RTEMS 7.0-rc1
ti-tmp112.h
2
3/*
4 * Copyright (c) 2016-2017 Chris Johns <chrisj@rtems.org>
5 * All rights reserved.
6 *
7 * Redistribution and use in source and binary forms, with or without
8 * modification, are permitted provided that the following conditions
9 * are met:
10 * 1. Redistributions of source code must retain the above copyright
11 * notice, this list of conditions and the following disclaimer.
12 * 2. Redistributions in binary form must reproduce the above copyright
13 * notice, this list of conditions and the following disclaimer in the
14 * documentation and/or other materials provided with the distribution.
15 *
16 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
17 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
18 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
19 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
20 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
21 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
22 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
23 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
24 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
25 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
26 * POSSIBILITY OF SUCH DAMAGE.
27 */
28
29/*
30 * TI TMP112
31 * http://www.ti.com/product/TMP112
32 */
33
34#ifndef TI_TMP112_H
35#define TI_TMP112_H
36
37#include <dev/i2c/i2c.h>
38
39/*
40 * Confirguration.
41 */
42#define TI_TMP112_CR_0_25Hz (0 << 6)
43#define TI_TMP112_CR_1Hz (1 << 6)
44#define TI_TMP112_CR_4Hz (2 << 6) /* default */
45#define TI_TMP112_CR_8Hz (3 << 6)
46#define TI_TMP112_EM_NORMAL (0 << 4) /* default */
47#define TI_TMP112_EM_EXTENDED (1 << 4)
48#define TI_TMP112_SD_ON (0 << 8) /* default */
49#define TI_TMP112_SD_SHUTDOWN (1 << 8)
50#define TI_TMP112_TM_COMPARATOR (0 << 9) /* default */
51#define TI_TMP112_TM_INTERRUPT (1 << 9)
52#define TI_TMP112_POL_ALERT_LOW (0 << 10) /* default */
53#define TI_TMP112_POL_ALERT_HIGH (1 << 10)
54#define TI_TMP112_FQL_1 (0 << 11) /* default */
55#define TI_TMP112_FQL_2 (1 << 11)
56#define TI_TMP112_FQL_4 (2 << 11)
57#define TI_TMP112_FQL_6 (3 << 11)
58
59/*
60 * IO control interface.
61 */
62#define TI_TMP112_GET_TEMP (I2C_DEV_IO_CONTROL + 0)
63#define TI_TMP112_GET_TEMP_RAW (I2C_DEV_IO_CONTROL + 1)
64#define TI_TMP112_SET_CONFIG (I2C_DEV_IO_CONTROL + 2)
65#define TI_TMP112_SET_LOW_TEMP (I2C_DEV_IO_CONTROL + 3)
66#define TI_TMP112_SET_HIGH_TEMP (I2C_DEV_IO_CONTROL + 4)
67
68/*
69 * Register the device.
70 */
71int i2c_dev_register_ti_tmp112(const char* bus_path,
72 const char* dev_path,
73 uint16_t address);
74
75/*
76 * Get the temperature in degrees C x 10000. To print you would so:
77 *
78 * printf("Temperature is %3d.%04d\n", temp / 10000, temp % 10000);
79 *
80 * If the device is shutdown a single conversion is made waiting for the
81 * conversion to complete.
82 */
83static inline int
84ti_tmp112_get_temperature(int fd, int* temp)
85{
86 return ioctl(fd, TI_TMP112_GET_TEMP, temp);
87}
88
89/*
90 * Get the temperature as the raw register value.
91 *
92 * If the device is shutdown a single conversion is made waiting for the
93 * conversion to complete.
94 */
95static inline int
96ti_tmp112_get_temperature_raw(int fd, unsigned int* temp)
97{
98 return ioctl(fd, TI_TMP112_GET_TEMP_RAW, temp);
99}
100
101/*
102 * Set the configuration.
103 */
104static inline int
105ti_tmp112_adc_set_config(int fd, uint16_t config)
106{
107 return ioctl(fd, TI_TMP112_SET_CONFIG, (void *)(uintptr_t) config);
108}
109
110/*
111 * Set the low temperature.
112 */
113static inline int
114ti_tmp112_set_low_temperator(int fd, uint16_t temp)
115{
116 return ioctl(fd, TI_TMP112_SET_LOW_TEMP, (void *)(uintptr_t) temp);
117}
118
119/*
120 * Set the high temperature.
121 */
122static inline int
123ti_tmp112_adc_set_high_threshold(int fd, uint16_t level)
124{
125 return ioctl(fd, TI_TMP112_SET_HIGH_TEMP, (void *)(uintptr_t) level);
126}
127
128#endif
Inter-Integrated Circuit (I2C) Driver API.
