RTEMS 7.0-rc1
usart_dma.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
37#ifndef _USART_DMA_H_
38#define _USART_DMA_H_
39
40/*----------------------------------------------------------------------------
41 * Headers
42 *----------------------------------------------------------------------------*/
43
44#include "chip.h"
45
46/*----------------------------------------------------------------------------
47 * Definitions
48 *----------------------------------------------------------------------------*/
49
51#define USARTD_ERROR 1
52
54#define USARTD_ERROR_LOCK 2
55
56
57#ifdef __cplusplus
58extern "C" {
59#endif
60
61/*----------------------------------------------------------------------------
62 * Types
63 *----------------------------------------------------------------------------*/
64
66#ifdef __rtems__
68#else
69typedef void (*UsartdCallback)(uint8_t, void *);
70#endif
71
77typedef struct {
79 uint8_t *pBuff;
81 uint32_t BuffSize;
83 uint8_t ChNum;
87 void *pArgument;
89 volatile uint8_t dmaProgress;
90 /* DMA LLI structure */
92 /* DMA transfer type */
93 eXdmadProgState dmaProgrammingMode;
94 /* DMA LLI size or num of micro block*/
95 uint16_t dmaBlockSize;
96 /* Flag using ring buffer or FiFo*/
97 uint8_t dmaRingBuffer;
99
102typedef struct {
104 uint8_t usartId;
113} UsartDma;
114
115/*----------------------------------------------------------------------------
116 * Exported functions
117 *----------------------------------------------------------------------------*/
118
119uint32_t USARTD_Configure(UsartDma *pUsartd ,
120 uint8_t USARTId,
121 uint32_t UsartMode,
122 uint32_t BaudRate,
123 uint32_t UsartClk);
124
125uint32_t USARTD_EnableTxChannels(UsartDma *pUsartd, UsartChannel *pTxCh);
126
127uint32_t USARTD_EnableRxChannels(UsartDma *pUsartd, UsartChannel *pRxCh);
128
129uint32_t USARTD_DisableTxChannels(UsartDma *pUsartd, UsartChannel *pTxCh);
130
131uint32_t USARTD_DisableRxChannels(UsartDma *pUsartd, UsartChannel *pTxCh);
132
133uint32_t USARTD_SendData(UsartDma *pUsartd);
134
135uint32_t USARTD_RcvData(UsartDma *pUsartd);
136
137#ifdef __cplusplus
138}
139#endif
140
141#endif /* #ifndef _USART_DMA_ */
enum _XdmadProgState eXdmadProgState
void(* XdmadTransferCallback)(uint32_t Channel, void *pArg, uint32_t status)
Definition: xdmad.h:110
Chip definitions for STM32U5.
usart Transfer Request prepared by the application upper layer.
Definition: usart_dma.h:77
uint32_t BuffSize
Definition: usart_dma.h:81
UsartdCallback callback
Definition: usart_dma.h:85
uint8_t ChNum
Definition: usart_dma.h:83
uint8_t * pBuff
Definition: usart_dma.h:79
Definition: usart_dma.h:89
void * pArgument
Definition: usart_dma.h:87
Definition: usart_dma.h:102
UsartChannel * pRxChannel
Definition: usart_dma.h:108
sXdmad * pXdmad
Definition: usart_dma.h:112
Usart * pUsartHw
Definition: usart_dma.h:106
uint8_t usartId
Definition: usart_dma.h:104
UsartChannel * pTxChannel
Definition: usart_dma.h:110
Usart hardware registers.
Definition: component_usart.h:41
Structure for storing parameters for DMA view1 that can be performed by the DMA Master transfer.
Definition: xdmad.h:167
Definition: xdmad.h:127
This function disables the appropriate DMA channel for Tx channel of USART.
Definition: usart_dma.c:545
uint32_t USARTD_Configure(UsartDma *pUsartd, uint8_t USARTId, uint32_t UsartMode, uint32_t BaudRate, uint32_t UsartClk)
Initializes the USARTDma structure and the corresponding USART & DMA . hardware select value....
Definition: usart_dma.c:360
Starts a USART master transfer. This is a non blocking function. It will return as soon as the transf...
Definition: usart_dma.c:600
This function initialize the appropriate DMA channel for Rx channel of USART.
Definition: usart_dma.c:402
Definition: usart_dma.c:578
void(* UsartdCallback)(uint8_t, void *)
Definition: usart_dma.h:69
This function initialize the appropriate DMA channel for Tx channel of USART.
Definition: usart_dma.c:457
This function disables the appropriate DMA channel for Rx channel of USART.
Definition: usart_dma.c:511
