RTEMS 7.0-rc1
z85c30_p.h
2
3/*
4 * This include file contains all private driver definitions for the
5 * Zilog z85c30.
6 */
7
8/*
9 * COPYRIGHT (c) 1998 by Radstone Technology
10 *
11 *
12 * THIS FILE IS PROVIDED TO YOU, THE USER, "AS IS", WITHOUT WARRANTY OF ANY
13 * KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE
14 * IMPLIED WARRANTY OF FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK
15 * AS TO THE QUALITY AND PERFORMANCE OF ALL CODE IN THIS FILE IS WITH YOU.
16 *
17 * You are hereby granted permission to use, copy, modify, and distribute
18 * this file, provided that this notice, plus the above copyright notice
19 * and disclaimer, appears in all copies. Radstone Technology will provide
20 * no support for this code.
21 */
22
23/*
24 * Copyright (C) 1989, 1997 On-Line Applications Research Corporation (OAR)
25 *
26 * Redistribution and use in source and binary forms, with or without
27 * modification, are permitted provided that the following conditions
28 * are met:
29 * 1. Redistributions of source code must retain the above copyright
30 * notice, this list of conditions and the following disclaimer.
31 * 2. Redistributions in binary form must reproduce the above copyright
32 * notice, this list of conditions and the following disclaimer in the
33 * documentation and/or other materials provided with the distribution.
34 *
35 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
36 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
37 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
38 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
39 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
40 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
41 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
42 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
43 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
44 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
45 * POSSIBILITY OF SUCH DAMAGE.
46 */
47
48#ifndef __Z85C30_P_H
49#define __Z85C30_P_H
50
51#ifdef __cplusplus
52extern "C" {
53#endif
54
55/*
56 * Define Z85C30_STATIC to nothing while debugging so the entry points
57 * will show up in the symbol table.
58 */
59
60#define Z85C30_STATIC
61
62/* #define Z85C30_STATIC static */
63
64/* bit values for write register 0 */
65/* command register */
66
67#define SCC_WR0_SEL_WR0 0x00
68#define SCC_WR0_SEL_WR1 0x01
69#define SCC_WR0_SEL_WR2 0x02
70#define SCC_WR0_SEL_WR3 0x03
71#define SCC_WR0_SEL_WR4 0x04
72#define SCC_WR0_SEL_WR5 0x05
73#define SCC_WR0_SEL_WR6 0x06
74#define SCC_WR0_SEL_WR7 0x07
75#define SCC_WR0_SEL_WR8 0x08
76#define SCC_WR0_SEL_WR9 0x09
77#define SCC_WR0_SEL_WR10 0x0a
78#define SCC_WR0_SEL_WR11 0x0b
79#define SCC_WR0_SEL_WR12 0x0c
80#define SCC_WR0_SEL_WR13 0x0d
81#define SCC_WR0_SEL_WR14 0x0e
82#define SCC_WR0_SEL_WR15 0x0f
83#define SCC_WR0_SEL_RD0 0x00
84#define SCC_WR0_SEL_RD1 0x01
85#define SCC_WR0_SEL_RD2 0x02
86#define SCC_WR0_SEL_RD3 0x03
87#define SCC_WR0_SEL_RD4 0x04
88#define SCC_WR0_SEL_RD5 0x05
89#define SCC_WR0_SEL_RD6 0x06
90#define SCC_WR0_SEL_RD7 0x07
91#define SCC_WR0_SEL_RD8 0x08
92#define SCC_WR0_SEL_RD9 0x09
93#define SCC_WR0_SEL_RD10 0x0a
94#define SCC_WR0_SEL_RD11 0x0b
95#define SCC_WR0_SEL_RD12 0x0c
96#define SCC_WR0_SEL_RD13 0x0d
97#define SCC_WR0_SEL_RD14 0x0e
98#define SCC_WR0_SEL_RD15 0x0f
99#define SCC_WR0_NULL_CODE 0x00
100#define SCC_WR0_RST_INT 0x10
101#define SCC_WR0_SEND_ABORT 0x18
102#define SCC_WR0_EN_INT_RX 0x20
103#define SCC_WR0_RST_TX_INT 0x28
104#define SCC_WR0_ERR_RST 0x30
105#define SCC_WR0_RST_HI_IUS 0x38
106#define SCC_WR0_RST_RX_CRC 0x40
107#define SCC_WR0_RST_TX_CRC 0x80
108#define SCC_WR0_RST_TX_UND 0xc0
109
110/* write register 2 */
111/* interrupt vector */
112
113/* bit values for write register 1 */
114/* tx/rx interrupt and data transfer mode definition */
115
116#define SCC_WR1_EXT_INT_EN 0x01
117#define SCC_WR1_TX_INT_EN 0x02
118#define SCC_WR1_PARITY 0x04
119#define SCC_WR1_RX_INT_DIS 0x00
120#define SCC_WR1_RX_INT_FIR 0x08
121#define SCC_WR1_INT_ALL_RX 0x10
122#define SCC_WR1_RX_INT_SPE 0x18
123#define SCC_WR1_RDMA_RECTR 0x20
124#define SCC_WR1_RDMA_FUNC 0x40
125#define SCC_WR1_RDMA_EN 0x80
126
127#define SCC_ENABLE_ALL_INTR \
128 (SCC_WR1_EXT_INT_EN | SCC_WR1_TX_INT_EN | SCC_WR1_INT_ALL_RX)
129
130#define SCC_DISABLE_ALL_INTR 0x00
131
132#define SCC_ENABLE_ALL_INTR_EXCEPT_TX \
133 (SCC_WR1_EXT_INT_EN | SCC_WR1_INT_ALL_RX)
134
135/* bit values for write register 3 */
136/* receive parameters and control */
137
138#define SCC_WR3_RX_EN 0x01
139#define SCC_WR3_SYNC_CHAR 0x02
140#define SCC_WR3_ADR_SEARCH 0x04
141#define SCC_WR3_RX_CRC_EN 0x08
142#define SCC_WR3_ENTER_HUNT 0x10
143#define SCC_WR3_AUTO_EN 0x20
144#define SCC_WR3_RX_5_BITS 0x00
145#define SCC_WR3_RX_7_BITS 0x40
146#define SCC_WR3_RX_6_BITS 0x80
147#define SCC_WR3_RX_8_BITS 0xc0
148
149/* bit values for write register 4 */
150/* tx/rx misc parameters and modes */
151
152#define SCC_WR4_PAR_EN 0x01
153#define SCC_WR4_PAR_EVEN 0x02
154#define SCC_WR4_SYNC_EN 0x00
155#define SCC_WR4_1_STOP 0x04
156#define SCC_WR4_2_STOP 0x0c
157#define SCC_WR4_8_SYNC 0x00
158#define SCC_WR4_16_SYNC 0x10
159#define SCC_WR4_SDLC 0x20
160#define SCC_WR4_EXT_SYNC 0x30
161#define SCC_WR4_1_CLOCK 0x00
162#define SCC_WR4_16_CLOCK 0x40
163#define SCC_WR4_32_CLOCK 0x80
164#define SCC_WR4_64_CLOCK 0xc0
165
166/* bit values for write register 5 */
167/* transmit parameter and controls */
168
169#define SCC_WR5_TX_CRC_EN 0x01
170#define SCC_WR5_RTS 0x02
171#define SCC_WR5_SDLC 0x04
172#define SCC_WR5_TX_EN 0x08
173#define SCC_WR5_SEND_BRK 0x10
174
175#define SCC_WR5_TX_5_BITS 0x00
176#define SCC_WR5_TX_7_BITS 0x20
177#define SCC_WR5_TX_6_BITS 0x40
178#define SCC_WR5_TX_8_BITS 0x60
179#define SCC_WR5_DTR 0x80
180
181/* write register 6 */
182/* sync chars or sdlc address field */
183
184/* write register 7 */
185/* sync char or sdlc flag */
186
187/* write register 8 */
188/* transmit buffer */
189
190/* bit values for write register 9 */
191/* master interrupt control */
192
193#define SCC_WR9_VIS 0x01
194#define SCC_WR9_NV 0x02
195#define SCC_WR9_DLC 0x04
196#define SCC_WR9_MIE 0x08
197#define SCC_WR9_STATUS_HI 0x10
198#define SCC_WR9_NO_RST 0x00
199#define SCC_WR9_CH_B_RST 0x40
200#define SCC_WR9_CH_A_RST 0x80
201#define SCC_WR9_HDWR_RST 0xc0
202
203/* bit values for write register 10 */
204/* misc tx/rx control bits */
205
206#define SCC_WR10_6_BIT_SYNC 0x01
207#define SCC_WR10_LOOP_MODE 0x02
208#define SCC_WR10_ABORT_UND 0x04
209#define SCC_WR10_MARK_IDLE 0x08
210#define SCC_WR10_ACT_POLL 0x10
211#define SCC_WR10_NRZ 0x00
212#define SCC_WR10_NRZI 0x20
213#define SCC_WR10_FM1 0x40
214#define SCC_WR10_FM0 0x60
215#define SCC_WR10_CRC_PRESET 0x80
216
217/* bit values for write register 11 */
218/* clock mode control */
219
220#define SCC_WR11_OUT_XTAL 0x00
221#define SCC_WR11_OUT_TX_CLK 0x01
222#define SCC_WR11_OUT_BR_GEN 0x02
223#define SCC_WR11_OUT_DPLL 0x03
224#define SCC_WR11_TRXC_OI 0x04
225#define SCC_WR11_TX_RTXC 0x00
226#define SCC_WR11_TX_TRXC 0x08
227#define SCC_WR11_TX_BR_GEN 0x10
228#define SCC_WR11_TX_DPLL 0x18
229#define SCC_WR11_RX_RTXC 0x00
230#define SCC_WR11_RX_TRXC 0x20
231#define SCC_WR11_RX_BR_GEN 0x40
232#define SCC_WR11_RX_DPLL 0x60
233#define SCC_WR11_RTXC_XTAL 0x80
234
235/* write register 12 */
236/* lower byte of baud rate generator time constant */
237
238/* write register 13 */
239/* upper byte of baud rate generator time constant */
240
241/* bit values for write register 14 */
242/* misc control bits */
243
244#define SCC_WR14_BR_EN 0x01
245#define SCC_WR14_BR_SRC 0x02
246#define SCC_WR14_DTR_FUNC 0x04
247#define SCC_WR14_AUTO_ECHO 0x08
248#define SCC_WR14_LCL_LOOP 0x10
249#define SCC_WR14_NULL 0x00
250#define SCC_WR14_SEARCH 0x20
251#define SCC_WR14_RST_CLK 0x40
252#define SCC_WR14_DIS_DPLL 0x60
253#define SCC_WR14_SRC_BR 0x80
254#define SCC_WR14_SRC_RTXC 0xa0
255#define SCC_WR14_FM_MODE 0xc0
256#define SCC_WR14_NRZI 0xe0
257
258/* bit values for write register 15 */
259/* external/status interrupt control */
260
261#define SCC_WR15_ZERO_CNT 0x02
262#define SCC_WR15_CD_IE 0x08
263#define SCC_WR15_SYNC_IE 0x10
264#define SCC_WR15_CTS_IE 0x20
265#define SCC_WR15_TX_UND_IE 0x40
266#define SCC_WR15_BREAK_IE 0x80
267
268/* bit values for read register 0 */
269/* tx/rx buffer status and external status */
270
271#define SCC_RR0_RX_AVAIL 0x01
272#define SCC_RR0_ZERO_CNT 0x02
273#define SCC_RR0_TX_EMPTY 0x04
274#define SCC_RR0_CD 0x08
275#define SCC_RR0_SYNC 0x10
276#define SCC_RR0_CTS 0x20
277#define SCC_RR0_TX_UND 0x40
278#define SCC_RR0_BREAK 0x80
279
280/* bit values for read register 1 */
281
282#define SCC_RR1_ALL_SENT 0x01
283#define SCC_RR1_RES_CD_2 0x02
284#define SCC_RR1_RES_CD_1 0x01
285#define SCC_RR1_RES_CD_0 0x08
286#define SCC_RR1_PAR_ERR 0x10
287#define SCC_RR1_RX_OV_ERR 0x20
288#define SCC_RR1_CRC_ERR 0x40
289#define SCC_RR1_END_FRAME 0x80
290
291/* read register 2 */
292/* interrupt vector */
293
294/* bit values for read register 3 */
295/* interrupt pending register */
296
297#define SCC_RR3_B_EXT_IP 0x01
298#define SCC_RR3_B_TX_IP 0x02
299#define SCC_RR3_B_RX_IP 0x04
300#define SCC_RR3_A_EXT_IP 0x08
301#define SCC_RR3_A_TX_IP 0x10
302#define SCC_RR3_A_RX_IP 0x20
303
304/* read register 8 */
305/* receive data register */
306
307/* bit values for read register 10 */
308/* misc status bits */
309
310#define SCC_RR10_ON_LOOP 0x02
311#define SCC_RR10_LOOP_SEND 0x10
312#define SCC_RR10_2_CLK_MIS 0x40
313#define SCC_RR10_1_CLK_MIS 0x80
314
315/* read register 12 */
316/* lower byte of time constant */
317
318/* read register 13 */
319/* upper byte of time constant */
320
321/* bit values for read register 15 */
322/* external/status ie bits */
323
324#define SCC_RR15_ZERO_CNT 0x02
325#define SCC_RR15_CD_IE 0x08
326#define SCC_RR15_SYNC_IE 0x10
327#define SCC_RR15_CTS_IE 0x20
328#define SCC_RR15_TX_UND_IE 0x40
329#define SCC_RR15_BREAK_IE 0x80
330
331typedef struct _z85c30_context
332{
333 uint8_t ucModemCtrl;
335
336/*
337 * The following macro calculates the Baud constant. For the Z85C30 chip.
338 *
339 * Note: baud constant = ((clock frequency / Clock_X) / (2 * Baud Rate)) - 2
340 * eg ((10,000,000 / 16) / (2 * Baud Rate)) - 2
341 */
342
343#define Z85C30_Baud( _clock, _baud_rate ) \
344 ( ((_clock) /( 16 * 2 * _baud_rate)) - 2)
345
346#define Z85C30_Status_Is_RX_character_available(_status) \
347 ((_status) & SCC_RR0_RX_AVAIL)
348
349#define Z85C30_Status_Is_TX_buffer_empty(_status) \
350 ((_status) & SCC_RR0_TX_EMPTY)
351
352#define Z85C30_Status_Is_CTS_asserted(_status) \
353 ((_status) & SCC_RR0_CTS)
354
355#define Z85C30_Status_Is_break_abort(_status) \
356 ((_status) & SCC_RR0_BREAK)
357
358/*
359 * Private routines
360 */
361
362Z85C30_STATIC void z85c30_initialize_port(
363 int minor
364);
365
366Z85C30_STATIC void z85c30_init(int minor);
367
368Z85C30_STATIC int z85c30_set_attributes(
369 int minor,
370 const struct termios *t
371);
372
373Z85C30_STATIC int z85c30_open(
374 int major,
375 int minor,
376 void * arg
377);
378
379Z85C30_STATIC int z85c30_close(
380 int major,
381 int minor,
382 void * arg
383);
384
385Z85C30_STATIC void z85c30_write_polled(
386 int minor,
387 char cChar
388);
389
390Z85C30_STATIC int z85c30_assert_RTS(
391 int minor
392);
393
394Z85C30_STATIC int z85c30_negate_RTS(
395 int minor
396);
397
398Z85C30_STATIC int z85c30_assert_DTR(
399 int minor
400);
401
402Z85C30_STATIC int z85c30_negate_DTR(
403 int minor
404);
405
406Z85C30_STATIC void z85c30_initialize_interrupts(int minor);
407
408Z85C30_STATIC ssize_t z85c30_write_support_int(
409 int minor,
410 const char *buf,
411 size_t len
412);
413
414Z85C30_STATIC ssize_t z85c30_write_support_polled(
415 int minor,
416 const char *buf,
417 size_t len
418);
419
420Z85C30_STATIC int z85c30_inbyte_nonblocking_polled(
421 int minor
422);
423
424Z85C30_STATIC void z85c30_enable_interrupts(
425 int minor,
426 int interrupt_mask
427);
428
429Z85C30_STATIC void z85c30_process(
430 int minor,
431 uint8_t ucIntPend
432);
433
434Z85C30_STATIC rtems_isr z85c30_isr(
436);
437
438#ifdef __cplusplus
439}
440#endif
441
442#endif
ISR_Handler rtems_isr
This type defines the return type of interrupt service routines.
Definition: intr.h:123
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition: intr.h:102
Definition: z85c30_p.h:332
