39#ifndef _RTEMS_SCORE_USEREXT_H
40#define _RTEMS_SCORE_USEREXT_H
226 bool always_set_to_false,
227 Internal_errors_t code
Internal_errors_Source
This type lists the possible sources from which an error can be reported.
Definition: interr.h:63
void(* User_extensions_thread_begin_extension)(struct _Thread_Control *executing)
Task begin extension.
Definition: userext.h:192
bool(* User_extensions_thread_create_extension)(struct _Thread_Control *executing, struct _Thread_Control *created)
Task create extension.
Definition: userext.h:92
void(* User_extensions_thread_start_extension)(struct _Thread_Control *executing, struct _Thread_Control *started)
Task start extension.
Definition: userext.h:132
void(* User_extensions_thread_restart_extension)(struct _Thread_Control *executing, struct _Thread_Control *restarted)
Task restart extension.
Definition: userext.h:154
void(* User_extensions_thread_delete_extension)(struct _Thread_Control *executing, struct _Thread_Control *deleted)
Task delete extension.
Definition: userext.h:112
void(* User_extensions_thread_switch_extension)(struct _Thread_Control *executing, struct _Thread_Control *heir)
Task switch extension.
Definition: userext.h:177
void(* User_extensions_thread_terminate_extension)(struct _Thread_Control *terminated)
Task termination extension.
Definition: userext.h:246
void(* User_extensions_fatal_extension)(Internal_errors_Source source, bool always_set_to_false, Internal_errors_t code)
Fatal error extension.
Definition: userext.h:224
void(* User_extensions_thread_exitted_extension)(struct _Thread_Control *executing)
Task exitted extension.
Definition: userext.h:206
This header file provides the interfaces of the Internal Error Handler.
User extension table.
Definition: userext.h:253
