6.2. Change Control with GitLab#
6.2.1. Updating GitLab Metadata#
Only GitLab accounts with a role of Developer or above have permissions to modify the metadata of Issues and Merge Requests. This section is intended for those individuals.
6.2.1.1. Assignee#
The assignee of a merge request should usually be set to the submitter. Not all users will appear in the Edit boxes. Add the user by a @user in a comment, refresh your browser and then you can edit the assignee.
The assignee of an Issue should be set to someone (accepting to be) responsible for handling it.
6.2.1.2. Reviewers#
You may add reviewers to a Merge Request to ensure specific individuals are in the approval chain. This should be done (or undone) at your discretion.
6.2.1.3. Labels#
Until further guidance can be determined, use your best effort to assign one or more relevant labels to Issues and Merge Requests.
6.2.1.4. Milestones#
The milestone assigned to a Merge Request must match the branch that it
targets. Usually, the target branch should be main and you should set
the milestone to the next release. See below in case a Merge Request targets
a release branch.
6.2.1.5. Release Branches#
There are additional checks to use for any changes that directly apply or are backported to a release branch. These checks need to satisfy the requirements of the Release Process. For requested backports, please refer directly to How to Handle Backports. With any Merge Request targeting a release branch, ensure that:
The commit messages of the Merge Request refer to an Issue with the Milestone that matches the release branch. Add this Milestone to the Merge Request.
The Issue referenced by the Merge Request is linked to the Epic for the target release.
6.2.2. Approving Merge Requests#
This section is intended for those individuals who are Approvers and for
anyone else who wants to participate in the Merge Request Review Process as a code
reviewer.
6.2.2.1. Conflict of Interest Rules#
We do not have formally adopted Conflict of Interest rules, but we generally avoid public review and approval by individuals who (should) have privately reviewed code. This means that you should not approve code that is submitted by someone who works with you commercially. Instead, you could provide input to the review or to assist your colleague in resolving review feedback.
6.2.2.2. Continuous Integration Pipelines#
Check the status of the pipelines and give feedback to help contributors to fix errors.
6.2.2.3. Check the Commits#
Ensure the commits are properly made according to the Commit Message Guidance. For new contributors, download the patch file (under the Code button) and make sure they have set a name and email address in their git metadata.
6.2.2.4. Creating a Review#
Navigate to the Changes tab in GitLab, and provide inline comments. It is up
to you if you want to add comments one at a time or in bulk using the “Start a
review” option.
Avoid adding comments directly in the Overview tab. If you do make comments
there that need to be addressed, you should ensure they show up as “threads” by
either checking that option when you write the comment, or by replying to your
own comment to turn it into a thread.
Each comment that you add should only be on one concern. Grouping multiple review concerns in the same comment makes it harder to check that all concerns are resolved satisfactorily.
6.2.2.5. Marking a Merge Request as a Draft#
You can mark a Merge Request as a Draft if there are deficiencies that will take some time to resolve or simply to prevent it from being merged. In general, other reviewers will ignore such Draft Merge Requests. This should be used to reduce reviewer burden or to indicate the change should be held off regardless of the approval. For example, during the preparation of a release the pending Merge Requests may be marked as Draft to prevent them from being merged.
6.2.2.6. Cloning a Merge Request#
Prior to approving, it is your responsibility to ensure that the change works as intended. In some cases this may be done without having to clone and test changes, but often you will need to do some work locally. There are a few ways you can do this. The GitLab Documentation has advice on this. You can also get a check-out from the “Code” button dropdown, “Check out branch” menu.
The following are some potentially useful git aliases that may help simplify
this process:
[alias]
mr = !sh -c 'git fetch $1 merge-requests/$2/head:mr-$1-$2 && git checkout mr-$1-$2' -
fetch-fork = !sh -c 'git remote add $1 ssh://git@gitlab.rtems.org:2222/$1/$(basename $(git rev-parse --show-toplevel)).git && git fetch $1' -
push-fork = !sh -c 'git push $1 $(git rev-parse --abbrev-ref --symbolic-full-name HEAD):$2 $3' -
checkout-fork = !git checkout -t $1/$2
close-fork = !git remote remove
close-mr = !sh -c 'git checkout main && git fetch && git pull && git branch -d mr-$1-$2' -
These aliases were created on a Linux machine and would likely need
modification in other hosts. The mainly useful alias is the first one, you can
use git mr origin 123 to checkout merge request 123 against the origin repo.
If you want to make changes and push them back, you have to use the other
commands, for example:
git fetch-fork gedare
git checkout-fork gedare somebranch
edit edit edit
git commit/rebase
git push-fork gedare somebranch -f
Which is a fairly rude thing to do, but can be a handy way to fix a submitted Merge Request if the submitter is unable to do so themselves. The ability to push to the Merge Request submitter’s branch can be disabled, but it is turned on by default.
6.2.2.7. Approving#
Approve! Merge! If you think it should be merged but cannot, check for reasons that block it. For example, if it just needs to be rebased, do it! If the rebase has conflicts, you can either ask the submitter to handle it, or you can use the preceding instructions for cloning the Merge Request to fix it yourself. It is generally preferable to give the submitter a chance to fix it on their own. If you cannot see why a Merge Request cannot be merged, please make an inquiry in the Discord.
