11. Real-Time Clock Driver¶
11.1. Introduction¶
The Real-Time Clock (RTC) driver is responsible for providing an interface to an RTC device. The capabilities provided by this driver are:
- Set the RTC TOD to RTEMS TOD
- Set the RTEMS TOD to the RTC TOD
- Get the RTC TOD
- Set the RTC TOD to the Specified TOD
- Get the Difference Between the RTEMS and RTC TOD
Note
In this chapter, the abbreviation TOD is used for Time of Day.
The reference implementation for a real-time clock driver can be found in bsps/shared/dev/rtc/rtc-support.c. This driver is based on the libchip concept and can be easily configured to work with any of the RTC chips supported by the RTC chip drivers in the directory bsps/shared/dev/rtc. There is a README file in this directory for each supported RTC chip. Each of these README explains how to configure the shared libchip implementation of the RTC driver for that particular RTC chip.
The DY-4 DMV177 BSP used the shared libchip implementation of the RTC driver.
There were no DMV177 specific configuration routines. A BSP could use
configuration routines to dynamically determine what type of real-time clock is
on a particular board. This would be useful for a BSP supporting multiple
board models. The relevant ports of the DMV177’s RTC_Table
configuration
table is below:
#include <bsp.h>
#include <libchip/rtc.h>
#include <libchip/icm7170.h>
bool dmv177_icm7170_probe(int minor);
rtc_tbl RTC_Table[] = {
{ "/dev/rtc0", /* sDeviceName */
RTC_ICM7170, /* deviceType */
&icm7170_fns, /* pDeviceFns */
dmv177_icm7170_probe, /* deviceProbe */
(void *) ICM7170_AT_1_MHZ, /* pDeviceParams */
DMV170_RTC_ADDRESS, /* ulCtrlPort1 */
0, /* ulDataPort */
icm7170_get_register_8, /* getRegister */
icm7170_set_register_8, /* setRegister */
unsigned long RTC_Count = (sizeof(RTC_Table)/sizeof(rtc_tbl));
rtems_device_minor_number RTC_Minor;
volatile unsigned16 *card_resource_reg;
card_resource_reg = (volatile unsigned16 *) DMV170_CARD_RESORCE_REG;
if ( (*card_resource_reg & DMV170_RTC_INST_MASK) == DMV170_RTC_INSTALLED )
return TRUE;
return FALSE;
11.2. Initialization¶
The rtc_initialize
routine is responsible for initializing the RTC chip so
it can be used. The shared libchip implementation of this driver supports
multiple RTCs and bases its initialization order on the order the chips are
defined in the RTC_Table
. Each chip defined in the table may or may not be
present on this particular board. It is the responsibility of the
deviceProbe
to indicate the presence of a particular RTC chip. The first
RTC found to be present is considered the preferred RTC.
In the shared libchip based implementation of the driver, the following actions are performed:
rtems_device_driver rtc_initialize(
rtems_device_major_number major,
rtems_device_minor_number minor_arg,
void *arg
for each RTC configured in RTC_Table
if the deviceProbe for this RTC indicates it is present
set RTC_Minor to this device
set RTC_Present to TRUE
break out of this loop
if RTC_Present is not TRUE
return RTEMS_INVALID_NUMBER to indicate that no RTC is present
register this minor number as the "/dev/rtc"
perform the deviceInitialize routine for the preferred RTC chip
for RTCs past this one in the RTC_Table
perform the deviceInitialize routine for this RTC chip
register the configured name for this RTC
The deviceProbe
routine returns TRUE if the device configured by this entry
in the RTC_Table
is present. This configuration scheme allows one to
support multiple versions of the same board with a single BSP. For example, if
the first generation of a board had Vendor A’s RTC chip and the second
generation had Vendor B’s RTC chip, RTC_Table could contain information for
both. The deviceProbe
configured for Vendor A’s RTC chip would need to
return TRUE if the board was a first generation one. The deviceProbe
routines are very board dependent and must be provided by the BSP.
11.3. setRealTimeToRTEMS¶
The setRealTimeToRTEMS
routine sets the current RTEMS TOD to that
of the preferred RTC.
void setRealTimeToRTEMS(void)
if no RTCs are present
return
invoke the deviceGetTime routine for the preferred RTC
set the RTEMS TOD using rtems_clock_set
11.4. setRealTimeFromRTEMS¶
The setRealTimeFromRTEMS
routine sets the preferred RTC TOD to the
current RTEMS TOD.
void setRealTimeFromRTEMS(void)
return
obtain the RTEMS TOD using rtems_clock_get
invoke the deviceSetTime routine for the preferred RTC
11.5. getRealTime¶
The getRealTime
returns the preferred RTC TOD to the caller.
void getRealTime( rtems_time_of_day *tod )
return
11.6. setRealTime¶
The setRealTime
routine sets the preferred RTC TOD to the TOD specified by
the caller.
void setRealTime( rtems_time_of_day *tod )
return
11.7. checkRealTime¶
The checkRealTime
routine returns the number of seconds difference between
the RTC TOD and the current RTEMS TOD.
int checkRealTime( void )
return -1
get the TOD from the preferred RTC using the deviceGetTime routine
convert the RTEMS TOD to seconds
convert the RTC TOD to seconds
return the RTEMS TOD in seconds - RTC TOD in seconds
