RTEMS  5.1
GT64260ethreg.h
1 /* $NetBSD: GT64260ethreg.h,v 1.2 2003/03/17 16:41:16 matt Exp $ */
2
3 /*
4  * Copyright (c) 2002 Allegro Networks, Inc., Wasabi Systems, Inc.
5  * All rights reserved.
6  *
7  * Redistribution and use in source and binary forms, with or without
8  * modification, are permitted provided that the following conditions
9  * are met:
10  * 1. Redistributions of source code must retain the above copyright
11  * notice, this list of conditions and the following disclaimer.
12  * 2. Redistributions in binary form must reproduce the above copyright
13  * notice, this list of conditions and the following disclaimer in the
14  * documentation and/or other materials provided with the distribution.
15  * 3. All advertising materials mentioning features or use of this software
16  * must display the following acknowledgement:
17  * This product includes software developed for the NetBSD Project by
18  * Allegro Networks, Inc., and Wasabi Systems, Inc.
19  * 4. The name of Allegro Networks, Inc. may not be used to endorse
20  * or promote products derived from this software without specific prior
21  * written permission.
22  * 5. The name of Wasabi Systems, Inc. may not be used to endorse
23  * or promote products derived from this software without specific prior
24  * written permission.
25  *
26  * THIS SOFTWARE IS PROVIDED BY ALLEGRO NETWORKS, INC. AND
27  * WASABI SYSTEMS, INC. ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES,
28  * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
29  * AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
30  * IN NO EVENT SHALL EITHER ALLEGRO NETWORKS, INC. OR WASABI SYSTEMS, INC.
31  * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
32  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
33  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
34  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
35  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
36  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
37  * POSSIBILITY OF SUCH DAMAGE.
38  */
39
40 #ifndef _DEV_GTETHREG_H_
41 #define _DEV_GTETHREG_H_
42
43 #define ETH__BIT(bit) (1U << (bit))
44 #define ETH__LLBIT(bit) (1ULL << (bit))
45 #define ETH__MASK(bit) (ETH__BIT(bit) - 1)
46 #define ETH__LLMASK(bit) (ETH__LLBIT(bit) - 1)
47 #define ETH__GEN(n, off) (0x2400+((n) << 10)+(ETH__ ## off))
48 #define ETH__EXT(data, bit, len) (((data) >> (bit)) & ETH__MASK(len))
49 #define ETH__LLEXT(data, bit, len) (((data) >> (bit)) & ETH__LLMASK(len))
50 #define ETH__CLR(data, bit, len) ((data) &= ~(ETH__MASK(len) << (bit)))
51 #define ETH__INS(new, bit) ((new) << (bit))
52 #define ETH__LLINS(new, bit) ((unsigned long long)(new) << (bit))
53
54 /*
55  * Descriptors used for both receive & transmit data. Note that the descriptor
56  * must start on a 4LW boundary. Since the GT accesses the descriptor as
57  * two 64-bit quantities, we must present them 32bit quantities in the right
58  * order based on endianess.
59  */
60
61 struct GTeth_desc {
62 #if defined(BYTE_ORDER) && BYTE_ORDER == BIG_ENDIAN /* for mvme5500 */
63  unsigned ed_lencnt; /* Buffer size is hi 16 bits; Byte count (rx) is lo 16 */
64  unsigned ed_cmdsts; /* command (hi16)/status (lo16) bits */
65  unsigned ed_nxtptr; /* next descriptor (must be 4LW aligned) */
66  unsigned ed_bufptr; /* pointer to packet buffer */
67 #endif
68 #if defined(BYTE_ORDER) && BYTE_ORDER == LITTLE_ENDIAN
69  unsigned ed_cmdsts; /* command (hi16)/status (lo16) bits */
70  unsigned ed_lencnt; /* length is hi 16 bits; count (rx) is lo 16 */
71  unsigned ed_bufptr; /* pointer to packet buffer */
72  unsigned ed_nxtptr; /* next descriptor (must be 4LW aligned) */
73 #endif
74 };
75
76 /* Ethernet 0 address control (Low), Offset: 0xf200 */
77 #define RxBSnoopEn ETH__BIT(6) /* Rx buffer snoop enable,1=enable*/
78 #define TxBSnoopEn ETH__BIT(14) /* Tx buffer snoop enable */
79 #define RxDSnoopEn ETH__BIT(22) /* Rx descriptor snoop enable */
80 #define TxDSnoopEn ETH__BIT(30) /* Tx descriptor snoop enable */
81
82 /* Ethernet 0 address control (High), Offset: 0xf204 */
83 #define HashSnoopEn ETH__BIT(6) /* Hash Table snoop enable */
84
85 /* <skf> */
86 #define GT_CUU_Eth0_AddrCtrlLow 0xf200
87 #define GT_CUU_Eth0_AddrCtrlHigh 0xf204
88
89 /* Table 578: Ethernet TX Descriptor - Command/Status word
90  * All bits except F, EI, AM, O are only valid if TX_CMD_L is also set,
91  * otherwise should be 0 (tx).
92  */
93
94 #define TX_STS_LC ETH__BIT(5) /* Late Collision */
95 #define TX_STS_UR ETH__BIT(6) /* Underrun error */
96 #define TX_STS_RL ETH__BIT(8) /* Retransmit Limit (excession coll) */
97 #define TX_STS_COL ETH__BIT(9) /* Collision Occurred */
98 #define TX_STS_RC(v) ETH__GETBITS(v, 10, 4) /* Retransmit Count */
99 #define TX_STS_ES ETH__BIT(15) /* Error Summary (LC|UR|RL) */
100 #define TX_CMD_L ETH__BIT(16) /* Last - End Of Packet */
101 #define TX_CMD_F ETH__BIT(17) /* First - Start Of Packet */
102 #define TX_CMD_P ETH__BIT(18) /* Pad Packet */
103 #define TX_CMD_GC ETH__BIT(22) /* Generate CRC */
104 #define TX_CMD_EI ETH__BIT(23) /* Enable Interrupt */
105 #define TX_CMD_AM ETH__BIT(30) /* Auto Mode */
106 #define TX_CMD_O ETH__BIT(31) /* Ownership (1=GT 0=CPU) */
107
108 #define TX_CMD_FIRST (TX_CMD_F|TX_CMD_O)
109 #define TX_CMD_LAST (TX_CMD_L|TX_CMD_GC|TX_CMD_P|TX_CMD_O)
110
111 /* Table 608: Ethernet RX Descriptor - Command/Status Word
112  * All bits except F, EI, AM, O are only valid if RX_CMD_L is also set,
113  * otherwise should be ignored (rx).
114  */
115 #define RX_STS_CE ETH__BIT(0) /* CRC Error */
116 #define RX_STS_COL ETH__BIT(1) /* Collision sensed during reception */
117 #define RX_STS_LC ETH__BIT(5) /* Late Collision (Reserved) */
118 #define RX_STS_OR ETH__BIT(6) /* Overrun Error */
119 #define RX_STS_MFL ETH__BIT(7) /* Max Frame Len Error */
120 #define RX_STS_SF ETH__BIT(8) /* Short Frame Error (< 64 bytes) */
121 #define RX_STS_FT ETH__BIT(11) /* Frame Type (1 = 802.3) */
122 #define RX_STS_M ETH__BIT(12) /* Missed Frame */
123 #define RX_STS_HE ETH__BIT(13) /* Hash Expired (manual match) */
124 #define RX_STS_IGMP ETH__BIT(14) /* IGMP Packet */
125 #define RX_STS_ES ETH__BIT(15) /* Error Summary (CE|COL|LC|OR|MFL|SF) */
126 #define RX_CMD_L ETH__BIT(16) /* Last - End Of Packet */
127 #define RX_CMD_F ETH__BIT(17) /* First - Start Of Packet */
128 #define RX_CMD_EI ETH__BIT(23) /* Enable Interrupt */
129 #define RX_CMD_AM ETH__BIT(30) /* Auto Mode */
130 #define RX_CMD_O ETH__BIT(31) /* Ownership (1=GT 0=CPU) */
131
132 /* Table 586: Hash Table Entry Fields
133  */
134 #define HSH_V ETH__LLBIT(0) /* Entry is valid */
135 #define HSH_S ETH__LLBIT(1) /* Skip this entry */
136 #define HSH_RD ETH__LLBIT(2) /* Receive(1) / Discard (0) */
137 #define HSH_R ETH__LLBIT(2) /* Receive(1) */
138 #define HSH_PRIO_GET(v) ETH__LLEXT(v, 51, 2)
139 #define HSH_PRIO_INS(v) ETH__LLINS(v, 51)
140 #define HSH_ADDR_MASK 0x7fffff8LLU
141 #define HSH_LIMIT 12
142
143
144 #define ETH_EPAR 0x2000 /* PHY Address Register */
145 #define ETH_ESMIR 0x2010 /* SMI Register */
146
147 #define ETH_BASE_ETH0 0x2400 /* Ethernet0 Register Base */
148 #define ETH_BASE_ETH1 0x2800 /* Ethernet1 Register Base */
149 #define ETH_BASE_ETH2 0x2c00 /* Ethernet2 Register Base */
150 #define ETH_SIZE 0x0400 /* Register Space */
151
152 #define ETH__EBASE 0x0000 /* Base of Registers */
153 #define ETH__EPCR 0x0000 /* Port Config. Register */
154 #define ETH__EPCXR 0x0008 /* Port Config. Extend Reg */
155 #define ETH__EPCMR 0x0010 /* Port Command Register */
156 #define ETH__EPSR 0x0018 /* Port Status Register */
157 #define ETH__ESPR 0x0020 /* Port Serial Parameters Reg */
158 #define ETH__EHTPR 0x0028 /* Port Hash Table Pointer Reg*/
159 #define ETH__EFCSAL 0x0030 /* Flow Control Src Addr Low */
160 #define ETH__EFCSAH 0x0038 /* Flow Control Src Addr High */
161 #define ETH__ESDCR 0x0040 /* SDMA Configuration Reg */
162 #define ETH__ESDCMR 0x0048 /* SDMA Command Register */
163 #define ETH__EICR 0x0050 /* Interrupt Cause Register */
164 #define ETH__EIMR 0x0058 /* Interrupt Mask Register */
165 #define ETH__EFRDP0 0x0080 /* First Rx Desc Pointer 0 */
166 #define ETH__EFRDP1 0x0084 /* First Rx Desc Pointer 1 */
167 #define ETH__EFRDP2 0x0088 /* First Rx Desc Pointer 2 */
168 #define ETH__EFRDP3 0x008c /* First Rx Desc Pointer 3 */
169 #define ETH__ECRDP0 0x00a0 /* Current Rx Desc Pointer 0 */
170 #define ETH__ECRDP1 0x00a4 /* Current Rx Desc Pointer 1 */
171 #define ETH__ECRDP2 0x00a8 /* Current Rx Desc Pointer 2 */
172 #define ETH__ECRDP3 0x00ac /* Current Rx Desc Pointer 3 */
173 #define ETH__ECTDP0 0x00e0 /* Current Tx Desc Pointer 0 */
174 #define ETH__ECTDP1 0x00e4 /* Current Tx Desc Pointer 1 */
175 #define ETH__EDSCP2P0L 0x0060 /* IP Differentiated Services
176  CodePoint to Priority0 low */
177 #define ETH__EDSCP2P0H 0x0064 /* IP Differentiated Services
178  CodePoint to Priority0 high*/
179 #define ETH__EDSCP2P1L 0x0068 /* IP Differentiated Services
180  CodePoint to Priority1 low */
181 #define ETH__EDSCP2P1H 0x006c /* IP Differentiated Services
182  CodePoint to Priority1 high*/
183 #define ETH__EVPT2P 0x0068 /* VLAN Prio. Tag to Priority */
184 #define ETH__EMIBCTRS 0x0100 /* MIB Counters */
185
186 /* SKF : we are only concerned with the Ethernet0 for the mvme5500 board */
187 #define ETH0_EBASE 0x2400 /* Base of Registers */
188 #define ETH0_EPCR 0x2400 /* Port Config. Register */
189 #define ETH0_EPCXR 0x2408 /* Port Config. Extend Reg */
190 #define ETH0_EPCMR 0x2410 /* Port Command Register */
191 #define ETH0_EPSR 0x2418 /* Port Status Register */
192 #define ETH0_ESPR 0x2420 /* Port Serial Parameters Reg */
193 #define ETH0_EHTPR 0x2428 /* Port Hash Table Pointer Reg*/
194 #define ETH0_EFCSAL 0x2430 /* Flow Control Src Addr Low */
195 #define ETH0_EFCSAH 0x2438 /* Flow Control Src Addr High */
196 #define ETH0_ESDCR 0x2440 /* SDMA Configuration Reg */
197 #define ETH0_ESDCMR 0x2448 /* SDMA Command Register */
198 #define ETH0_EICR 0x2450 /* Interrupt Cause Register */
199 #define ETH0_EIMR 0x2458 /* Interrupt Mask Register */
200 #define ETH0_EFRDP0 0x2480 /* First Rx Desc Pointer 0 */
201 #define ETH0_EFRDP1 0x2484 /* First Rx Desc Pointer 1 */
202 #define ETH0_EFRDP2 0x2488 /* First Rx Desc Pointer 2 */
203 #define ETH0_EFRDP3 0x248c /* First Rx Desc Pointer 3 */
204 #define ETH0_ECRDP0 0x24a0 /* Current Rx Desc Pointer 0 */
205 #define ETH0_ECRDP1 0x24a4 /* Current Rx Desc Pointer 1 */
206 #define ETH0_ECRDP2 0x24a8 /* Current Rx Desc Pointer 2 */
207 #define ETH0_ECRDP3 0x24ac /* Current Rx Desc Pointer 3 */
208 #define ETH0_ECTDP0 0x24e0 /* Current Tx Desc Pointer 0 */
209 #define ETH0_ECTDP1 0x24e4 /* Current Tx Desc Pointer 1 */
210 #define ETH0_EDSCP2P0L 0x2460 /* IP Differentiated Services
211  CodePoint to Priority0 low */
212 #define ETH0_EDSCP2P0H 0x2464 /* IP Differentiated Services
213  CodePoint to Priority0 high*/
214 #define ETH0_EDSCP2P1L 0x2468 /* IP Differentiated Services
215  CodePoint to Priority1 low */
216 #define ETH0_EDSCP2P1H 0x246c /* IP Differentiated Services
217  CodePoint to Priority1 high*/
218 #define ETH0_EVPT2P 0x2468 /* VLAN Prio. Tag to Priority */
219 #define ETH0_EMIBCTRS 0x2500 /* MIB Counters */
220
221 #define ETH_BASE(n) ETH__GEN(n, EBASE)
222 #define ETH_EPCR(n) ETH__GEN(n, EPCR) /* Port Config. Register */
223 #define ETH_EPCXR(n) ETH__GEN(n, EPCXR) /* Port Config. Extend Reg */
224 #define ETH_EPCMR(n) ETH__GEN(n, EPCMR) /* Port Command Register */
225 #define ETH_EPSR(n) ETH__GEN(n, EPSR) /* Port Status Register */
226 #define ETH_ESPR(n) ETH__GEN(n, ESPR) /* Port Serial Parameters Reg */
227 #define ETH_EHTPR(n) ETH__GEN(n, EHPTR) /* Port Hash Table Pointer Reg*/
228 #define ETH_EFCSAL(n) ETH__GEN(n, EFCSAL) /* Flow Control Src Addr Low */
229 #define ETH_EFCSAH(n) ETH__GEN(n, EFCSAH) /* Flow Control Src Addr High */
230 #define ETH_ESDCR(n) ETH__GEN(n, ESDCR) /* SDMA Configuration Reg */
231 #define ETH_ESDCMR(n) ETH__GEN(n, ESDCMR) /* SDMA Command Register */
232 #define ETH_EICR(n) ETH__GEN(n, EICR) /* Interrupt Cause Register */
233 #define ETH_EIMR(n) ETH__GEN(n, EIMR) /* Interrupt Mask Register */
234 #define ETH_EFRDP0(n) ETH__GEN(n, EFRDP0) /* First Rx Desc Pointer 0 */
235 #define ETH_EFRDP1(n) ETH__GEN(n, EFRDP1) /* First Rx Desc Pointer 1 */
236 #define ETH_EFRDP2(n) ETH__GEN(n, EFRDP2) /* First Rx Desc Pointer 2 */
237 #define ETH_EFRDP3(n) ETH__GEN(n, EFRDP3) /* First Rx Desc Pointer 3 */
238 #define ETH_ECRDP0(n) ETH__GEN(n, ECRDP0) /* Current Rx Desc Pointer 0 */
239 #define ETH_ECRDP1(n) ETH__GEN(n, ECRDP1) /* Current Rx Desc Pointer 1 */
240 #define ETH_ECRDP2(n) ETH__GEN(n, ECRDP2) /* Current Rx Desc Pointer 2 */
241 #define ETH_ECRDP3(n) ETH__GEN(n, ECRDP3) /* Current Rx Desc Pointer 3 */
242 #define ETH_ECTDP0(n) ETH__GEN(n, ECTDP0) /* Current Tx Desc Pointer 0 */
243 #define ETH_ECTDP1(n) ETH__GEN(n, ECTDP1) /* Current Tx Desc Pointer 1 */
244 #define ETH_EDSCP2P0L(n) ETH__GEN(n, EDSCP2P0L) /* IP Differentiated Services
245  CodePoint to Priority0 low */
246 #define ETH_EDSCP2P0H(n) ETH__GEN(n, EDSCP2P0H) /* IP Differentiated Services
247  CodePoint to Priority0 high*/
248 #define ETH_EDSCP2P1L(n) ETH__GEN(n, EDSCP2P1L) /* IP Differentiated Services
249  CodePoint to Priority1 low */
250 #define ETH_EDSCP2P1H(n) ETH__GEN(n, EDSCP1P1H) /* IP Differentiated Services
251  CodePoint to Priority1 high*/
252 #define ETH_EVPT2P(n) ETH__GEN(n, EVPT2P) /* VLAN Prio. Tag to Priority */
253 #define ETH_EMIBCTRS(n) ETH__GEN(n, EMIBCTRS) /* MIB Counters */
254
255 #define ETH_EPAR_PhyAD_GET(v, n) (((v) >> ((n) * 5)) & 0x1f)
256
257 #define ETH_ESMIR_READ(phy, reg) (ETH__INS(phy, 16)|\
258  ETH__INS(reg, 21)|\
259  ETH_ESMIR_ReadOpcode)
260 #define ETH_ESMIR_WRITE(phy, reg, val) (ETH__INS(phy, 16)|\
261  ETH__INS(reg, 21)|\
262  ETH__INS(val, 0)|\
263  ETH_ESMIR_WriteOpcode)
264 #define ETH_ESMIR_Value_GET(v) ETH__EXT(v, 0, 16)
265 #define ETH_ESMIR_WriteOpcode 0
266 #define ETH_ESMIR_ReadOpcode ETH__BIT(26)
267 #define ETH_ESMIR_ReadValid ETH__BIT(27)
268 #define ETH_ESMIR_Busy ETH__BIT(28)
269
270 /*
271  * Table 597: Port Configuration Register (PCR)
272  * 00:00 PM Promiscuous mode
273  * 0: Normal mode (Frames are only received if the
274  * destination address is found in the hash
275  * table)
276  * 1: Promiscuous mode (Frames are received
277  * regardless of their destination address.
278  * Errored frames are discarded unless the Port
279  * Configuration register's PBF bit is set)
280  * 01:01 RBM Reject Broadcast Mode
281  * 0: Receive broadcast address
282  * 1: Reject frames with broadcast address
283  * Overridden by the promiscuous mode.
284  * 02:02 PBF Pass Bad Frames
285  * (0: Normal mode, 1: Pass bad Frames)
286  * The Ethernet receiver passes to the CPU errored
287  * frames (like fragments and collided packets)
288  * that are normally rejected.
289  * NOTE: Frames are only passed if they
290  * successfully pass address filtering.
291  * 06:03 Reserved
292  * 07:07 EN Enable (0: Disabled, 1: Enable)
293  * When enabled, the ethernet port is ready to
294  * transmit/receive.
295  * 09:08 LPBK Loop Back Mode
296  * 00: Normal mode
297  * 01: Internal loop back mode (TX data is looped
298  * back to the RX lines. No transition is seen
299  * on the interface pins)
300  * 10: External loop back mode (TX data is looped
301  * back to the RX lines and also transmitted
302  * out to the MII interface pins)
303  * 11: Reserved
304  * 10:10 FC Force Collision
305  * 0: Normal mode.
306  * 1: Force Collision on any TX frame.
307  * For RXM test (in Loopback mode).
308  * 11:11 Reserved.
309  * 12:12 HS Hash Size
310  * 0: 8K address filtering
311  * (256KB of memory space required).
312  * 1: 512 address filtering
313  * ( 16KB of memory space required).
314  * 13:13 HM Hash Mode (0: Hash Func. 0; 1: Hash Func. 1)
315  * 14:14 HDM Hash Default Mode
316  * 0: Discard addresses not found in address table
317  * 1: Pass addresses not found in address table
318  * 15:15 HD Duplex Mode (0: Half Duplex, 1: Full Duplex)
319  * NOTE: Valid only when auto-negotiation for
320  * duplex mode is disabled.
321  * 30:16 Reserved
322  * 31:31 ACCS Accelerate Slot Time
323  * (0: Normal mode, 1: Reserved)
324  */
325 #define ETH_EPCR_PM ETH__BIT(0)
326 #define ETH_EPCR_RBM ETH__BIT(1)
327 #define ETH_EPCR_PBF ETH__BIT(2)
328 #define ETH_EPCR_EN ETH__BIT(7)
329 #define ETH_EPCR_LPBK_GET(v) ETH__BIT(v, 8, 2)
330 #define ETH_EPCR_LPBK_Normal 0
331 #define ETH_EPCR_LPBK_Internal 1
332 #define ETH_EPCR_LPBK_External 2
333 #define ETH_EPCR_FC ETH__BIT(10)
334
335 #define ETH_EPCR_HS ETH__BIT(12)
336 #define ETH_EPCR_HS_8K 0
337 #define ETH_EPCR_HS_512 ETH_EPCR_HS
338
339 #define ETH_EPCR_HM ETH__BIT(13)
340 #define ETH_EPCR_HM_0 0
341 #define ETH_EPCR_HM_1 ETH_EPCR_HM
342
343 #define ETH_EPCR_HDM ETH__BIT(14)
344 #define ETH_EPCR_HDM_Discard 0
345 #define ETH_EPCR_HDM_Pass ETH_EPCR_HDM
346
347 #define ETH_EPCR_HD_Half 0
348 #define ETH_EPCR_HD_Full ETH_EPCR_HD_Full
349
350 #define ETH_EPCR_ACCS ETH__BIT(31)
351
352
353
354 /*
355  * Table 598: Port Configuration Extend Register (PCXR)
356  * 00:00 IGMP IGMP Packets Capture Enable
357  * 0: IGMP packets are treated as normal Multicast
358  * packets.
359  * 1: IGMP packets on IPv4/Ipv6 over Ethernet/802.3
360  * are trapped and sent to high priority RX
361  * queue.
362  * 01:01 SPAN Spanning Tree Packets Capture Enable
363  * 0: BPDU (Bridge Protocol Data Unit) packets are
364  * treated as normal Multicast packets.
365  * 1: BPDU packets are trapped and sent to high
366  * priority RX queue.
367  * 02:02 PAR Partition Enable (0: Normal, 1: Partition)
368  * When more than 61 collisions occur while
369  * transmitting, the port enters Partition mode.
370  * It waits for the first good packet from the
371  * wire and then goes back to Normal mode. Under
372  * Partition mode it continues transmitting, but
373  * it does not receive.
374  * 05:03 PRIOtx Priority weight in the round-robin between high
375  * and low priority TX queues.
376  * 000: 1 pkt from HIGH, 1 pkt from LOW.
377  * 001: 2 pkt from HIGH, 1 pkt from LOW.
378  * 010: 4 pkt from HIGH, 1 pkt from LOW.
379  * 011: 6 pkt from HIGH, 1 pkt from LOW.
380  * 100: 8 pkt from HIGH, 1 pkt from LOW.
381  * 101: 10 pkt from HIGH, 1 pkt from LOW.
382  * 110: 12 pkt from HIGH, 1 pkt from LOW.
383  * 111: All pkt from HIGH, 0 pkt from LOW. LOW is
384  * served only if HIGH is empty.
385  * NOTE: If the HIGH queue is emptied before
386  * finishing the count, the count is reset
387  * until the next first HIGH comes in.
388  * 07:06 PRIOrx Default Priority for Packets Received on this
389  * Port (00: Lowest priority, 11: Highest priority)
390  * 08:08 PRIOrx_Override Override Priority for Packets Received on this
391  * Port (0: Do not override, 1: Override with
392  * <PRIOrx> field)
393  * 09:09 DPLXen Enable Auto-negotiation for Duplex Mode
394  * (0: Enable, 1: Disable)
395  * 11:10 FCTLen Enable Auto-negotiation for 802.3x Flow-control
396  * 0: Enable; When enabled, 1 is written (through
397  * SMI access) to the PHY's register 4 bit 10
398  * to advertise flow-control capability.
399  * 1: Disable; Only enables flow control after the
400  * PHY address is set by the CPU. When changing
401  * the PHY address the flow control
402  * auto-negotiation must be disabled.
403  * 11:11 FLP Force Link Pass
404  * (0: Force Link Pass, 1: Do NOT Force Link pass)
405  * 12:12 FCTL 802.3x Flow-Control Mode (0: Enable, 1: Disable)
406  * NOTE: Only valid when auto negotiation for flow
407  * control is disabled.
408  * 13:13 Reserved
409  * 15:14 MFL Max Frame Length
410  * Maximum packet allowed for reception (including
411  * CRC): 00: 1518 bytes, 01: 1536 bytes,
412  * 10: 2048 bytes, 11: 64K bytes
413  * 16:16 MIBclrMode MIB Counters Clear Mode (0: Clear, 1: No effect)
414  * 17:17 MIBctrMode Reserved. (MBZ)
415  * 18:18 Speed Port Speed (0: 10Mbit/Sec, 1: 100Mbit/Sec)
416  * NOTE: Only valid if SpeedEn bit is set.
417  * 19:19 SpeedEn Enable Auto-negotiation for Speed
418  * (0: Enable, 1: Disable)
419  * 20:20 RMIIen RMII enable
420  * 0: Port functions as MII port
421  * 1: Port functions as RMII port
422  * 21:21 DSCPen DSCP enable
423  * 0: IP DSCP field decoding is disabled.
424  * 1: IP DSCP field decoding is enabled.
425  * 31:22 Reserved
426  */
427 #define ETH_EPCXR_IGMP ETH__BIT(0)
428 #define ETH_EPCXR_SPAN ETH__BIT(1)
429 #define ETH_EPCXR_PAR ETH__BIT(2)
430 #define ETH_EPCXR_PRIOtx_GET(v) ETH__EXT(v, 3, 3)
431 #define ETH_EPCXR_PRIOrx_GET(v) ETH__EXT(v, 3, 3)
432 #define ETH_EPCXR_PRIOrx_Override ETH__BIT(8)
433 #define ETH_EPCXR_DLPXen ETH__BIT(9)
434 #define ETH_EPCXR_FCTLen ETH__BIT(10)
435 #define ETH_EPCXR_FLP ETH__BIT(11)
436 #define ETH_EPCXR_FCTL ETH__BIT(12)
437 #define ETH_EPCXR_MFL_GET(v) ETH__EXT(v, 14, 2)
438 #define ETH_EPCXR_MFL_1518 0
439 #define ETH_EPCXR_MFL_1536 1
440 #define ETH_EPCXR_MFL_2048 2
441 #define ETH_EPCXR_MFL_64K 3
442 #define ETH_EPCXR_MIBclrMode ETH__BIT(16)
443 #define ETH_EPCXR_MIBctrMode ETH__BIT(17)
444 #define ETH_EPCXR_Speed ETH__BIT(18)
445 #define ETH_EPCXR_SpeedEn ETH__BIT(19)
446 #define ETH_EPCXR_RMIIEn ETH__BIT(20)
447 #define ETH_EPCXR_DSCPEn ETH__BIT(21)
448
449
450
451 /*
452  * Table 599: Port Command Register (PCMR)
453  * 14:00 Reserved
454  * 15:15 FJ Force Jam / Flow Control
455  * When in half-duplex mode, the CPU uses this bit
456  * to force collisions on the Ethernet segment.
457  * When the CPU recognizes that it is going to run
458  * out of receive buffers, it can force the
459  * transmitter to send jam frames, forcing
460  * collisions on the wire. To allow transmission
461  * on the Ethernet segment, the CPU must clear the
462  * FJ bit when more resources are available. When
463  * in full-duplex and flow-control is enabled, this
464  * bit causes the port's transmitter to send
465  * flow-control PAUSE packets. The CPU must reset
466  * this bit when more resources are available.
467  * 31:16 Reserved
468  */
469
470 #define ETH_EPCMR_FJ ETH__BIT(15)
471
472
473 /*
474  * Table 600: Port Status Register (PSR) -- Read Only
475  * 00:00 Speed Indicates Port Speed (0: 10Mbs, 1: 100Mbs)
476  * 01:01 Duplex Indicates Port Duplex Mode (0: Half, 1: Full)
477  * 02:02 Fctl Indicates Flow-control Mode
478  * (0: enabled, 1: disabled)
479  * 03:03 Link Indicates Link Status (0: down, 1: up)
480  * 04:04 Pause Indicates that the port is in flow-control
481  * disabled state. This bit is set when an IEEE
482  * 802.3x flow-control PAUSE (XOFF) packet is
483  * received (assuming that flow-control is
484  * enabled and the port is in full-duplex mode).
485  * Reset when XON is received, or when the XOFF
486  * timer has expired.
487  * 05:05 TxLow Tx Low Priority Status
488  * Indicates the status of the low priority
489  * transmit queue: (0: Stopped, 1: Running)
490  * 06:06 TxHigh Tx High Priority Status
491  * Indicates the status of the high priority
492  * transmit queue: (0: Stopped, 1: Running)
493  * 07:07 TXinProg TX in Progress
494  * Indicates that the port's transmitter is in an
495  * active transmission state.
496  * 31:08 Reserved
497  */
498 #define ETH_EPSR_Speed ETH__BIT(0)
499 #define ETH_EPSR_Duplex ETH__BIT(1)
500 #define ETH_EPSR_Fctl ETH__BIT(2)
501 #define ETH_EPSR_Link ETH__BIT(3)
502 #define ETH_EPSR_Pause ETH__BIT(4)
503 #define ETH_EPSR_TxLow ETH__BIT(5)
504 #define ETH_EPSR_TxHigh ETH__BIT(6)
505 #define ETH_EPSR_TXinProg ETH__BIT(7)
506
507
508 /*
509  * Table 601: Serial Parameters Register (SPR)
510  * 01:00 JAM_LENGTH Two bits to determine the JAM Length
511  * (in Backpressure) as follows:
512  * 00 = 12K bit-times
513  * 01 = 24K bit-times
514  * 10 = 32K bit-times
515  * 11 = 48K bit-times
516  * 06:02 JAM_IPG Five bits to determine the JAM IPG.
517  * The step is four bit-times. The value may vary
518  * between 4 bit time to 124.
519  * 11:07 IPG_JAM_TO_DATA Five bits to determine the IPG JAM to DATA.
520  * The step is four bit-times. The value may vary
521  * between 4 bit time to 124.
522  * 16:12 IPG_DATA Inter-Packet Gap (IPG)
523  * The step is four bit-times. The value may vary
524  * between 12 bit time to 124.
525  * NOTE: These bits may be changed only when the
526  * Ethernet ports is disabled.
527  * 21:17 Data_Blind Data Blinder
528  * The number of nibbles from the beginning of the
529  * IPG, in which the IPG counter is restarted when
530  * detecting a carrier activity. Following this
531  * value, the port enters the Data Blinder zone and
532  * does not reset the IPG counter. This ensures
533  * fair access to the medium.
534  * The default is 10 hex (64 bit times - 2/3 of the
535  * default IPG). The step is 4 bit-times. Valid
536  * range is 3 to 1F hex nibbles.
537  * NOTE: These bits may be only changed when the
538  * Ethernet port is disabled.
539  * 22:22 Limit4 The number of consecutive packet collisions that
540  * occur before the collision counter is reset.
541  * 0: The port resets its collision counter after
542  * 16 consecutive retransmit trials and
543  * restarts the Backoff algorithm.
544  * 1: The port resets its collision counter and
545  * restarts the Backoff algorithm after 4
546  * consecutive transmit trials.
547  * 31:23 Reserved
548  */
549 #define ETH_ESPR_JAM_LENGTH_GET(v) ETH__EXT(v, 0, 2)
550 #define ETH_ESPR_JAM_IPG_GET(v) ETH__EXT(v, 2, 5)
551 #define ETH_ESPR_IPG_JAM_TO_DATA_GET(v) ETH__EXT(v, 7, 5)
552 #define ETH_ESPR_IPG_DATA_GET(v) ETH__EXT(v, 12, 5)
553 #define ETH_ESPR_Data_Bilnd_GET(v) ETH__EXT(v, 17, 5)
554 #define ETH_ESPR_Limit4(v) ETH__BIT(22)
555
556 /*
557  * Table 602: Hash Table Pointer Register (HTPR)
558  * 31:00 HTP 32-bit pointer to the address table.
559  * Bits [2:0] must be set to zero.
560  */
561
562 /*
563  * Table 603: Flow Control Source Address Low (FCSAL)
564  * 15:0 SA[15:0] Source Address
565  * The least significant bits of the source
566  * address for the port. This address is used for
567  * Flow Control.
568  * 31:16 Reserved
569  */
570
571 /*
572  * Table 604: Flow Control Source Address High (FCSAH)
573  * 31:0 SA[47:16] Source Address
574  * The most significant bits of the source address
575  * for the port. This address is used for Flow
576  * Control.
577  */
578
579
580 /*
581  * Table 605: SDMA Configuration Register (SDCR)
582  * 01:00 Reserved
583  * 05:02 RC Retransmit Count
584  * Sets the maximum number of retransmits per
585  * packet. After executing retransmit for RC
586  * times, the TX SDMA closes the descriptor with a
587  * Retransmit Limit error indication and processes
588  * the next packet. When RC is set to 0, the
589  * number of retransmits is unlimited. In this
590  * case, the retransmit process is only terminated
591  * if CPU issues an Abort command.
592  * 06:06 BLMR Big/Little Endian Receive Mode
593  * The DMA supports Big or Little Endian
594  * configurations on a per channel basis. The BLMR
595  * bit only affects data transfer to memory.
596  * 0: Big Endian
597  * 1: Little Endian
598  * 07:07 BLMT Big/Little Endian Transmit Mode
599  * The DMA supports Big or Little Endian
600  * configurations on a per channel basis. The BLMT
601  * bit only affects data transfer from memory.
602  * 0: Big Endian
603  * 1: Little Endian
604  * 08:08 POVR PCI Override
605  * When set, causes the SDMA to direct all its
606  * accesses in PCI_0 direction and overrides
607  * normal address decoding process.
608  * 09:09 RIFB Receive Interrupt on Frame Boundaries
609  * When set, the SDMA Rx generates interrupts only
610  * on frame boundaries (i.e. after writing the
611  * frame status to the descriptor).
612  * 11:10 Reserved
613  * 13:12 BSZ Burst Size
614  * Sets the maximum burst size for SDMA
615  * transactions:
616  * 00: Burst is limited to 1 64bit words.
617  * 01: Burst is limited to 2 64bit words.
618  * 10: Burst is limited to 4 64bit words.
619  * 11: Burst is limited to 8 64bit words.
620  * 31:14 Reserved
621  */
622 #define ETH_ESDCR_RC_GET(v) ETH__EXT(v, 2, 4)
623 #define ETH_ESDCR_BLMR ETH__BIT(6)
624 #define ETH_ESDCR_BLMT ETH__BIT(7)
625 #define ETH_ESDCR_POVR ETH__BIT(8)
626 #define ETH_ESDCR_RIFB ETH__BIT(9)
627 #define ETH_ESDCR_BSZ_GET(v) ETH__EXT(v, 12, 2)
628 #define ETH_ESDCR_BSZ_SET(v, n) (ETH__CLR(v, 12, 2),\
629  (v) |= ETH__INS(n, 12))
630 #define ETH_ESDCR_BSZ_1 0
631 #define ETH_ESDCR_BSZ_2 1
632 #define ETH_ESDCR_BSZ_4 2
633 #define ETH_ESDCR_BSZ_8 3
634
635 #define ETH_ESDCR_BSZ_Strings { "1 64-bit word", "2 64-bit words", \
636  "4 64-bit words", "8 64-bit words" }
637
638 /*
639  * Table 606: SDMA Command Register (SDCMR)
640  * 06:00 Reserved
641  * 07:07 ERD Enable RX DMA.
642  * Set to 1 by the CPU to cause the SDMA to start
643  * a receive process. Cleared when the CPU issues
644  * an Abort Receive command.
645  * 14:08 Reserved
646  * 15:15 AR Abort Receive
647  * Set to 1 by the CPU to abort a receive SDMA
648  * operation. When the AR bit is set, the SDMA
649  * aborts its current operation and moves to IDLE.
650  * No descriptor is closed. The AR bit is cleared
651  * upon entering IDLE. After setting the AR bit,
652  * the CPU must poll the bit to verify that the
653  * abort sequence is completed.
654  * 16:16 STDH Stop TX High
655  * Set to 1 by the CPU to stop the transmission
656  * process from the high priority queue at the end
657  * of the current frame. An interrupt is generated
658  * when the stop command has been executed.
659  * Writing 1 to STDH resets TXDH bit.
660  * Writing 0 to this bit has no effect.
661  * 17:17 STDL Stop TX Low
662  * Set to 1 by the CPU to stop the transmission
663  * process from the low priority queue at the end
664  * of the current frame. An interrupt is generated
665  * when the stop command has been executed.
666  * Writing 1 to STDL resets TXDL bit.
667  * Writing 0 to this bit has no effect.
668  * 22:18 Reserved
669  * 23:23 TXDH Start Tx High
670  * Set to 1 by the CPU to cause the SDMA to fetch
671  * the first descriptor and start a transmit
672  * process from the high priority Tx queue.
673  * Writing 1 to TXDH resets STDH bit.
674  * Writing 0 to this bit has no effect.
675  * 24:24 TXDL Start Tx Low
676  * Set to 1 by the CPU to cause the SDMA to fetch
677  * the first descriptor and start a transmit
678  * process from the low priority Tx queue.
679  * Writing 1 to TXDL resets STDL bit.
680  * Writing 0 to this bit has no effect.
681  * 30:25 Reserved
682  * 31:31 AT Abort Transmit
683  * Set to 1 by the CPU to abort a transmit DMA
684  * operation. When the AT bit is set, the SDMA
685  * aborts its current operation and moves to IDLE.
686  * No descriptor is closed. Cleared upon entering
687  * IDLE. After setting AT bit, the CPU must poll
688  * it in order to verify that the abort sequence
689  * is completed.
690  */
691 #define ETH_ESDCMR_ERD ETH__BIT(7)
692 #define ETH_ESDCMR_AR ETH__BIT(15)
693 #define ETH_ESDCMR_STDH ETH__BIT(16)
694 #define ETH_ESDCMR_STDL ETH__BIT(17)
695 #define ETH_ESDCMR_TXDH ETH__BIT(23)
696 #define ETH_ESDCMR_TXDL ETH__BIT(24)
697 #define ETH_ESDCMR_AT ETH__BIT(31)
698
699 /*
700  * Table 607: Interrupt Cause Register (ICR)
701  * 00:00 RxBuffer Rx Buffer Return
702  * Indicates an Rx buffer returned to CPU ownership
703  * or that the port finished reception of a Rx
704  * frame in either priority queues.
705  * NOTE: In order to get a Rx Buffer return per
706  * priority queue, use bit 19:16. This bit is
707  * set upon closing any Rx descriptor which
708  * has its EI bit set. To limit the
709  * interrupts to frame (rather than buffer)
710  * boundaries, the user must set SDMA
711  * Configuration register's RIFB bit. When
712  * the RIFB bit is set, an interrupt
713  * generates only upon closing the first
714  * descriptor of a received packet, if this
715  * descriptor has it EI bit set.
716  * 01:01 Reserved
717  * 02:02 TxBufferHigh Tx Buffer for High priority Queue
718  * Indicates a Tx buffer returned to CPU ownership
719  * or that the port finished transmission of a Tx
720  * frame.
721  * NOTE: This bit is set upon closing any Tx
722  * descriptor which has its EI bit set. To
723  * limit the interrupts to frame (rather than
724  * buffer) boundaries, the user must set EI
725  * only in the last descriptor.
726  * 03:03 TxBufferLow Tx Buffer for Low Priority Queue
727  * Indicates a Tx buffer returned to CPU ownership
728  * or that the port finished transmission of a Tx
729  * frame.
730  * NOTE: This bit is set upon closing any Tx
731  * descriptor which has its EI bit set. To
732  * limit the interrupts to frame (rather than
733  * buffer) boundaries, the user must set EI
734  * only in the last descriptor.
735  * 05:04 Reserved
736  * 06:06 TxEndHigh Tx End for High Priority Queue
737  * Indicates that the Tx DMA stopped processing the
738  * high priority queue after stop command, or that
739  * it reached the end of the high priority
740  * descriptor chain.
741  * 07:07 TxEndLow Tx End for Low Priority Queue
742  * Indicates that the Tx DMA stopped processing the
743  * low priority queue after stop command, or that
744  * it reached the end of the low priority
745  * descriptor chain.
746  * 08:08 RxError Rx Resource Error
747  * Indicates a Rx resource error event in one of
748  * the priority queues.
749  * NOTE: To get a Rx Resource Error Indication per
750  * priority queue, use bit 23:20.
751  * 09:09 Reserved
752  * 10:10 TxErrorHigh Tx Resource Error for High Priority Queue
753  * Indicates a Tx resource error event during
754  * packet transmission from the high priority queue
755  * 11:11 TxErrorLow Tx Resource Error for Low Priority Queue
756  * Indicates a Tx resource error event during
757  * packet transmission from the low priority queue
758  * 12:12 RxOVR Rx Overrun
759  * Indicates an overrun event that occurred during
760  * reception of a packet.
761  * 13:13 TxUdr Tx Underrun
762  * Indicates an underrun event that occurred during
763  * transmission of packet from either queue.
764  * 15:14 Reserved
765  * 16:16 RxBuffer-Queue[0] Rx Buffer Return in Priority Queue[0]
766  * Indicates a Rx buffer returned to CPU ownership
767  * or that the port completed reception of a Rx
768  * frame in a receive priority queue[0]
769  * 17:17 RxBuffer-Queue[1] Rx Buffer Return in Priority Queue[1]
770  * Indicates a Rx buffer returned to CPU ownership
771  * or that the port completed reception of a Rx
772  * frame in a receive priority queue[1].
773  * 18:18 RxBuffer-Queue[2] Rx Buffer Return in Priority Queue[2]
774  * Indicates a Rx buffer returned to CPU ownership
775  * or that the port completed reception of a Rx
776  * frame in a receive priority queue[2].
777  * 19:19 RxBuffer-Queue[3] Rx Buffer Return in Priority Queue[3]
778  * Indicates a Rx buffer returned to CPU ownership
779  * or that the port completed reception of a Rx
780  * frame in a receive priority queue[3].
781  * 20:20 RxError-Queue[0] Rx Resource Error in Priority Queue[0]
782  * Indicates a Rx resource error event in receive
783  * priority queue[0].
784  * 21:21 RxError-Queue[1] Rx Resource Error in Priority Queue[1]
785  * Indicates a Rx resource error event in receive
786  * priority queue[1].
787  * 22:22 RxError-Queue[2] Rx Resource Error in Priority Queue[2]
788  * Indicates a Rx resource error event in receive
789  * priority queue[2].
790  * 23:23 RxError-Queue[3] Rx Resource Error in Priority Queue[3]
791  * Indicates a Rx resource error event in receive
792  * priority queue[3].
793  * 27:24 Reserved
794  * 28:29 MIIPhySTC MII PHY Status Change
795  * Indicates a status change reported by the PHY
796  * connected to this port. Set when the MII
797  * management interface block identifies a change
798  * in PHY's register 1.
799  * 29:29 SMIdone SMI Command Done
800  * Indicates that the SMI completed a MII
801  * management command (either read or write) that
802  * was initiated by the CPU writing to the SMI
803  * register.
804  * 30:30 Reserved
805  * 31:31 EtherIntSum Ethernet Interrupt Summary
806  * This bit is a logical OR of the (unmasked) bits
807  * [30:04] in the Interrupt Cause register.
808  */
809
810 #define ETH_IR_RxBuffer ETH__BIT(0)
811 #define ETH_IR_TxBufferHigh ETH__BIT(2)
812 #define ETH_IR_TxBufferLow ETH__BIT(3)
813 #define ETH_IR_TxEndHigh ETH__BIT(6)
814 #define ETH_IR_TxEndLow ETH__BIT(7)
815 #define ETH_IR_RxError ETH__BIT(8)
816 #define ETH_IR_TxErrorHigh ETH__BIT(10)
817 #define ETH_IR_TxErrorLow ETH__BIT(11)
818 #define ETH_IR_RxOVR ETH__BIT(12)
819 #define ETH_IR_TxUdr ETH__BIT(13)
820 #define ETH_IR_RxBuffer_0 ETH__BIT(16)
821 #define ETH_IR_RxBuffer_1 ETH__BIT(17)
822 #define ETH_IR_RxBuffer_2 ETH__BIT(18)
823 #define ETH_IR_RxBuffer_3 ETH__BIT(19)
824 #define ETH_IR_RxBuffer_GET(v) ETH__EXT(v, 16, 4)
825 #define ETH_IR_RxError_0 ETH__BIT(20)
826 #define ETH_IR_RxError_1 ETH__BIT(21)
827 #define ETH_IR_RxError_2 ETH__BIT(22)
828 #define ETH_IR_RxError_3 ETH__BIT(23)
829 #define ETH_IR_RxError_GET(v) ETH__EXT(v, 20, 4)
830 #define ETH_IR_RxBits (ETH_IR_RxBuffer_0|\
831  ETH_IR_RxBuffer_1|\
832  ETH_IR_RxBuffer_2|\
833  ETH_IR_RxBuffer_3|\
834  ETH_IR_RxError_0|\
835  ETH_IR_RxError_1|\
836  ETH_IR_RxError_2|\
837  ETH_IR_RxError_3)
838 #define ETH_IR_MIIPhySTC ETH__BIT(28)
839 #define ETH_IR_SMIdone ETH__BIT(29)
840 #define ETH_IR_EtherIntSum (1<<31)
841 #define ETH_IR_Summary (1<<31)
842 #define ETH_IR_ErrorSum 0x803d00
843 #define INTR_RX_ERROR 0x801100
844 #define INTR_TX_ERROR 0x002c00
845
846 /*
847  * Table 608: Interrupt Mask Register (IMR)
848  * 31:00 Various Mask bits for the Interrupt Cause register.
849  */
850
851 /*
852  * Table 609: IP Differentiated Services CodePoint to Priority0 low (DSCP2P0L),
853  * 31:00 Priority0_low The LSB priority bits for DSCP[31:0] entries.
854  */
855
856 /*
857  * Table 610: IP Differentiated Services CodePoint to Priority0 high (DSCP2P0H)
858  * 31:00 Priority0_high The LSB priority bits for DSCP[63:32] entries.
859  */
860
861 /*
862  * Table 611: IP Differentiated Services CodePoint to Priority1 low (DSCP2P1L)
863  * 31:00 Priority1_low The MSB priority bits for DSCP[31:0] entries.
864  */
865
866 /*
867  * Table 612: IP Differentiated Services CodePoint to Priority1 high (DSCP2P1H)
868  * 31:00 Priority1_high The MSB priority bit for DSCP[63:32] entries.
869  */
870
871 /*
872  * Table 613: VLAN Priority Tag to Priority (VPT2P)
873  * 07:00 Priority0 The LSB priority bits for VLAN Priority[7:0]
874  * entries.
875  * 15:08 Priority1 The MSB priority bits for VLAN Priority[7:0]
876  * entries.
877  * 31:16 Reserved
878  */
879 #endif /* _DEV_GTETHREG_H_ */
Definition: GT64260ethreg.h:61
