RTEMS
7.0-rc1
bsps
include
dev
serial
zynq-uart.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* Copyright (C) 2013, 2024 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_ARM_XILINX_ZYNQ_UART_H
37
#define LIBBSP_ARM_XILINX_ZYNQ_UART_H
38
39
rtems/termiosdevice.h
40
41
#ifdef __cplusplus
42
extern
"C"
43
#endif
/* __cplusplus */
44
51
typedef
struct
52
rtems_termios_device_context
base;
53
volatile
struct
zynq_uart
*regs;
54
int
tx_queued;
55
bool
transmitting;
56
rtems_vector_number
irq;
57
zynq_uart_context
58
59
extern
const
rtems_termios_device_handler
zynq_uart_handler;
60
63
#ifdef __cplusplus
64
65
#endif
/* __cplusplus */
66
67
#endif
/* LIBBSP_ARM_XILINX_ZYNQ_UART_H */
rtems_vector_number
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition:
intr.h:102
Termios device context.
Definition:
termiosdevice.h:68
Termios device handler.
Definition:
termiosdevice.h:100
zynq_uart_context
Definition:
zynq-uart.h:51
zynq_uart
Definition:
zynq-uart-regs.h:55
termiosdevice.h
This header file provides the interfaces of the RTEMS Termios Device Support.
