13. Frame Buffer Driver
In this chapter, we present the basic functionality implemented by a frame buffer driver:
  • frame_buffer_initialize()
  • frame_buffer_open()
  • frame_buffer_close()
  • frame_buffer_read()
  • frame_buffer_write()
  • frame_buffer_control()
13.1. Introduction
The purpose of the frame buffer driver is to provide an abstraction for graphics hardware. By using the frame buffer interface, an application can display graphics without knowing anything about the low-level details of interfacing to a particular graphics adapter. The parameters governing the mapping of memory to displayed pixels (planar or linear, bit depth, etc) is still implementation-specific, but device-independent methods are provided to determine and potentially modify these parameters.
The frame buffer driver is commonly located in the console directory of the BSP and registered by the name /dev/fb0. Additional frame buffers (if available) are named /dev/fb1*,*/dev/fb2, etc.
To work with the frame buffer, the following operation sequence is used:open(), ioctls() to get the frame buffer info, read() and/or write(), and close().
13.2. Driver Function Overview
13.2.1. Initialization
The driver initialization is called once during the RTEMS initialization process and returns RTEMS_SUCCESSFUL when the device driver is successfully initialized. During the initialization, a name is assigned to the frame buffer device. If the graphics hardware supports console text output, as is the case with the pc386 VGA hardware, initialization into graphics mode may be deferred until the device is open() ed.
The frame_buffer_initialize() function may look like this:
rtems_device_driver frame_buffer_initialize(
  rtems_device_major_number  major,
  rtems_device_minor_number  minor,
  void                      *arg)
  rtems_status_code status;
  printk( "frame buffer driver initializing..\n" );
   * Register the device
  status = rtems_io_register_name("/dev/fb0", major, 0);
  if (status != RTEMS_SUCCESSFUL)
    printk("Error registering frame buffer device!\n");
    rtems_fatal_error_occurred( status );
   * graphics hardware initialization goes here for non-console
   * devices
  return RTEMS_SUCCESSFUL;
13.2.2. Opening the Frame Buffer Device
The frame_buffer_open() function is called whenever a frame buffer device is opened. If the frame buffer is registered as /dev/fb0, the frame_buffer_open entry point will be called as the result of an open("/dev/fb0", mode) in the application.
Thread safety of the frame buffer driver is implementation-dependent. The VGA driver shown below uses a mutex to prevent multiple open() operations of the frame buffer device.
The frame_buffer_open() function returns RTEMS_SUCCESSFUL when the device driver is successfully opened, and RTEMS_UNSATISFIED if the device is already open:
rtems_device_driver frame_buffer_close(
  void                      *arg
  if (pthread_mutex_unlock(&mutex) == 0) {
    /* restore previous state.  for VGA this means return to text mode.
     * leave out if graphics hardware has been initialized in
     * frame_buffer_initialize()
    ega_hwterm();
    printk( "FBVGA close called.\n" );
  return RTEMS_UNSATISFIED;
In the previous example, the function ega_hwinit() takes care of hardware-specific initialization.
13.2.3. Closing the Frame Buffer Device
The frame_buffer_close() is invoked when the frame buffer device is closed. It frees up any resources allocated in frame_buffer_open(), and should restore previous hardware state. The entry point corresponds to the device driver close entry point.
Returns RTEMS_SUCCESSFUL when the device driver is successfully closed:
  void                      *arg)
  pthread_mutex_unlock(&mutex);
  /* TODO check mutex return value, RTEMS_UNSATISFIED if it failed.  we
   * don't want to unconditionally call ega_hwterm()... */
   * frame_buffer_initialize() */
  ega_hwterm();
  printk( "frame buffer close called.\n" );
13.2.4. Reading from the Frame Buffer Device
The frame_buffer_read() is invoked from a read() operation on the frame buffer device. Read functions should allow normal and partial reading at the end of frame buffer memory. This method returns RTEMS_SUCCESSFUL when the device is successfully read from:
rtems_device_driver frame_buffer_read(
  void                      *arg
  rtems_libio_rw_args_t *rw_args = (rtems_libio_rw_args_t *)arg;
  rw_args->bytes_moved = ((rw_args->offset + rw_args->count) > fb_fix.smem_len ) ?
                           (fb_fix.smem_len - rw_args->offset) : rw_args->count;
  memcpy(rw_args->buffer,
         (const void *) (fb_fix.smem_start + rw_args->offset),
         rw_args->bytes_moved);
13.2.5. Writing to the Frame Buffer Device
The frame_buffer_write() is invoked from a write() operation on the frame buffer device. The frame buffer write function is similar to the read function, and should handle similar cases involving partial writes.
This method returns RTEMS_SUCCESSFUL when the device is successfully written to:
rtems_device_driver frame_buffer_write(
  void                      *arg
  memcpy((void *) (fb_fix.smem_start + rw_args->offset),
         rw_args->buffer,
13.2.6. Frame Buffer IO Control
The frame buffer driver allows several ioctls, partially compatible with the Linux kernel, to obtain information about the hardware.
All ioctl() operations on the frame buffer device invoke frame_buffer_control().
Ioctls supported:
  • ioctls to get the frame buffer screen info (fixed and variable).
  • ioctl to set and get palette.
rtems_device_driver frame_buffer_control(
  void                      *arg
  rtems_libio_ioctl_args_t *args = arg;
  printk( "FBVGA ioctl called, cmd=%x\n", args->command  );
  switch( args->command ) {
    case FBIOGET_FSCREENINFO:
      args->ioctl_return =  get_fix_screen_info( ( struct fb_fix_screeninfo * ) args->buffer );
      break;
    case FBIOGET_VSCREENINFO:
      args->ioctl_return =  get_var_screen_info( ( struct fb_var_screeninfo * ) args->buffer );
      break;
    case FBIOPUT_VSCREENINFO:
      /* not implemented yet*/
      args->ioctl_return = -1;
    case FBIOGETCMAP:
      args->ioctl_return =  get_palette( ( struct fb_cmap * ) args->buffer );
      break;
    case FBIOPUTCMAP:
      args->ioctl_return =  set_palette( ( struct fb_cmap * ) args->buffer );
      break;
    default:
      args->ioctl_return = 0;
      break;
See rtems/fb.h for more information on the list of ioctls and data structures they work with.
