RTEMS 7.0-rc1
zynq-qspi-flashdev.h
2
3/*
4 * Copyright (C) 2024 Aaron Nyholm
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS AS IS
16 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25 * POSSIBILITY OF SUCH DAMAGE.
26 */
27
28#ifndef _ZYNQ_QSPI_FLASHDEV_H
29#define _ZYNQ_QSPI_FLASHDEV_H
30
31#include <dev/flash/flashdev.h>
32#include <dev/spi/zynq-qspi-flash.h>
33
34#define ZQSPI_FLASH_MAX_REGIONS ((size_t)32)
35
36/*
37 * @brief Initializes a flash device using zynq qspi flash driver.
38 *
39 * The flash device is not registered in this call. If an rtems_flashdev is
40 * created using zqspi_flash_init and is not registered, it must be destroyed
41 * using rtems_flashdev_destroy.
42 *
43 * @param[in] zqspiflash A initialised zqspiflash device to wrap.
44 *
45 * @retval A pointer to the rtems_flashdev.
46 * @retval NULL on failure.
47*/
48rtems_flashdev* zqspi_flashdev_init(zqspiflash *bmdriver);
49
50#endif /* _ZYNQ_QSPI_FLASHDEV_H */
Generic Flash API.
Flash device.
Definition: flashdev.h:358
Definition: zynq-qspi-flash.h:115
