51#ifndef _TR_FATAL_SPARC_LEON3_CLOCK_INITIALIZATION_H
52#define _TR_FATAL_SPARC_LEON3_CLOCK_INITIALIZATION_H
void BspSparcLeon3ValFatalClockInitialization_Run(rtems_fatal_source source, rtems_fatal_code code)
Runs the parameterized test case.
Definition: tr-fatal-sparc-leon3-clock-initialization.c:167
Internal_errors_t rtems_fatal_code
This integer type represents system termination codes.
Definition: extension.h:162
Internal_errors_Source
This type lists the possible sources from which an error can be reported.
Definition: interr.h:63
