51#ifndef _TR_FATAL_SMP_H
52#define _TR_FATAL_SMP_H
Internal_errors_t rtems_fatal_code
This integer type represents system termination codes.
Definition: extension.h:162
Internal_errors_Source
This type lists the possible sources from which an error can be reported.
Definition: interr.h:63
void ScoreSmpValFatal_Run(rtems_fatal_source source, rtems_fatal_code code)
Runs the parameterized test case.
Definition: tr-fatal-smp.c:297
