ALT_STATUS_CODE | alt_16550_init (ALT_16550_DEVICE_t device, void *location, alt_freq_t clock_freq, ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_uninit (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_reset (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_enable (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_disable (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_read (ALT_16550_HANDLE_t *handle, char *item) |
ALT_STATUS_CODE | alt_16550_write (ALT_16550_HANDLE_t *handle, char item) |
ALT_STATUS_CODE | alt_16550_fifo_enable (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_fifo_disable (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_fifo_read (ALT_16550_HANDLE_t *handle, char *buffer, size_t count) |
ALT_STATUS_CODE | alt_16550_fifo_write (ALT_16550_HANDLE_t *handle, const char *buffer, size_t count) |
ALT_STATUS_CODE | alt_16550_fifo_clear_rx (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_fifo_clear_tx (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_fifo_clear_all (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_fifo_size_get_rx (ALT_16550_HANDLE_t *handle, uint32_t *size) |
ALT_STATUS_CODE | alt_16550_fifo_size_get_tx (ALT_16550_HANDLE_t *handle, uint32_t *size) |
ALT_STATUS_CODE | alt_16550_fifo_level_get_rx (ALT_16550_HANDLE_t *handle, uint32_t *level) |
ALT_STATUS_CODE | alt_16550_fifo_level_get_tx (ALT_16550_HANDLE_t *handle, uint32_t *level) |
ALT_STATUS_CODE | alt_16550_fifo_trigger_set_rx (ALT_16550_HANDLE_t *handle, ALT_16550_FIFO_TRIGGER_RX_t trigger) |
ALT_STATUS_CODE | alt_16550_fifo_trigger_set_tx (ALT_16550_HANDLE_t *handle, ALT_16550_FIFO_TRIGGER_TX_t trigger) |
ALT_STATUS_CODE | alt_16550_baudrate_get (ALT_16550_HANDLE_t *handle, uint32_t *baudrate) |
ALT_STATUS_CODE | alt_16550_baudrate_set (ALT_16550_HANDLE_t *handle, uint32_t baudrate) |
ALT_STATUS_CODE | alt_16550_divisor_get (ALT_16550_HANDLE_t *handle, uint32_t *divisor) |
ALT_STATUS_CODE | alt_16550_divisor_set (ALT_16550_HANDLE_t *handle, uint32_t divisor) |
ALT_STATUS_CODE | alt_16550_int_enable_rx (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_int_disable_rx (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_int_enable_tx (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_int_disable_tx (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_int_enable_line (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_int_disable_line (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_int_enable_modem (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_int_disable_modem (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_int_disable_all (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_int_status_get (ALT_16550_HANDLE_t *handle, ALT_16550_INT_STATUS_t *status) |
ALT_STATUS_CODE | alt_16550_line_config_set (ALT_16550_HANDLE_t *handle, ALT_16550_DATABITS_t databits, ALT_16550_PARITY_t parity, ALT_16550_STOPBITS_t stopbits) |
ALT_STATUS_CODE | alt_16550_line_break_enable (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_line_break_disable (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_line_status_get (ALT_16550_HANDLE_t *handle, uint32_t *status) |
ALT_STATUS_CODE | alt_16550_flowcontrol_enable (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_flowcontrol_disable (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_loopback_enable (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_loopback_disable (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_modem_enable_out1 (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_modem_disable_out1 (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_modem_enable_out2 (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_modem_disable_out2 (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_modem_enable_rts (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_modem_disable_rts (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_modem_enable_dtr (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_modem_disable_dtr (ALT_16550_HANDLE_t *handle) |
ALT_STATUS_CODE | alt_16550_modem_status_get (ALT_16550_HANDLE_t *handle, uint32_t *status) |
