13. Frame Buffer Driver¶
In this chapter, we present the basic functionality implemented by a frame buffer driver:
frame_buffer_initialize()frame_buffer_open()frame_buffer_close()frame_buffer_read()frame_buffer_write()frame_buffer_control()
13.1. Introduction¶
The purpose of the frame buffer driver is to provide an abstraction for graphics hardware. By using the frame buffer interface, an application can display graphics without knowing anything about the low-level details of interfacing to a particular graphics adapter. The parameters governing the mapping of memory to displayed pixels (planar or linear, bit depth, etc) is still implementation-specific, but device-independent methods are provided to determine and potentially modify these parameters.
The frame buffer driver is commonly located in the console directory of the
BSP and registered by the name /dev/fb0. Additional frame buffers (if
available) are named /dev/fb1*,*/dev/fb2, etc.
To work with the frame buffer, the following operation sequence is
used:open(), ioctls() to get the frame buffer info, read()
and/or write(), and close().
13.2. Driver Function Overview¶
13.2.1. Initialization¶
The driver initialization is called once during the RTEMS initialization
process and returns RTEMS_SUCCESSFUL when the device driver is successfully
initialized. During the initialization, a name is assigned to the frame buffer
device. If the graphics hardware supports console text output, as is the case
with the pc386 VGA hardware, initialization into graphics mode may be deferred
until the device is open() ed.
The frame_buffer_initialize() function may look like this:
rtems_device_driver frame_buffer_initialize(
rtems_device_major_number major,
rtems_device_minor_number minor,
void *arg)
rtems_status_code status;
printk( "frame buffer driver initializing..\n" );
* Register the device
status = rtems_io_register_name("/dev/fb0", major, 0);
if (status != RTEMS_SUCCESSFUL)
printk("Error registering frame buffer device!\n");
rtems_fatal_error_occurred( status );
* graphics hardware initialization goes here for non-console
* devices
return RTEMS_SUCCESSFUL;
13.2.2. Opening the Frame Buffer Device¶
The frame_buffer_open() function is called whenever a frame buffer device
is opened. If the frame buffer is registered as /dev/fb0, the
frame_buffer_open entry point will be called as the result of an
open("/dev/fb0", mode) in the application.
Thread safety of the frame buffer driver is implementation-dependent. The VGA driver shown below uses a mutex to prevent multiple open() operations of the frame buffer device.
The frame_buffer_open() function returns RTEMS_SUCCESSFUL when the
device driver is successfully opened, and RTEMS_UNSATISFIED if the device
is already open:
rtems_device_driver frame_buffer_close(
void *arg
if (pthread_mutex_unlock(&mutex) == 0) {
/* restore previous state. for VGA this means return to text mode.
* leave out if graphics hardware has been initialized in
* frame_buffer_initialize()
ega_hwterm();
printk( "FBVGA close called.\n" );
return RTEMS_UNSATISFIED;
In the previous example, the function ega_hwinit() takes care of
hardware-specific initialization.
13.2.3. Closing the Frame Buffer Device¶
The frame_buffer_close() is invoked when the frame buffer device is closed.
It frees up any resources allocated in frame_buffer_open(), and should
restore previous hardware state. The entry point corresponds to the device
driver close entry point.
Returns RTEMS_SUCCESSFUL when the device driver is successfully closed:
void *arg)
pthread_mutex_unlock(&mutex);
/* TODO check mutex return value, RTEMS_UNSATISFIED if it failed. we
* don't want to unconditionally call ega_hwterm()... */
* frame_buffer_initialize() */
ega_hwterm();
printk( "frame buffer close called.\n" );
13.2.4. Reading from the Frame Buffer Device¶
The frame_buffer_read() is invoked from a read() operation on the frame
buffer device. Read functions should allow normal and partial reading at the
end of frame buffer memory. This method returns RTEMS_SUCCESSFUL when the
device is successfully read from:
rtems_device_driver frame_buffer_read(
void *arg
rtems_libio_rw_args_t *rw_args = (rtems_libio_rw_args_t *)arg;
rw_args->bytes_moved = ((rw_args->offset + rw_args->count) > fb_fix.smem_len ) ?
(fb_fix.smem_len - rw_args->offset) : rw_args->count;
memcpy(rw_args->buffer,
(const void *) (fb_fix.smem_start + rw_args->offset),
rw_args->bytes_moved);
13.2.5. Writing to the Frame Buffer Device¶
The frame_buffer_write() is invoked from a write() operation on the
frame buffer device. The frame buffer write function is similar to the read
function, and should handle similar cases involving partial writes.
This method returns RTEMS_SUCCESSFUL when the device is successfully
written to:
rtems_device_driver frame_buffer_write(
void *arg
memcpy((void *) (fb_fix.smem_start + rw_args->offset),
rw_args->buffer,
13.2.6. Frame Buffer IO Control¶
The frame buffer driver allows several ioctls, partially compatible with the Linux kernel, to obtain information about the hardware.
All ioctl() operations on the frame buffer device invoke
frame_buffer_control().
Ioctls supported:
- ioctls to get the frame buffer screen info (fixed and variable).
- ioctl to set and get palette.
rtems_device_driver frame_buffer_control(
void *arg
rtems_libio_ioctl_args_t *args = arg;
printk( "FBVGA ioctl called, cmd=%x\n", args->command );
switch( args->command ) {
case FBIOGET_FSCREENINFO:
args->ioctl_return = get_fix_screen_info( ( struct fb_fix_screeninfo * ) args->buffer );
break;
case FBIOGET_VSCREENINFO:
args->ioctl_return = get_var_screen_info( ( struct fb_var_screeninfo * ) args->buffer );
break;
case FBIOPUT_VSCREENINFO:
/* not implemented yet*/
args->ioctl_return = -1;
case FBIOGETCMAP:
args->ioctl_return = get_palette( ( struct fb_cmap * ) args->buffer );
break;
case FBIOPUTCMAP:
args->ioctl_return = set_palette( ( struct fb_cmap * ) args->buffer );
break;
default:
args->ioctl_return = 0;
break;
See rtems/fb.h for more information on the list of ioctls and data
structures they work with.
