RTEMS
7.0-rc1
bsps
include
dev
spi
xqspi_flash.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* Copyright (C) 2023, 2023 Aaron Nyholm
5
6
7
* modification, are permitted provided that the following conditions
8
* are met:
9
* 1. Redistributions of source code must retain the above copyright
10
* notice, this list of conditions and the following disclaimer.
11
* 2. Redistributions in binary form must reproduce the above copyright
12
* notice, this list of conditions and the following disclaimer in the
13
* documentation and/or other materials provided with the distribution.
14
15
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS AS IS
16
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25
* POSSIBILITY OF SUCH DAMAGE.
26
27
28
#ifndef XILINX_XQSPI_FLASH_H
29
#define XILINX_XQSPI_FLASH_H
30
31
dev/flash/flashdev.h
32
dev/spi/xqspipsu.h
33
34
#ifdef __cplusplus
35
extern
"C"
36
#endif
37
38
#define XQSPI_FLASH_MAX_REGIONS ((size_t)32)
39
40
41
* @brief Initializes a flash device using Xilinx's xqspi flash driver.
42
43
* The flash device is not registered in this call. The returned object must be
44
* destroyed with rtems_flashdev_destroy_and_free if it has not been registered.
45
46
* @param[in] xQspiDev A configured XQspiPsu device to initialise.
47
48
* @retval A pointer to the rtems_flashdev.
49
* @retval NULL on failure.
50
51
rtems_flashdev
* xqspi_flash_init(
XQspiPsu
*xQspiDev);
52
53
#ifdef __cplusplus
54
55
#endif
56
57
#endif
/* XILINX_XQSPI_FLASH_H */
flashdev.h
Generic Flash API.
XQspiPsu
Definition:
xqspipsu.h:257
rtems_flashdev
Flash device.
Definition:
flashdev.h:358
xqspipsu.h
