RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
bsps
include
grlib
ahbstat.h
1
/* AHBSTAT driver interface
2
3
* COPYRIGHT (c) 2011.
4
* Cobham Gaisler AB.
5
6
* The license and distribution terms for this file may be
7
* found in the file LICENSE in this distribution or at
8
* http://www.rtems.org/license/LICENSE.
9
10
11
#ifndef __AHBSTAT_H__
12
#define __AHBSTAT_H__
13
14
#include <stdint.h>
15
16
#ifdef __cplusplus
17
extern
"C"
18
#endif
19
20
/* AHBSTAT Registers layout */
21
struct
ahbstat_regs
22
volatile
uint32_t status;
23
volatile
uint32_t failing;
24
25
26
/* AHB fail interrupt callback to user. This function is declared weak so that
27
* the user can define a function pointer variable containing the address
28
* responsible for handling errors
29
30
* minor Index of AHBSTAT hardware
31
* regs Register address of AHBSTAT
32
* status AHBSTAT status register at IRQ
33
* failing_address AHBSTAT Failing address register at IRQ
34
35
* * User return
36
* 0: print error onto terminal with printk and reenable AHBSTAT
37
* 1: just re-enable AHBSTAT
38
* 2: just print error
39
* 3: do nothing, let user do custom handling
40
41
extern
int (*ahbstat_error)(
42
int
minor,
43
struct
ahbstat_regs
*regs,
44
uint32_t status,
45
uint32_t failing_address);
46
47
/* Get Last received AHB Error
48
49
* \param minor Index used to indentify a specific AHBSTAT core
50
* \param status Status register at time of error IRQ was recevied
51
* \param address Failing address register at time of error IRQ
52
53
* Return
54
* 0: No error received
55
* 1: Error Received, last status and address stored into argument pointers
56
* -1: No such AHBSTAT device
57
58
extern
int
ahbstat_last_error(
int
minor, uint32_t *status, uint32_t *address);
59
60
/* Get AHBSTAT registers address from minor. Can also be used to check if
61
* AHBSTAT hardware is present.
62
63
* Return
64
* NULL returned if no such device
65
* non-zero Address to AHBSTAT register
66
67
extern
struct
ahbstat_regs
*ahbstat_get_regs(
int
minor);
68
69
/* Registers the AHBSTAT driver to the Driver Manager */
70
void
ahbstat_register_drv (
void
71
72
#ifdef __cplusplus
73
74
#endif
75
76
#endif
ahbstat_regs
Definition:
ahbstat.h:21
