RTEMS  5.1
alt_gpio.h
1
7 /*******************************************************************************
8 * *
9 * Copyright 2013 Altera Corporation. All Rights Reserved. *
10 * *
11 * Redistribution and use in source and binary forms, with or without *
12 * modification, are permitted provided that the following conditions are met: *
13 * *
14 * 1. Redistributions of source code must retain the above copyright notice, *
15 * this list of conditions and the following disclaimer. *
16 * *
17 * 2. Redistributions in binary form must reproduce the above copyright notice, *
18 * this list of conditions and the following disclaimer in the documentation *
19 * and/or other materials provided with the distribution. *
20 * *
21 * 3. The name of the author may not be used to endorse or promote products *
22 * derived from this software without specific prior written permission. *
23 * *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR *
25 * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
26 * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO *
27 * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, *
28 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, *
29 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; *
30 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, *
31 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR *
32 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF *
33 * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. *
34 * *
35 *******************************************************************************/
36
37 /* Altera - ALT_GPIO */
38
39 #ifndef __ALTERA_ALT_GPIO_H__
40 #define __ALTERA_ALT_GPIO_H__
41
42 #ifdef __cplusplus
43 extern "C"
44 {
45 #endif /* __cplusplus */
46
47 /*
48  * Component : GPIO Module - ALT_GPIO
49  * GPIO Module
50  *
51  * Registers in the GPIO module
52  *
53  */
54 /*
55  * Register : Port A Data Register - gpio_swporta_dr
56  *
57  * This GPIO Data register is used to input or output data
58  *
59  * Check the GPIO chapter in the handbook for details on how GPIO2 is implemented.
60  *
61  * Register Layout
62  *
63  * Bits | Access | Reset | Description
64  * :--------|:-------|:------|:------------
65  * [28:0] | RW | 0x0 | Port A Data
66  * [31:29] | ??? | 0x0 | *UNDEFINED*
67  *
68  */
69 /*
70  * Field : Port A Data - gpio_swporta_dr
71  *
72  * Values written to this register are output on the I/O signals of the GPIO Data
73  * Register, if the corresponding data direction bits for GPIO Data Direction Field
74  * are set to Output mode. The value read back is equal to the last value written
75  * to this register.
76  *
77  * Check the GPIO chapter in the handbook for details on how GPIO2 is implemented.
78  *
79  * Field Access Macros:
80  *
81  */
82 /* The Least Significant Bit (LSB) position of the ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR register field. */
83 #define ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_LSB 0
84 /* The Most Significant Bit (MSB) position of the ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR register field. */
85 #define ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_MSB 28
86 /* The width in bits of the ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR register field. */
87 #define ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_WIDTH 29
88 /* The mask used to set the ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR register field value. */
89 #define ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_SET_MSK 0x1fffffff
90 /* The mask used to clear the ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR register field value. */
91 #define ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_CLR_MSK 0xe0000000
92 /* The reset value of the ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR register field. */
93 #define ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_RESET 0x0
94 /* Extracts the ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR field value from a register. */
95 #define ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_GET(value) (((value) & 0x1fffffff) >> 0)
96 /* Produces a ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR register field value suitable for setting the register. */
97 #define ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_SET(value) (((value) << 0) & 0x1fffffff)
98
99 #ifndef __ASSEMBLY__
100 /*
101  * WARNING: The C register and register group struct declarations are provided for
102  * convenience and illustrative purposes. They should, however, be used with
103  * caution as the C language standard provides no guarantees about the alignment or
104  * atomicity of device memory accesses. The recommended practice for writing
105  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
106  * alt_write_word() functions.
107  *
108  * The struct declaration for register ALT_GPIO_SWPORTA_DR.
109  */
111 {
112  uint32_t gpio_swporta_dr : 29; /* Port A Data */
113  uint32_t : 3; /* *UNDEFINED* */
114 };
115
116 /* The typedef declaration for register ALT_GPIO_SWPORTA_DR. */
117 typedef volatile struct ALT_GPIO_SWPORTA_DR_s ALT_GPIO_SWPORTA_DR_t;
118 #endif /* __ASSEMBLY__ */
119
120 /* The byte offset of the ALT_GPIO_SWPORTA_DR register from the beginning of the component. */
121 #define ALT_GPIO_SWPORTA_DR_OFST 0x0
122 /* The address of the ALT_GPIO_SWPORTA_DR register. */
123 #define ALT_GPIO_SWPORTA_DR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_SWPORTA_DR_OFST))
124
125 /*
126  * Register : Port A Data Direction Register - gpio_swporta_ddr
127  *
128  * This register establishes the direction of each corresponding GPIO Data Field
129  * Bit.
130  *
131  * Check the GPIO chapter in the handbook for details on how GPIO2 is implemented.
132  *
133  * Register Layout
134  *
135  * Bits | Access | Reset | Description
136  * :--------|:-------|:------|:----------------------------
137  * [28:0] | RW | 0x0 | Port A Data Direction Field
138  * [31:29] | ??? | 0x0 | *UNDEFINED*
139  *
140  */
141 /*
142  * Field : Port A Data Direction Field - gpio_swporta_ddr
143  *
144  * Values written to this register independently control the direction of the
145  * corresponding data bit in the Port A Data Register.
146  *
147  * Check the GPIO chapter in the handbook for details on how GPIO2 is implemented.
148  *
149  * Field Enumeration Values:
150  *
151  * Enum | Value | Description
152  * :--------------------------------------------|:------|:-----------------
153  * ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_E_IN | 0x0 | Input Direction
154  * ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_E_OUT | 0x1 | Output Direction
155  *
156  * Field Access Macros:
157  *
158  */
159 /*
160  * Enumerated value for register field ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR
161  *
162  * Input Direction
163  */
164 #define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_E_IN 0x0
165 /*
166  * Enumerated value for register field ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR
167  *
168  * Output Direction
169  */
170 #define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_E_OUT 0x1
171
172 /* The Least Significant Bit (LSB) position of the ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR register field. */
173 #define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_LSB 0
174 /* The Most Significant Bit (MSB) position of the ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR register field. */
175 #define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_MSB 28
176 /* The width in bits of the ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR register field. */
177 #define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_WIDTH 29
178 /* The mask used to set the ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR register field value. */
179 #define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_SET_MSK 0x1fffffff
180 /* The mask used to clear the ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR register field value. */
181 #define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_CLR_MSK 0xe0000000
182 /* The reset value of the ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR register field. */
183 #define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_RESET 0x0
184 /* Extracts the ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR field value from a register. */
185 #define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_GET(value) (((value) & 0x1fffffff) >> 0)
186 /* Produces a ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR register field value suitable for setting the register. */
187 #define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_SET(value) (((value) << 0) & 0x1fffffff)
188
189 #ifndef __ASSEMBLY__
190 /*
191  * WARNING: The C register and register group struct declarations are provided for
192  * convenience and illustrative purposes. They should, however, be used with
193  * caution as the C language standard provides no guarantees about the alignment or
194  * atomicity of device memory accesses. The recommended practice for writing
195  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
196  * alt_write_word() functions.
197  *
198  * The struct declaration for register ALT_GPIO_SWPORTA_DDR.
199  */
201 {
202  uint32_t gpio_swporta_ddr : 29; /* Port A Data Direction Field */
203  uint32_t : 3; /* *UNDEFINED* */
204 };
205
206 /* The typedef declaration for register ALT_GPIO_SWPORTA_DDR. */
207 typedef volatile struct ALT_GPIO_SWPORTA_DDR_s ALT_GPIO_SWPORTA_DDR_t;
208 #endif /* __ASSEMBLY__ */
209
210 /* The byte offset of the ALT_GPIO_SWPORTA_DDR register from the beginning of the component. */
211 #define ALT_GPIO_SWPORTA_DDR_OFST 0x4
212 /* The address of the ALT_GPIO_SWPORTA_DDR register. */
213 #define ALT_GPIO_SWPORTA_DDR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_SWPORTA_DDR_OFST))
214
215 /*
216  * Register : Interrupt Enable Register - gpio_inten
217  *
218  * The Interrupt enable register allows interrupts for each bit of the Port A data
219  * register.
220  *
221  * Register Layout
222  *
223  * Bits | Access | Reset | Description
224  * :--------|:-------|:------|:-----------------------
225  * [28:0] | RW | 0x0 | Interrupt Enable Field
226  * [31:29] | ??? | 0x0 | *UNDEFINED*
227  *
228  */
229 /*
230  * Field : Interrupt Enable Field - gpio_inten
231  *
232  * Allows each bit of Port A Data Register to be configured for interrupt
233  * capability. Interrupts are disabled on the corresponding bits of Port A Data
234  * Register if the corresponding data direction register is set to Output.
235  *
236  * Field Enumeration Values:
237  *
238  * Enum | Value | Description
239  * :--------------------------------|:------|:----------------------------
240  * ALT_GPIO_INTEN_GPIO_INTEN_E_DIS | 0x0 | Disable Interrupt on Port A
241  * ALT_GPIO_INTEN_GPIO_INTEN_E_EN | 0x1 | Enable Interrupt on Port A
242  *
243  * Field Access Macros:
244  *
245  */
246 /*
247  * Enumerated value for register field ALT_GPIO_INTEN_GPIO_INTEN
248  *
249  * Disable Interrupt on Port A
250  */
251 #define ALT_GPIO_INTEN_GPIO_INTEN_E_DIS 0x0
252 /*
253  * Enumerated value for register field ALT_GPIO_INTEN_GPIO_INTEN
254  *
255  * Enable Interrupt on Port A
256  */
257 #define ALT_GPIO_INTEN_GPIO_INTEN_E_EN 0x1
258
259 /* The Least Significant Bit (LSB) position of the ALT_GPIO_INTEN_GPIO_INTEN register field. */
260 #define ALT_GPIO_INTEN_GPIO_INTEN_LSB 0
261 /* The Most Significant Bit (MSB) position of the ALT_GPIO_INTEN_GPIO_INTEN register field. */
262 #define ALT_GPIO_INTEN_GPIO_INTEN_MSB 28
263 /* The width in bits of the ALT_GPIO_INTEN_GPIO_INTEN register field. */
264 #define ALT_GPIO_INTEN_GPIO_INTEN_WIDTH 29
265 /* The mask used to set the ALT_GPIO_INTEN_GPIO_INTEN register field value. */
266 #define ALT_GPIO_INTEN_GPIO_INTEN_SET_MSK 0x1fffffff
267 /* The mask used to clear the ALT_GPIO_INTEN_GPIO_INTEN register field value. */
268 #define ALT_GPIO_INTEN_GPIO_INTEN_CLR_MSK 0xe0000000
269 /* The reset value of the ALT_GPIO_INTEN_GPIO_INTEN register field. */
270 #define ALT_GPIO_INTEN_GPIO_INTEN_RESET 0x0
271 /* Extracts the ALT_GPIO_INTEN_GPIO_INTEN field value from a register. */
272 #define ALT_GPIO_INTEN_GPIO_INTEN_GET(value) (((value) & 0x1fffffff) >> 0)
273 /* Produces a ALT_GPIO_INTEN_GPIO_INTEN register field value suitable for setting the register. */
274 #define ALT_GPIO_INTEN_GPIO_INTEN_SET(value) (((value) << 0) & 0x1fffffff)
275
276 #ifndef __ASSEMBLY__
277 /*
278  * WARNING: The C register and register group struct declarations are provided for
279  * convenience and illustrative purposes. They should, however, be used with
280  * caution as the C language standard provides no guarantees about the alignment or
281  * atomicity of device memory accesses. The recommended practice for writing
282  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
283  * alt_write_word() functions.
284  *
285  * The struct declaration for register ALT_GPIO_INTEN.
286  */
288 {
289  uint32_t gpio_inten : 29; /* Interrupt Enable Field */
290  uint32_t : 3; /* *UNDEFINED* */
291 };
292
293 /* The typedef declaration for register ALT_GPIO_INTEN. */
294 typedef volatile struct ALT_GPIO_INTEN_s ALT_GPIO_INTEN_t;
295 #endif /* __ASSEMBLY__ */
296
297 /* The byte offset of the ALT_GPIO_INTEN register from the beginning of the component. */
298 #define ALT_GPIO_INTEN_OFST 0x30
299 /* The address of the ALT_GPIO_INTEN register. */
300 #define ALT_GPIO_INTEN_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_INTEN_OFST))
301
302 /*
303  * Register : Interrupt Mask Register - gpio_intmask
304  *
305  * Controls which pins cause interrupts on Port A Data Register inputs.
306  *
307  * Register Layout
308  *
309  * Bits | Access | Reset | Description
310  * :--------|:-------|:------|:---------------------
311  * [28:0] | RW | 0x0 | Interrupt Mask Field
312  * [31:29] | ??? | 0x0 | *UNDEFINED*
313  *
314  */
315 /*
316  * Field : Interrupt Mask Field - gpio_intmask
317  *
318  * Controls whether an interrupt on Port A Data Register can generate an interrupt
319  * to the interrupt controller by not masking it. The unmasked status can be read
320  * as well as the resultant status after masking.
321  *
322  * Field Enumeration Values:
323  *
324  * Enum | Value | Description
325  * :----------------------------------|:------|:----------------------------
326  * ALT_GPIO_INTMSK_GPIO_INTMSK_E_DIS | 0x0 | Interrupt bits are unmasked
327  * ALT_GPIO_INTMSK_GPIO_INTMSK_E_EN | 0x1 | Mask Interrupt
328  *
329  * Field Access Macros:
330  *
331  */
332 /*
333  * Enumerated value for register field ALT_GPIO_INTMSK_GPIO_INTMSK
334  *
335  * Interrupt bits are unmasked
336  */
337 #define ALT_GPIO_INTMSK_GPIO_INTMSK_E_DIS 0x0
338 /*
339  * Enumerated value for register field ALT_GPIO_INTMSK_GPIO_INTMSK
340  *
341  * Mask Interrupt
342  */
343 #define ALT_GPIO_INTMSK_GPIO_INTMSK_E_EN 0x1
344
345 /* The Least Significant Bit (LSB) position of the ALT_GPIO_INTMSK_GPIO_INTMSK register field. */
346 #define ALT_GPIO_INTMSK_GPIO_INTMSK_LSB 0
347 /* The Most Significant Bit (MSB) position of the ALT_GPIO_INTMSK_GPIO_INTMSK register field. */
348 #define ALT_GPIO_INTMSK_GPIO_INTMSK_MSB 28
349 /* The width in bits of the ALT_GPIO_INTMSK_GPIO_INTMSK register field. */
350 #define ALT_GPIO_INTMSK_GPIO_INTMSK_WIDTH 29
351 /* The mask used to set the ALT_GPIO_INTMSK_GPIO_INTMSK register field value. */
352 #define ALT_GPIO_INTMSK_GPIO_INTMSK_SET_MSK 0x1fffffff
353 /* The mask used to clear the ALT_GPIO_INTMSK_GPIO_INTMSK register field value. */
354 #define ALT_GPIO_INTMSK_GPIO_INTMSK_CLR_MSK 0xe0000000
355 /* The reset value of the ALT_GPIO_INTMSK_GPIO_INTMSK register field. */
356 #define ALT_GPIO_INTMSK_GPIO_INTMSK_RESET 0x0
357 /* Extracts the ALT_GPIO_INTMSK_GPIO_INTMSK field value from a register. */
358 #define ALT_GPIO_INTMSK_GPIO_INTMSK_GET(value) (((value) & 0x1fffffff) >> 0)
359 /* Produces a ALT_GPIO_INTMSK_GPIO_INTMSK register field value suitable for setting the register. */
360 #define ALT_GPIO_INTMSK_GPIO_INTMSK_SET(value) (((value) << 0) & 0x1fffffff)
361
362 #ifndef __ASSEMBLY__
363 /*
364  * WARNING: The C register and register group struct declarations are provided for
365  * convenience and illustrative purposes. They should, however, be used with
366  * caution as the C language standard provides no guarantees about the alignment or
367  * atomicity of device memory accesses. The recommended practice for writing
368  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
369  * alt_write_word() functions.
370  *
371  * The struct declaration for register ALT_GPIO_INTMSK.
372  */
374 {
375  uint32_t gpio_intmask : 29; /* Interrupt Mask Field */
376  uint32_t : 3; /* *UNDEFINED* */
377 };
378
379 /* The typedef declaration for register ALT_GPIO_INTMSK. */
380 typedef volatile struct ALT_GPIO_INTMSK_s ALT_GPIO_INTMSK_t;
381 #endif /* __ASSEMBLY__ */
382
383 /* The byte offset of the ALT_GPIO_INTMSK register from the beginning of the component. */
384 #define ALT_GPIO_INTMSK_OFST 0x34
385 /* The address of the ALT_GPIO_INTMSK register. */
386 #define ALT_GPIO_INTMSK_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_INTMSK_OFST))
387
388 /*
389  * Register : Interrupt Level Register - gpio_inttype_level
390  *
391  * The interrupt level register defines the type of interrupt (edge or level).
392  *
393  * Register Layout
394  *
395  * Bits | Access | Reset | Description
396  * :--------|:-------|:------|:----------------------
397  * [28:0] | RW | 0x0 | Interrupt Level Field
398  * [31:29] | ??? | 0x0 | *UNDEFINED*
399  *
400  */
401 /*
402  * Field : Interrupt Level Field - gpio_inttype_level
403  *
404  * This field controls the type of interrupt that can occur on the Port A Data
405  * Register.
406  *
407  * Field Enumeration Values:
408  *
409  * Enum | Value | Description
410  * :--------------------------------------------------|:------|:----------------
411  * ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_E_LEVEL | 0x0 | Level-sensitive
412  * ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_E_EDGE | 0x1 | Edge-sensitive
413  *
414  * Field Access Macros:
415  *
416  */
417 /*
418  * Enumerated value for register field ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL
419  *
420  * Level-sensitive
421  */
422 #define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_E_LEVEL 0x0
423 /*
424  * Enumerated value for register field ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL
425  *
426  * Edge-sensitive
427  */
428 #define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_E_EDGE 0x1
429
430 /* The Least Significant Bit (LSB) position of the ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL register field. */
431 #define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_LSB 0
432 /* The Most Significant Bit (MSB) position of the ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL register field. */
433 #define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_MSB 28
434 /* The width in bits of the ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL register field. */
435 #define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_WIDTH 29
436 /* The mask used to set the ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL register field value. */
437 #define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_SET_MSK 0x1fffffff
438 /* The mask used to clear the ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL register field value. */
439 #define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_CLR_MSK 0xe0000000
440 /* The reset value of the ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL register field. */
441 #define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_RESET 0x0
442 /* Extracts the ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL field value from a register. */
443 #define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_GET(value) (((value) & 0x1fffffff) >> 0)
444 /* Produces a ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL register field value suitable for setting the register. */
445 #define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_SET(value) (((value) << 0) & 0x1fffffff)
446
447 #ifndef __ASSEMBLY__
448 /*
449  * WARNING: The C register and register group struct declarations are provided for
450  * convenience and illustrative purposes. They should, however, be used with
451  * caution as the C language standard provides no guarantees about the alignment or
452  * atomicity of device memory accesses. The recommended practice for writing
453  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
454  * alt_write_word() functions.
455  *
456  * The struct declaration for register ALT_GPIO_INTTYPE_LEVEL.
457  */
459 {
460  uint32_t gpio_inttype_level : 29; /* Interrupt Level Field */
461  uint32_t : 3; /* *UNDEFINED* */
462 };
463
464 /* The typedef declaration for register ALT_GPIO_INTTYPE_LEVEL. */
465 typedef volatile struct ALT_GPIO_INTTYPE_LEVEL_s ALT_GPIO_INTTYPE_LEVEL_t;
466 #endif /* __ASSEMBLY__ */
467
468 /* The byte offset of the ALT_GPIO_INTTYPE_LEVEL register from the beginning of the component. */
469 #define ALT_GPIO_INTTYPE_LEVEL_OFST 0x38
470 /* The address of the ALT_GPIO_INTTYPE_LEVEL register. */
471 #define ALT_GPIO_INTTYPE_LEVEL_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_INTTYPE_LEVEL_OFST))
472
473 /*
474  * Register : Interrupt Polarity Register - gpio_int_polarity
475  *
476  * Controls the Polarity of Interrupts that can occur on inputs of Port A Data
477  * Register
478  *
479  * Register Layout
480  *
481  * Bits | Access | Reset | Description
482  * :--------|:-------|:------|:-----------------------
483  * [28:0] | RW | 0x0 | Polarity Control Field
484  * [31:29] | ??? | 0x0 | *UNDEFINED*
485  *
486  */
487 /*
488  * Field : Polarity Control Field - gpio_int_polarity
489  *
490  * Controls the polarity of edge or level sensitivity that can occur on input of
491  * Port A Data Register.
492  *
493  * Field Enumeration Values:
494  *
495  * Enum | Value | Description
496  * :----------------------------------------|:------|:------------
497  * ALT_GPIO_INT_POL_GPIO_INT_POL_E_ACTLOW | 0x0 | Active low
498  * ALT_GPIO_INT_POL_GPIO_INT_POL_E_ACTHIGH | 0x1 | Active high
499  *
500  * Field Access Macros:
501  *
502  */
503 /*
504  * Enumerated value for register field ALT_GPIO_INT_POL_GPIO_INT_POL
505  *
506  * Active low
507  */
508 #define ALT_GPIO_INT_POL_GPIO_INT_POL_E_ACTLOW 0x0
509 /*
510  * Enumerated value for register field ALT_GPIO_INT_POL_GPIO_INT_POL
511  *
512  * Active high
513  */
514 #define ALT_GPIO_INT_POL_GPIO_INT_POL_E_ACTHIGH 0x1
515
516 /* The Least Significant Bit (LSB) position of the ALT_GPIO_INT_POL_GPIO_INT_POL register field. */
517 #define ALT_GPIO_INT_POL_GPIO_INT_POL_LSB 0
518 /* The Most Significant Bit (MSB) position of the ALT_GPIO_INT_POL_GPIO_INT_POL register field. */
519 #define ALT_GPIO_INT_POL_GPIO_INT_POL_MSB 28
520 /* The width in bits of the ALT_GPIO_INT_POL_GPIO_INT_POL register field. */
521 #define ALT_GPIO_INT_POL_GPIO_INT_POL_WIDTH 29
522 /* The mask used to set the ALT_GPIO_INT_POL_GPIO_INT_POL register field value. */
523 #define ALT_GPIO_INT_POL_GPIO_INT_POL_SET_MSK 0x1fffffff
524 /* The mask used to clear the ALT_GPIO_INT_POL_GPIO_INT_POL register field value. */
525 #define ALT_GPIO_INT_POL_GPIO_INT_POL_CLR_MSK 0xe0000000
526 /* The reset value of the ALT_GPIO_INT_POL_GPIO_INT_POL register field. */
527 #define ALT_GPIO_INT_POL_GPIO_INT_POL_RESET 0x0
528 /* Extracts the ALT_GPIO_INT_POL_GPIO_INT_POL field value from a register. */
529 #define ALT_GPIO_INT_POL_GPIO_INT_POL_GET(value) (((value) & 0x1fffffff) >> 0)
530 /* Produces a ALT_GPIO_INT_POL_GPIO_INT_POL register field value suitable for setting the register. */
531 #define ALT_GPIO_INT_POL_GPIO_INT_POL_SET(value) (((value) << 0) & 0x1fffffff)
532
533 #ifndef __ASSEMBLY__
534 /*
535  * WARNING: The C register and register group struct declarations are provided for
536  * convenience and illustrative purposes. They should, however, be used with
537  * caution as the C language standard provides no guarantees about the alignment or
538  * atomicity of device memory accesses. The recommended practice for writing
539  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
540  * alt_write_word() functions.
541  *
542  * The struct declaration for register ALT_GPIO_INT_POL.
543  */
545 {
546  uint32_t gpio_int_polarity : 29; /* Polarity Control Field */
547  uint32_t : 3; /* *UNDEFINED* */
548 };
549
550 /* The typedef declaration for register ALT_GPIO_INT_POL. */
551 typedef volatile struct ALT_GPIO_INT_POL_s ALT_GPIO_INT_POL_t;
552 #endif /* __ASSEMBLY__ */
553
554 /* The byte offset of the ALT_GPIO_INT_POL register from the beginning of the component. */
555 #define ALT_GPIO_INT_POL_OFST 0x3c
556 /* The address of the ALT_GPIO_INT_POL register. */
557 #define ALT_GPIO_INT_POL_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_INT_POL_OFST))
558
559 /*
560  * Register : Interrupt Status Register - gpio_intstatus
561  *
562  * The Interrupt status is reported for all Port A Data Register Bits.
563  *
564  * Register Layout
565  *
566  * Bits | Access | Reset | Description
567  * :--------|:-------|:------|:-----------------------
568  * [28:0] | RW | 0x0 | Interrupt Status Field
569  * [31:29] | ??? | 0x0 | *UNDEFINED*
570  *
571  */
572 /*
573  * Field : Interrupt Status Field - gpio_intstatus
574  *
575  * Interrupt status of Port A Data Register.
576  *
577  * Field Enumeration Values:
578  *
579  * Enum | Value | Description
580  * :--------------------------------------|:------|:------------
581  * ALT_GPIO_INTSTAT_GPIO_INTSTAT_E_INACT | 0x0 | Inactive
582  * ALT_GPIO_INTSTAT_GPIO_INTSTAT_E_ACT | 0x1 | Active
583  *
584  * Field Access Macros:
585  *
586  */
587 /*
588  * Enumerated value for register field ALT_GPIO_INTSTAT_GPIO_INTSTAT
589  *
590  * Inactive
591  */
592 #define ALT_GPIO_INTSTAT_GPIO_INTSTAT_E_INACT 0x0
593 /*
594  * Enumerated value for register field ALT_GPIO_INTSTAT_GPIO_INTSTAT
595  *
596  * Active
597  */
598 #define ALT_GPIO_INTSTAT_GPIO_INTSTAT_E_ACT 0x1
599
600 /* The Least Significant Bit (LSB) position of the ALT_GPIO_INTSTAT_GPIO_INTSTAT register field. */
601 #define ALT_GPIO_INTSTAT_GPIO_INTSTAT_LSB 0
602 /* The Most Significant Bit (MSB) position of the ALT_GPIO_INTSTAT_GPIO_INTSTAT register field. */
603 #define ALT_GPIO_INTSTAT_GPIO_INTSTAT_MSB 28
604 /* The width in bits of the ALT_GPIO_INTSTAT_GPIO_INTSTAT register field. */
605 #define ALT_GPIO_INTSTAT_GPIO_INTSTAT_WIDTH 29
606 /* The mask used to set the ALT_GPIO_INTSTAT_GPIO_INTSTAT register field value. */
607 #define ALT_GPIO_INTSTAT_GPIO_INTSTAT_SET_MSK 0x1fffffff
608 /* The mask used to clear the ALT_GPIO_INTSTAT_GPIO_INTSTAT register field value. */
609 #define ALT_GPIO_INTSTAT_GPIO_INTSTAT_CLR_MSK 0xe0000000
610 /* The reset value of the ALT_GPIO_INTSTAT_GPIO_INTSTAT register field. */
611 #define ALT_GPIO_INTSTAT_GPIO_INTSTAT_RESET 0x0
612 /* Extracts the ALT_GPIO_INTSTAT_GPIO_INTSTAT field value from a register. */
613 #define ALT_GPIO_INTSTAT_GPIO_INTSTAT_GET(value) (((value) & 0x1fffffff) >> 0)
614 /* Produces a ALT_GPIO_INTSTAT_GPIO_INTSTAT register field value suitable for setting the register. */
615 #define ALT_GPIO_INTSTAT_GPIO_INTSTAT_SET(value) (((value) << 0) & 0x1fffffff)
616
617 #ifndef __ASSEMBLY__
618 /*
619  * WARNING: The C register and register group struct declarations are provided for
620  * convenience and illustrative purposes. They should, however, be used with
621  * caution as the C language standard provides no guarantees about the alignment or
622  * atomicity of device memory accesses. The recommended practice for writing
623  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
624  * alt_write_word() functions.
625  *
626  * The struct declaration for register ALT_GPIO_INTSTAT.
627  */
629 {
630  uint32_t gpio_intstatus : 29; /* Interrupt Status Field */
631  uint32_t : 3; /* *UNDEFINED* */
632 };
633
634 /* The typedef declaration for register ALT_GPIO_INTSTAT. */
635 typedef volatile struct ALT_GPIO_INTSTAT_s ALT_GPIO_INTSTAT_t;
636 #endif /* __ASSEMBLY__ */
637
638 /* The byte offset of the ALT_GPIO_INTSTAT register from the beginning of the component. */
639 #define ALT_GPIO_INTSTAT_OFST 0x40
640 /* The address of the ALT_GPIO_INTSTAT register. */
641 #define ALT_GPIO_INTSTAT_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_INTSTAT_OFST))
642
643 /*
644  * Register : Raw Interrupt Status Register - gpio_raw_intstatus
645  *
646  * This is the Raw Interrupt Status Register for Port A Data Register. It is used
647  * with the Interrupt Mask Register to allow interrupts from the Port A Data
648  * Register.
649  *
650  * Register Layout
651  *
652  * Bits | Access | Reset | Description
653  * :--------|:-------|:------|:---------------------------
654  * [28:0] | RW | 0x0 | Raw Interrupt Status Field
655  * [31:29] | ??? | 0x0 | *UNDEFINED*
656  *
657  */
658 /*
659  * Field : Raw Interrupt Status Field - gpio_raw_intstatus
660  *
661  * Raw interrupt of status of Port A Data Register (premasking bits)
662  *
663  * Field Enumeration Values:
664  *
665  * Enum | Value | Description
666  * :----------------------------------------------|:------|:------------
667  * ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_E_INACT | 0x0 | Inactive
668  * ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_E_ACT | 0x1 | Active
669  *
670  * Field Access Macros:
671  *
672  */
673 /*
674  * Enumerated value for register field ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT
675  *
676  * Inactive
677  */
678 #define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_E_INACT 0x0
679 /*
680  * Enumerated value for register field ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT
681  *
682  * Active
683  */
684 #define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_E_ACT 0x1
685
686 /* The Least Significant Bit (LSB) position of the ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT register field. */
687 #define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_LSB 0
688 /* The Most Significant Bit (MSB) position of the ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT register field. */
689 #define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_MSB 28
690 /* The width in bits of the ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT register field. */
691 #define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_WIDTH 29
692 /* The mask used to set the ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT register field value. */
693 #define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_SET_MSK 0x1fffffff
694 /* The mask used to clear the ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT register field value. */
695 #define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_CLR_MSK 0xe0000000
696 /* The reset value of the ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT register field. */
697 #define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_RESET 0x0
698 /* Extracts the ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT field value from a register. */
699 #define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_GET(value) (((value) & 0x1fffffff) >> 0)
700 /* Produces a ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT register field value suitable for setting the register. */
701 #define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_SET(value) (((value) << 0) & 0x1fffffff)
702
703 #ifndef __ASSEMBLY__
704 /*
705  * WARNING: The C register and register group struct declarations are provided for
706  * convenience and illustrative purposes. They should, however, be used with
707  * caution as the C language standard provides no guarantees about the alignment or
708  * atomicity of device memory accesses. The recommended practice for writing
709  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
710  * alt_write_word() functions.
711  *
712  * The struct declaration for register ALT_GPIO_RAW_INTSTAT.
713  */
715 {
716  uint32_t gpio_raw_intstatus : 29; /* Raw Interrupt Status Field */
717  uint32_t : 3; /* *UNDEFINED* */
718 };
719
720 /* The typedef declaration for register ALT_GPIO_RAW_INTSTAT. */
721 typedef volatile struct ALT_GPIO_RAW_INTSTAT_s ALT_GPIO_RAW_INTSTAT_t;
722 #endif /* __ASSEMBLY__ */
723
724 /* The byte offset of the ALT_GPIO_RAW_INTSTAT register from the beginning of the component. */
725 #define ALT_GPIO_RAW_INTSTAT_OFST 0x44
726 /* The address of the ALT_GPIO_RAW_INTSTAT register. */
727 #define ALT_GPIO_RAW_INTSTAT_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_RAW_INTSTAT_OFST))
728
729 /*
730  * Register : Debounce Enable Register - gpio_debounce
731  *
732  * Debounces each IO Pin
733  *
734  * Register Layout
735  *
736  * Bits | Access | Reset | Description
737  * :--------|:-------|:------|:--------------------------------
738  * [28:0] | RW | 0x0 | ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE
739  * [31:29] | ??? | 0x0 | *UNDEFINED*
740  *
741  */
742 /*
743  * Field : gpio_debounce
744  *
745  * Controls whether an external signal that is the source of an interrupt needs to
746  * be debounced to remove any spurious glitches. A signal must be valid for two
747  * periods of an external clock (gpio_db_clk) before it is internally processed.
748  *
749  * Field Enumeration Values:
750  *
751  * Enum | Value | Description
752  * :--------------------------------------|:------|:----------------
753  * ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_E_DIS | 0x0 | No debounce
754  * ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_E_EN | 0x1 | Enable debounce
755  *
756  * Field Access Macros:
757  *
758  */
759 /*
760  * Enumerated value for register field ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE
761  *
762  * No debounce
763  */
764 #define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_E_DIS 0x0
765 /*
766  * Enumerated value for register field ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE
767  *
768  * Enable debounce
769  */
770 #define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_E_EN 0x1
771
772 /* The Least Significant Bit (LSB) position of the ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE register field. */
773 #define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_LSB 0
774 /* The Most Significant Bit (MSB) position of the ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE register field. */
775 #define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_MSB 28
776 /* The width in bits of the ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE register field. */
777 #define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_WIDTH 29
778 /* The mask used to set the ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE register field value. */
779 #define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_SET_MSK 0x1fffffff
780 /* The mask used to clear the ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE register field value. */
781 #define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_CLR_MSK 0xe0000000
782 /* The reset value of the ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE register field. */
783 #define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_RESET 0x0
784 /* Extracts the ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE field value from a register. */
785 #define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_GET(value) (((value) & 0x1fffffff) >> 0)
786 /* Produces a ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE register field value suitable for setting the register. */
787 #define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_SET(value) (((value) << 0) & 0x1fffffff)
788
789 #ifndef __ASSEMBLY__
790 /*
791  * WARNING: The C register and register group struct declarations are provided for
792  * convenience and illustrative purposes. They should, however, be used with
793  * caution as the C language standard provides no guarantees about the alignment or
794  * atomicity of device memory accesses. The recommended practice for writing
795  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
796  * alt_write_word() functions.
797  *
798  * The struct declaration for register ALT_GPIO_DEBOUNCE.
799  */
801 {
802  uint32_t gpio_debounce : 29; /* ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE */
803  uint32_t : 3; /* *UNDEFINED* */
804 };
805
806 /* The typedef declaration for register ALT_GPIO_DEBOUNCE. */
807 typedef volatile struct ALT_GPIO_DEBOUNCE_s ALT_GPIO_DEBOUNCE_t;
808 #endif /* __ASSEMBLY__ */
809
810 /* The byte offset of the ALT_GPIO_DEBOUNCE register from the beginning of the component. */
811 #define ALT_GPIO_DEBOUNCE_OFST 0x48
812 /* The address of the ALT_GPIO_DEBOUNCE register. */
813 #define ALT_GPIO_DEBOUNCE_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_DEBOUNCE_OFST))
814
815 /*
816  * Register : Clear Interrupt Register - gpio_porta_eoi
817  *
818  * Port A Data Register interrupt handling.
819  *
820  * Register Layout
821  *
822  * Bits | Access | Reset | Description
823  * :--------|:-------|:------|:-----------------------------
824  * [28:0] | W | 0x0 | Clears Edge Interrupts Field
825  * [31:29] | ??? | 0x0 | *UNDEFINED*
826  *
827  */
828 /*
829  * Field : Clears Edge Interrupts Field - gpio_porta_eoi
830  *
831  * Controls the clearing of edge type interrupts from the Port A Data Register.
832  *
833  * Field Enumeration Values:
834  *
835  * Enum | Value | Description
836  * :------------------------------------------|:------|:-------------------
837  * ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_E_NOCLR | 0x0 | No interrupt clear
838  * ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_E_CLR | 0x1 | Clear interrupt
839  *
840  * Field Access Macros:
841  *
842  */
843 /*
844  * Enumerated value for register field ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI
845  *
846  * No interrupt clear
847  */
848 #define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_E_NOCLR 0x0
849 /*
850  * Enumerated value for register field ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI
851  *
852  * Clear interrupt
853  */
854 #define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_E_CLR 0x1
855
856 /* The Least Significant Bit (LSB) position of the ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI register field. */
857 #define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_LSB 0
858 /* The Most Significant Bit (MSB) position of the ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI register field. */
859 #define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_MSB 28
860 /* The width in bits of the ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI register field. */
861 #define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_WIDTH 29
862 /* The mask used to set the ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI register field value. */
863 #define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_SET_MSK 0x1fffffff
864 /* The mask used to clear the ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI register field value. */
865 #define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_CLR_MSK 0xe0000000
866 /* The reset value of the ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI register field. */
867 #define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_RESET 0x0
868 /* Extracts the ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI field value from a register. */
869 #define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_GET(value) (((value) & 0x1fffffff) >> 0)
870 /* Produces a ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI register field value suitable for setting the register. */
871 #define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_SET(value) (((value) << 0) & 0x1fffffff)
872
873 #ifndef __ASSEMBLY__
874 /*
875  * WARNING: The C register and register group struct declarations are provided for
876  * convenience and illustrative purposes. They should, however, be used with
877  * caution as the C language standard provides no guarantees about the alignment or
878  * atomicity of device memory accesses. The recommended practice for writing
879  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
880  * alt_write_word() functions.
881  *
882  * The struct declaration for register ALT_GPIO_PORTA_EOI.
883  */
885 {
886  uint32_t gpio_porta_eoi : 29; /* Clears Edge Interrupts Field */
887  uint32_t : 3; /* *UNDEFINED* */
888 };
889
890 /* The typedef declaration for register ALT_GPIO_PORTA_EOI. */
891 typedef volatile struct ALT_GPIO_PORTA_EOI_s ALT_GPIO_PORTA_EOI_t;
892 #endif /* __ASSEMBLY__ */
893
894 /* The byte offset of the ALT_GPIO_PORTA_EOI register from the beginning of the component. */
895 #define ALT_GPIO_PORTA_EOI_OFST 0x4c
896 /* The address of the ALT_GPIO_PORTA_EOI register. */
897 #define ALT_GPIO_PORTA_EOI_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_PORTA_EOI_OFST))
898
899 /*
900  * Register : External Port A Register - gpio_ext_porta
901  *
902  * The external port register is used to input data to the metastability flops.
903  *
904  * Register Layout
905  *
906  * Bits | Access | Reset | Description
907  * :--------|:-------|:------|:--------------------
908  * [28:0] | R | 0x0 | External Port Field
909  * [31:29] | ??? | 0x0 | *UNDEFINED*
910  *
911  */
912 /*
913  * Field : External Port Field - gpio_ext_porta
914  *
915  * When Port A Data Register is configured as Input, then reading this location
916  * reads the values on the signals. When the data direction of Port A Data Register
917  * is set as Output, reading this location reads Port A Data Register
918  *
919  * Field Access Macros:
920  *
921  */
922 /* The Least Significant Bit (LSB) position of the ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA register field. */
923 #define ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_LSB 0
924 /* The Most Significant Bit (MSB) position of the ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA register field. */
925 #define ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_MSB 28
926 /* The width in bits of the ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA register field. */
927 #define ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_WIDTH 29
928 /* The mask used to set the ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA register field value. */
929 #define ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_SET_MSK 0x1fffffff
930 /* The mask used to clear the ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA register field value. */
931 #define ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_CLR_MSK 0xe0000000
932 /* The reset value of the ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA register field. */
933 #define ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_RESET 0x0
934 /* Extracts the ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA field value from a register. */
935 #define ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_GET(value) (((value) & 0x1fffffff) >> 0)
936 /* Produces a ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA register field value suitable for setting the register. */
937 #define ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_SET(value) (((value) << 0) & 0x1fffffff)
938
939 #ifndef __ASSEMBLY__
940 /*
941  * WARNING: The C register and register group struct declarations are provided for
942  * convenience and illustrative purposes. They should, however, be used with
943  * caution as the C language standard provides no guarantees about the alignment or
944  * atomicity of device memory accesses. The recommended practice for writing
945  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
946  * alt_write_word() functions.
947  *
948  * The struct declaration for register ALT_GPIO_EXT_PORTA.
949  */
951 {
952  const uint32_t gpio_ext_porta : 29; /* External Port Field */
953  uint32_t : 3; /* *UNDEFINED* */
954 };
955
956 /* The typedef declaration for register ALT_GPIO_EXT_PORTA. */
957 typedef volatile struct ALT_GPIO_EXT_PORTA_s ALT_GPIO_EXT_PORTA_t;
958 #endif /* __ASSEMBLY__ */
959
960 /* The byte offset of the ALT_GPIO_EXT_PORTA register from the beginning of the component. */
961 #define ALT_GPIO_EXT_PORTA_OFST 0x50
962 /* The address of the ALT_GPIO_EXT_PORTA register. */
963 #define ALT_GPIO_EXT_PORTA_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_EXT_PORTA_OFST))
964
965 /*
966  * Register : Synchronization Level Register - gpio_ls_sync
967  *
968  * The Synchronization level register is used to synchronize input with l4_mp_clk
969  *
970  * Register Layout
971  *
972  * Bits | Access | Reset | Description
973  * :-------|:-------|:------|:----------------------------
974  * [0] | RW | 0x0 | Synchronization Level Field
975  * [31:1] | ??? | 0x0 | *UNDEFINED*
976  *
977  */
978 /*
979  * Field : Synchronization Level Field - gpio_ls_sync
980  *
981  * The level-sensitive interrupts is synchronized to l4_mp_clk.
982  *
983  * Field Enumeration Values:
984  *
985  * Enum | Value | Description
986  * :---------------------------------------|:------|:--------------------------------
987  * ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_E_NOSYNC | 0x0 | No synchronization to l4_mp_clk
988  * ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_E_SYNC | 0x1 | Synchronize to l4_mp_clk
989  *
990  * Field Access Macros:
991  *
992  */
993 /*
994  * Enumerated value for register field ALT_GPIO_LS_SYNC_GPIO_LS_SYNC
995  *
996  * No synchronization to l4_mp_clk
997  */
998 #define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_E_NOSYNC 0x0
999 /*
1000  * Enumerated value for register field ALT_GPIO_LS_SYNC_GPIO_LS_SYNC
1001  *
1002  * Synchronize to l4_mp_clk
1003  */
1004 #define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_E_SYNC 0x1
1005
1006 /* The Least Significant Bit (LSB) position of the ALT_GPIO_LS_SYNC_GPIO_LS_SYNC register field. */
1007 #define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_LSB 0
1008 /* The Most Significant Bit (MSB) position of the ALT_GPIO_LS_SYNC_GPIO_LS_SYNC register field. */
1009 #define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_MSB 0
1010 /* The width in bits of the ALT_GPIO_LS_SYNC_GPIO_LS_SYNC register field. */
1011 #define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_WIDTH 1
1012 /* The mask used to set the ALT_GPIO_LS_SYNC_GPIO_LS_SYNC register field value. */
1013 #define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_SET_MSK 0x00000001
1014 /* The mask used to clear the ALT_GPIO_LS_SYNC_GPIO_LS_SYNC register field value. */
1015 #define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_CLR_MSK 0xfffffffe
1016 /* The reset value of the ALT_GPIO_LS_SYNC_GPIO_LS_SYNC register field. */
1017 #define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_RESET 0x0
1018 /* Extracts the ALT_GPIO_LS_SYNC_GPIO_LS_SYNC field value from a register. */
1019 #define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_GET(value) (((value) & 0x00000001) >> 0)
1020 /* Produces a ALT_GPIO_LS_SYNC_GPIO_LS_SYNC register field value suitable for setting the register. */
1021 #define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_SET(value) (((value) << 0) & 0x00000001)
1022
1023 #ifndef __ASSEMBLY__
1024 /*
1025  * WARNING: The C register and register group struct declarations are provided for
1026  * convenience and illustrative purposes. They should, however, be used with
1027  * caution as the C language standard provides no guarantees about the alignment or
1028  * atomicity of device memory accesses. The recommended practice for writing
1029  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1030  * alt_write_word() functions.
1031  *
1032  * The struct declaration for register ALT_GPIO_LS_SYNC.
1033  */
1035 {
1036  uint32_t gpio_ls_sync : 1; /* Synchronization Level Field */
1037  uint32_t : 31; /* *UNDEFINED* */
1038 };
1039
1040 /* The typedef declaration for register ALT_GPIO_LS_SYNC. */
1041 typedef volatile struct ALT_GPIO_LS_SYNC_s ALT_GPIO_LS_SYNC_t;
1042 #endif /* __ASSEMBLY__ */
1043
1044 /* The byte offset of the ALT_GPIO_LS_SYNC register from the beginning of the component. */
1045 #define ALT_GPIO_LS_SYNC_OFST 0x60
1046 /* The address of the ALT_GPIO_LS_SYNC register. */
1047 #define ALT_GPIO_LS_SYNC_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_LS_SYNC_OFST))
1048
1049 /*
1050  * Register : ID Code Register - gpio_id_code
1051  *
1052  * GPIO ID code.
1053  *
1054  * Register Layout
1055  *
1056  * Bits | Access | Reset | Description
1057  * :-------|:-------|:------|:--------------
1058  * [31:0] | R | 0x0 | ID Code Field
1059  *
1060  */
1061 /*
1062  * Field : ID Code Field - gpio_id_code
1063  *
1064  * Chip identification
1065  *
1066  * Field Access Macros:
1067  *
1068  */
1069 /* The Least Significant Bit (LSB) position of the ALT_GPIO_ID_CODE_GPIO_ID_CODE register field. */
1070 #define ALT_GPIO_ID_CODE_GPIO_ID_CODE_LSB 0
1071 /* The Most Significant Bit (MSB) position of the ALT_GPIO_ID_CODE_GPIO_ID_CODE register field. */
1072 #define ALT_GPIO_ID_CODE_GPIO_ID_CODE_MSB 31
1073 /* The width in bits of the ALT_GPIO_ID_CODE_GPIO_ID_CODE register field. */
1074 #define ALT_GPIO_ID_CODE_GPIO_ID_CODE_WIDTH 32
1075 /* The mask used to set the ALT_GPIO_ID_CODE_GPIO_ID_CODE register field value. */
1076 #define ALT_GPIO_ID_CODE_GPIO_ID_CODE_SET_MSK 0xffffffff
1077 /* The mask used to clear the ALT_GPIO_ID_CODE_GPIO_ID_CODE register field value. */
1078 #define ALT_GPIO_ID_CODE_GPIO_ID_CODE_CLR_MSK 0x00000000
1079 /* The reset value of the ALT_GPIO_ID_CODE_GPIO_ID_CODE register field. */
1080 #define ALT_GPIO_ID_CODE_GPIO_ID_CODE_RESET 0x0
1081 /* Extracts the ALT_GPIO_ID_CODE_GPIO_ID_CODE field value from a register. */
1082 #define ALT_GPIO_ID_CODE_GPIO_ID_CODE_GET(value) (((value) & 0xffffffff) >> 0)
1083 /* Produces a ALT_GPIO_ID_CODE_GPIO_ID_CODE register field value suitable for setting the register. */
1084 #define ALT_GPIO_ID_CODE_GPIO_ID_CODE_SET(value) (((value) << 0) & 0xffffffff)
1085
1086 #ifndef __ASSEMBLY__
1087 /*
1088  * WARNING: The C register and register group struct declarations are provided for
1089  * convenience and illustrative purposes. They should, however, be used with
1090  * caution as the C language standard provides no guarantees about the alignment or
1091  * atomicity of device memory accesses. The recommended practice for writing
1092  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1093  * alt_write_word() functions.
1094  *
1095  * The struct declaration for register ALT_GPIO_ID_CODE.
1096  */
1098 {
1099  const uint32_t gpio_id_code : 32; /* ID Code Field */
1100 };
1101
1102 /* The typedef declaration for register ALT_GPIO_ID_CODE. */
1103 typedef volatile struct ALT_GPIO_ID_CODE_s ALT_GPIO_ID_CODE_t;
1104 #endif /* __ASSEMBLY__ */
1105
1106 /* The byte offset of the ALT_GPIO_ID_CODE register from the beginning of the component. */
1107 #define ALT_GPIO_ID_CODE_OFST 0x64
1108 /* The address of the ALT_GPIO_ID_CODE register. */
1109 #define ALT_GPIO_ID_CODE_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_ID_CODE_OFST))
1110
1111 /*
1112  * Register : GPIO Version Register - gpio_ver_id_code
1113  *
1114  * GPIO Component Version
1115  *
1116  * Register Layout
1117  *
1118  * Bits | Access | Reset | Description
1119  * :-------|:-------|:-----------|:------------------------------
1120  * [31:0] | R | 0x3230382a | ASCII Component Version Field
1121  *
1122  */
1123 /*
1124  * Field : ASCII Component Version Field - gpio_ver_id_code
1125  *
1126  * ASCII value for each number in the version, followed by *. For example.
1127  * 32_30_31_2A represents the version 2.01
1128  *
1129  * Field Access Macros:
1130  *
1131  */
1132 /* The Least Significant Bit (LSB) position of the ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE register field. */
1133 #define ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_LSB 0
1134 /* The Most Significant Bit (MSB) position of the ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE register field. */
1135 #define ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_MSB 31
1136 /* The width in bits of the ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE register field. */
1137 #define ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_WIDTH 32
1138 /* The mask used to set the ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE register field value. */
1139 #define ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_SET_MSK 0xffffffff
1140 /* The mask used to clear the ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE register field value. */
1141 #define ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_CLR_MSK 0x00000000
1142 /* The reset value of the ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE register field. */
1143 #define ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_RESET 0x3230382a
1144 /* Extracts the ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE field value from a register. */
1145 #define ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_GET(value) (((value) & 0xffffffff) >> 0)
1146 /* Produces a ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE register field value suitable for setting the register. */
1147 #define ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_SET(value) (((value) << 0) & 0xffffffff)
1148
1149 #ifndef __ASSEMBLY__
1150 /*
1151  * WARNING: The C register and register group struct declarations are provided for
1152  * convenience and illustrative purposes. They should, however, be used with
1153  * caution as the C language standard provides no guarantees about the alignment or
1154  * atomicity of device memory accesses. The recommended practice for writing
1155  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1156  * alt_write_word() functions.
1157  *
1158  * The struct declaration for register ALT_GPIO_VER_ID_CODE.
1159  */
1161 {
1162  const uint32_t gpio_ver_id_code : 32; /* ASCII Component Version Field */
1163 };
1164
1165 /* The typedef declaration for register ALT_GPIO_VER_ID_CODE. */
1166 typedef volatile struct ALT_GPIO_VER_ID_CODE_s ALT_GPIO_VER_ID_CODE_t;
1167 #endif /* __ASSEMBLY__ */
1168
1169 /* The byte offset of the ALT_GPIO_VER_ID_CODE register from the beginning of the component. */
1170 #define ALT_GPIO_VER_ID_CODE_OFST 0x6c
1171 /* The address of the ALT_GPIO_VER_ID_CODE register. */
1172 #define ALT_GPIO_VER_ID_CODE_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_VER_ID_CODE_OFST))
1173
1174 /*
1175  * Register : Configuration Register 2 - gpio_config_reg2
1176  *
1177  * Specifies the bit width of port A.
1178  *
1179  * Register Layout
1180  *
1181  * Bits | Access | Reset | Description
1182  * :--------|:-------|:------|:----------------------
1183  * [4:0] | R | 0x1c | Port A Width (less 1)
1184  * [9:5] | R | 0x7 | Port B Width (less 1)
1185  * [14:10] | R | 0x7 | Port C Width (less 1)
1186  * [19:15] | R | 0x7 | Port D Width (less 1)
1187  * [31:20] | ??? | 0x0 | *UNDEFINED*
1188  *
1189  */
1190 /*
1191  * Field : Port A Width (less 1) - encoded_id_pwidth_a
1192  *
1193  * Specifies the width of GPIO Port A. The value 28 represents the 29-bit width
1194  * less one.
1195  *
1196  * Field Enumeration Values:
1197  *
1198  * Enum | Value | Description
1199  * :-------------------------------------------------------|:------|:--------------------------
1200  * ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_E_WIDTHLESSONE8BITS | 0x7 | Width (less 1) of 8 bits
1201  * ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_E_WIDTHLESSONE29BITS | 0x1c | Width (less 1) of 29 bits
1202  *
1203  * Field Access Macros:
1204  *
1205  */
1206 /*
1207  * Enumerated value for register field ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A
1208  *
1209  * Width (less 1) of 8 bits
1210  */
1211 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_E_WIDTHLESSONE8BITS 0x7
1212 /*
1213  * Enumerated value for register field ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A
1214  *
1215  * Width (less 1) of 29 bits
1216  */
1217 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_E_WIDTHLESSONE29BITS 0x1c
1218
1219 /* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A register field. */
1220 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_LSB 0
1221 /* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A register field. */
1222 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_MSB 4
1223 /* The width in bits of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A register field. */
1224 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_WIDTH 5
1225 /* The mask used to set the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A register field value. */
1226 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_SET_MSK 0x0000001f
1227 /* The mask used to clear the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A register field value. */
1228 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_CLR_MSK 0xffffffe0
1229 /* The reset value of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A register field. */
1230 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_RESET 0x1c
1231 /* Extracts the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A field value from a register. */
1232 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_GET(value) (((value) & 0x0000001f) >> 0)
1233 /* Produces a ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A register field value suitable for setting the register. */
1234 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_SET(value) (((value) << 0) & 0x0000001f)
1235
1236 /*
1237  * Field : Port B Width (less 1) - encoded_id_pwidth_b
1238  *
1239  * Specifies the width of GPIO Port B. Ignored because there is no Port B in the
1240  * GPIO.
1241  *
1242  * Field Enumeration Values:
1243  *
1244  * Enum | Value | Description
1245  * :-------------------------------------------------------|:------|:--------------------------
1246  * ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_E_WIDTHLESSONE8BITS | 0x7 | Width (less 1) of 8 bits
1247  * ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_E_WIDTHLESSONE29BITS | 0x1c | Width (less 1) of 29 bits
1248  *
1249  * Field Access Macros:
1250  *
1251  */
1252 /*
1253  * Enumerated value for register field ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B
1254  *
1255  * Width (less 1) of 8 bits
1256  */
1257 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_E_WIDTHLESSONE8BITS 0x7
1258 /*
1259  * Enumerated value for register field ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B
1260  *
1261  * Width (less 1) of 29 bits
1262  */
1263 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_E_WIDTHLESSONE29BITS 0x1c
1264
1265 /* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B register field. */
1266 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_LSB 5
1267 /* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B register field. */
1268 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_MSB 9
1269 /* The width in bits of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B register field. */
1270 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_WIDTH 5
1271 /* The mask used to set the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B register field value. */
1272 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_SET_MSK 0x000003e0
1273 /* The mask used to clear the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B register field value. */
1274 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_CLR_MSK 0xfffffc1f
1275 /* The reset value of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B register field. */
1276 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_RESET 0x7
1277 /* Extracts the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B field value from a register. */
1278 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_GET(value) (((value) & 0x000003e0) >> 5)
1279 /* Produces a ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B register field value suitable for setting the register. */
1280 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_SET(value) (((value) << 5) & 0x000003e0)
1281
1282 /*
1283  * Field : Port C Width (less 1) - encoded_id_pwidth_c
1284  *
1285  * Specifies the width of GPIO Port C. Ignored because there is no Port C in the
1286  * GPIO.
1287  *
1288  * Field Enumeration Values:
1289  *
1290  * Enum | Value | Description
1291  * :-------------------------------------------------------|:------|:--------------------------
1292  * ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_E_WIDTHLESSONE8BITS | 0x7 | Width (less 1) of 8 bits
1293  * ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_E_WIDTHLESSONE29BITS | 0x1c | Width (less 1) of 29 bits
1294  *
1295  * Field Access Macros:
1296  *
1297  */
1298 /*
1299  * Enumerated value for register field ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C
1300  *
1301  * Width (less 1) of 8 bits
1302  */
1303 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_E_WIDTHLESSONE8BITS 0x7
1304 /*
1305  * Enumerated value for register field ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C
1306  *
1307  * Width (less 1) of 29 bits
1308  */
1309 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_E_WIDTHLESSONE29BITS 0x1c
1310
1311 /* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C register field. */
1312 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_LSB 10
1313 /* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C register field. */
1314 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_MSB 14
1315 /* The width in bits of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C register field. */
1316 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_WIDTH 5
1317 /* The mask used to set the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C register field value. */
1318 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_SET_MSK 0x00007c00
1319 /* The mask used to clear the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C register field value. */
1320 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_CLR_MSK 0xffff83ff
1321 /* The reset value of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C register field. */
1322 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_RESET 0x7
1323 /* Extracts the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C field value from a register. */
1324 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_GET(value) (((value) & 0x00007c00) >> 10)
1325 /* Produces a ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C register field value suitable for setting the register. */
1326 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_SET(value) (((value) << 10) & 0x00007c00)
1327
1328 /*
1329  * Field : Port D Width (less 1) - encoded_id_pwidth_d
1330  *
1331  * Specifies the width of GPIO Port D. Ignored because there is no Port D in the
1332  * GPIO.
1333  *
1334  * Field Enumeration Values:
1335  *
1336  * Enum | Value | Description
1337  * :-------------------------------------------------------|:------|:--------------------------
1338  * ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_E_WIDTHLESSONE8BITS | 0x7 | Width (less 1) of 8 bits
1339  * ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_E_WIDTHLESSONE29BITS | 0x1c | Width (less 1) of 29 bits
1340  *
1341  * Field Access Macros:
1342  *
1343  */
1344 /*
1345  * Enumerated value for register field ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D
1346  *
1347  * Width (less 1) of 8 bits
1348  */
1349 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_E_WIDTHLESSONE8BITS 0x7
1350 /*
1351  * Enumerated value for register field ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D
1352  *
1353  * Width (less 1) of 29 bits
1354  */
1355 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_E_WIDTHLESSONE29BITS 0x1c
1356
1357 /* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D register field. */
1358 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_LSB 15
1359 /* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D register field. */
1360 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_MSB 19
1361 /* The width in bits of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D register field. */
1362 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_WIDTH 5
1363 /* The mask used to set the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D register field value. */
1364 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_SET_MSK 0x000f8000
1365 /* The mask used to clear the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D register field value. */
1366 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_CLR_MSK 0xfff07fff
1367 /* The reset value of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D register field. */
1368 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_RESET 0x7
1369 /* Extracts the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D field value from a register. */
1370 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_GET(value) (((value) & 0x000f8000) >> 15)
1371 /* Produces a ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D register field value suitable for setting the register. */
1372 #define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_SET(value) (((value) << 15) & 0x000f8000)
1373
1374 #ifndef __ASSEMBLY__
1375 /*
1376  * WARNING: The C register and register group struct declarations are provided for
1377  * convenience and illustrative purposes. They should, however, be used with
1378  * caution as the C language standard provides no guarantees about the alignment or
1379  * atomicity of device memory accesses. The recommended practice for writing
1380  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1381  * alt_write_word() functions.
1382  *
1383  * The struct declaration for register ALT_GPIO_CFG_REG2.
1384  */
1386 {
1387  const uint32_t encoded_id_pwidth_a : 5; /* Port A Width (less 1) */
1388  const uint32_t encoded_id_pwidth_b : 5; /* Port B Width (less 1) */
1389  const uint32_t encoded_id_pwidth_c : 5; /* Port C Width (less 1) */
1390  const uint32_t encoded_id_pwidth_d : 5; /* Port D Width (less 1) */
1391  uint32_t : 12; /* *UNDEFINED* */
1392 };
1393
1394 /* The typedef declaration for register ALT_GPIO_CFG_REG2. */
1395 typedef volatile struct ALT_GPIO_CFG_REG2_s ALT_GPIO_CFG_REG2_t;
1396 #endif /* __ASSEMBLY__ */
1397
1398 /* The byte offset of the ALT_GPIO_CFG_REG2 register from the beginning of the component. */
1399 #define ALT_GPIO_CFG_REG2_OFST 0x70
1400 /* The address of the ALT_GPIO_CFG_REG2 register. */
1401 #define ALT_GPIO_CFG_REG2_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_CFG_REG2_OFST))
1402
1403 /*
1404  * Register : Configuration Register 1 - gpio_config_reg1
1405  *
1406  * Reports settings of various GPIO configuration parameters
1407  *
1408  * Register Layout
1409  *
1410  * Bits | Access | Reset | Description
1411  * :--------|:-------|:------|:----------------------------------
1412  * [1:0] | R | 0x2 | APB DATA WIDTH
1413  * [3:2] | R | 0x0 | NUM PORTS
1414  * [4] | R | 0x1 | PORT A SINGLE CTL
1415  * [5] | R | 0x1 | PORT B SINGLE CTL
1416  * [6] | R | 0x1 | PORT C SINGLE CTL
1417  * [7] | R | 0x1 | PORT D SINGLE CTL
1418  * [8] | R | 0x0 | HW PORTA
1419  * [11:9] | ??? | 0x0 | *UNDEFINED*
1420  * [12] | R | 0x1 | Port A Interrupt Field
1421  * [13] | R | 0x1 | Debounce Field
1422  * [14] | R | 0x1 | Encoded GPIO Parameters Available
1423  * [15] | R | 0x1 | ID Field
1424  * [20:16] | R | 0x1f | Encoded ID Width Field
1425  * [31:21] | ??? | 0x0 | *UNDEFINED*
1426  *
1427  */
1428 /*
1429  * Field : APB DATA WIDTH - apb_data_width
1430  *
1431  * Fixed to support an ABP data bus width of 32-bits.
1432  *
1433  * Field Enumeration Values:
1434  *
1435  * Enum | Value | Description
1436  * :-----------------------------------------------|:------|:-------------------------
1437  * ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_E_WIDTH32BITS | 0x2 | APB Data Width = 32-bits
1438  *
1439  * Field Access Macros:
1440  *
1441  */
1442 /*
1443  * Enumerated value for register field ALT_GPIO_CFG_REG1_APB_DATA_WIDTH
1444  *
1445  * APB Data Width = 32-bits
1446  */
1447 #define ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_E_WIDTH32BITS 0x2
1448
1449 /* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_APB_DATA_WIDTH register field. */
1450 #define ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_LSB 0
1451 /* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_APB_DATA_WIDTH register field. */
1452 #define ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_MSB 1
1453 /* The width in bits of the ALT_GPIO_CFG_REG1_APB_DATA_WIDTH register field. */
1454 #define ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_WIDTH 2
1455 /* The mask used to set the ALT_GPIO_CFG_REG1_APB_DATA_WIDTH register field value. */
1456 #define ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_SET_MSK 0x00000003
1457 /* The mask used to clear the ALT_GPIO_CFG_REG1_APB_DATA_WIDTH register field value. */
1458 #define ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_CLR_MSK 0xfffffffc
1459 /* The reset value of the ALT_GPIO_CFG_REG1_APB_DATA_WIDTH register field. */
1460 #define ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_RESET 0x2
1461 /* Extracts the ALT_GPIO_CFG_REG1_APB_DATA_WIDTH field value from a register. */
1462 #define ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_GET(value) (((value) & 0x00000003) >> 0)
1463 /* Produces a ALT_GPIO_CFG_REG1_APB_DATA_WIDTH register field value suitable for setting the register. */
1464 #define ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_SET(value) (((value) << 0) & 0x00000003)
1465
1466 /*
1467  * Field : NUM PORTS - num_ports
1468  *
1469  * The value of this register is fixed at one port (Port A).
1470  *
1471  * Field Enumeration Values:
1472  *
1473  * Enum | Value | Description
1474  * :---------------------------------------|:------|:-------------------------
1475  * ALT_GPIO_CFG_REG1_NUM_PORTS_E_ONEPORTA | 0x0 | Number of GPIO Ports = 1
1476  *
1477  * Field Access Macros:
1478  *
1479  */
1480 /*
1481  * Enumerated value for register field ALT_GPIO_CFG_REG1_NUM_PORTS
1482  *
1483  * Number of GPIO Ports = 1
1484  */
1485 #define ALT_GPIO_CFG_REG1_NUM_PORTS_E_ONEPORTA 0x0
1486
1487 /* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_NUM_PORTS register field. */
1488 #define ALT_GPIO_CFG_REG1_NUM_PORTS_LSB 2
1489 /* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_NUM_PORTS register field. */
1490 #define ALT_GPIO_CFG_REG1_NUM_PORTS_MSB 3
1491 /* The width in bits of the ALT_GPIO_CFG_REG1_NUM_PORTS register field. */
1492 #define ALT_GPIO_CFG_REG1_NUM_PORTS_WIDTH 2
1493 /* The mask used to set the ALT_GPIO_CFG_REG1_NUM_PORTS register field value. */
1494 #define ALT_GPIO_CFG_REG1_NUM_PORTS_SET_MSK 0x0000000c
1495 /* The mask used to clear the ALT_GPIO_CFG_REG1_NUM_PORTS register field value. */
1496 #define ALT_GPIO_CFG_REG1_NUM_PORTS_CLR_MSK 0xfffffff3
1497 /* The reset value of the ALT_GPIO_CFG_REG1_NUM_PORTS register field. */
1498 #define ALT_GPIO_CFG_REG1_NUM_PORTS_RESET 0x0
1499 /* Extracts the ALT_GPIO_CFG_REG1_NUM_PORTS field value from a register. */
1500 #define ALT_GPIO_CFG_REG1_NUM_PORTS_GET(value) (((value) & 0x0000000c) >> 2)
1501 /* Produces a ALT_GPIO_CFG_REG1_NUM_PORTS register field value suitable for setting the register. */
1502 #define ALT_GPIO_CFG_REG1_NUM_PORTS_SET(value) (((value) << 2) & 0x0000000c)
1503
1504 /*
1505  * Field : PORT A SINGLE CTL - porta_single_ctl
1506  *
1507  * Indicates the mode of operation of Port A to be software controlled only.
1508  *
1509  * Field Enumeration Values:
1510  *
1511  * Enum | Value | Description
1512  * :-------------------------------------------------|:------|:-----------------------------------------
1513  * ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_E_SOFTCTLONLY | 0x1 | Software Enabled Individual Port Control
1514  *
1515  * Field Access Macros:
1516  *
1517  */
1518 /*
1519  * Enumerated value for register field ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL
1520  *
1521  * Software Enabled Individual Port Control
1522  */
1523 #define ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_E_SOFTCTLONLY 0x1
1524
1525 /* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL register field. */
1526 #define ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_LSB 4
1527 /* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL register field. */
1528 #define ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_MSB 4
1529 /* The width in bits of the ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL register field. */
1530 #define ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_WIDTH 1
1531 /* The mask used to set the ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL register field value. */
1532 #define ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_SET_MSK 0x00000010
1533 /* The mask used to clear the ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL register field value. */
1534 #define ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_CLR_MSK 0xffffffef
1535 /* The reset value of the ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL register field. */
1536 #define ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_RESET 0x1
1537 /* Extracts the ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL field value from a register. */
1538 #define ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_GET(value) (((value) & 0x00000010) >> 4)
1539 /* Produces a ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL register field value suitable for setting the register. */
1540 #define ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_SET(value) (((value) << 4) & 0x00000010)
1541
1542 /*
1543  * Field : PORT B SINGLE CTL - portb_single_ctl
1544  *
1545  * Indicates the mode of operation of Port B to be software controlled only.
1546  * Ignored because there is no Port B in the GPIO.
1547  *
1548  * Field Enumeration Values:
1549  *
1550  * Enum | Value | Description
1551  * :-------------------------------------------------|:------|:-----------------------------------------
1552  * ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_E_SOFTCTLONLY | 0x1 | Software Enabled Individual Port Control
1553  *
1554  * Field Access Macros:
1555  *
1556  */
1557 /*
1558  * Enumerated value for register field ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL
1559  *
1560  * Software Enabled Individual Port Control
1561  */
1562 #define ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_E_SOFTCTLONLY 0x1
1563
1564 /* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL register field. */
1565 #define ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_LSB 5
1566 /* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL register field. */
1567 #define ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_MSB 5
1568 /* The width in bits of the ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL register field. */
1569 #define ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_WIDTH 1
1570 /* The mask used to set the ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL register field value. */
1571 #define ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_SET_MSK 0x00000020
1572 /* The mask used to clear the ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL register field value. */
1573 #define ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_CLR_MSK 0xffffffdf
1574 /* The reset value of the ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL register field. */
1575 #define ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_RESET 0x1
1576 /* Extracts the ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL field value from a register. */
1577 #define ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_GET(value) (((value) & 0x00000020) >> 5)
1578 /* Produces a ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL register field value suitable for setting the register. */
1579 #define ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_SET(value) (((value) << 5) & 0x00000020)
1580
1581 /*
1582  * Field : PORT C SINGLE CTL - portc_single_ctl
1583  *
1584  * Indicates the mode of operation of Port C to be software controlled only.
1585  * Ignored because there is no Port C in the GPIO.
1586  *
1587  * Field Enumeration Values:
1588  *
1589  * Enum | Value | Description
1590  * :-------------------------------------------------|:------|:-----------------------------------------
1591  * ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_E_SOFTCTLONLY | 0x1 | Software Enabled Individual Port Control
1592  *
1593  * Field Access Macros:
1594  *
1595  */
1596 /*
1597  * Enumerated value for register field ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL
1598  *
1599  * Software Enabled Individual Port Control
1600  */
1601 #define ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_E_SOFTCTLONLY 0x1
1602
1603 /* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL register field. */
1604 #define ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_LSB 6
1605 /* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL register field. */
1606 #define ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_MSB 6
1607 /* The width in bits of the ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL register field. */
1608 #define ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_WIDTH 1
1609 /* The mask used to set the ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL register field value. */
1610 #define ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_SET_MSK 0x00000040
1611 /* The mask used to clear the ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL register field value. */
1612 #define ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_CLR_MSK 0xffffffbf
1613 /* The reset value of the ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL register field. */
1614 #define ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_RESET 0x1
1615 /* Extracts the ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL field value from a register. */
1616 #define ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_GET(value) (((value) & 0x00000040) >> 6)
1617 /* Produces a ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL register field value suitable for setting the register. */
1618 #define ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_SET(value) (((value) << 6) & 0x00000040)
1619
1620 /*
1621  * Field : PORT D SINGLE CTL - portd_single_ctl
1622  *
1623  * Indicates the mode of operation of Port D to be software controlled only.
1624  * Ignored because there is no Port D in the GPIO.
1625  *
1626  * Field Enumeration Values:
1627  *
1628  * Enum | Value | Description
1629  * :-------------------------------------------------|:------|:-----------------------------------------
1630  * ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_E_SOFTCTLONLY | 0x1 | Software Enabled Individual Port Control
1631  *
1632  * Field Access Macros:
1633  *
1634  */
1635 /*
1636  * Enumerated value for register field ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL
1637  *
1638  * Software Enabled Individual Port Control
1639  */
1640 #define ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_E_SOFTCTLONLY 0x1
1641
1642 /* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL register field. */
1643 #define ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_LSB 7
1644 /* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL register field. */
1645 #define ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_MSB 7
1646 /* The width in bits of the ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL register field. */
1647 #define ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_WIDTH 1
1648 /* The mask used to set the ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL register field value. */
1649 #define ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_SET_MSK 0x00000080
1650 /* The mask used to clear the ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL register field value. */
1651 #define ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_CLR_MSK 0xffffff7f
1652 /* The reset value of the ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL register field. */
1653 #define ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_RESET 0x1
1654 /* Extracts the ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL field value from a register. */
1655 #define ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_GET(value) (((value) & 0x00000080) >> 7)
1656 /* Produces a ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL register field value suitable for setting the register. */
1657 #define ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_SET(value) (((value) << 7) & 0x00000080)
1658
1659 /*
1660  * Field : HW PORTA - hw_porta
1661  *
1662  * The value is fixed to enable Port A configuration to be controlled by software
1663  * only.
1664  *
1665  * Field Enumeration Values:
1666  *
1667  * Enum | Value | Description
1668  * :-----------------------------------------|:------|:---------------------------------------
1669  * ALT_GPIO_CFG_REG1_HW_PORTA_E_PORTANOHARD | 0x0 | Software Configuration Control Enabled
1670  *
1671  * Field Access Macros:
1672  *
1673  */
1674 /*
1675  * Enumerated value for register field ALT_GPIO_CFG_REG1_HW_PORTA
1676  *
1677  * Software Configuration Control Enabled
1678  */
1679 #define ALT_GPIO_CFG_REG1_HW_PORTA_E_PORTANOHARD 0x0
1680
1681 /* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_HW_PORTA register field. */
1682 #define ALT_GPIO_CFG_REG1_HW_PORTA_LSB 8
1683 /* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_HW_PORTA register field. */
1684 #define ALT_GPIO_CFG_REG1_HW_PORTA_MSB 8
1685 /* The width in bits of the ALT_GPIO_CFG_REG1_HW_PORTA register field. */
1686 #define ALT_GPIO_CFG_REG1_HW_PORTA_WIDTH 1
1687 /* The mask used to set the ALT_GPIO_CFG_REG1_HW_PORTA register field value. */
1688 #define ALT_GPIO_CFG_REG1_HW_PORTA_SET_MSK 0x00000100
1689 /* The mask used to clear the ALT_GPIO_CFG_REG1_HW_PORTA register field value. */
1690 #define ALT_GPIO_CFG_REG1_HW_PORTA_CLR_MSK 0xfffffeff
1691 /* The reset value of the ALT_GPIO_CFG_REG1_HW_PORTA register field. */
1692 #define ALT_GPIO_CFG_REG1_HW_PORTA_RESET 0x0
1693 /* Extracts the ALT_GPIO_CFG_REG1_HW_PORTA field value from a register. */
1694 #define ALT_GPIO_CFG_REG1_HW_PORTA_GET(value) (((value) & 0x00000100) >> 8)
1695 /* Produces a ALT_GPIO_CFG_REG1_HW_PORTA register field value suitable for setting the register. */
1696 #define ALT_GPIO_CFG_REG1_HW_PORTA_SET(value) (((value) << 8) & 0x00000100)
1697
1698 /*
1699  * Field : Port A Interrupt Field - porta_intr
1700  *
1701  * The value of this field is fixed to allow interrupts on Port A.
1702  *
1703  * Field Enumeration Values:
1704  *
1705  * Enum | Value | Description
1706  * :-------------------------------------------|:------|:--------------------------
1707  * ALT_GPIO_CFG_REG1_PORTA_INTR_E_PORTAINTERR | 0x1 | Port A Interrupts Enabled
1708  *
1709  * Field Access Macros:
1710  *
1711  */
1712 /*
1713  * Enumerated value for register field ALT_GPIO_CFG_REG1_PORTA_INTR
1714  *
1715  * Port A Interrupts Enabled
1716  */
1717 #define ALT_GPIO_CFG_REG1_PORTA_INTR_E_PORTAINTERR 0x1
1718
1719 /* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_PORTA_INTR register field. */
1720 #define ALT_GPIO_CFG_REG1_PORTA_INTR_LSB 12
1721 /* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_PORTA_INTR register field. */
1722 #define ALT_GPIO_CFG_REG1_PORTA_INTR_MSB 12
1723 /* The width in bits of the ALT_GPIO_CFG_REG1_PORTA_INTR register field. */
1724 #define ALT_GPIO_CFG_REG1_PORTA_INTR_WIDTH 1
1725 /* The mask used to set the ALT_GPIO_CFG_REG1_PORTA_INTR register field value. */
1726 #define ALT_GPIO_CFG_REG1_PORTA_INTR_SET_MSK 0x00001000
1727 /* The mask used to clear the ALT_GPIO_CFG_REG1_PORTA_INTR register field value. */
1728 #define ALT_GPIO_CFG_REG1_PORTA_INTR_CLR_MSK 0xffffefff
1729 /* The reset value of the ALT_GPIO_CFG_REG1_PORTA_INTR register field. */
1730 #define ALT_GPIO_CFG_REG1_PORTA_INTR_RESET 0x1
1731 /* Extracts the ALT_GPIO_CFG_REG1_PORTA_INTR field value from a register. */
1732 #define ALT_GPIO_CFG_REG1_PORTA_INTR_GET(value) (((value) & 0x00001000) >> 12)
1733 /* Produces a ALT_GPIO_CFG_REG1_PORTA_INTR register field value suitable for setting the register. */
1734 #define ALT_GPIO_CFG_REG1_PORTA_INTR_SET(value) (((value) << 12) & 0x00001000)
1735
1736 /*
1737  * Field : Debounce Field - debounce
1738  *
1739  * The value of this field is fixed to allow debouncing of the Port A signals.
1740  *
1741  * Field Enumeration Values:
1742  *
1743  * Enum | Value | Description
1744  * :---------------------------------------|:------|:--------------------
1745  * ALT_GPIO_CFG_REG1_DEBOUNCE_E_DEBOUNCEA | 0x1 | Debounce is Enabled
1746  *
1747  * Field Access Macros:
1748  *
1749  */
1750 /*
1751  * Enumerated value for register field ALT_GPIO_CFG_REG1_DEBOUNCE
1752  *
1753  * Debounce is Enabled
1754  */
1755 #define ALT_GPIO_CFG_REG1_DEBOUNCE_E_DEBOUNCEA 0x1
1756
1757 /* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_DEBOUNCE register field. */
1758 #define ALT_GPIO_CFG_REG1_DEBOUNCE_LSB 13
1759 /* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_DEBOUNCE register field. */
1760 #define ALT_GPIO_CFG_REG1_DEBOUNCE_MSB 13
1761 /* The width in bits of the ALT_GPIO_CFG_REG1_DEBOUNCE register field. */
1762 #define ALT_GPIO_CFG_REG1_DEBOUNCE_WIDTH 1
1763 /* The mask used to set the ALT_GPIO_CFG_REG1_DEBOUNCE register field value. */
1764 #define ALT_GPIO_CFG_REG1_DEBOUNCE_SET_MSK 0x00002000
1765 /* The mask used to clear the ALT_GPIO_CFG_REG1_DEBOUNCE register field value. */
1766 #define ALT_GPIO_CFG_REG1_DEBOUNCE_CLR_MSK 0xffffdfff
1767 /* The reset value of the ALT_GPIO_CFG_REG1_DEBOUNCE register field. */
1768 #define ALT_GPIO_CFG_REG1_DEBOUNCE_RESET 0x1
1769 /* Extracts the ALT_GPIO_CFG_REG1_DEBOUNCE field value from a register. */
1770 #define ALT_GPIO_CFG_REG1_DEBOUNCE_GET(value) (((value) & 0x00002000) >> 13)
1771 /* Produces a ALT_GPIO_CFG_REG1_DEBOUNCE register field value suitable for setting the register. */
1772 #define ALT_GPIO_CFG_REG1_DEBOUNCE_SET(value) (((value) << 13) & 0x00002000)
1773
1774 /*
1775  * Field : Encoded GPIO Parameters Available - add_encoded_params
1776  *
1777  * Fixed to allow the indentification of the Designware IP component.
1778  *
1779  * Field Enumeration Values:
1780  *
1781  * Enum | Value | Description
1782  * :------------------------------------------------|:------|:--------------------------
1783  * ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_E_ADDENCPARAMS | 0x1 | Enable IP indentification
1784  *
1785  * Field Access Macros:
1786  *
1787  */
1788 /*
1789  * Enumerated value for register field ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS
1790  *
1791  * Enable IP indentification
1792  */
1793 #define ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_E_ADDENCPARAMS 0x1
1794
1795 /* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS register field. */
1796 #define ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_LSB 14
1797 /* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS register field. */
1798 #define ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_MSB 14
1799 /* The width in bits of the ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS register field. */
1800 #define ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_WIDTH 1
1801 /* The mask used to set the ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS register field value. */
1802 #define ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_SET_MSK 0x00004000
1803 /* The mask used to clear the ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS register field value. */
1804 #define ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_CLR_MSK 0xffffbfff
1805 /* The reset value of the ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS register field. */
1806 #define ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_RESET 0x1
1807 /* Extracts the ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS field value from a register. */
1808 #define ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_GET(value) (((value) & 0x00004000) >> 14)
1809 /* Produces a ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS register field value suitable for setting the register. */
1810 #define ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_SET(value) (((value) << 14) & 0x00004000)
1811
1812 /*
1813  * Field : ID Field - gpio_id
1814  *
1815  * Provides an ID code value
1816  *
1817  * Field Enumeration Values:
1818  *
1819  * Enum | Value | Description
1820  * :-----------------------------------|:------|:-------------
1821  * ALT_GPIO_CFG_REG1_GPIO_ID_E_IDCODE | 0x1 | GPIO ID Code
1822  *
1823  * Field Access Macros:
1824  *
1825  */
1826 /*
1827  * Enumerated value for register field ALT_GPIO_CFG_REG1_GPIO_ID
1828  *
1829  * GPIO ID Code
1830  */
1831 #define ALT_GPIO_CFG_REG1_GPIO_ID_E_IDCODE 0x1
1832
1833 /* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_GPIO_ID register field. */
1834 #define ALT_GPIO_CFG_REG1_GPIO_ID_LSB 15
1835 /* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_GPIO_ID register field. */
1836 #define ALT_GPIO_CFG_REG1_GPIO_ID_MSB 15
1837 /* The width in bits of the ALT_GPIO_CFG_REG1_GPIO_ID register field. */
1838 #define ALT_GPIO_CFG_REG1_GPIO_ID_WIDTH 1
1839 /* The mask used to set the ALT_GPIO_CFG_REG1_GPIO_ID register field value. */
1840 #define ALT_GPIO_CFG_REG1_GPIO_ID_SET_MSK 0x00008000
1841 /* The mask used to clear the ALT_GPIO_CFG_REG1_GPIO_ID register field value. */
1842 #define ALT_GPIO_CFG_REG1_GPIO_ID_CLR_MSK 0xffff7fff
1843 /* The reset value of the ALT_GPIO_CFG_REG1_GPIO_ID register field. */
1844 #define ALT_GPIO_CFG_REG1_GPIO_ID_RESET 0x1
1845 /* Extracts the ALT_GPIO_CFG_REG1_GPIO_ID field value from a register. */
1846 #define ALT_GPIO_CFG_REG1_GPIO_ID_GET(value) (((value) & 0x00008000) >> 15)
1847 /* Produces a ALT_GPIO_CFG_REG1_GPIO_ID register field value suitable for setting the register. */
1848 #define ALT_GPIO_CFG_REG1_GPIO_ID_SET(value) (((value) << 15) & 0x00008000)
1849
1850 /*
1851  * Field : Encoded ID Width Field - encoded_id_width
1852  *
1853  * This value is fixed at 32 bits.
1854  *
1855  * Field Enumeration Values:
1856  *
1857  * Enum | Value | Description
1858  * :--------------------------------------------|:------|:------------------
1859  * ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_E_ENCIDWIDTH | 0x1f | Width of ID Field
1860  *
1861  * Field Access Macros:
1862  *
1863  */
1864 /*
1865  * Enumerated value for register field ALT_GPIO_CFG_REG1_ENC_ID_WIDTH
1866  *
1867  * Width of ID Field
1868  */
1869 #define ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_E_ENCIDWIDTH 0x1f
1870
1871 /* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_ENC_ID_WIDTH register field. */
1872 #define ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_LSB 16
1873 /* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_ENC_ID_WIDTH register field. */
1874 #define ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_MSB 20
1875 /* The width in bits of the ALT_GPIO_CFG_REG1_ENC_ID_WIDTH register field. */
1876 #define ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_WIDTH 5
1877 /* The mask used to set the ALT_GPIO_CFG_REG1_ENC_ID_WIDTH register field value. */
1878 #define ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_SET_MSK 0x001f0000
1879 /* The mask used to clear the ALT_GPIO_CFG_REG1_ENC_ID_WIDTH register field value. */
1880 #define ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_CLR_MSK 0xffe0ffff
1881 /* The reset value of the ALT_GPIO_CFG_REG1_ENC_ID_WIDTH register field. */
1882 #define ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_RESET 0x1f
1883 /* Extracts the ALT_GPIO_CFG_REG1_ENC_ID_WIDTH field value from a register. */
1884 #define ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_GET(value) (((value) & 0x001f0000) >> 16)
1885 /* Produces a ALT_GPIO_CFG_REG1_ENC_ID_WIDTH register field value suitable for setting the register. */
1886 #define ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_SET(value) (((value) << 16) & 0x001f0000)
1887
1888 #ifndef __ASSEMBLY__
1889 /*
1890  * WARNING: The C register and register group struct declarations are provided for
1891  * convenience and illustrative purposes. They should, however, be used with
1892  * caution as the C language standard provides no guarantees about the alignment or
1893  * atomicity of device memory accesses. The recommended practice for writing
1894  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1895  * alt_write_word() functions.
1896  *
1897  * The struct declaration for register ALT_GPIO_CFG_REG1.
1898  */
1900 {
1901  const uint32_t apb_data_width : 2; /* APB DATA WIDTH */
1902  const uint32_t num_ports : 2; /* NUM PORTS */
1903  const uint32_t porta_single_ctl : 1; /* PORT A SINGLE CTL */
1904  const uint32_t portb_single_ctl : 1; /* PORT B SINGLE CTL */
1905  const uint32_t portc_single_ctl : 1; /* PORT C SINGLE CTL */
1906  const uint32_t portd_single_ctl : 1; /* PORT D SINGLE CTL */
1907  const uint32_t hw_porta : 1; /* HW PORTA */
1908  uint32_t : 3; /* *UNDEFINED* */
1909  const uint32_t porta_intr : 1; /* Port A Interrupt Field */
1910  const uint32_t debounce : 1; /* Debounce Field */
1911  const uint32_t add_encoded_params : 1; /* Encoded GPIO Parameters Available */
1912  const uint32_t gpio_id : 1; /* ID Field */
1913  const uint32_t encoded_id_width : 5; /* Encoded ID Width Field */
1914  uint32_t : 11; /* *UNDEFINED* */
1915 };
1916
1917 /* The typedef declaration for register ALT_GPIO_CFG_REG1. */
1918 typedef volatile struct ALT_GPIO_CFG_REG1_s ALT_GPIO_CFG_REG1_t;
1919 #endif /* __ASSEMBLY__ */
1920
1921 /* The byte offset of the ALT_GPIO_CFG_REG1 register from the beginning of the component. */
1922 #define ALT_GPIO_CFG_REG1_OFST 0x74
1923 /* The address of the ALT_GPIO_CFG_REG1 register. */
1924 #define ALT_GPIO_CFG_REG1_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_CFG_REG1_OFST))
1925
1926 #ifndef __ASSEMBLY__
1927 /*
1928  * WARNING: The C register and register group struct declarations are provided for
1929  * convenience and illustrative purposes. They should, however, be used with
1930  * caution as the C language standard provides no guarantees about the alignment or
1931  * atomicity of device memory accesses. The recommended practice for writing
1932  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1933  * alt_write_word() functions.
1934  *
1935  * The struct declaration for register group ALT_GPIO.
1936  */
1938 {
1939  volatile ALT_GPIO_SWPORTA_DR_t gpio_swporta_dr; /* ALT_GPIO_SWPORTA_DR */
1940  volatile ALT_GPIO_SWPORTA_DDR_t gpio_swporta_ddr; /* ALT_GPIO_SWPORTA_DDR */
1941  volatile uint32_t _pad_0x8_0x2f[10]; /* *UNDEFINED* */
1942  volatile ALT_GPIO_INTEN_t gpio_inten; /* ALT_GPIO_INTEN */
1943  volatile ALT_GPIO_INTMSK_t gpio_intmask; /* ALT_GPIO_INTMSK */
1944  volatile ALT_GPIO_INTTYPE_LEVEL_t gpio_inttype_level; /* ALT_GPIO_INTTYPE_LEVEL */
1945  volatile ALT_GPIO_INT_POL_t gpio_int_polarity; /* ALT_GPIO_INT_POL */
1946  volatile ALT_GPIO_INTSTAT_t gpio_intstatus; /* ALT_GPIO_INTSTAT */
1947  volatile ALT_GPIO_RAW_INTSTAT_t gpio_raw_intstatus; /* ALT_GPIO_RAW_INTSTAT */
1948  volatile ALT_GPIO_DEBOUNCE_t gpio_debounce; /* ALT_GPIO_DEBOUNCE */
1949  volatile ALT_GPIO_PORTA_EOI_t gpio_porta_eoi; /* ALT_GPIO_PORTA_EOI */
1950  volatile ALT_GPIO_EXT_PORTA_t gpio_ext_porta; /* ALT_GPIO_EXT_PORTA */
1951  volatile uint32_t _pad_0x54_0x5f[3]; /* *UNDEFINED* */
1952  volatile ALT_GPIO_LS_SYNC_t gpio_ls_sync; /* ALT_GPIO_LS_SYNC */
1953  volatile ALT_GPIO_ID_CODE_t gpio_id_code; /* ALT_GPIO_ID_CODE */
1954  volatile uint32_t _pad_0x68_0x6b; /* *UNDEFINED* */
1955  volatile ALT_GPIO_VER_ID_CODE_t gpio_ver_id_code; /* ALT_GPIO_VER_ID_CODE */
1956  volatile ALT_GPIO_CFG_REG2_t gpio_config_reg2; /* ALT_GPIO_CFG_REG2 */
1957  volatile ALT_GPIO_CFG_REG1_t gpio_config_reg1; /* ALT_GPIO_CFG_REG1 */
1958  volatile uint32_t _pad_0x78_0x80[2]; /* *UNDEFINED* */
1959 };
1960
1961 /* The typedef declaration for register group ALT_GPIO. */
1962 typedef volatile struct ALT_GPIO_s ALT_GPIO_t;
1963 /* The struct declaration for the raw register contents of register group ALT_GPIO. */
1965 {
1966  volatile uint32_t gpio_swporta_dr; /* ALT_GPIO_SWPORTA_DR */
1967  volatile uint32_t gpio_swporta_ddr; /* ALT_GPIO_SWPORTA_DDR */
1968  volatile uint32_t _pad_0x8_0x2f[10]; /* *UNDEFINED* */
1969  volatile uint32_t gpio_inten; /* ALT_GPIO_INTEN */
1970  volatile uint32_t gpio_intmask; /* ALT_GPIO_INTMSK */
1971  volatile uint32_t gpio_inttype_level; /* ALT_GPIO_INTTYPE_LEVEL */
1972  volatile uint32_t gpio_int_polarity; /* ALT_GPIO_INT_POL */
1973  volatile uint32_t gpio_intstatus; /* ALT_GPIO_INTSTAT */
1974  volatile uint32_t gpio_raw_intstatus; /* ALT_GPIO_RAW_INTSTAT */
1975  volatile uint32_t gpio_debounce; /* ALT_GPIO_DEBOUNCE */
1976  volatile uint32_t gpio_porta_eoi; /* ALT_GPIO_PORTA_EOI */
1977  volatile uint32_t gpio_ext_porta; /* ALT_GPIO_EXT_PORTA */
1978  volatile uint32_t _pad_0x54_0x5f[3]; /* *UNDEFINED* */
1979  volatile uint32_t gpio_ls_sync; /* ALT_GPIO_LS_SYNC */
1980  volatile uint32_t gpio_id_code; /* ALT_GPIO_ID_CODE */
1981  volatile uint32_t _pad_0x68_0x6b; /* *UNDEFINED* */
1982  volatile uint32_t gpio_ver_id_code; /* ALT_GPIO_VER_ID_CODE */
1983  volatile uint32_t gpio_config_reg2; /* ALT_GPIO_CFG_REG2 */
1984  volatile uint32_t gpio_config_reg1; /* ALT_GPIO_CFG_REG1 */
1985  volatile uint32_t _pad_0x78_0x80[2]; /* *UNDEFINED* */
1986 };
1987
1988 /* The typedef declaration for the raw register contents of register group ALT_GPIO. */
1989 typedef volatile struct ALT_GPIO_raw_s ALT_GPIO_raw_t;
1990 #endif /* __ASSEMBLY__ */
1991
1992
1993 #ifdef __cplusplus
1994 }
1995 #endif /* __cplusplus */
1996 #endif /* __ALTERA_ALT_GPIO_H__ */
1997
Definition: alt_gpio.h:800
Definition: alt_gpio.h:1160
Definition: alt_gpio.h:714
Definition: alt_gpio.h:1385
Definition: alt_gpio.h:544
Definition: alt_gpio.h:200
Definition: alt_gpio.h:950
Definition: alt_gpio.h:884
Definition: alt_gpio.h:1899
Definition: alt_gpio.h:458
Definition: alt_gpio.h:1964
Definition: alt_gpio.h:1937
Definition: alt_gpio.h:373
Definition: alt_gpio.h:628
Definition: alt_gpio.h:1097
Definition: alt_gpio.h:287
Definition: alt_gpio.h:1034
Definition: alt_gpio.h:110
