarations are provided for
2987  * convenience and illustrative purposes. They should, however, be used with
2988  * caution as the C language standard provides no guarantees about the alignment or
2989  * atomicity of device memory accesses. The recommended practice for writing
2990  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2991  * alt_write_word() functions.
2992  *
2993  * The struct declaration for register ALT_UART_TFR.
2994  */
2996 {
2997  const uint32_t tfr : 8; /* Transmit FIFO Read */
2998  uint32_t : 24; /* *UNDEFINED* */
2999 };
3000
3001 /* The typedef declaration for register ALT_UART_TFR. */
3002 typedef volatile struct ALT_UART_TFR_s ALT_UART_TFR_t;
3003 #endif /* __ASSEMBLY__ */
3004
3005 /* The byte offset of the ALT_UART_TFR register from the beginning of the component. */
3006 #define ALT_UART_TFR_OFST 0x74
3007 /* The address of the ALT_UART_TFR register. */
3008 #define ALT_UART_TFR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_TFR_OFST))
3009
3010 /*
3011  * Register : Receive FIFO Write - RFW
3012  *
3013  * Used only with FIFO access test mode.
3014  *
3015  * Register Layout
3016  *
3017  * Bits | Access | Reset | Description
3018  * :--------|:-------|:------|:---------------------------
3019  * [7:0] | W | 0x0 | Receive FIFO Write Field
3020  * [8] | W | 0x0 | Receive FIFO Parity Error
3021  * [9] | W | 0x0 | Receive FIFO Framing Error
3022  * [31:10] | ??? | 0x0 | *UNDEFINED*
3023  *
3024  */
3025 /*
3026  * Field : Receive FIFO Write Field - rfwd
3027  *
3028  * These bits are only valid when FIFO access mode is enabled (FAR[0] is set to
3029  * one). When FIFO's are enabled, the data that is written to the RFWD is pushed
3030  * into the receive FIFO. Each consecutive write pushes the new data to the next
3031  * write location in the receive FIFO. When FIFO's are not enabled, the data that
3032  * is written to the RFWD is pushed into the RBR.
3033  *
3034  * Field Access Macros:
3035  *
3036  */
3037 /* The Least Significant Bit (LSB) position of the ALT_UART_RFW_RFWD register field. */
3038 #define ALT_UART_RFW_RFWD_LSB 0
3039 /* The Most Significant Bit (MSB) position of the ALT_UART_RFW_RFWD register field. */
3040 #define ALT_UART_RFW_RFWD_MSB 7
3041 /* The width in bits of the ALT_UART_RFW_RFWD register field. */
3042 #define ALT_UART_RFW_RFWD_WIDTH 8
3043 /* The mask used to set the ALT_UART_RFW_RFWD register field value. */
3044 #define ALT_UART_RFW_RFWD_SET_MSK 0x000000ff
3045 /* The mask used to clear the ALT_UART_RFW_RFWD register field value. */
3046 #define ALT_UART_RFW_RFWD_CLR_MSK 0xffffff00
3047 /* The reset value of the ALT_UART_RFW_RFWD register field. */
3048 #define ALT_UART_RFW_RFWD_RESET 0x0
3049 /* Extracts the ALT_UART_RFW_RFWD field value from a register. */
3050 #define ALT_UART_RFW_RFWD_GET(value) (((value) & 0x000000ff) >> 0)
3051 /* Produces a ALT_UART_RFW_RFWD register field value suitable for setting the register. */
3052 #define ALT_UART_RFW_RFWD_SET(value) (((value) << 0) & 0x000000ff)
3053
3054 /*
3055  * Field : Receive FIFO Parity Error - rfpe
3056  *
3057  * These bits are only valid when FIFO access mode is enabled (FAR[0] is set to
3058  * one). When FIFO's are enabled, this bit is used to write parity error detection
3059  * information to the receive FIFO. When FIFO's are not enabled, this bit is used
3060  * to write parity error detection information to the RBR.
3061  *
3062  * Field Access Macros:
3063  *
3064  */
3065 /* The Least Significant Bit (LSB) position of the ALT_UART_RFW_RFPE register field. */
3066 #define ALT_UART_RFW_RFPE_LSB 8
3067 /* The Most Significant Bit (MSB) position of the ALT_UART_RFW_RFPE register field. */
3068 #define ALT_UART_RFW_RFPE_MSB 8
3069 /* The width in bits of the ALT_UART_RFW_RFPE register field. */
3070 #define ALT_UART_RFW_RFPE_WIDTH 1
3071 /* The mask used to set the ALT_UART_RFW_RFPE register field value. */
3072 #define ALT_UART_RFW_RFPE_SET_MSK 0x00000100
3073 /* The mask used to clear the ALT_UART_RFW_RFPE register field value. */
3074 #define ALT_UART_RFW_RFPE_CLR_MSK 0xfffffeff
3075 /* The reset value of the ALT_UART_RFW_RFPE register field. */
3076 #define ALT_UART_RFW_RFPE_RESET 0x0
3077 /* Extracts the ALT_UART_RFW_RFPE field value from a register. */
3078 #define ALT_UART_RFW_RFPE_GET(value) (((value) & 0x00000100) >> 8)
3079 /* Produces a ALT_UART_RFW_RFPE register field value suitable for setting the register. */
3080 #define ALT_UART_RFW_RFPE_SET(value) (((value) << 8) & 0x00000100)
3081
3082 /*
3083  * Field : Receive FIFO Framing Error - RFFE
3084  *
3085  * These bits are only valid when FIFO access mode is enabled (FAR[0] is set to
3086  * one). When FIFO's are enabled, this bit is used to write framing error detection
3087  * information to the receive FIFO. When FIFO's are not enabled, this bit is used
3088  * to write framing error detection information to the RBR.
3089  *
3090  * Field Access Macros:
3091  *
3092  */
3093 /* The Least Significant Bit (LSB) position of the ALT_UART_RFW_RFFE register field. */
3094 #define ALT_UART_RFW_RFFE_LSB 9
3095 /* The Most Significant Bit (MSB) position of the ALT_UART_RFW_RFFE register field. */
3096 #define ALT_UART_RFW_RFFE_MSB 9
3097 /* The width in bits of the ALT_UART_RFW_RFFE register field. */
3098 #define ALT_UART_RFW_RFFE_WIDTH 1
3099 /* The mask used to set the ALT_UART_RFW_RFFE register field value. */
3100 #define ALT_UART_RFW_RFFE_SET_MSK 0x00000200
3101 /* The mask used to clear the ALT_UART_RFW_RFFE register field value. */
3102 #define ALT_UART_RFW_RFFE_CLR_MSK 0xfffffdff
3103 /* The reset value of the ALT_UART_RFW_RFFE register field. */
3104 #define ALT_UART_RFW_RFFE_RESET 0x0
3105 /* Extracts the ALT_UART_RFW_RFFE field value from a register. */
3106 #define ALT_UART_RFW_RFFE_GET(value) (((value) & 0x00000200) >> 9)
3107 /* Produces a ALT_UART_RFW_RFFE register field value suitable for setting the register. */
3108 #define ALT_UART_RFW_RFFE_SET(value) (((value) << 9) & 0x00000200)
3109
3110 #ifndef __ASSEMBLY__
3111 /*
3112  * WARNING: The C register and register group struct declarations are provided for
3113  * convenience and illustrative purposes. They should, however, be used with
3114  * caution as the C language standard provides no guarantees about the alignment or
3115  * atomicity of device memory accesses. The recommended practice for writing
3116  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3117  * alt_write_word() functions.
3118  *
3119  * The struct declaration for register ALT_UART_RFW.
3120  */
3122 {
3123  uint32_t rfwd : 8; /* Receive FIFO Write Field */
3124  uint32_t rfpe : 1; /* Receive FIFO Parity Error */
3125  uint32_t RFFE : 1; /* Receive FIFO Framing Error */
3126  uint32_t : 22; /* *UNDEFINED* */
3127 };
3128
3129 /* The typedef declaration for register ALT_UART_RFW. */
3130 typedef volatile struct ALT_UART_RFW_s ALT_UART_RFW_t;
3131 #endif /* __ASSEMBLY__ */
3132
3133 /* The byte offset of the ALT_UART_RFW register from the beginning of the component. */
3134 #define ALT_UART_RFW_OFST 0x78
3135 /* The address of the ALT_UART_RFW register. */
3136 #define ALT_UART_RFW_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_RFW_OFST))
3137
3138 /*
3139  * Register : UART Status Register - usr
3140  *
3141  * Status of FIFO Operations.
3142  *
3143  * Register Layout
3144  *
3145  * Bits | Access | Reset | Description
3146  * :-------|:-------|:------|:-----------------------
3147  * [0] | ??? | 0x0 | *UNDEFINED*
3148  * [1] | R | 0x1 | Transmit FIFO Not Full
3149  * [2] | R | 0x1 | Transmit FIFO Empty
3150  * [3] | R | 0x0 | Receive FIFO Not Empty
3151  * [4] | R | 0x0 | Receive FIFO Full
3152  * [31:5] | ??? | 0x0 | *UNDEFINED*
3153  *
3154  */
3155 /*
3156  * Field : Transmit FIFO Not Full - tfnf
3157  *
3158  * This Bit is used to indicate that the transmit FIFO in not full. This bit is
3159  * cleared when the Tx FIFO is full.
3160  *
3161  * Field Enumeration Values:
3162  *
3163  * Enum | Value | Description
3164  * :----------------------------|:------|:--------------------------
3165  * ALT_UART_USR_TFNF_E_FULL | 0x0 | Transmit FIFO is full
3166  * ALT_UART_USR_TFNF_E_NOTFULL | 0x1 | Transmit FIFO is not full
3167  *
3168  * Field Access Macros:
3169  *
3170  */
3171 /*
3172  * Enumerated value for register field ALT_UART_USR_TFNF
3173  *
3174  * Transmit FIFO is full
3175  */
3176 #define ALT_UART_USR_TFNF_E_FULL 0x0
3177 /*
3178  * Enumerated value for register field ALT_UART_USR_TFNF
3179  *
3180  * Transmit FIFO is not full
3181  */
3182 #define ALT_UART_USR_TFNF_E_NOTFULL 0x1
3183
3184 /* The Least Significant Bit (LSB) position of the ALT_UART_USR_TFNF register field. */
3185 #define ALT_UART_USR_TFNF_LSB 1
3186 /* The Most Significant Bit (MSB) position of the ALT_UART_USR_TFNF register field. */
3187 #define ALT_UART_USR_TFNF_MSB 1
3188 /* The width in bits of the ALT_UART_USR_TFNF register field. */
3189 #define ALT_UART_USR_TFNF_WIDTH 1
3190 /* The mask used to set the ALT_UART_USR_TFNF register field value. */
3191 #define ALT_UART_USR_TFNF_SET_MSK 0x00000002
3192 /* The mask used to clear the ALT_UART_USR_TFNF register field value. */
3193 #define ALT_UART_USR_TFNF_CLR_MSK 0xfffffffd
3194 /* The reset value of the ALT_UART_USR_TFNF register field. */
3195 #define ALT_UART_USR_TFNF_RESET 0x1
3196 /* Extracts the ALT_UART_USR_TFNF field value from a register. */
3197 #define ALT_UART_USR_TFNF_GET(value) (((value) & 0x00000002) >> 1)
3198 /* Produces a ALT_UART_USR_TFNF register field value suitable for setting the register. */
3199 #define ALT_UART_USR_TFNF_SET(value) (((value) << 1) & 0x00000002)
3200
3201 /*
3202  * Field : Transmit FIFO Empty - tfe
3203  *
3204  * This is used to indicate that the transmit FIFO is completely empty. This bit is
3205  * cleared when the Tx FIFO is no longer empty.
3206  *
3207  * Field Enumeration Values:
3208  *
3209  * Enum | Value | Description
3210  * :----------------------------|:------|:---------------------------
3211  * ALT_UART_USR_TFE_E_NOTEMPTY | 0x0 | Transmit FIFO is not empty
3212  * ALT_UART_USR_TFE_E_EMPTY | 0x1 | Transmit FIFO is empty
3213  *
3214  * Field Access Macros:
3215  *
3216  */
3217 /*
3218  * Enumerated value for register field ALT_UART_USR_TFE
3219  *
3220  * Transmit FIFO is not empty
3221  */
3222 #define ALT_UART_USR_TFE_E_NOTEMPTY 0x0
3223 /*
3224  * Enumerated value for register field ALT_UART_USR_TFE
3225  *
3226  * Transmit FIFO is empty
3227  */
3228 #define ALT_UART_USR_TFE_E_EMPTY 0x1
3229
3230 /* The Least Significant Bit (LSB) position of the ALT_UART_USR_TFE register field. */
3231 #define ALT_UART_USR_TFE_LSB 2
3232 /* The Most Significant Bit (MSB) position of the ALT_UART_USR_TFE register field. */
3233 #define ALT_UART_USR_TFE_MSB 2
3234 /* The width in bits of the ALT_UART_USR_TFE register field. */
3235 #define ALT_UART_USR_TFE_WIDTH 1
3236 /* The mask used to set the ALT_UART_USR_TFE register field value. */
3237 #define ALT_UART_USR_TFE_SET_MSK 0x00000004
3238 /* The mask used to clear the ALT_UART_USR_TFE register field value. */
3239 #define ALT_UART_USR_TFE_CLR_MSK 0xfffffffb
3240 /* The reset value of the ALT_UART_USR_TFE register field. */
3241 #define ALT_UART_USR_TFE_RESET 0x1
3242 /* Extracts the ALT_UART_USR_TFE field value from a register. */
3243 #define ALT_UART_USR_TFE_GET(value) (((value) & 0x00000004) >> 2)
3244 /* Produces a ALT_UART_USR_TFE register field value suitable for setting the register. */
3245 #define ALT_UART_USR_TFE_SET(value) (((value) << 2) & 0x00000004)
3246
3247 /*
3248  * Field : Receive FIFO Not Empty - rfne
3249  *
3250  * This Bit is used to indicate that the receive FIFO contains one or more entries.
3251  * This bit is cleared when the Rx FIFO is empty.
3252  *
3253  * Field Enumeration Values:
3254  *
3255  * Enum | Value | Description
3256  * :-----------------------------|:------|:--------------------------
3257  * ALT_UART_USR_RFNE_E_EMPTY | 0x0 | Receiive FIFO is empty
3258  * ALT_UART_USR_RFNE_E_NOTEMPTY | 0x1 | Receive FIFO is not empty
3259  *
3260  * Field Access Macros:
3261  *
3262  */
3263 /*
3264  * Enumerated value for register field ALT_UART_USR_RFNE
3265  *
3266  * Receiive FIFO is empty
3267  */
3268 #define ALT_UART_USR_RFNE_E_EMPTY 0x0
3269 /*
3270  * Enumerated value for register field ALT_UART_USR_RFNE
3271  *
3272  * Receive FIFO is not empty
3273  */
3274 #define ALT_UART_USR_RFNE_E_NOTEMPTY 0x1
3275
3276 /* The Least Significant Bit (LSB) position of the ALT_UART_USR_RFNE register field. */
3277 #define ALT_UART_USR_RFNE_LSB 3
3278 /* The Most Significant Bit (MSB) position of the ALT_UART_USR_RFNE register field. */
3279 #define ALT_UART_USR_RFNE_MSB 3
3280 /* The width in bits of the ALT_UART_USR_RFNE register field. */
3281 #define ALT_UART_USR_RFNE_WIDTH 1
3282 /* The mask used to set the ALT_UART_USR_RFNE register field value. */
3283 #define ALT_UART_USR_RFNE_SET_MSK 0x00000008
3284 /* The mask used to clear the ALT_UART_USR_RFNE register field value. */
3285 #define ALT_UART_USR_RFNE_CLR_MSK 0xfffffff7
3286 /* The reset value of the ALT_UART_USR_RFNE register field. */
3287 #define ALT_UART_USR_RFNE_RESET 0x0
3288 /* Extracts the ALT_UART_USR_RFNE field value from a register. */
3289 #define ALT_UART_USR_RFNE_GET(value) (((value) & 0x00000008) >> 3)
3290 /* Produces a ALT_UART_USR_RFNE register field value suitable for setting the register. */
3291 #define ALT_UART_USR_RFNE_SET(value) (((value) << 3) & 0x00000008)
3292
3293 /*
3294  * Field : Receive FIFO Full - rff
3295  *
3296  * This Bit is used to indicate that the receive FIFO is completely full. This bit
3297  * is cleared when the Rx FIFO is no longer full.
3298  *
3299  * Field Enumeration Values:
3300  *
3301  * Enum | Value | Description
3302  * :---------------------------|:------|:-----------------------
3303  * ALT_UART_USR_RFF_E_NOTFULL | 0x0 | Receiive FIFO not full
3304  * ALT_UART_USR_RFF_E_FULL | 0x1 | Transmit FIFO is full
3305  *
3306  * Field Access Macros:
3307  *
3308  */
3309 /*
3310  * Enumerated value for register field ALT_UART_USR_RFF
3311  *
3312  * Receiive FIFO not full
3313  */
3314 #define ALT_UART_USR_RFF_E_NOTFULL 0x0
3315 /*
3316  * Enumerated value for register field ALT_UART_USR_RFF
3317  *
3318  * Transmit FIFO is full
3319  */
3320 #define ALT_UART_USR_RFF_E_FULL 0x1
3321
3322 /* The Least Significant Bit (LSB) position of the ALT_UART_USR_RFF register field. */
3323 #define ALT_UART_USR_RFF_LSB 4
3324 /* The Most Significant Bit (MSB) position of the ALT_UART_USR_RFF register field. */
3325 #define ALT_UART_USR_RFF_MSB 4
3326 /* The width in bits of the ALT_UART_USR_RFF register field. */
3327 #define ALT_UART_USR_RFF_WIDTH 1
3328 /* The mask used to set the ALT_UART_USR_RFF register field value. */
3329 #define ALT_UART_USR_RFF_SET_MSK 0x00000010
3330 /* The mask used to clear the ALT_UART_USR_RFF register field value. */
3331 #define ALT_UART_USR_RFF_CLR_MSK 0xffffffef
3332 /* The reset value of the ALT_UART_USR_RFF register field. */
3333 #define ALT_UART_USR_RFF_RESET 0x0
3334 /* Extracts the ALT_UART_USR_RFF field value from a register. */
3335 #define ALT_UART_USR_RFF_GET(value) (((value) & 0x00000010) >> 4)
3336 /* Produces a ALT_UART_USR_RFF register field value suitable for setting the register. */
3337 #define ALT_UART_USR_RFF_SET(value) (((value) << 4) & 0x00000010)
3338
3339 #ifndef __ASSEMBLY__
3340 /*
3341  * WARNING: The C register and register group struct declarations are provided for
3342  * convenience and illustrative purposes. They should, however, be used with
3343  * caution as the C language standard provides no guarantees about the alignment or
3344  * atomicity of device memory accesses. The recommended practice for writing
3345  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3346  * alt_write_word() functions.
3347  *
3348  * The struct declaration for register ALT_UART_USR.
3349  */
3351 {
3352  uint32_t : 1; /* *UNDEFINED* */
3353  const uint32_t tfnf : 1; /* Transmit FIFO Not Full */
3354  const uint32_t tfe : 1; /* Transmit FIFO Empty */
3355  const uint32_t rfne : 1; /* Receive FIFO Not Empty */
3356  const uint32_t rff : 1; /* Receive FIFO Full */
3357  uint32_t : 27; /* *UNDEFINED* */
3358 };
3359
3360 /* The typedef declaration for register ALT_UART_USR. */
3361 typedef volatile struct ALT_UART_USR_s ALT_UART_USR_t;
3362 #endif /* __ASSEMBLY__ */
3363
3364 /* The byte offset of the ALT_UART_USR register from the beginning of the component. */
3365 #define ALT_UART_USR_OFST 0x7c
3366 /* The address of the ALT_UART_USR register. */
3367 #define ALT_UART_USR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_USR_OFST))
3368
3369 /*
3370  * Register : Transmit FIFO Level - tfl
3371  *
3372  * This register is used to specify the number of data entries in the Tx FIFO.
3373  * Status Bits in USR register monitor the FIFO state.
3374  *
3375  * Register Layout
3376  *
3377  * Bits | Access | Reset | Description
3378  * :-------|:-------|:------|:--------------------
3379  * [4:0] | R | 0x0 | Transmit FIFO Level
3380  * [31:5] | ??? | 0x0 | *UNDEFINED*
3381  *
3382  */
3383 /*
3384  * Field : Transmit FIFO Level - tfl
3385  *
3386  * This indicates the number of data entries in the transmit FIFO.
3387  *
3388  * Field Access Macros:
3389  *
3390  */
3391 /* The Least Significant Bit (LSB) position of the ALT_UART_TFL_TFL register field. */
3392 #define ALT_UART_TFL_TFL_LSB 0
3393 /* The Most Significant Bit (MSB) position of the ALT_UART_TFL_TFL register field. */
3394 #define ALT_UART_TFL_TFL_MSB 4
3395 /* The width in bits of the ALT_UART_TFL_TFL register field. */
3396 #define ALT_UART_TFL_TFL_WIDTH 5
3397 /* The mask used to set the ALT_UART_TFL_TFL register field value. */
3398 #define ALT_UART_TFL_TFL_SET_MSK 0x0000001f
3399 /* The mask used to clear the ALT_UART_TFL_TFL register field value. */
3400 #define ALT_UART_TFL_TFL_CLR_MSK 0xffffffe0
3401 /* The reset value of the ALT_UART_TFL_TFL register field. */
3402 #define ALT_UART_TFL_TFL_RESET 0x0
3403 /* Extracts the ALT_UART_TFL_TFL field value from a register. */
3404 #define ALT_UART_TFL_TFL_GET(value) (((value) & 0x0000001f) >> 0)
3405 /* Produces a ALT_UART_TFL_TFL register field value suitable for setting the register. */
3406 #define ALT_UART_TFL_TFL_SET(value) (((value) << 0) & 0x0000001f)
3407
3408 #ifndef __ASSEMBLY__
3409 /*
3410  * WARNING: The C register and register group struct declarations are provided for
3411  * convenience and illustrative purposes. They should, however, be used with
3412  * caution as the C language standard provides no guarantees about the alignment or
3413  * atomicity of device memory accesses. The recommended practice for writing
3414  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3415  * alt_write_word() functions.
3416  *
3417  * The struct declaration for register ALT_UART_TFL.
3418  */
3420 {
3421  const uint32_t tfl : 5; /* Transmit FIFO Level */
3422  uint32_t : 27; /* *UNDEFINED* */
3423 };
3424
3425 /* The typedef declaration for register ALT_UART_TFL. */
3426 typedef volatile struct ALT_UART_TFL_s ALT_UART_TFL_t;
3427 #endif /* __ASSEMBLY__ */
3428
3429 /* The byte offset of the ALT_UART_TFL register from the beginning of the component. */
3430 #define ALT_UART_TFL_OFST 0x80
3431 /* The address of the ALT_UART_TFL register. */
3432 #define ALT_UART_TFL_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_TFL_OFST))
3433
3434 /*
3435  * Register : Receive FIFO Level Write - rfl
3436  *
3437  * This register is used to specify the number of data entries in the Tx FIFO.
3438  * Status Bits in USR register monitor the FIFO state.
3439  *
3440  * Register Layout
3441  *
3442  * Bits | Access | Reset | Description
3443  * :-------|:-------|:------|:--------------------------
3444  * [4:0] | R | 0x0 | Receive FIFO Level Status
3445  * [31:5] | ??? | 0x0 | *UNDEFINED*
3446  *
3447  */
3448 /*
3449  * Field : Receive FIFO Level Status - rfl
3450  *
3451  * This indicates the number of data entries in the receive FIFO.
3452  *
3453  * Field Access Macros:
3454  *
3455  */
3456 /* The Least Significant Bit (LSB) position of the ALT_UART_RFL_RFL register field. */
3457 #define ALT_UART_RFL_RFL_LSB 0
3458 /* The Most Significant Bit (MSB) position of the ALT_UART_RFL_RFL register field. */
3459 #define ALT_UART_RFL_RFL_MSB 4
3460 /* The width in bits of the ALT_UART_RFL_RFL register field. */
3461 #define ALT_UART_RFL_RFL_WIDTH 5
3462 /* The mask used to set the ALT_UART_RFL_RFL register field value. */
3463 #define ALT_UART_RFL_RFL_SET_MSK 0x0000001f
3464 /* The mask used to clear the ALT_UART_RFL_RFL register field value. */
3465 #define ALT_UART_RFL_RFL_CLR_MSK 0xffffffe0
3466 /* The reset value of the ALT_UART_RFL_RFL register field. */
3467 #define ALT_UART_RFL_RFL_RESET 0x0
3468 /* Extracts the ALT_UART_RFL_RFL field value from a register. */
3469 #define ALT_UART_RFL_RFL_GET(value) (((value) & 0x0000001f) >> 0)
3470 /* Produces a ALT_UART_RFL_RFL register field value suitable for setting the register. */
3471 #define ALT_UART_RFL_RFL_SET(value) (((value) << 0) & 0x0000001f)
3472
3473 #ifndef __ASSEMBLY__
3474 /*
3475  * WARNING: The C register and register group struct declarations are provided for
3476  * convenience and illustrative purposes. They should, however, be used with
3477  * caution as the C language standard provides no guarantees about the alignment or
3478  * atomicity of device memory accesses. The recommended practice for writing
3479  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3480  * alt_write_word() functions.
3481  *
3482  * The struct declaration for register ALT_UART_RFL.
3483  */
3485 {
3486  const uint32_t rfl : 5; /* Receive FIFO Level Status */
3487  uint32_t : 27; /* *UNDEFINED* */
3488 };
3489
3490 /* The typedef declaration for register ALT_UART_RFL. */
3491 typedef volatile struct ALT_UART_RFL_s ALT_UART_RFL_t;
3492 #endif /* __ASSEMBLY__ */
3493
3494 /* The byte offset of the ALT_UART_RFL register from the beginning of the component. */
3495 #define ALT_UART_RFL_OFST 0x84
3496 /* The address of the ALT_UART_RFL register. */
3497 #define ALT_UART_RFL_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_RFL_OFST))
3498
3499 /*
3500  * Register : Software Reset Register - srr
3501  *
3502  * Provides Software Resets for Tx/Rx FIFO's and the uart.
3503  *
3504  * Register Layout
3505  *
3506  * Bits | Access | Reset | Description
3507  * :-------|:-------|:------|:--------------
3508  * [0] | W | 0x0 | UART Reset
3509  * [1] | W | 0x0 | Rx FIFO Reset
3510  * [2] | W | 0x0 | Tx FIFO Reset
3511  * [31:3] | ??? | 0x0 | *UNDEFINED*
3512  *
3513  */
3514 /*
3515  * Field : UART Reset - ur
3516  *
3517  * This asynchronously resets the UART and synchronously removes the reset
3518  * assertion.
3519  *
3520  * Field Enumeration Values:
3521  *
3522  * Enum | Value | Description
3523  * :------------------------|:------|:--------------
3524  * ALT_UART_SRR_UR_E_NORST | 0x0 | No reset Uart
3525  * ALT_UART_SRR_UR_E_RST | 0x1 | Reset Uart
3526  *
3527  * Field Access Macros:
3528  *
3529  */
3530 /*
3531  * Enumerated value for register field ALT_UART_SRR_UR
3532  *
3533  * No reset Uart
3534  */
3535 #define ALT_UART_SRR_UR_E_NORST 0x0
3536 /*
3537  * Enumerated value for register field ALT_UART_SRR_UR
3538  *
3539  * Reset Uart
3540  */
3541 #define ALT_UART_SRR_UR_E_RST 0x1
3542
3543 /* The Least Significant Bit (LSB) position of the ALT_UART_SRR_UR register field. */
3544 #define ALT_UART_SRR_UR_LSB 0
3545 /* The Most Significant Bit (MSB) position of the ALT_UART_SRR_UR register field. */
3546 #define ALT_UART_SRR_UR_MSB 0
3547 /* The width in bits of the ALT_UART_SRR_UR register field. */
3548 #define ALT_UART_SRR_UR_WIDTH 1
3549 /* The mask used to set the ALT_UART_SRR_UR register field value. */
3550 #define ALT_UART_SRR_UR_SET_MSK 0x00000001
3551 /* The mask used to clear the ALT_UART_SRR_UR register field value. */
3552 #define ALT_UART_SRR_UR_CLR_MSK 0xfffffffe
3553 /* The reset value of the ALT_UART_SRR_UR register field. */
3554 #define ALT_UART_SRR_UR_RESET 0x0
3555 /* Extracts the ALT_UART_SRR_UR field value from a register. */
3556 #define ALT_UART_SRR_UR_GET(value) (((value) & 0x00000001) >> 0)
3557 /* Produces a ALT_UART_SRR_UR register field value suitable for setting the register. */
3558 #define ALT_UART_SRR_UR_SET(value) (((value) << 0) & 0x00000001)
3559
3560 /*
3561  * Field : Rx FIFO Reset - rfr
3562  *
3563  * This is a shadow register for the Rx FIFO Reset bit (FCR[1]). This can be used
3564  * to remove the burden on software having to store previously written FCR values
3565  * (which are pretty static) just to reset the receive FIFO. This resets the
3566  * control portion of the receive FIFO and treats the FIFO as empty. This will also
3567  * de-assert the DMA Rx request and single signals. Note that this bit is 'self-
3568  * clearing' and it is not necessary to clear this bit.
3569  *
3570  * Field Enumeration Values:
3571  *
3572  * Enum | Value | Description
3573  * :-------------------------|:------|:-----------------
3574  * ALT_UART_SRR_RFR_E_NORST | 0x0 | No reset Rx FIFO
3575  * ALT_UART_SRR_RFR_E_RST | 0x1 | Reset Rx FIFO
3576  *
3577  * Field Access Macros:
3578  *
3579  */
3580 /*
3581  * Enumerated value for register field ALT_UART_SRR_RFR
3582  *
3583  * No reset Rx FIFO
3584  */
3585 #define ALT_UART_SRR_RFR_E_NORST 0x0
3586 /*
3587  * Enumerated value for register field ALT_UART_SRR_RFR
3588  *
3589  * Reset Rx FIFO
3590  */
3591 #define ALT_UART_SRR_RFR_E_RST 0x1
3592
3593 /* The Least Significant Bit (LSB) position of the ALT_UART_SRR_RFR register field. */
3594 #define ALT_UART_SRR_RFR_LSB 1
3595 /* The Most Significant Bit (MSB) position of the ALT_UART_SRR_RFR register field. */
3596 #define ALT_UART_SRR_RFR_MSB 1
3597 /* The width in bits of the ALT_UART_SRR_RFR register field. */
3598 #define ALT_UART_SRR_RFR_WIDTH 1
3599 /* The mask used to set the ALT_UART_SRR_RFR register field value. */
3600 #define ALT_UART_SRR_RFR_SET_MSK 0x00000002
3601 /* The mask used to clear the ALT_UART_SRR_RFR register field value. */
3602 #define ALT_UART_SRR_RFR_CLR_MSK 0xfffffffd
3603 /* The reset value of the ALT_UART_SRR_RFR register field. */
3604 #define ALT_UART_SRR_RFR_RESET 0x0
3605 /* Extracts the ALT_UART_SRR_RFR field value from a register. */
3606 #define ALT_UART_SRR_RFR_GET(value) (((value) & 0x00000002) >> 1)
3607 /* Produces a ALT_UART_SRR_RFR register field value suitable for setting the register. */
3608 #define ALT_UART_SRR_RFR_SET(value) (((value) << 1) & 0x00000002)
3609
3610 /*
3611  * Field : Tx FIFO Reset - xfr
3612  *
3613  * This is a shadow register forthe Tx FIFO Reset bit (FCR[2]). This can be used
3614  * to remove the burden on software having to store previously written FCR values
3615  * (which are pretty static) just to reset the transmit FIFO.This resets the
3616  * control portion of the transmit FIFO and treats the FIFO as empty. This will
3617  * also de-assert the DMA Tx request and single signals.
3618  *
3619  * Field Enumeration Values:
3620  *
3621  * Enum | Value | Description
3622  * :-------------------------|:------|:-----------------
3623  * ALT_UART_SRR_XFR_E_NORST | 0x0 | No reset Tx FIFO
3624  * ALT_UART_SRR_XFR_E_RST | 0x1 | Reset Tx FIFO
3625  *
3626  * Field Access Macros:
3627  *
3628  */
3629 /*
3630  * Enumerated value for register field ALT_UART_SRR_XFR
3631  *
3632  * No reset Tx FIFO
3633  */
3634 #define ALT_UART_SRR_XFR_E_NORST 0x0
3635 /*
3636  * Enumerated value for register field ALT_UART_SRR_XFR
3637  *
3638  * Reset Tx FIFO
3639  */
3640 #define ALT_UART_SRR_XFR_E_RST 0x1
3641
3642 /* The Least Significant Bit (LSB) position of the ALT_UART_SRR_XFR register field. */
3643 #define ALT_UART_SRR_XFR_LSB 2
3644 /* The Most Significant Bit (MSB) position of the ALT_UART_SRR_XFR register field. */
3645 #define ALT_UART_SRR_XFR_MSB 2
3646 /* The width in bits of the ALT_UART_SRR_XFR register field. */
3647 #define ALT_UART_SRR_XFR_WIDTH 1
3648 /* The mask used to set the ALT_UART_SRR_XFR register field value. */
3649 #define ALT_UART_SRR_XFR_SET_MSK 0x00000004
3650 /* The mask used to clear the ALT_UART_SRR_XFR register field value. */
3651 #define ALT_UART_SRR_XFR_CLR_MSK 0xfffffffb
3652 /* The reset value of the ALT_UART_SRR_XFR register field. */
3653 #define ALT_UART_SRR_XFR_RESET 0x0
3654 /* Extracts the ALT_UART_SRR_XFR field value from a register. */
3655 #define ALT_UART_SRR_XFR_GET(value) (((value) & 0x00000004) >> 2)
3656 /* Produces a ALT_UART_SRR_XFR register field value suitable for setting the register. */
3657 #define ALT_UART_SRR_XFR_SET(value) (((value) << 2) & 0x00000004)
3658
3659 #ifndef __ASSEMBLY__
3660 /*
3661  * WARNING: The C register and register group struct declarations are provided for
3662  * convenience and illustrative purposes. They should, however, be used with
3663  * caution as the C language standard provides no guarantees about the alignment or
3664  * atomicity of device memory accesses. The recommended practice for writing
3665  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3666  * alt_write_word() functions.
3667  *
3668  * The struct declaration for register ALT_UART_SRR.
3669  */
3671 {
3672  uint32_t ur : 1; /* UART Reset */
3673  uint32_t rfr : 1; /* Rx FIFO Reset */
3674  uint32_t xfr : 1; /* Tx FIFO Reset */
3675  uint32_t : 29; /* *UNDEFINED* */
3676 };
3677
3678 /* The typedef declaration for register ALT_UART_SRR. */
3679 typedef volatile struct ALT_UART_SRR_s ALT_UART_SRR_t;
3680 #endif /* __ASSEMBLY__ */
3681
3682 /* The byte offset of the ALT_UART_SRR register from the beginning of the component. */
3683 #define ALT_UART_SRR_OFST 0x88
3684 /* The address of the ALT_UART_SRR register. */
3685 #define ALT_UART_SRR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_SRR_OFST))
3686
3687 /*
3688  * Register : Shadow Request to Send - srts
3689  *
3690  * This is a shadow register for the RTS status (MCR[1]), this can be used to
3691  * remove the burden of having to performing a read modify write on the MCR.
3692  *
3693  * Register Layout
3694  *
3695  * Bits | Access | Reset | Description
3696  * :-------|:-------|:------|:-----------------------
3697  * [0] | RW | 0x0 | Shadow Request to Send
3698  * [31:1] | ??? | 0x0 | *UNDEFINED*
3699  *
3700  */
3701 /*
3702  * Field : Shadow Request to Send - srts
3703  *
3704  * This is used to directly control the Request to Send (uart_rts_n) output. The
3705  * Request to Send (uart_rts_n) output is used to inform the modem or data set that
3706  * the UART is read to exchange data. The uart_rts_n signal is set low by
3707  * programming MCR[1] (RTS) to a high. In Auto Flow Control, (MCR[5] set to one)
3708  * and FIFO's are enabled (FCR[0] set to one), the uart_rts_n output is controlled
3709  * in the same way, but is also gated with the receiver FIFO threshold trigger
3710  * (uart_rts_n is inactive high when above the threshold).
3711  *
3712  * Note that in Loopback mode (MCR[4] set to one), the uart_rts_n output is held
3713  * inactive high while the value of this location is internally looped back to an
3714  * input.
3715  *
3716  * Field Enumeration Values:
3717  *
3718  * Enum | Value | Description
3719  * :----------------------------|:------|:------------------
3720  * ALT_UART_SRTS_SRTS_E_LOGIC0 | 0x1 | uart_rts_n logic0
3721  * ALT_UART_SRTS_SRTS_E_LOGIC1 | 0x0 | uart_rts_n logic1
3722  *
3723  * Field Access Macros:
3724  *
3725  */
3726 /*
3727  * Enumerated value for register field ALT_UART_SRTS_SRTS
3728  *
3729  * uart_rts_n logic0
3730  */
3731 #define ALT_UART_SRTS_SRTS_E_LOGIC0 0x1
3732 /*
3733  * Enumerated value for register field ALT_UART_SRTS_SRTS
3734  *
3735  * uart_rts_n logic1
3736  */
3737 #define ALT_UART_SRTS_SRTS_E_LOGIC1 0x0
3738
3739 /* The Least Significant Bit (LSB) position of the ALT_UART_SRTS_SRTS register field. */
3740 #define ALT_UART_SRTS_SRTS_LSB 0
3741 /* The Most Significant Bit (MSB) position of the ALT_UART_SRTS_SRTS register field. */
3742 #define ALT_UART_SRTS_SRTS_MSB 0
3743 /* The width in bits of the ALT_UART_SRTS_SRTS register field. */
3744 #define ALT_UART_SRTS_SRTS_WIDTH 1
3745 /* The mask used to set the ALT_UART_SRTS_SRTS register field value. */
3746 #define ALT_UART_SRTS_SRTS_SET_MSK 0x00000001
3747 /* The mask used to clear the ALT_UART_SRTS_SRTS register field value. */
3748 #define ALT_UART_SRTS_SRTS_CLR_MSK 0xfffffffe
3749 /* The reset value of the ALT_UART_SRTS_SRTS register field. */
3750 #define ALT_UART_SRTS_SRTS_RESET 0x0
3751 /* Extracts the ALT_UART_SRTS_SRTS field value from a register. */
3752 #define ALT_UART_SRTS_SRTS_GET(value) (((value) & 0x00000001) >> 0)
3753 /* Produces a ALT_UART_SRTS_SRTS register field value suitable for setting the register. */
3754 #define ALT_UART_SRTS_SRTS_SET(value) (((value) << 0) & 0x00000001)
3755
3756 #ifndef __ASSEMBLY__
3757 /*
3758  * WARNING: The C register and register group struct declarations are provided for
3759  * convenience and illustrative purposes. They should, however, be used with
3760  * caution as the C language standard provides no guarantees about the alignment or
3761  * atomicity of device memory accesses. The recommended practice for writing
3762  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3763  * alt_write_word() functions.
3764  *
3765  * The struct declaration for register ALT_UART_SRTS.
3766  */
3768 {
3769  uint32_t srts : 1; /* Shadow Request to Send */
3770  uint32_t : 31; /* *UNDEFINED* */
3771 };
3772
3773 /* The typedef declaration for register ALT_UART_SRTS. */
3774 typedef volatile struct ALT_UART_SRTS_s ALT_UART_SRTS_t;
3775 #endif /* __ASSEMBLY__ */
3776
3777 /* The byte offset of the ALT_UART_SRTS register from the beginning of the component. */
3778 #define ALT_UART_SRTS_OFST 0x8c
3779 /* The address of the ALT_UART_SRTS register. */
3780 #define ALT_UART_SRTS_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_SRTS_OFST))
3781
3782 /*
3783  * Register : Shadow Break Control Register - sbcr
3784  *
3785  * This is a shadow register for the Break bit [6] of the register LCR. This can be
3786  * used to remove the burden of having to performing a read modify write on the
3787  * LCR.
3788  *
3789  * Register Layout
3790  *
3791  * Bits | Access | Reset | Description
3792  * :-------|:-------|:------|:---------------------
3793  * [0] | RW | 0x0 | Shadow Break Control
3794  * [31:1] | ??? | 0x0 | *UNDEFINED*
3795  *
3796  */
3797 /*
3798  * Field : Shadow Break Control - sbcr
3799  *
3800  * This is used to cause a break condition to be transmitted to the receiving
3801  * device. If set to one the serial output is forced to the spacing (logic 0)
3802  * state. When not in Loopback Mode, as determined by MCR[4], the uart_txd line is
3803  * forced low until the Break bit is cleared. When in Loopback Mode, the break
3804  * condition is internally looped back to the receiver.
3805  *
3806  * Field Enumeration Values:
3807  *
3808  * Enum | Value | Description
3809  * :--------------------------|:------|:----------------------------
3810  * ALT_UART_SBCR_SBCR_E_DISD | 0x0 | no break
3811  * ALT_UART_SBCR_SBCR_E_END | 0x1 | break serial output spacing
3812  *
3813  * Field Access Macros:
3814  *
3815  */
3816 /*
3817  * Enumerated value for register field ALT_UART_SBCR_SBCR
3818  *
3819  * no break
3820  */
3821 #define ALT_UART_SBCR_SBCR_E_DISD 0x0
3822 /*
3823  * Enumerated value for register field ALT_UART_SBCR_SBCR
3824  *
3825  * break serial output spacing
3826  */
3827 #define ALT_UART_SBCR_SBCR_E_END 0x1
3828
3829 /* The Least Significant Bit (LSB) position of the ALT_UART_SBCR_SBCR register field. */
3830 #define ALT_UART_SBCR_SBCR_LSB 0
3831 /* The Most Significant Bit (MSB) position of the ALT_UART_SBCR_SBCR register field. */
3832 #define ALT_UART_SBCR_SBCR_MSB 0
3833 /* The width in bits of the ALT_UART_SBCR_SBCR register field. */
3834 #define ALT_UART_SBCR_SBCR_WIDTH 1
3835 /* The mask used to set the ALT_UART_SBCR_SBCR register field value. */
3836 #define ALT_UART_SBCR_SBCR_SET_MSK 0x00000001
3837 /* The mask used to clear the ALT_UART_SBCR_SBCR register field value. */
3838 #define ALT_UART_SBCR_SBCR_CLR_MSK 0xfffffffe
3839 /* The reset value of the ALT_UART_SBCR_SBCR register field. */
3840 #define ALT_UART_SBCR_SBCR_RESET 0x0
3841 /* Extracts the ALT_UART_SBCR_SBCR field value from a register. */
3842 #define ALT_UART_SBCR_SBCR_GET(value) (((value) & 0x00000001) >> 0)
3843 /* Produces a ALT_UART_SBCR_SBCR register field value suitable for setting the register. */
3844 #define ALT_UART_SBCR_SBCR_SET(value) (((value) << 0) & 0x00000001)
3845
3846 #ifndef __ASSEMBLY__
3847 /*
3848  * WARNING: The C register and register group struct declarations are provided for
3849  * convenience and illustrative purposes. They should, however, be used with
3850  * caution as the C language standard provides no guarantees about the alignment or
3851  * atomicity of device memory accesses. The recommended practice for writing
3852  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3853  * alt_write_word() functions.
3854  *
3855  * The struct declaration for register ALT_UART_SBCR.
3856  */
3858 {
3859  uint32_t sbcr : 1; /* Shadow Break Control */
3860  uint32_t : 31; /* *UNDEFINED* */
3861 };
3862
3863 /* The typedef declaration for register ALT_UART_SBCR. */
3864 typedef volatile struct ALT_UART_SBCR_s ALT_UART_SBCR_t;
3865 #endif /* __ASSEMBLY__ */
3866
3867 /* The byte offset of the ALT_UART_SBCR register from the beginning of the component. */
3868 #define ALT_UART_SBCR_OFST 0x90
3869 /* The address of the ALT_UART_SBCR register. */
3870 #define ALT_UART_SBCR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_SBCR_OFST))
3871
3872 /*
3873  * Register : Shadow DMA Mode - sdmam
3874  *
3875  * This is a shadow register for the DMA mode bit (FCR[3]).
3876  *
3877  * Register Layout
3878  *
3879  * Bits | Access | Reset | Description
3880  * :-------|:-------|:------|:----------------
3881  * [0] | RW | 0x0 | Shadow DMA Mode
3882  * [31:1] | ??? | 0x0 | *UNDEFINED*
3883  *
3884  */
3885 /*
3886  * Field : Shadow DMA Mode - sdmam
3887  *
3888  * This can be used to remove the burden of having to store the previously written
3889  * value to the FCR in memory and having to mask this value so that only the DMA
3890  * Mode bit gets updated.
3891  *
3892  * Field Enumeration Values:
3893  *
3894  * Enum | Value | Description
3895  * :------------------------------|:------|:---------------------------
3896  * ALT_UART_SDMAM_SDMAM_E_SINGLE | 0x0 | Single DMA Transfer Mode
3897  * ALT_UART_SDMAM_SDMAM_E_MULT | 0x1 | Multiple DMA Transfer Mode
3898  *
3899  * Field Access Macros:
3900  *
3901  */
3902 /*
3903  * Enumerated value for register field ALT_UART_SDMAM_SDMAM
3904  *
3905  * Single DMA Transfer Mode
3906  */
3907 #define ALT_UART_SDMAM_SDMAM_E_SINGLE 0x0
3908 /*
3909  * Enumerated value for register field ALT_UART_SDMAM_SDMAM
3910  *
3911  * Multiple DMA Transfer Mode
3912  */
3913 #define ALT_UART_SDMAM_SDMAM_E_MULT 0x1
3914
3915 /* The Least Significant Bit (LSB) position of the ALT_UART_SDMAM_SDMAM register field. */
3916 #define ALT_UART_SDMAM_SDMAM_LSB 0
3917 /* The Most Significant Bit (MSB) position of the ALT_UART_SDMAM_SDMAM register field. */
3918 #define ALT_UART_SDMAM_SDMAM_MSB 0
3919 /* The width in bits of the ALT_UART_SDMAM_SDMAM register field. */
3920 #define ALT_UART_SDMAM_SDMAM_WIDTH 1
3921 /* The mask used to set the ALT_UART_SDMAM_SDMAM register field value. */
3922 #define ALT_UART_SDMAM_SDMAM_SET_MSK 0x00000001
3923 /* The mask used to clear the ALT_UART_SDMAM_SDMAM register field value. */
3924 #define ALT_UART_SDMAM_SDMAM_CLR_MSK 0xfffffffe
3925 /* The reset value of the ALT_UART_SDMAM_SDMAM register field. */
3926 #define ALT_UART_SDMAM_SDMAM_RESET 0x0
3927 /* Extracts the ALT_UART_SDMAM_SDMAM field value from a register. */
3928 #define ALT_UART_SDMAM_SDMAM_GET(value) (((value) & 0x00000001) >> 0)
3929 /* Produces a ALT_UART_SDMAM_SDMAM register field value suitable for setting the register. */
3930 #define ALT_UART_SDMAM_SDMAM_SET(value) (((value) << 0) & 0x00000001)
3931
3932 #ifndef __ASSEMBLY__
3933 /*
3934  * WARNING: The C register and register group struct declarations are provided for
3935  * convenience and illustrative purposes. They should, however, be used with
3936  * caution as the C language standard provides no guarantees about the alignment or
3937  * atomicity of device memory accesses. The recommended practice for writing
3938  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3939  * alt_write_word() functions.
3940  *
3941  * The struct declaration for register ALT_UART_SDMAM.
3942  */
3944 {
3945  uint32_t sdmam : 1; /* Shadow DMA Mode */
3946  uint32_t : 31; /* *UNDEFINED* */
3947 };
3948
3949 /* The typedef declaration for register ALT_UART_SDMAM. */
3950 typedef volatile struct ALT_UART_SDMAM_s ALT_UART_SDMAM_t;
3951 #endif /* __ASSEMBLY__ */
3952
3953 /* The byte offset of the ALT_UART_SDMAM register from the beginning of the component. */
3954 #define ALT_UART_SDMAM_OFST 0x94
3955 /* The address of the ALT_UART_SDMAM register. */
3956 #define ALT_UART_SDMAM_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_SDMAM_OFST))
3957
3958 /*
3959  * Register : Shadow FIFO Enable - sfe
3960  *
3961  * This is a shadow register for the FIFO enable bit [0] of register FCR.
3962  *
3963  * Register Layout
3964  *
3965  * Bits | Access | Reset | Description
3966  * :-------|:-------|:------|:-------------------
3967  * [0] | RW | 0x0 | Shadow FIFO Enable
3968  * [31:1] | ??? | 0x0 | *UNDEFINED*
3969  *
3970  */
3971 /*
3972  * Field : Shadow FIFO Enable - sfe
3973  *
3974  * This can be used to remove the burden of having to store the previously written
3975  * value to the FCR in memory and having to mask this value so that only the FIFO
3976  * enable bit gets updated. This enables/disables the transmit (Tx) and receive (Rx
3977  * ) FIFO's. If this bit is set to zero (disabled) after being enabled then both
3978  * the Tx and Rx controller portion of FIFO's will be reset.
3979  *
3980  * Field Enumeration Values:
3981  *
3982  * Enum | Value | Description
3983  * :------------------------|:------|:--------------
3984  * ALT_UART_SFE_SFE_E_DISD | 0x0 | Disable Rx/Tx
3985  * ALT_UART_SFE_SFE_E_END | 0x1 | Enable Rx/Tx
3986  *
3987  * Field Access Macros:
3988  *
3989  */
3990 /*
3991  * Enumerated value for register field ALT_UART_SFE_SFE
3992  *
3993  * Disable Rx/Tx
3994  */
3995 #define ALT_UART_SFE_SFE_E_DISD 0x0
3996 /*
3997  * Enumerated value for register field ALT_UART_SFE_SFE
3998  *
3999  * Enable Rx/Tx
4000  */
4001 #define ALT_UART_SFE_SFE_E_END 0x1
4002
4003 /* The Least Significant Bit (LSB) position of the ALT_UART_SFE_SFE register field. */
4004 #define ALT_UART_SFE_SFE_LSB 0
4005 /* The Most Significant Bit (MSB) position of the ALT_UART_SFE_SFE register field. */
4006 #define ALT_UART_SFE_SFE_MSB 0
4007 /* The width in bits of the ALT_UART_SFE_SFE register field. */
4008 #define ALT_UART_SFE_SFE_WIDTH 1
4009 /* The mask used to set the ALT_UART_SFE_SFE register field value. */
4010 #define ALT_UART_SFE_SFE_SET_MSK 0x00000001
4011 /* The mask used to clear the ALT_UART_SFE_SFE register field value. */
4012 #define ALT_UART_SFE_SFE_CLR_MSK 0xfffffffe
4013 /* The reset value of the ALT_UART_SFE_SFE register field. */
4014 #define ALT_UART_SFE_SFE_RESET 0x0
4015 /* Extracts the ALT_UART_SFE_SFE field value from a register. */
4016 #define ALT_UART_SFE_SFE_GET(value) (((value) & 0x00000001) >> 0)
4017 /* Produces a ALT_UART_SFE_SFE register field value suitable for setting the register. */
4018 #define ALT_UART_SFE_SFE_SET(value) (((value) << 0) & 0x00000001)
4019
4020 #ifndef __ASSEMBLY__
4021 /*
4022  * WARNING: The C register and register group struct declarations are provided for
4023  * convenience and illustrative purposes. They should, however, be used with
4024  * caution as the C language standard provides no guarantees about the alignment or
4025  * atomicity of device memory accesses. The recommended practice for writing
4026  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4027  * alt_write_word() functions.
4028  *
4029  * The struct declaration for register ALT_UART_SFE.
4030  */
4032 {
4033  uint32_t sfe : 1; /* Shadow FIFO Enable */
4034  uint32_t : 31; /* *UNDEFINED* */
4035 };
4036
4037 /* The typedef declaration for register ALT_UART_SFE. */
4038 typedef volatile struct ALT_UART_SFE_s ALT_UART_SFE_t;
4039 #endif /* __ASSEMBLY__ */
4040
4041 /* The byte offset of the ALT_UART_SFE register from the beginning of the component. */
4042 #define ALT_UART_SFE_OFST 0x98
4043 /* The address of the ALT_UART_SFE register. */
4044 #define ALT_UART_SFE_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_SFE_OFST))
4045
4046 /*
4047  * Register : Shadow Rx Trigger - srt
4048  *
4049  * This is a shadow register for the Rx trigger bits (FCR[7:6]).
4050  *
4051  * Register Layout
4052  *
4053  * Bits | Access | Reset | Description
4054  * :-------|:-------|:------|:------------------------
4055  * [1:0] | RW | 0x0 | Shadow Rx Trigger Bits
4056  * [31:2] | ??? | 0x0 | *UNDEFINED*
4057  *
4058  */
4059 /*
4060  * Field : Shadow Rx Trigger Bits - srt
4061  *
4062  * This can be used to remove the burden of having to store the previously written
4063  * value to the FCR in memory and having to mask this value so that only the Rx
4064  * trigger bit gets updated. This is used to select the trigger level in the
4065  * receiver FIFO at which the Received Data Available Interrupt will be generated.
4066  * It also determines when the uart_dma_rx_req_n signal will be asserted when DMA
4067  * Mode (FCR[3]) is set to one. The enum below shows trigger levels that are
4068  * supported.
4069  *
4070  * Field Enumeration Values:
4071  *
4072  * Enum | Value | Description
4073  * :-------------------------------|:------|:----------------------
4074  * ALT_UART_SRT_SRT_E_ONECHAR | 0x0 | one character in fifo
4075  * ALT_UART_SRT_SRT_E_QUARTERFULL | 0x1 | FIFO 1/4 full
4076  * ALT_UART_SRT_SRT_E_HALFFULL | 0x2 | FIFO 1/2 full
4077  * ALT_UART_SRT_SRT_E_FULLLESS2 | 0x3 | FIFO 2 less than full
4078  *
4079  * Field Access Macros:
4080  *
4081  */
4082 /*
4083  * Enumerated value for register field ALT_UART_SRT_SRT
4084  *
4085  * one character in fifo
4086  */
4087 #define ALT_UART_SRT_SRT_E_ONECHAR 0x0
4088 /*
4089  * Enumerated value for register field ALT_UART_SRT_SRT
4090  *
4091  * FIFO 1/4 full
4092  */
4093 #define ALT_UART_SRT_SRT_E_QUARTERFULL 0x1
4094 /*
4095  * Enumerated value for register field ALT_UART_SRT_SRT
4096  *
4097  * FIFO 1/2 full
4098  */
4099 #define ALT_UART_SRT_SRT_E_HALFFULL 0x2
4100 /*
4101  * Enumerated value for register field ALT_UART_SRT_SRT
4102  *
4103  * FIFO 2 less than full
4104  */
4105 #define ALT_UART_SRT_SRT_E_FULLLESS2 0x3
4106
4107 /* The Least Significant Bit (LSB) position of the ALT_UART_SRT_SRT register field. */
4108 #define ALT_UART_SRT_SRT_LSB 0
4109 /* The Most Significant Bit (MSB) position of the ALT_UART_SRT_SRT register field. */
4110 #define ALT_UART_SRT_SRT_MSB 1
4111 /* The width in bits of the ALT_UART_SRT_SRT register field. */
4112 #define ALT_UART_SRT_SRT_WIDTH 2
4113 /* The mask used to set the ALT_UART_SRT_SRT register field value. */
4114 #define ALT_UART_SRT_SRT_SET_MSK 0x00000003
4115 /* The mask used to clear the ALT_UART_SRT_SRT register field value. */
4116 #define ALT_UART_SRT_SRT_CLR_MSK 0xfffffffc
4117 /* The reset value of the ALT_UART_SRT_SRT register field. */
4118 #define ALT_UART_SRT_SRT_RESET 0x0
4119 /* Extracts the ALT_UART_SRT_SRT field value from a register. */
4120 #define ALT_UART_SRT_SRT_GET(value) (((value) & 0x00000003) >> 0)
4121 /* Produces a ALT_UART_SRT_SRT register field value suitable for setting the register. */
4122 #define ALT_UART_SRT_SRT_SET(value) (((value) << 0) & 0x00000003)
4123
4124 #ifndef __ASSEMBLY__
4125 /*
4126  * WARNING: The C register and register group struct declarations are provided for
4127  * convenience and illustrative purposes. They should, however, be used with
4128  * caution as the C language standard provides no guarantees about the alignment or
4129  * atomicity of device memory accesses. The recommended practice for writing
4130  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4131  * alt_write_word() functions.
4132  *
4133  * The struct declaration for register ALT_UART_SRT.
4134  */
4136 {
4137  uint32_t srt : 2; /* Shadow Rx Trigger Bits */
4138  uint32_t : 30; /* *UNDEFINED* */
4139 };
4140
4141 /* The typedef declaration for register ALT_UART_SRT. */
4142 typedef volatile struct ALT_UART_SRT_s ALT_UART_SRT_t;
4143 #endif /* __ASSEMBLY__ */
4144
4145 /* The byte offset of the ALT_UART_SRT register from the beginning of the component. */
4146 #define ALT_UART_SRT_OFST 0x9c
4147 /* The address of the ALT_UART_SRT register. */
4148 #define ALT_UART_SRT_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_SRT_OFST))
4149
4150 /*
4151  * Register : Shadow Tx Empty Trigger - stet
4152  *
4153  * This is a shadow register for the Tx empty trigger bits (FCR[5:4]).
4154  *
4155  * Register Layout
4156  *
4157  * Bits | Access | Reset | Description
4158  * :-------|:-------|:------|:-----------------------------
4159  * [1:0] | RW | 0x0 | Shadow Tx Empty Trigger Bits
4160  * [31:2] | ??? | 0x0 | *UNDEFINED*
4161  *
4162  */
4163 /*
4164  * Field : Shadow Tx Empty Trigger Bits - stet
4165  *
4166  * This can be used to remove the burden of having to store the previously written
4167  * value to the FCR in memory and having to mask this value so that only the Tx
4168  * empty trigger bit gets updated. This is used to select the empty threshold level
4169  * at which the THRE Interrupts will be generated when the mode is active. These
4170  * threshold levels are also described in. The enum trigger levels are supported.
4171  *
4172  * Field Enumeration Values:
4173  *
4174  * Enum | Value | Description
4175  * :---------------------------------|:------|:-----------------------
4176  * ALT_UART_STET_STET_E_FIFOEMPTY | 0x0 | FIFO empty
4177  * ALT_UART_STET_STET_E_TWOCHARS | 0x1 | Two characters in FIFO
4178  * ALT_UART_STET_STET_E_QUARTERFULL | 0x2 | FIFO quarter full
4179  * ALT_UART_STET_STET_E_HALFFULL | 0x3 | FIFO half full
4180  *
4181  * Field Access Macros:
4182  *
4183  */
4184 /*
4185  * Enumerated value for register field ALT_UART_STET_STET
4186  *
4187  * FIFO empty
4188  */
4189 #define ALT_UART_STET_STET_E_FIFOEMPTY 0x0
4190 /*
4191  * Enumerated value for register field ALT_UART_STET_STET
4192  *
4193  * Two characters in FIFO
4194  */
4195 #define ALT_UART_STET_STET_E_TWOCHARS 0x1
4196 /*
4197  * Enumerated value for register field ALT_UART_STET_STET
4198  *
4199  * FIFO quarter full
4200  */
4201 #define ALT_UART_STET_STET_E_QUARTERFULL 0x2
4202 /*
4203  * Enumerated value for register field ALT_UART_STET_STET
4204  *
4205  * FIFO half full
4206  */
4207 #define ALT_UART_STET_STET_E_HALFFULL 0x3
4208
4209 /* The Least Significant Bit (LSB) position of the ALT_UART_STET_STET register field. */
4210 #define ALT_UART_STET_STET_LSB 0
4211 /* The Most Significant Bit (MSB) position of the ALT_UART_STET_STET register field. */
4212 #define ALT_UART_STET_STET_MSB 1
4213 /* The width in bits of the ALT_UART_STET_STET register field. */
4214 #define ALT_UART_STET_STET_WIDTH 2
4215 /* The mask used to set the ALT_UART_STET_STET register field value. */
4216 #define ALT_UART_STET_STET_SET_MSK 0x00000003
4217 /* The mask used to clear the ALT_UART_STET_STET register field value. */
4218 #define ALT_UART_STET_STET_CLR_MSK 0xfffffffc
4219 /* The reset value of the ALT_UART_STET_STET register field. */
4220 #define ALT_UART_STET_STET_RESET 0x0
4221 /* Extracts the ALT_UART_STET_STET field value from a register. */
4222 #define ALT_UART_STET_STET_GET(value) (((value) & 0x00000003) >> 0)
4223 /* Produces a ALT_UART_STET_STET register field value suitable for setting the register. */
4224 #define ALT_UART_STET_STET_SET(value) (((value) << 0) & 0x00000003)
4225
4226 #ifndef __ASSEMBLY__
4227 /*
4228  * WARNING: The C register and register group struct declarations are provided for
4229  * convenience and illustrative purposes. They should, however, be used with
4230  * caution as the C language standard provides no guarantees about the alignment or
4231  * atomicity of device memory accesses. The recommended practice for writing
4232  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4233  * alt_write_word() functions.
4234  *
4235  * The struct declaration for register ALT_UART_STET.
4236  */
4238 {
4239  uint32_t stet : 2; /* Shadow Tx Empty Trigger Bits */
4240  uint32_t : 30; /* *UNDEFINED* */
4241 };
4242
4243 /* The typedef declaration for register ALT_UART_STET. */
4244 typedef volatile struct ALT_UART_STET_s ALT_UART_STET_t;
4245 #endif /* __ASSEMBLY__ */
4246
4247 /* The byte offset of the ALT_UART_STET register from the beginning of the component. */
4248 #define ALT_UART_STET_OFST 0xa0
4249 /* The address of the ALT_UART_STET register. */
4250 #define ALT_UART_STET_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_STET_OFST))
4251
4252 /*
4253  * Register : Halt Tx - htx
4254  *
4255  * Used to halt transmission for testing.
4256  *
4257  * Register Layout
4258  *
4259  * Bits | Access | Reset | Description
4260  * :-------|:-------|:------|:-------------
4261  * [0] | RW | 0x0 | Halt Tx Bits
4262  * [31:1] | ??? | 0x0 | *UNDEFINED*
4263  *
4264  */
4265 /*
4266  * Field : Halt Tx Bits - htx
4267  *
4268  * This register is use to halt transmissions for testing, so that the transmit
4269  * FIFO can be filled by the master when FIFO's are enabled.
4270  *
4271  * Note, if FIFO's are not enabled, the setting of the halt Tx register will have
4272  * no effect on operation.
4273  *
4274  * Field Enumeration Values:
4275  *
4276  * Enum | Value | Description
4277  * :------------------------|:------|:-----------------
4278  * ALT_UART_HTX_HTX_E_DISD | 0x0 | Halt Tx disabled
4279  * ALT_UART_HTX_HTX_E_END | 0x1 | Halt Tx enabled
4280  *
4281  * Field Access Macros:
4282  *
4283  */
4284 /*
4285  * Enumerated value for register field ALT_UART_HTX_HTX
4286  *
4287  * Halt Tx disabled
4288  */
4289 #define ALT_UART_HTX_HTX_E_DISD 0x0
4290 /*
4291  * Enumerated value for register field ALT_UART_HTX_HTX
4292  *
4293  * Halt Tx enabled
4294  */
4295 #define ALT_UART_HTX_HTX_E_END 0x1
4296
4297 /* The Least Significant Bit (LSB) position of the ALT_UART_HTX_HTX register field. */
4298 #define ALT_UART_HTX_HTX_LSB 0
4299 /* The Most Significant Bit (MSB) position of the ALT_UART_HTX_HTX register field. */
4300 #define ALT_UART_HTX_HTX_MSB 0
4301 /* The width in bits of the ALT_UART_HTX_HTX register field. */
4302 #define ALT_UART_HTX_HTX_WIDTH 1
4303 /* The mask used to set the ALT_UART_HTX_HTX register field value. */
4304 #define ALT_UART_HTX_HTX_SET_MSK 0x00000001
4305 /* The mask used to clear the ALT_UART_HTX_HTX register field value. */
4306 #define ALT_UART_HTX_HTX_CLR_MSK 0xfffffffe
4307 /* The reset value of the ALT_UART_HTX_HTX register field. */
4308 #define ALT_UART_HTX_HTX_RESET 0x0
4309 /* Extracts the ALT_UART_HTX_HTX field value from a register. */
4310 #define ALT_UART_HTX_HTX_GET(value) (((value) & 0x00000001) >> 0)
4311 /* Produces a ALT_UART_HTX_HTX register field value suitable for setting the register. */
4312 #define ALT_UART_HTX_HTX_SET(value) (((value) << 0) & 0x00000001)
4313
4314 #ifndef __ASSEMBLY__
4315 /*
4316  * WARNING: The C register and register group struct declarations are provided for
4317  * convenience and illustrative purposes. They should, however, be used with
4318  * caution as the C language standard provides no guarantees about the alignment or
4319  * atomicity of device memory accesses. The recommended practice for writing
4320  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4321  * alt_write_word() functions.
4322  *
4323  * The struct declaration for register ALT_UART_HTX.
4324  */
4326 {
4327  uint32_t htx : 1; /* Halt Tx Bits */
4328  uint32_t : 31; /* *UNDEFINED* */
4329 };
4330
4331 /* The typedef declaration for register ALT_UART_HTX. */
4332 typedef volatile struct ALT_UART_HTX_s ALT_UART_HTX_t;
4333 #endif /* __ASSEMBLY__ */
4334
4335 /* The byte offset of the ALT_UART_HTX register from the beginning of the component. */
4336 #define ALT_UART_HTX_OFST 0xa4
4337 /* The address of the ALT_UART_HTX register. */
4338 #define ALT_UART_HTX_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_HTX_OFST))
4339
4340 /*
4341  * Register : DMA Software Acknowledge - dmasa
4342  *
4343  * DMA Operation Control
4344  *
4345  * Register Layout
4346  *
4347  * Bits | Access | Reset | Description
4348  * :-------|:-------|:------|:------------------------------
4349  * [0] | W | 0x0 | DMA Software Acknowledge Bits
4350  * [31:1] | ??? | 0x0 | *UNDEFINED*
4351  *
4352  */
4353 /*
4354  * Field : DMA Software Acknowledge Bits - dmasa
4355  *
4356  * This register is used to perform DMA software acknowledge if a transfer needs to
4357  * be terminated due to an error condition. For example, if the DMA disables the
4358  * channel, then the uart should clear its request. This will cause the Tx request,
4359  * Tx single, Rx request and Rx single signals to de-assert. Note that this bit is
4360  * 'self-clearing' and it is not necessary to clear this bit.
4361  *
4362  * Field Access Macros:
4363  *
4364  */
4365 /* The Least Significant Bit (LSB) position of the ALT_UART_DMASA_DMASA register field. */
4366 #define ALT_UART_DMASA_DMASA_LSB 0
4367 /* The Most Significant Bit (MSB) position of the ALT_UART_DMASA_DMASA register field. */
4368 #define ALT_UART_DMASA_DMASA_MSB 0
4369 /* The width in bits of the ALT_UART_DMASA_DMASA register field. */
4370 #define ALT_UART_DMASA_DMASA_WIDTH 1
4371 /* The mask used to set the ALT_UART_DMASA_DMASA register field value. */
4372 #define ALT_UART_DMASA_DMASA_SET_MSK 0x00000001
4373 /* The mask used to clear the ALT_UART_DMASA_DMASA register field value. */
4374 #define ALT_UART_DMASA_DMASA_CLR_MSK 0xfffffffe
4375 /* The reset value of the ALT_UART_DMASA_DMASA register field. */
4376 #define ALT_UART_DMASA_DMASA_RESET 0x0
4377 /* Extracts the ALT_UART_DMASA_DMASA field value from a register. */
4378 #define ALT_UART_DMASA_DMASA_GET(value) (((value) & 0x00000001) >> 0)
4379 /* Produces a ALT_UART_DMASA_DMASA register field value suitable for setting the register. */
4380 #define ALT_UART_DMASA_DMASA_SET(value) (((value) << 0) & 0x00000001)
4381
4382 #ifndef __ASSEMBLY__
4383 /*
4384  * WARNING: The C register and register group struct declarations are provided for
4385  * convenience and illustrative purposes. They should, however, be used with
4386  * caution as the C language standard provides no guarantees about the alignment or
4387  * atomicity of device memory accesses. The recommended practice for writing
4388  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4389  * alt_write_word() functions.
4390  *
4391  * The struct declaration for register ALT_UART_DMASA.
4392  */
4394 {
4395  uint32_t dmasa : 1; /* DMA Software Acknowledge Bits */
4396  uint32_t : 31; /* *UNDEFINED* */
4397 };
4398
4399 /* The typedef declaration for register ALT_UART_DMASA. */
4400 typedef volatile struct ALT_UART_DMASA_s ALT_UART_DMASA_t;
4401 #endif /* __ASSEMBLY__ */
4402
4403 /* The byte offset of the ALT_UART_DMASA register from the beginning of the component. */
4404 #define ALT_UART_DMASA_OFST 0xa8
4405 /* The address of the ALT_UART_DMASA register. */
4406 #define ALT_UART_DMASA_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_DMASA_OFST))
4407
4408 /*
4409  * Register : Component Parameter Register - cpr
4410  *
4411  * Describes various fixed hardware setups states.
4412  *
4413  * Register Layout
4414  *
4415  * Bits | Access | Reset | Description
4416  * :--------|:-------|:------|:----------------------------------
4417  * [1:0] | R | 0x2 | APB DATA WIDTH
4418  * [3:2] | ??? | 0x0 | *UNDEFINED*
4419  * [4] | R | 0x1 | Auto Flow Control
4420  * [5] | R | 0x1 | THRE MODE
4421  * [6] | R | 0x0 | SIR MODE Unsupported
4422  * [7] | R | 0x0 | SIR LP MODE Unsupported
4423  * [8] | R | 0x1 | ADDITIONAL FEATURES Supported
4424  * [9] | R | 0x1 | FIFO ACCESS Supported
4425  * [10] | R | 0x1 | FIFO STAT Supported
4426  * [11] | R | 0x1 | SHADOW Supported
4427  * [12] | R | 0x1 | Configuartion ID Register Present
4428  * [13] | R | 0x1 | DMA EXTRA Supported
4429  * [15:14] | ??? | 0x0 | *UNDEFINED*
4430  * [23:16] | R | 0x37 | FIFO Depth
4431  * [31:24] | ??? | 0x0 | *UNDEFINED*
4432  *
4433  */
4434 /*
4435  * Field : APB DATA WIDTH - apbdatawidth
4436  *
4437  * Fixed to support an ABP data bus width of 32-bits.
4438  *
4439  * Field Enumeration Values:
4440  *
4441  * Enum | Value | Description
4442  * :----------------------------------------|:------|:-------------------------
4443  * ALT_UART_CPR_APBDATAWIDTH_E_WIDTH32BITS | 0x2 | APB Data Width = 32-bits
4444  *
4445  * Field Access Macros:
4446  *
4447  */
4448 /*
4449  * Enumerated value for register field ALT_UART_CPR_APBDATAWIDTH
4450  *
4451  * APB Data Width = 32-bits
4452  */
4453 #define ALT_UART_CPR_APBDATAWIDTH_E_WIDTH32BITS 0x2
4454
4455 /* The Least Significant Bit (LSB) position of the ALT_UART_CPR_APBDATAWIDTH register field. */
4456 #define ALT_UART_CPR_APBDATAWIDTH_LSB 0
4457 /* The Most Significant Bit (MSB) position of the ALT_UART_CPR_APBDATAWIDTH register field. */
4458 #define ALT_UART_CPR_APBDATAWIDTH_MSB 1
4459 /* The width in bits of the ALT_UART_CPR_APBDATAWIDTH register field. */
4460 #define ALT_UART_CPR_APBDATAWIDTH_WIDTH 2
4461 /* The mask used to set the ALT_UART_CPR_APBDATAWIDTH register field value. */
4462 #define ALT_UART_CPR_APBDATAWIDTH_SET_MSK 0x00000003
4463 /* The mask used to clear the ALT_UART_CPR_APBDATAWIDTH register field value. */
4464 #define ALT_UART_CPR_APBDATAWIDTH_CLR_MSK 0xfffffffc
4465 /* The reset value of the ALT_UART_CPR_APBDATAWIDTH register field. */
4466 #define ALT_UART_CPR_APBDATAWIDTH_RESET 0x2
4467 /* Extracts the ALT_UART_CPR_APBDATAWIDTH field value from a register. */
4468 #define ALT_UART_CPR_APBDATAWIDTH_GET(value) (((value) & 0x00000003) >> 0)
4469 /* Produces a ALT_UART_CPR_APBDATAWIDTH register field value suitable for setting the register. */
4470 #define ALT_UART_CPR_APBDATAWIDTH_SET(value) (((value) << 0) & 0x00000003)
4471
4472 /*
4473  * Field : Auto Flow Control - afce_mode
4474  *
4475  * Allows auto flow control.
4476  *
4477  * Field Enumeration Values:
4478  *
4479  * Enum | Value | Description
4480  * :----------------------------|:------|:------------
4481  * ALT_UART_CPR_AFCE_MOD_E_END | 0x1 | Auto Flow
4482  *
4483  * Field Access Macros:
4484  *
4485  */
4486 /*
4487  * Enumerated value for register field ALT_UART_CPR_AFCE_MOD
4488  *
4489  * Auto Flow
4490  */
4491 #define ALT_UART_CPR_AFCE_MOD_E_END 0x1
4492
4493 /* The Least Significant Bit (LSB) position of the ALT_UART_CPR_AFCE_MOD register field. */
4494 #define ALT_UART_CPR_AFCE_MOD_LSB 4
4495 /* The Most Significant Bit (MSB) position of the ALT_UART_CPR_AFCE_MOD register field. */
4496 #define ALT_UART_CPR_AFCE_MOD_MSB 4
4497 /* The width in bits of the ALT_UART_CPR_AFCE_MOD register field. */
4498 #define ALT_UART_CPR_AFCE_MOD_WIDTH 1
4499 /* The mask used to set the ALT_UART_CPR_AFCE_MOD register field value. */
4500 #define ALT_UART_CPR_AFCE_MOD_SET_MSK 0x00000010
4501 /* The mask used to clear the ALT_UART_CPR_AFCE_MOD register field value. */
4502 #define ALT_UART_CPR_AFCE_MOD_CLR_MSK 0xffffffef
4503 /* The reset value of the ALT_UART_CPR_AFCE_MOD register field. */
4504 #define ALT_UART_CPR_AFCE_MOD_RESET 0x1
4505 /* Extracts the ALT_UART_CPR_AFCE_MOD field value from a register. */
4506 #define ALT_UART_CPR_AFCE_MOD_GET(value) (((value) & 0x00000010) >> 4)
4507 /* Produces a ALT_UART_CPR_AFCE_MOD register field value suitable for setting the register. */
4508 #define ALT_UART_CPR_AFCE_MOD_SET(value) (((value) << 4) & 0x00000010)
4509
4510 /*
4511  * Field : THRE MODE - thre_mode
4512  *
4513  * Programmable Transmitter Hold Register Empty interrupt
4514  *
4515  * Field Enumeration Values:
4516  *
4517  * Enum | Value | Description
4518  * :----------------------------|:------|:------------------------------------------
4519  * ALT_UART_CPR_THRE_MOD_E_END | 0x1 | Programmable Tx Hold Reg. Empty interrupt
4520  * : | | present
4521  *
4522  * Field Access Macros:
4523  *
4524  */
4525 /*
4526  * Enumerated value for register field ALT_UART_CPR_THRE_MOD
4527  *
4528  * Programmable Tx Hold Reg. Empty interrupt present
4529  */
4530 #define ALT_UART_CPR_THRE_MOD_E_END 0x1
4531
4532 /* The Least Significant Bit (LSB) position of the ALT_UART_CPR_THRE_MOD register field. */
4533 #define ALT_UART_CPR_THRE_MOD_LSB 5
4534 /* The Most Significant Bit (MSB) position of the ALT_UART_CPR_THRE_MOD register field. */
4535 #define ALT_UART_CPR_THRE_MOD_MSB 5
4536 /* The width in bits of the ALT_UART_CPR_THRE_MOD register field. */
4537 #define ALT_UART_CPR_THRE_MOD_WIDTH 1
4538 /* The mask used to set the ALT_UART_CPR_THRE_MOD register field value. */
4539 #define ALT_UART_CPR_THRE_MOD_SET_MSK 0x00000020
4540 /* The mask used to clear the ALT_UART_CPR_THRE_MOD register field value. */
4541 #define ALT_UART_CPR_THRE_MOD_CLR_MSK 0xffffffdf
4542 /* The reset value of the ALT_UART_CPR_THRE_MOD register field. */
4543 #define ALT_UART_CPR_THRE_MOD_RESET 0x1
4544 /* Extracts the ALT_UART_CPR_THRE_MOD field value from a register. */
4545 #define ALT_UART_CPR_THRE_MOD_GET(value) (((value) & 0x00000020) >> 5)
4546 /* Produces a ALT_UART_CPR_THRE_MOD register field value suitable for setting the register. */
4547 #define ALT_UART_CPR_THRE_MOD_SET(value) (((value) << 5) & 0x00000020)
4548
4549 /*
4550  * Field : SIR MODE Unsupported - sir_mode
4551  *
4552  * Sir mode not used in this application.
4553  *
4554  * Field Enumeration Values:
4555  *
4556  * Enum | Value | Description
4557  * :----------------------------|:------|:-----------------------
4558  * ALT_UART_CPR_SIR_MOD_E_DISD | 0x0 | Sir Mode Not Supported
4559  *
4560  * Field Access Macros:
4561  *
4562  */
4563 /*
4564  * Enumerated value for register field ALT_UART_CPR_SIR_MOD
4565  *
4566  * Sir Mode Not Supported
4567  */
4568 #define ALT_UART_CPR_SIR_MOD_E_DISD 0x0
4569
4570 /* The Least Significant Bit (LSB) position of the ALT_UART_CPR_SIR_MOD register field. */
4571 #define ALT_UART_CPR_SIR_MOD_LSB 6
4572 /* The Most Significant Bit (MSB) position of the ALT_UART_CPR_SIR_MOD register field. */
4573 #define ALT_UART_CPR_SIR_MOD_MSB 6
4574 /* The width in bits of the ALT_UART_CPR_SIR_MOD register field. */
4575 #define ALT_UART_CPR_SIR_MOD_WIDTH 1
4576 /* The mask used to set the ALT_UART_CPR_SIR_MOD register field value. */
4577 #define ALT_UART_CPR_SIR_MOD_SET_MSK 0x00000040
4578 /* The mask used to clear the ALT_UART_CPR_SIR_MOD register field value. */
4579 #define ALT_UART_CPR_SIR_MOD_CLR_MSK 0xffffffbf
4580 /* The reset value of the ALT_UART_CPR_SIR_MOD register field. */
4581 #define ALT_UART_CPR_SIR_MOD_RESET 0x0
4582 /* Extracts the ALT_UART_CPR_SIR_MOD field value from a register. */
4583 #define ALT_UART_CPR_SIR_MOD_GET(value) (((value) & 0x00000040) >> 6)
4584 /* Produces a ALT_UART_CPR_SIR_MOD register field value suitable for setting the register. */
4585 #define ALT_UART_CPR_SIR_MOD_SET(value) (((value) << 6) & 0x00000040)
4586
4587 /*
4588  * Field : SIR LP MODE Unsupported - sir_lp_mode
4589  *
4590  * LP Sir Mode not used in this application.
4591  *
4592  * Field Enumeration Values:
4593  *
4594  * Enum | Value | Description
4595  * :-------------------------------|:------|:--------------------------
4596  * ALT_UART_CPR_SIR_LP_MOD_E_DISD | 0x0 | LP Sir Mode Not Supported
4597  *
4598  * Field Access Macros:
4599  *
4600  */
4601 /*
4602  * Enumerated value for register field ALT_UART_CPR_SIR_LP_MOD
4603  *
4604  * LP Sir Mode Not Supported
4605  */
4606 #define ALT_UART_CPR_SIR_LP_MOD_E_DISD 0x0
4607
4608 /* The Least Significant Bit (LSB) position of the ALT_UART_CPR_SIR_LP_MOD register field. */
4609 #define ALT_UART_CPR_SIR_LP_MOD_LSB 7
4610 /* The Most Significant Bit (MSB) position of the ALT_UART_CPR_SIR_LP_MOD register field. */
4611 #define ALT_UART_CPR_SIR_LP_MOD_MSB 7
4612 /* The width in bits of the ALT_UART_CPR_SIR_LP_MOD register field. */
4613 #define ALT_UART_CPR_SIR_LP_MOD_WIDTH 1
4614 /* The mask used to set the ALT_UART_CPR_SIR_LP_MOD register field value. */
4615 #define ALT_UART_CPR_SIR_LP_MOD_SET_MSK 0x00000080
4616 /* The mask used to clear the ALT_UART_CPR_SIR_LP_MOD register field value. */
4617 #define ALT_UART_CPR_SIR_LP_MOD_CLR_MSK 0xffffff7f
4618 /* The reset value of the ALT_UART_CPR_SIR_LP_MOD register field. */
4619 #define ALT_UART_CPR_SIR_LP_MOD_RESET 0x0
4620 /* Extracts the ALT_UART_CPR_SIR_LP_MOD field value from a register. */
4621 #define ALT_UART_CPR_SIR_LP_MOD_GET(value) (((value) & 0x00000080) >> 7)
4622 /* Produces a ALT_UART_CPR_SIR_LP_MOD register field value suitable for setting the register. */
4623 #define ALT_UART_CPR_SIR_LP_MOD_SET(value) (((value) << 7) & 0x00000080)
4624
4625 /*
4626  * Field : ADDITIONAL FEATURES Supported - additional_feat
4627  *
4628  * Configures the uart to include fifo status register, shadow registers and
4629  * encoded parameter register.
4630  *
4631  * Field Enumeration Values:
4632  *
4633  * Enum | Value | Description
4634  * :-----------------------------------|:------|:------------------------------
4635  * ALT_UART_CPR_ADDITIONAL_FEAT_E_END | 0x1 | Additional Features Supported
4636  *
4637  * Field Access Macros:
4638  *
4639  */
4640 /*
4641  * Enumerated value for register field ALT_UART_CPR_ADDITIONAL_FEAT
4642  *
4643  * Additional Features Supported
4644  */
4645 #define ALT_UART_CPR_ADDITIONAL_FEAT_E_END 0x1
4646
4647 /* The Least Significant Bit (LSB) position of the ALT_UART_CPR_ADDITIONAL_FEAT register field. */
4648 #define ALT_UART_CPR_ADDITIONAL_FEAT_LSB 8
4649 /* The Most Significant Bit (MSB) position of the ALT_UART_CPR_ADDITIONAL_FEAT register field. */
4650 #define ALT_UART_CPR_ADDITIONAL_FEAT_MSB 8
4651 /* The width in bits of the ALT_UART_CPR_ADDITIONAL_FEAT register field. */
4652 #define ALT_UART_CPR_ADDITIONAL_FEAT_WIDTH 1
4653 /* The mask used to set the ALT_UART_CPR_ADDITIONAL_FEAT register field value. */
4654 #define ALT_UART_CPR_ADDITIONAL_FEAT_SET_MSK 0x00000100
4655 /* The mask used to clear the ALT_UART_CPR_ADDITIONAL_FEAT register field value. */
4656 #define ALT_UART_CPR_ADDITIONAL_FEAT_CLR_MSK 0xfffffeff
4657 /* The reset value of the ALT_UART_CPR_ADDITIONAL_FEAT register field. */
4658 #define ALT_UART_CPR_ADDITIONAL_FEAT_RESET 0x1
4659 /* Extracts the ALT_UART_CPR_ADDITIONAL_FEAT field value from a register. */
4660 #define ALT_UART_CPR_ADDITIONAL_FEAT_GET(value) (((value) & 0x00000100) >> 8)
4661 /* Produces a ALT_UART_CPR_ADDITIONAL_FEAT register field value suitable for setting the register. */
4662 #define ALT_UART_CPR_ADDITIONAL_FEAT_SET(value) (((value) << 8) & 0x00000100)
4663
4664 /*
4665  * Field : FIFO ACCESS Supported - fifo_access
4666  *
4667  * Configures the peripheral to have a programmable FIFO access mode. This is used
4668  * for test purposes, to allow the receiver FIFO to be written and the transmit
4669  * FIFO to be read when FIFOs are implemented and enabled.
4670  *
4671  * Field Enumeration Values:
4672  *
4673  * Enum | Value | Description
4674  * :-------------------------------|:------|:----------------------
4675  * ALT_UART_CPR_FIFO_ACCESS_E_END | 0x1 | FIFO Access Supported
4676  *
4677  * Field Access Macros:
4678  *
4679  */
4680 /*
4681  * Enumerated value for register field ALT_UART_CPR_FIFO_ACCESS
4682  *
4683  * FIFO Access Supported
4684  */
4685 #define ALT_UART_CPR_FIFO_ACCESS_E_END 0x1
4686
4687 /* The Least Significant Bit (LSB) position of the ALT_UART_CPR_FIFO_ACCESS register field. */
4688 #define ALT_UART_CPR_FIFO_ACCESS_LSB 9
4689 /* The Most Significant Bit (MSB) position of the ALT_UART_CPR_FIFO_ACCESS register field. */
4690 #define ALT_UART_CPR_FIFO_ACCESS_MSB 9
4691 /* The width in bits of the ALT_UART_CPR_FIFO_ACCESS register field. */
4692 #define ALT_UART_CPR_FIFO_ACCESS_WIDTH 1
4693 /* The mask used to set the ALT_UART_CPR_FIFO_ACCESS register field value. */
4694 #define ALT_UART_CPR_FIFO_ACCESS_SET_MSK 0x00000200
4695 /* The mask used to clear the ALT_UART_CPR_FIFO_ACCESS register field value. */
4696 #define ALT_UART_CPR_FIFO_ACCESS_CLR_MSK 0xfffffdff
4697 /* The reset value of the ALT_UART_CPR_FIFO_ACCESS register field. */
4698 #define ALT_UART_CPR_FIFO_ACCESS_RESET 0x1
4699 /* Extracts the ALT_UART_CPR_FIFO_ACCESS field value from a register. */
4700 #define ALT_UART_CPR_FIFO_ACCESS_GET(value) (((value) & 0x00000200) >> 9)
4701 /* Produces a ALT_UART_CPR_FIFO_ACCESS register field value suitable for setting the register. */
4702 #define ALT_UART_CPR_FIFO_ACCESS_SET(value) (((value) << 9) & 0x00000200)
4703
4704 /*
4705  * Field : FIFO STAT Supported - fifo_stat
4706  *
4707  * Configures the peripheral to have three additional FIFO status registers.
4708  *
4709  * Field Enumeration Values:
4710  *
4711  * Enum | Value | Description
4712  * :-----------------------------|:------|:--------------------
4713  * ALT_UART_CPR_FIFO_STAT_E_END | 0x1 | FIFO Stat Supported
4714  *
4715  * Field Access Macros:
4716  *
4717  */
4718 /*
4719  * Enumerated value for register field ALT_UART_CPR_FIFO_STAT
4720  *
4721  * FIFO Stat Supported
4722  */
4723 #define ALT_UART_CPR_FIFO_STAT_E_END 0x1
4724
4725 /* The Least Significant Bit (LSB) position of the ALT_UART_CPR_FIFO_STAT register field. */
4726 #define ALT_UART_CPR_FIFO_STAT_LSB 10
4727 /* The Most Significant Bit (MSB) position of the ALT_UART_CPR_FIFO_STAT register field. */
4728 #define ALT_UART_CPR_FIFO_STAT_MSB 10
4729 /* The width in bits of the ALT_UART_CPR_FIFO_STAT register field. */
4730 #define ALT_UART_CPR_FIFO_STAT_WIDTH 1
4731 /* The mask used to set the ALT_UART_CPR_FIFO_STAT register field value. */
4732 #define ALT_UART_CPR_FIFO_STAT_SET_MSK 0x00000400
4733 /* The mask used to clear the ALT_UART_CPR_FIFO_STAT register field value. */
4734 #define ALT_UART_CPR_FIFO_STAT_CLR_MSK 0xfffffbff
4735 /* The reset value of the ALT_UART_CPR_FIFO_STAT register field. */
4736 #define ALT_UART_CPR_FIFO_STAT_RESET 0x1
4737 /* Extracts the ALT_UART_CPR_FIFO_STAT field value from a register. */
4738 #define ALT_UART_CPR_FIFO_STAT_GET(value) (((value) & 0x00000400) >> 10)
4739 /* Produces a ALT_UART_CPR_FIFO_STAT register field value suitable for setting the register. */
4740 #define ALT_UART_CPR_FIFO_STAT_SET(value) (((value) << 10) & 0x00000400)
4741
4742 /*
4743  * Field : SHADOW Supported - shadow
4744  *
4745  * Configures the peripheral to have seven additional registers that shadow some of
4746  * the existing register bits that are regularly modified by software. These can be
4747  * used to reduce the software overhead that is introduced by having to perform
4748  * read-modify writes.
4749  *
4750  * Field Enumeration Values:
4751  *
4752  * Enum | Value | Description
4753  * :--------------------------|:------|:-----------------
4754  * ALT_UART_CPR_SHADOW_E_END | 0x1 | Shadow Supported
4755  *
4756  * Field Access Macros:
4757  *
4758  */
4759 /*
4760  * Enumerated value for register field ALT_UART_CPR_SHADOW
4761  *
4762  * Shadow Supported
4763  */
4764 #define ALT_UART_CPR_SHADOW_E_END 0x1
4765
4766 /* The Least Significant Bit (LSB) position of the ALT_UART_CPR_SHADOW register field. */
4767 #define ALT_UART_CPR_SHADOW_LSB 11
4768 /* The Most Significant Bit (MSB) position of the ALT_UART_CPR_SHADOW register field. */
4769 #define ALT_UART_CPR_SHADOW_MSB 11
4770 /* The width in bits of the ALT_UART_CPR_SHADOW register field. */
4771 #define ALT_UART_CPR_SHADOW_WIDTH 1
4772 /* The mask used to set the ALT_UART_CPR_SHADOW register field value. */
4773 #define ALT_UART_CPR_SHADOW_SET_MSK 0x00000800
4774 /* The mask used to clear the ALT_UART_CPR_SHADOW register field value. */
4775 #define ALT_UART_CPR_SHADOW_CLR_MSK 0xfffff7ff
4776 /* The reset value of the ALT_UART_CPR_SHADOW register field. */
4777 #define ALT_UART_CPR_SHADOW_RESET 0x1
4778 /* Extracts the ALT_UART_CPR_SHADOW field value from a register. */
4779 #define ALT_UART_CPR_SHADOW_GET(value) (((value) & 0x00000800) >> 11)
4780 /* Produces a ALT_UART_CPR_SHADOW register field value suitable for setting the register. */
4781 #define ALT_UART_CPR_SHADOW_SET(value) (((value) << 11) & 0x00000800)
4782
4783 /*
4784  * Field : Configuartion ID Register Present - uart_add_encoded_param
4785  *
4786  * Configures the peripheral to have a configuration identification register.
4787  *
4788  * Field Enumeration Values:
4789  *
4790  * Enum | Value | Description
4791  * :--------------------------------------|:------|:--------------------
4792  * ALT_UART_CPR_UART_ADD_ENC_PARAM_E_END | 0x1 | ID register present
4793  *
4794  * Field Access Macros:
4795  *
4796  */
4797 /*
4798  * Enumerated value for register field ALT_UART_CPR_UART_ADD_ENC_PARAM
4799  *
4800  * ID register present
4801  */
4802 #define ALT_UART_CPR_UART_ADD_ENC_PARAM_E_END 0x1
4803
4804 /* The Least Significant Bit (LSB) position of the ALT_UART_CPR_UART_ADD_ENC_PARAM register field. */
4805 #define ALT_UART_CPR_UART_ADD_ENC_PARAM_LSB 12
4806 /* The Most Significant Bit (MSB) position of the ALT_UART_CPR_UART_ADD_ENC_PARAM register field. */
4807 #define ALT_UART_CPR_UART_ADD_ENC_PARAM_MSB 12
4808 /* The width in bits of the ALT_UART_CPR_UART_ADD_ENC_PARAM register field. */
4809 #define ALT_UART_CPR_UART_ADD_ENC_PARAM_WIDTH 1
4810 /* The mask used to set the ALT_UART_CPR_UART_ADD_ENC_PARAM register field value. */
4811 #define ALT_UART_CPR_UART_ADD_ENC_PARAM_SET_MSK 0x00001000
4812 /* The mask used to clear the ALT_UART_CPR_UART_ADD_ENC_PARAM register field value. */
4813 #define ALT_UART_CPR_UART_ADD_ENC_PARAM_CLR_MSK 0xffffefff
4814 /* The reset value of the ALT_UART_CPR_UART_ADD_ENC_PARAM register field. */
4815 #define ALT_UART_CPR_UART_ADD_ENC_PARAM_RESET 0x1
4816 /* Extracts the ALT_UART_CPR_UART_ADD_ENC_PARAM field value from a register. */
4817 #define ALT_UART_CPR_UART_ADD_ENC_PARAM_GET(value) (((value) & 0x00001000) >> 12)
4818 /* Produces a ALT_UART_CPR_UART_ADD_ENC_PARAM register field value suitable for setting the register. */
4819 #define ALT_UART_CPR_UART_ADD_ENC_PARAM_SET(value) (((value) << 12) & 0x00001000)
4820
4821 /*
4822  * Field : DMA EXTRA Supported - dma_extra
4823  *
4824  * Configures the peripheral to have four additional DMA signals on the interface.
4825  *
4826  * Field Enumeration Values:
4827  *
4828  * Enum | Value | Description
4829  * :-----------------------------|:------|:--------------------
4830  * ALT_UART_CPR_DMA_EXTRA_E_END | 0x1 | DMA Extra Supported
4831  *
4832  * Field Access Macros:
4833  *
4834  */
4835 /*
4836  * Enumerated value for register field ALT_UART_CPR_DMA_EXTRA
4837  *
4838  * DMA Extra Supported
4839  */
4840 #define ALT_UART_CPR_DMA_EXTRA_E_END 0x1
4841
4842 /* The Least Significant Bit (LSB) position of the ALT_UART_CPR_DMA_EXTRA register field. */
4843 #define ALT_UART_CPR_DMA_EXTRA_LSB 13
4844 /* The Most Significant Bit (MSB) position of the ALT_UART_CPR_DMA_EXTRA register field. */
4845 #define ALT_UART_CPR_DMA_EXTRA_MSB 13
4846 /* The width in bits of the ALT_UART_CPR_DMA_EXTRA register field. */
4847 #define ALT_UART_CPR_DMA_EXTRA_WIDTH 1
4848 /* The mask used to set the ALT_UART_CPR_DMA_EXTRA register field value. */
4849 #define ALT_UART_CPR_DMA_EXTRA_SET_MSK 0x00002000
4850 /* The mask used to clear the ALT_UART_CPR_DMA_EXTRA register field value. */
4851 #define ALT_UART_CPR_DMA_EXTRA_CLR_MSK 0xffffdfff
4852 /* The reset value of the ALT_UART_CPR_DMA_EXTRA register field. */
4853 #define ALT_UART_CPR_DMA_EXTRA_RESET 0x1
4854 /* Extracts the ALT_UART_CPR_DMA_EXTRA field value from a register. */
4855 #define ALT_UART_CPR_DMA_EXTRA_GET(value) (((value) & 0x00002000) >> 13)
4856 /* Produces a ALT_UART_CPR_DMA_EXTRA register field value suitable for setting the register. */
4857 #define ALT_UART_CPR_DMA_EXTRA_SET(value) (((value) << 13) & 0x00002000)
4858
4859 /*
4860  * Field : FIFO Depth - fifo_mode
4861  *
4862  * Receiver and Transmitter FIFO depth in bytes.
4863  *
4864  * Field Enumeration Values:
4865  *
4866  * Enum | Value | Description
4867  * :-------------------------------------|:------|:---------------------
4868  * ALT_UART_CPR_FIFO_MOD_E_FIFO128BYTES | 0x80 | FIFO Depth 128 bytes
4869  *
4870  * Field Access Macros:
4871  *
4872  */
4873 /*
4874  * Enumerated value for register field ALT_UART_CPR_FIFO_MOD
4875  *
4876  * FIFO Depth 128 bytes
4877  */
4878 #define ALT_UART_CPR_FIFO_MOD_E_FIFO128BYTES 0x80
4879
4880 /* The Least Significant Bit (LSB) position of the ALT_UART_CPR_FIFO_MOD register field. */
4881 #define ALT_UART_CPR_FIFO_MOD_LSB 16
4882 /* The Most Significant Bit (MSB) position of the ALT_UART_CPR_FIFO_MOD register field. */
4883 #define ALT_UART_CPR_FIFO_MOD_MSB 23
4884 /* The width in bits of the ALT_UART_CPR_FIFO_MOD register field. */
4885 #define ALT_UART_CPR_FIFO_MOD_WIDTH 8
4886 /* The mask used to set the ALT_UART_CPR_FIFO_MOD register field value. */
4887 #define ALT_UART_CPR_FIFO_MOD_SET_MSK 0x00ff0000
4888 /* The mask used to clear the ALT_UART_CPR_FIFO_MOD register field value. */
4889 #define ALT_UART_CPR_FIFO_MOD_CLR_MSK 0xff00ffff
4890 /* The reset value of the ALT_UART_CPR_FIFO_MOD register field. */
4891 #define ALT_UART_CPR_FIFO_MOD_RESET 0x37
4892 /* Extracts the ALT_UART_CPR_FIFO_MOD field value from a register. */
4893 #define ALT_UART_CPR_FIFO_MOD_GET(value) (((value) & 0x00ff0000) >> 16)
4894 /* Produces a ALT_UART_CPR_FIFO_MOD register field value suitable for setting the register. */
4895 #define ALT_UART_CPR_FIFO_MOD_SET(value) (((value) << 16) & 0x00ff0000)
4896
4897 #ifndef __ASSEMBLY__
4898 /*
4899  * WARNING: The C register and register group struct declarations are provided for
4900  * convenience and illustrative purposes. They should, however, be used with
4901  * caution as the C language standard provides no guarantees about the alignment or
4902  * atomicity of device memory accesses. The recommended practice for writing
4903  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4904  * alt_write_word() functions.
4905  *
4906  * The struct declaration for register ALT_UART_CPR.
4907  */
4909 {
4910  const uint32_t apbdatawidth : 2; /* APB DATA WIDTH */
4911  uint32_t : 2; /* *UNDEFINED* */
4912  const uint32_t afce_mode : 1; /* Auto Flow Control */
4913  const uint32_t thre_mode : 1; /* THRE MODE */
4914  const uint32_t sir_mode : 1; /* SIR MODE Unsupported */
4915  const uint32_t sir_lp_mode : 1; /* SIR LP MODE Unsupported */
4916  const uint32_t additional_feat : 1; /* ADDITIONAL FEATURES Supported */
4917  const uint32_t fifo_access : 1; /* FIFO ACCESS Supported */
4918  const uint32_t fifo_stat : 1; /* FIFO STAT Supported */
4919  const uint32_t shadow : 1; /* SHADOW Supported */
4920  const uint32_t uart_add_encoded_param : 1; /* Configuartion ID Register Present */
4921  const uint32_t dma_extra : 1; /* DMA EXTRA Supported */
4922  uint32_t : 2; /* *UNDEFINED* */
4923  const uint32_t fifo_mode : 8; /* FIFO Depth */
4924  uint32_t : 8; /* *UNDEFINED* */
4925 };
4926
4927 /* The typedef declaration for register ALT_UART_CPR. */
4928 typedef volatile struct ALT_UART_CPR_s ALT_UART_CPR_t;
4929 #endif /* __ASSEMBLY__ */
4930
4931 /* The byte offset of the ALT_UART_CPR register from the beginning of the component. */
4932 #define ALT_UART_CPR_OFST 0xf4
4933 /* The address of the ALT_UART_CPR register. */
4934 #define ALT_UART_CPR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_CPR_OFST))
4935
4936 /*
4937  * Register : Component Version - ucv
4938  *
4939  * Used only with Additional Features
4940  *
4941  * Register Layout
4942  *
4943  * Bits | Access | Reset | Description
4944  * :-------|:-------|:-----------|:--------------
4945  * [31:0] | R | 0x3331312a | ASCII version
4946  *
4947  */
4948 /*
4949  * Field : ASCII version - uart_component_version
4950  *
4951  * ASCII value for each number in the version, followed by *For example 32_30_31_2A
4952  * represents the version 2.01a
4953  *
4954  * Field Access Macros:
4955  *
4956  */
4957 /* The Least Significant Bit (LSB) position of the ALT_UART_UCV_UART_COMPONENT_VER register field. */
4958 #define ALT_UART_UCV_UART_COMPONENT_VER_LSB 0
4959 /* The Most Significant Bit (MSB) position of the ALT_UART_UCV_UART_COMPONENT_VER register field. */
4960 #define ALT_UART_UCV_UART_COMPONENT_VER_MSB 31
4961 /* The width in bits of the ALT_UART_UCV_UART_COMPONENT_VER register field. */
4962 #define ALT_UART_UCV_UART_COMPONENT_VER_WIDTH 32
4963 /* The mask used to set the ALT_UART_UCV_UART_COMPONENT_VER register field value. */
4964 #define ALT_UART_UCV_UART_COMPONENT_VER_SET_MSK 0xffffffff
4965 /* The mask used to clear the ALT_UART_UCV_UART_COMPONENT_VER register field value. */
4966 #define ALT_UART_UCV_UART_COMPONENT_VER_CLR_MSK 0x00000000
4967 /* The reset value of the ALT_UART_UCV_UART_COMPONENT_VER register field. */
4968 #define ALT_UART_UCV_UART_COMPONENT_VER_RESET 0x3331312a
4969 /* Extracts the ALT_UART_UCV_UART_COMPONENT_VER field value from a register. */
4970 #define ALT_UART_UCV_UART_COMPONENT_VER_GET(value) (((value) & 0xffffffff) >> 0)
4971 /* Produces a ALT_UART_UCV_UART_COMPONENT_VER register field value suitable for setting the register. */
4972 #define ALT_UART_UCV_UART_COMPONENT_VER_SET(value) (((value) << 0) & 0xffffffff)
4973
4974 #ifndef __ASSEMBLY__
4975 /*
4976  * WARNING: The C register and register group struct declarations are provided for
4977  * convenience and illustrative purposes. They should, however, be used with
4978  * caution as the C language standard provides no guarantees about the alignment or
4979  * atomicity of device memory accesses. The recommended practice for writing
4980  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4981  * alt_write_word() functions.
4982  *
4983  * The struct declaration for register ALT_UART_UCV.
4984  */
4986 {
4987  const uint32_t uart_component_version : 32; /* ASCII version */
4988 };
4989
4990 /* The typedef declaration for register ALT_UART_UCV. */
4991 typedef volatile struct ALT_UART_UCV_s ALT_UART_UCV_t;
4992 #endif /* __ASSEMBLY__ */
4993
4994 /* The byte offset of the ALT_UART_UCV register from the beginning of the component. */
4995 #define ALT_UART_UCV_OFST 0xf8
4996 /* The address of the ALT_UART_UCV register. */
4997 #define ALT_UART_UCV_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_UCV_OFST))
4998
4999 /*
5000  * Register : Component Type Register - ctr
5001  *
5002  * Describes a hex value associated with the component.
5003  *
5004  * Register Layout
5005  *
5006  * Bits | Access | Reset | Description
5007  * :-------|:-------|:-----------|:--------------
5008  * [31:0] | R | 0x44570110 | Peripheral ID
5009  *
5010  */
5011 /*
5012  * Field : Peripheral ID - peripheral_id
5013  *
5014  * This register contains the peripherals identification code.
5015  *
5016  * Field Access Macros:
5017  *
5018  */
5019 /* The Least Significant Bit (LSB) position of the ALT_UART_CTR_PERIPHERAL_ID register field. */
5020 #define ALT_UART_CTR_PERIPHERAL_ID_LSB 0
5021 /* The Most Significant Bit (MSB) position of the ALT_UART_CTR_PERIPHERAL_ID register field. */
5022 #define ALT_UART_CTR_PERIPHERAL_ID_MSB 31
5023 /* The width in bits of the ALT_UART_CTR_PERIPHERAL_ID register field. */
5024 #define ALT_UART_CTR_PERIPHERAL_ID_WIDTH 32
5025 /* The mask used to set the ALT_UART_CTR_PERIPHERAL_ID register field value. */
5026 #define ALT_UART_CTR_PERIPHERAL_ID_SET_MSK 0xffffffff
5027 /* The mask used to clear the ALT_UART_CTR_PERIPHERAL_ID register field value. */
5028 #define ALT_UART_CTR_PERIPHERAL_ID_CLR_MSK 0x00000000
5029 /* The reset value of the ALT_UART_CTR_PERIPHERAL_ID register field. */
5030 #define ALT_UART_CTR_PERIPHERAL_ID_RESET 0x44570110
5031 /* Extracts the ALT_UART_CTR_PERIPHERAL_ID field value from a register. */
5032 #define ALT_UART_CTR_PERIPHERAL_ID_GET(value) (((value) & 0xffffffff) >> 0)
5033 /* Produces a ALT_UART_CTR_PERIPHERAL_ID register field value suitable for setting the register. */
5034 #define ALT_UART_CTR_PERIPHERAL_ID_SET(value) (((value) << 0) & 0xffffffff)
5035
5036 #ifndef __ASSEMBLY__
5037 /*
5038  * WARNING: The C register and register group struct declarations are provided for
5039  * convenience and illustrative purposes. They should, however, be used with
5040  * caution as the C language standard provides no guarantees about the alignment or
5041  * atomicity of device memory accesses. The recommended practice for writing
5042  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5043  * alt_write_word() functions.
5044  *
5045  * The struct declaration for register ALT_UART_CTR.
5046  */
5048 {
5049  const uint32_t peripheral_id : 32; /* Peripheral ID */
5050 };
5051
5052 /* The typedef declaration for register ALT_UART_CTR. */
5053 typedef volatile struct ALT_UART_CTR_s ALT_UART_CTR_t;
5054 #endif /* __ASSEMBLY__ */
5055
5056 /* The byte offset of the ALT_UART_CTR register from the beginning of the component. */
5057 #define ALT_UART_CTR_OFST 0xfc
5058 /* The address of the ALT_UART_CTR register. */
5059 #define ALT_UART_CTR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_UART_CTR_OFST))
5060
5061 #ifndef __ASSEMBLY__
5062 /*
5063  * WARNING: The C register and register group struct declarations are provided for
5064  * convenience and illustrative purposes. They should, however, be used with
5065  * caution as the C language standard provides no guarantees about the alignment or
5066  * atomicity of device memory accesses. The recommended practice for writing
5067  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5068  * alt_write_word() functions.
5069  *
5070  * The struct declaration for register group ALT_UART.
5071  */
5073 {
5074  volatile ALT_UART_RBR_THR_DLL_t rbr_thr_dll; /* ALT_UART_RBR_THR_DLL */
5075  volatile ALT_UART_IER_DLH_t ier_dlh; /* ALT_UART_IER_DLH */
5076  /* Union for registers colocated at base address offset #0x. */
5077  union
5078  {
5079  volatile ALT_UART_IIR_t iir; /* ALT_UART_IIR */
5080  volatile ALT_UART_FCR_t fcr; /* ALT_UART_FCR */
5081  } _u_0x8;
5082  volatile ALT_UART_LCR_t lcr; /* ALT_UART_LCR */
5083  volatile ALT_UART_MCR_t mcr; /* ALT_UART_MCR */
5084  volatile ALT_UART_LSR_t lsr; /* ALT_UART_LSR */
5085  volatile ALT_UART_MSR_t msr; /* ALT_UART_MSR */
5086  volatile ALT_UART_SCR_t scr; /* ALT_UART_SCR */
5087  volatile uint32_t _pad_0x20_0x2f[4]; /* *UNDEFINED* */
5088  volatile ALT_UART_SRBR_t srbr; /* ALT_UART_SRBR */
5089  volatile ALT_UART_STHR_t sthr; /* ALT_UART_STHR */
5090  volatile uint32_t _pad_0x38_0x6f[14]; /* *UNDEFINED* */
5091  volatile ALT_UART_FAR_t far; /* ALT_UART_FAR */
5092  volatile ALT_UART_TFR_t tfr; /* ALT_UART_TFR */
5093  volatile ALT_UART_RFW_t RFW; /* ALT_UART_RFW */
5094  volatile ALT_UART_USR_t usr; /* ALT_UART_USR */
5095  volatile ALT_UART_TFL_t tfl; /* ALT_UART_TFL */
5096  volatile ALT_UART_RFL_t rfl; /* ALT_UART_RFL */
5097  volatile ALT_UART_SRR_t srr; /* ALT_UART_SRR */
5098  volatile ALT_UART_SRTS_t srts; /* ALT_UART_SRTS */
5099  volatile ALT_UART_SBCR_t sbcr; /* ALT_UART_SBCR */
5100  volatile ALT_UART_SDMAM_t sdmam; /* ALT_UART_SDMAM */
5101  volatile ALT_UART_SFE_t sfe; /* ALT_UART_SFE */
5102  volatile ALT_UART_SRT_t srt; /* ALT_UART_SRT */
5103  volatile ALT_UART_STET_t stet; /* ALT_UART_STET */
5104  volatile ALT_UART_HTX_t htx; /* ALT_UART_HTX */
5105  volatile ALT_UART_DMASA_t dmasa; /* ALT_UART_DMASA */
5106  volatile uint32_t _pad_0xac_0xf3[18]; /* *UNDEFINED* */
5107  volatile ALT_UART_CPR_t cpr; /* ALT_UART_CPR */
5108  volatile ALT_UART_UCV_t ucv; /* ALT_UART_UCV */
5109  volatile ALT_UART_CTR_t ctr; /* ALT_UART_CTR */
5110 };
5111
5112 /* The typedef declaration for register group ALT_UART. */
5113 typedef volatile struct ALT_UART_s ALT_UART_t;
5114 /* The struct declaration for the raw register contents of register group ALT_UART. */
5116 {
5117  volatile uint32_t rbr_thr_dll; /* ALT_UART_RBR_THR_DLL */
5118  volatile uint32_t ier_dlh; /* ALT_UART_IER_DLH */
5119  /* Union for registers colocated at base address offset #0x. */
5120  union
5121  {
5122  volatile uint32_t iir; /* ALT_UART_IIR */
5123  volatile uint32_t fcr; /* ALT_UART_FCR */
5124  } _u_0x8;
5125  volatile uint32_t lcr; /* ALT_UART_LCR */
5126  volatile uint32_t mcr; /* ALT_UART_MCR */
5127  volatile uint32_t lsr; /* ALT_UART_LSR */
5128  volatile uint32_t msr; /* ALT_UART_MSR */
5129  volatile uint32_t scr; /* ALT_UART_SCR */
5130  volatile uint32_t _pad_0x20_0x2f[4]; /* *UNDEFINED* */
5131  volatile uint32_t srbr; /* ALT_UART_SRBR */
5132  volatile uint32_t sthr; /* ALT_UART_STHR */
5133  volatile uint32_t _pad_0x38_0x6f[14]; /* *UNDEFINED* */
5134  volatile uint32_t far; /* ALT_UART_FAR */
5135  volatile uint32_t tfr; /* ALT_UART_TFR */
5136  volatile uint32_t RFW; /* ALT_UART_RFW */
5137  volatile uint32_t usr; /* ALT_UART_USR */
5138  volatile uint32_t tfl; /* ALT_UART_TFL */
5139  volatile uint32_t rfl; /* ALT_UART_RFL */
5140  volatile uint32_t srr; /* ALT_UART_SRR */
5141  volatile uint32_t srts; /* ALT_UART_SRTS */
5142  volatile uint32_t sbcr; /* ALT_UART_SBCR */
5143  volatile uint32_t sdmam; /* ALT_UART_SDMAM */
5144  volatile uint32_t sfe; /* ALT_UART_SFE */
5145  volatile uint32_t srt; /* ALT_UART_SRT */
5146  volatile uint32_t stet; /* ALT_UART_STET */
5147  volatile uint32_t htx; /* ALT_UART_HTX */
5148  volatile uint32_t dmasa; /* ALT_UART_DMASA */
5149  volatile uint32_t _pad_0xac_0xf3[18]; /* *UNDEFINED* */
5150  volatile uint32_t cpr; /* ALT_UART_CPR */
5151  volatile uint32_t ucv; /* ALT_UART_UCV */
5152  volatile uint32_t ctr; /* ALT_UART_CTR */
5153 };
5154
5155 /* The typedef declaration for the raw register contents of register group ALT_UART. */
5156 typedef volatile struct ALT_UART_raw_s ALT_UART_raw_t;
5157 #endif /* __ASSEMBLY__ */
5158
5159
5160 #ifdef __cplusplus
5161 }
5162 #endif /* __cplusplus */
5163 #endif /* __ALTERA_ALT_UART_H__ */
5164
Definition: alt_uart.h:3419
Definition: alt_uart.h:712
Definition: alt_uart.h:5115
Definition: alt_uart.h:2927
Definition: alt_uart.h:3767
Definition: alt_uart.h:4135
Definition: alt_uart.h:4031
Definition: alt_uart.h:5072
Definition: alt_uart.h:2689
Definition: alt_uart.h:4985
Definition: alt_uart.h:3484
Definition: alt_uart.h:2837
Definition: alt_uart.h:1102
Definition: alt_uart.h:3121
Definition: alt_uart.h:1409
Definition: alt_uart.h:4325
Definition: alt_uart.h:4393
Definition: alt_uart.h:2618
Definition: alt_uart.h:3350
Definition: alt_uart.h:4237
Definition: alt_uart.h:3857
Definition: alt_uart.h:4908
Definition: alt_uart.h:546
Definition: alt_uart.h:3943
Definition: alt_uart.h:3670
Definition: alt_uart.h:142
Definition: alt_uart.h:5047
Definition: alt_uart.h:2995
Definition: alt_uart.h:2763
Definition: alt_uart.h:2159
Definition: alt_uart.h:1745
