18. IDE Controller Driver¶
Warning
The ATA/IDE Drivers are out of date and should not be used for new BSPs. The preferred alternative is to port the ATA/SATA/SCSI/NVMe support from FreeBSD to RTEMS using the libbsd. Ask on the mailing list if you plan to write a driver for an ATA/IDE device.
18.1. Introduction¶
The IDE Controller driver is responsible for providing an interface to an IDE Controller. The capabilities provided by this driver are:
- Read IDE Controller register
- Write IDE Controller register
- Read data block through IDE Controller Data Register
- Write data block through IDE Controller Data Register
The reference implementation for an IDE Controller driver can be found in
bsps/shared/dev/ide. This driver is based on the libchip
concept and allows to work with any of the IDE Controller chips simply by
appropriate configuration of BSP. Drivers for a particular IDE Controller chips
locate in the following directories: drivers for well-known IDE Controller
chips locate into bsps/shared/dev/ide
and drivers for custom IDE
Controller chips (for example, implemented on FPGA) locate into
bsps/${RTEMS_CPU}/${RTEMS_BSP/ata. There is a README file in these
directories for each supported IDE Controller chip. Each of these README
explains how to configure a BSP for that particular IDE Controller chip.
18.2. Initialization¶
IDE Controller chips used by a BSP are statically configured into
IDE_Controller_Table. The ide_controller_initialize routine is
responsible for initialization of all configured IDE controller chips.
Initialization order of the chips based on the order the chips are defined in
the IDE_Controller_Table.
The following actions are performed by the IDE Controller driver initialization routine:
rtems_device_driver ide_controller_initialize(
rtems_device_major_number major,
rtems_device_minor_number minor_arg,
void *arg
for each IDE Controller chip configured in IDE_Controller_Table
if (BSP dependent probe(if exists) AND device probe for this IDE chip
indicates it is present)
perform initialization of the particular chip
register device with configured name for this chip
18.3. Read IDE Controller Register¶
The ide_controller_read_register routine reads the content of the IDE
Controller chip register. IDE Controller chip is selected via the minor
number. This routine is not allowed to be called from an application.
void ide_controller_read_register(
rtems_device_minor_number minor,
unsigned32 reg,
unsigned32 *value
get IDE Controller chip configuration information from
IDE_Controller_Table by minor number
invoke read register routine for the chip
18.4. Write IDE Controller Register¶
The ide_controller_write_register routine writes IDE Controller chip
register with specified value. IDE Controller chip is selected via the minor
void ide_controller_write_register(
unsigned32 reg,
unsigned32 value
invoke write register routine for the chip
18.5. Read Data Block Through IDE Controller Data Register¶
The ide_controller_read_data_block provides multiple consequent read of the
IDE Controller Data Register. IDE Controller chip is selected via the minor
number. The same functionality may be achieved via separate multiple calls of
ide_controller_read_register routine but ide_controller_read_data_block
allows to escape functions call overhead. This routine is not allowed to be
void ide_controller_read_data_block(
unsigned16 block_size,
blkdev_sg_buffer *bufs,
uint32_t *cbuf,
uint32_t *pos
invoke read data block routine for the chip
18.6. Write Data Block Through IDE Controller Data Register¶
The ide_controller_write_data_block provides multiple consequent write into
the IDE Controller Data Register. IDE Controller chip is selected via the minor
ide_controller_write_register routine but
ide_controller_write_data_block allows to escape functions call
overhead. This routine is not allowed to be called from an application.
void ide_controller_write_data_block(
uint32_t *cbuf,
uint32_t *pos
invoke write data block routine for the chip
