43#ifndef LIBBSP_ARM_TMS570_PINMUX_H
44#define LIBBSP_ARM_TMS570_PINMUX_H
54#define TMS570_PIN_NUM_SHIFT 0
55#define TMS570_PIN_NUM_MASK 0x000007ff
63#define TMS570_PIN_CLEAR_RQ_MASK 0x00008000
65#define TMS570_PIN_FNC_SHIFT 11
66#define TMS570_PIN_FNC_MASK 0x00007800
74#define TMS570_PIN_FNC_CLEAR 0x10U
76#define TMS570_PIN_NUM_FNC_MASK 0x0000ffff
78#define TMS570_PIN_IN_ALT_SHIFT 16
79#define TMS570_PIN_IN_ALT_MASK 0xffff0000
81#define TMS570_PIN_FNC_AUTO (-1)
92#define TMS570_PIN_AND_FNC(pin, fnc) \
93 ((pin) | ((fnc) << TMS570_PIN_FNC_SHIFT))
95#define TMS570_PIN_WITH_IN_ALT(pin_num_and_fnc, pin_in_alt_num_and_fnc) \
96 ((pin_num_and_fnc) | ((pin_in_alt_num_and_fnc) << TMS570_PIN_IN_ALT_SHIFT))
98#define TMS570_BALL_WITH_MMR(mmrx, pos) \
99 ((pos) | ((mmrx) << 2))
148#define TMS570_PINMMR_REG_SINGLE_VAL_ACTION(reg, pin) \
149 (((((pin) & TMS570_PIN_NUM_MASK) >> 2 != (reg)) || ((pin) & TMS570_PIN_CLEAR_RQ_MASK))? 0: \
150 1 << ((((pin) & TMS570_PIN_FNC_MASK) >> TMS570_PIN_FNC_SHIFT) + \
154#define TMS570_PINMMR_REG_VAL_ACTION(reg, pin) \
155 TMS570_PINMMR_REG_SINGLE_VAL_ACTION(reg, pin) | \
156 ((pin) & TMS570_PIN_IN_ALT_MASK? \
157 TMS570_PINMMR_REG_SINGLE_VAL_ACTION(reg, (pin) >> TMS570_PIN_IN_ALT_SHIFT ): \
173#define TMS570_PINMMR_REG_VAL(reg, pin_list) \
174 pin_list(TMS570_PINMMR_REG_VAL_ACTION, reg) 0
176#define TMS570_PINMMR_COMA_LIST_ACTION(reg, pin) \
190#define TMS570_PINMMR_COMA_LIST(pin_list) \
191 pin_list(TMS570_PINMMR_COMA_LIST_ACTION, 0)
void tms570_bsp_pinmmr_config(const uint32_t *pinmmr_values, int reg_start, int reg_count)
configure block or whole pin multiplexer
Definition: pinmux.c:170
void tms570_bsp_pin_set_function(int pin_num, int pin_fnc)
select desired function of pin/ball
Definition: pinmux.c:80
void tms570_pin_config_array_apply(const uint32_t *config, size_t count)
Applies a pin configuration array.
Definition: pinmux.c:237
void tms570_bsp_pin_config_one(uint32_t pin_num_and_fnc)
configure one pin according to its function specification
Definition: pinmux.c:141
void tms570_pin_config_apply(uint32_t config)
Applies a pin configuration.
Definition: pinmux.c:222
void tms570_pin_config_complete(void)
Completes a pin configuration sequence.
Definition: pinmux.c:246
void tms570_pin_config_prepare(void)
Prepares a pin configuration sequence.
Definition: pinmux.c:194
void tms570_bsp_pin_clear_function(int pin_num, int pin_fnc)
clear connection between pin and specified peripherals/function
Definition: pinmux.c:105
