RTEMS  5.1
MCD_dma.h
1 /*
2  * File: MCD_dma.h
3  * Purpose: Main header file for multi-channel DMA API.
4  *
5  * Notes:
6  */
7 #ifndef _MCD_API_H
8 #define _MCD_API_H
9
10 /*
11  * Turn Execution Unit tasks ON (#define) or OFF (#undef)
12  */
13 #define MCD_INCLUDE_EU
14
15 /*
16  * Number of DMA channels
17  */
18 #define NCHANNELS 16
19
20 /*
21  * Total number of variants
22  */
23 #ifdef MCD_INCLUDE_EU
24 #define NUMOFVARIANTS 6
25 #else
26 #define NUMOFVARIANTS 4
27 #endif
28
29 /*
30  * Define sizes of the various tables
31  */
32 #define TASK_TABLE_SIZE (NCHANNELS*32)
33 #define VAR_TAB_SIZE (128)
34 #define CONTEXT_SAVE_SIZE (128)
35 #define FUNCDESC_TAB_SIZE (256)
36
37 #ifdef MCD_INCLUDE_EU
38 #define FUNCDESC_TAB_NUM 16
39 #else
40 #define FUNCDESC_TAB_NUM 1
41 #endif
42
43
44 #ifndef DEFINESONLY
45
46 /*
47  * Portability typedefs
48  */
49 typedef int s32;
50 typedef unsigned int u32;
51 typedef short s16;
52 typedef unsigned short u16;
53 typedef char s8;
54 typedef unsigned char u8;
55
56 /*
57  * These structures represent the internal registers of the
58  * multi-channel DMA
59  */
60 struct dmaRegs_s {
61  u32 taskbar; /* task table base address register */
62  u32 currPtr;
63  u32 endPtr;
64  u32 varTablePtr;
65  u16 dma_rsvd0;
66  u16 ptdControl; /* ptd control */
67  u32 intPending; /* interrupt pending register */
68  u32 intMask; /* interrupt mask register */
69  u16 taskControl[16]; /* task control registers */
70  u8 priority[32]; /* priority registers */
71  u32 initiatorMux; /* initiator mux control */
72  u32 taskSize0; /* task size control register 0. */
73  u32 taskSize1; /* task size control register 1. */
74  u32 dma_rsvd1; /* reserved */
75  u32 dma_rsvd2; /* reserved */
76  u32 debugComp1; /* debug comparator 1 */
77  u32 debugComp2; /* debug comparator 2 */
78  u32 debugControl; /* debug control */
79  u32 debugStatus; /* debug status */
80  u32 ptdDebug; /* priority task decode debug */
81  u32 dma_rsvd3[31]; /* reserved */
82 };
83 typedef volatile struct dmaRegs_s dmaRegs;
84
85 #endif
86
87 /*
88  * PTD contrl reg bits
89  */
90 #define PTD_CTL_TSK_PRI 0x8000
91 #define PTD_CTL_COMM_PREFETCH 0x0001
92
93 /*
94  * Task Control reg bits and field masks
95  */
96 #define TASK_CTL_EN 0x8000
97 #define TASK_CTL_VALID 0x4000
98 #define TASK_CTL_ALWAYS 0x2000
99 #define TASK_CTL_INIT_MASK 0x1f00
100 #define TASK_CTL_ASTRT 0x0080
101 #define TASK_CTL_HIPRITSKEN 0x0040
102 #define TASK_CTL_HLDINITNUM 0x0020
103 #define TASK_CTL_ASTSKNUM_MASK 0x000f
104
105 /*
106  * Priority reg bits and field masks
107  */
108 #define PRIORITY_HLD 0x80
109 #define PRIORITY_PRI_MASK 0x07
110
111 /*
112  * Debug Control reg bits and field masks
113  */
114 #define DBG_CTL_BLOCK_TASKS_MASK 0xffff0000
115 #define DBG_CTL_AUTO_ARM 0x00008000
116 #define DBG_CTL_BREAK 0x00004000
117 #define DBG_CTL_COMP1_TYP_MASK 0x00003800
118 #define DBG_CTL_COMP2_TYP_MASK 0x00000070
119 #define DBG_CTL_EXT_BREAK 0x00000004
120 #define DBG_CTL_INT_BREAK 0x00000002
121
122 /*
123  * PTD Debug reg selector addresses
124  * This reg must be written with a value to show the contents of
125  * one of the desired internal register.
126  */
127 #define PTD_DBG_REQ 0x00 /* shows the state of 31 initiators */
128 #define PTD_DBG_TSK_VLD_INIT 0x01 /* shows which 16 tasks are valid and
129  have initiators asserted */
130
131
132 /*
133  * General return values
134  */
135 #define MCD_OK 0
136 #define MCD_ERROR -1
137 #define MCD_TABLE_UNALIGNED -2
138 #define MCD_CHANNEL_INVALID -3
139
140 /*
141  * MCD_initDma input flags
142  */
143 #define MCD_RELOC_TASKS 0x00000001
144 #define MCD_NO_RELOC_TASKS 0x00000000
145 #define MCD_COMM_PREFETCH_EN 0x00000002 /* Commbus Prefetching - MCF547x/548x ONLY */
146
147 /*
148  * MCD_dmaStatus Status Values for each channel
149  */
150 #define MCD_NO_DMA 1 /* No DMA has been requested since reset */
151 #define MCD_IDLE 2 /* DMA active, but the initiator is currently inactive */
152 #define MCD_RUNNING 3 /* DMA active, and the initiator is currently active */
153 #define MCD_PAUSED 4 /* DMA active but it is currently paused */
154 #define MCD_HALTED 5 /* the most recent DMA has been killed with MCD_killTask() */
155 #define MCD_DONE 6 /* the most recent DMA has completed. */
156
157
158 /*
159  * MCD_startDma parameter defines
160  */
161
162 /*
163  * Constants for the funcDesc parameter
164  */
165 /* Byte swapping: */
166 #define MCD_NO_BYTE_SWAP 0x00045670 /* to disable byte swapping. */
167 #define MCD_BYTE_REVERSE 0x00076540 /* to reverse the bytes of each u32 of the DMAed data. */
168 #define MCD_U16_REVERSE 0x00067450 /* to reverse the 16-bit halves of
169  each 32-bit data value being DMAed.*/
170 #define MCD_U16_BYTE_REVERSE 0x00054760 /* to reverse the byte halves of each
171  16-bit half of each 32-bit data value DMAed */
172 #define MCD_NO_BIT_REV 0x00000000 /* do not reverse the bits of each byte DMAed. */
173 #define MCD_BIT_REV 0x00088880 /* reverse the bits of each byte DMAed */
174 /* CRCing: */
175 #define MCD_CRC16 0xc0100000 /* to perform CRC-16 on DMAed data. */
176 #define MCD_CRCCCITT 0xc0200000 /* to perform CRC-CCITT on DMAed data. */
177 #define MCD_CRC32 0xc0300000 /* to perform CRC-32 on DMAed data. */
178 #define MCD_CSUMINET 0xc0400000 /* to perform internet checksums on DMAed data.*/
179 #define MCD_NO_CSUM 0xa0000000 /* to perform no checksumming. */
180
181 #define MCD_FUNC_NOEU1 (MCD_NO_BYTE_SWAP | MCD_NO_BIT_REV | MCD_NO_CSUM)
182 #define MCD_FUNC_NOEU2 (MCD_NO_BYTE_SWAP | MCD_NO_CSUM)
183
184 /*
185  * Constants for the flags parameter
186  */
187 #define MCD_TT_FLAGS_RL 0x00000001 /* Read line */
188 #define MCD_TT_FLAGS_CW 0x00000002 /* Combine Writes */
189 #define MCD_TT_FLAGS_SP 0x00000004 /* Speculative prefetch(XLB) MCF547x/548x ONLY */
190 #define MCD_TT_FLAGS_MASK 0x000000ff
191 #define MCD_TT_FLAGS_DEF (MCD_TT_FLAGS_RL | MCD_TT_FLAGS_CW)
192
193 #define MCD_SINGLE_DMA 0x00000100 /* Unchained DMA */
194 #define MCD_CHAIN_DMA /* TBD */
195 #define MCD_EU_DMA /* TBD */
196 #define MCD_FECTX_DMA 0x00001000 /* FEC TX ring DMA */
197 #define MCD_FECRX_DMA 0x00002000 /* FEC RX ring DMA */
198
199
200 /* these flags are valid for MCD_startDma and the chained buffer descriptors */
201 #define MCD_BUF_READY 0x80000000 /* indicates that this buffer is now under the DMA's control */
202 #define MCD_WRAP 0x20000000 /* to tell the FEC Dmas to wrap to the first BD */
203 #define MCD_INTERRUPT 0x10000000 /* to generate an interrupt after completion of the DMA. */
204 #define MCD_END_FRAME 0x08000000 /* tell the DMA to end the frame when transferring
205  last byte of data in buffer */
206 #define MCD_CRC_RESTART 0x40000000 /* to empty out the accumulated checksum
207  prior to performing the DMA. */
208
209 /* Defines for the FEC buffer descriptor control/status word*/
210 #define MCD_FEC_BUF_READY 0x8000
211 #define MCD_FEC_WRAP 0x2000
212 #define MCD_FEC_INTERRUPT 0x1000
213 #define MCD_FEC_END_FRAME 0x0800
214
215
216 /*
217  * Defines for general intuitiveness
218  */
219
220 #define MCD_TRUE 1
221 #define MCD_FALSE 0
222
223 /*
224  * Three different cases for destination and source.
225  */
226 #define MINUS1 -1
227 #define ZERO 0
228 #define PLUS1 1
229
230 #ifndef DEFINESONLY
231
232 /* Task Table Entry struct*/
233 typedef struct {
234  u32 TDTstart; /* task descriptor table start */
235  u32 TDTend; /* task descriptor table end */
236  u32 varTab; /* variable table start */
237  u32 FDTandFlags; /* function descriptor table start and flags */
238  volatile u32 descAddrAndStatus;
239  volatile u32 modifiedVarTab;
240  u32 contextSaveSpace; /* context save space start */
241  u32 literalBases;
243
244
245 /* Chained buffer descriptor */
246 typedef volatile struct MCD_bufDesc_struct MCD_bufDesc;
248  u32 flags; /* flags describing the DMA */
249  u32 csumResult; /* checksum from checksumming performed since last checksum reset */
250  s8 *srcAddr; /* the address to move data from */
251  s8 *destAddr; /* the address to move data to */
252  s8 *lastDestAddr; /* the last address written to */
253  u32 dmaSize; /* the number of bytes to transfer independent of the transfer size */
254  MCD_bufDesc *next; /* next buffer descriptor in chain */
255  u32 info; /* private information about this descriptor; DMA does not affect it */
256 };
257
258 /* Progress Query struct */
259 typedef volatile struct MCD_XferProg_struct {
260  s8 *lastSrcAddr; /* the most-recent or last, post-increment source address */
261  s8 *lastDestAddr; /* the most-recent or last, post-increment destination address */
262  u32 dmaSize; /* the amount of data transferred for the current buffer */
263  MCD_bufDesc *currBufDesc;/* pointer to the current buffer descriptor being DMAed */
264 } MCD_XferProg;
265
266
267 /* FEC buffer descriptor */
268 typedef volatile struct MCD_bufDescFec_struct {
269  u16 statCtrl;
270  u16 length;
271  u32 dataPointer;
272 } MCD_bufDescFec;
273
274
275 /*************************************************************************/
276 /*
277  * API function Prototypes - see MCD_dmaApi.c for further notes
278  */
279
280 /*
281  * MCD_startDma starts a particular kind of DMA .
282  */
283 int MCD_startDma (
284  int channel, /* the channel on which to run the DMA */
285  s8 *srcAddr, /* the address to move data from, or buffer-descriptor address */
286  s16 srcIncr, /* the amount to increment the source address per transfer */
287  s8 *destAddr, /* the address to move data to */
288  s16 destIncr, /* the amount to increment the destination address per transfer */
289  u32 dmaSize, /* the number of bytes to transfer independent of the transfer size */
290  u32 xferSize, /* the number bytes in of each data movement (1, 2, or 4) */
291  u32 initiator, /* what device initiates the DMA */
292  int priority, /* priority of the DMA */
293  u32 flags, /* flags describing the DMA */
294  u32 funcDesc /* a description of byte swapping, bit swapping, and CRC actions */
295 );
296
297 /*
298  * MCD_initDma() initializes the DMA API by setting up a pointer to the DMA
299  * registers, relocating and creating the appropriate task structures, and
300  * setting up some global settings
301  */
302 int MCD_initDma (dmaRegs *sDmaBarAddr, void *taskTableDest, u32 flags);
303
304 /*
305  * MCD_dmaStatus() returns the status of the DMA on the requested channel.
306  */
307 int MCD_dmaStatus (int channel);
308
309 /*
310  * MCD_XferProgrQuery() returns progress of DMA on requested channel
311  */
312 int MCD_XferProgrQuery (int channel, MCD_XferProg *progRep);
313
314 /*
315  * MCD_killDma() halts the DMA on the requested channel, without any
316  * intention of resuming the DMA.
317  */
318 int MCD_killDma (int channel);
319
320 /*
321  * MCD_continDma() continues a DMA which as stopped due to encountering an
322  * unready buffer descriptor.
323  */
324 int MCD_continDma (int channel);
325
326 /*
327  * MCD_pauseDma() pauses the DMA on the given channel ( if any DMA is
328  * running on that channel).
329  */
330 int MCD_pauseDma (int channel);
331
332 /*
333  * MCD_resumeDma() resumes the DMA on a given channel (if any DMA is
334  * running on that channel).
335  */
336 int MCD_resumeDma (int channel);
337
338 /*
339  * MCD_csumQuery provides the checksum/CRC after performing a non-chained DMA
340  */
341 int MCD_csumQuery (int channel, u32 *csum);
342
343 /*
344  * MCD_getCodeSize provides the packed size required by the microcoded task
345  * and structures.
346  */
347 int MCD_getCodeSize(void);
348
349 /*
350  * MCD_getVersion provides a pointer to a version string and returns a
351  * version number.
352  */
353 int MCD_getVersion(char **longVersion);
354
355 /* macro for setting a location in the variable table */
356 #define MCD_SET_VAR(taskTab,idx,value) ((u32 *)(taskTab)->varTab)[idx] = value
357  /* Note that MCD_SET_VAR() is invoked many times in firing up a DMA function,
358  so I'm avoiding surrounding it with "do {} while(0)" */
359
360 #endif /* DEFINESONLY */
361
362 #endif /* _MCD_API_H */
Definition: MCD_dma.h:247
Definition: MCD_dma.h:259
Definition: MCD_dma.h:60
Definition: MCD_dma.h:233
Definition: MCD_dma.h:268
