| void | _Thread_queue_Enqueue_do_nothing_extra (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context) |
| | Does nothing.
| void | _Thread_queue_Add_timeout_ticks (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context) |
| | Adds timeout ticks of the queue to the thread.
| void | _Thread_queue_Add_timeout_monotonic_timespec (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context) |
| | Adds a monotonic timespec to the thread and sets the watchdog header to monotonic.
| void | _Thread_queue_Add_timeout_realtime_timespec (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context) |
| | Adds a monotonic timespec to the thread and sets the watchdog header to realtime.
| void | _Thread_queue_Add_timeout_by_clock_id_timespec (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context) |
| | Adds a timeout to the thread queue context and sets the enqueue callout to add a timeout based on the clock_id.
| void | _Thread_queue_Deadlock_status (Thread_Control *the_thread) |
| | Sets the thread wait return code to STATUS_DEADLOCK.
| void | _Thread_queue_Deadlock_fatal (Thread_Control *the_thread) |
| | Results in an INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK fatal error.
| size_t | _Thread_queue_Queue_get_name_and_id (const Thread_queue_Queue *queue, char *buffer, size_t buffer_size, Objects_Id *id) |
| | Copies the thread queue name to the specified buffer.
| void | _Thread_queue_Enqueue (Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_Control *the_thread, Thread_queue_Context *queue_context) |
| | Blocks the thread and places it on the thread queue.
| bool | _Thread_queue_Extract_locked (Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_Control *the_thread, Thread_queue_Context *queue_context) |
| | Extracts the thread from the thread queue, restores the default wait operations and restores the default thread lock.
| void | _Thread_queue_Resume (Thread_queue_Queue *queue, Thread_Control *the_thread, Thread_queue_Context *queue_context) |
| | Resumes the extracted or surrendered thread.
| void | _Thread_queue_Extract (Thread_Control *the_thread) |
| | Extracts thread from thread queue.
| void | _Thread_queue_Surrender (Thread_queue_Queue *queue, Thread_queue_Heads *heads, Thread_Control *previous_owner, Thread_queue_Context *queue_context, const Thread_queue_Operations *operations) |
| | Surrenders the thread queue previously owned by the thread to the first enqueued thread.
| void | _Thread_queue_Surrender_no_priority (Thread_queue_Queue *queue, Thread_queue_Heads *heads, Thread_queue_Context *queue_context, const Thread_queue_Operations *operations) |
| Status_Control | _Thread_queue_Surrender_priority_ceiling (Thread_queue_Queue *queue, Thread_Control *executing, Priority_Node *ceiling_priority, Thread_queue_Context *queue_context, const Thread_queue_Operations *operations) |
| Thread_Control * | _Thread_queue_First (Thread_queue_Control *the_thread_queue, const Thread_queue_Operations *operations) |
| | Returns the first thread on the thread queue if it exists, otherwise NULL.
| Thread_Control * | _Thread_queue_Flush_default_filter (Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context) |
| | Default thread queue flush filter function.
| Thread_Control * | _Thread_queue_Flush_status_unavailable (Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context) |
| | Status unavailable thread queue flush filter function.
| Thread_Control * | _Thread_queue_Flush_status_object_was_deleted (Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context) |
| | Status object was deleted thread queue flush filter function.
| size_t | _Thread_queue_Flush_critical (Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_queue_Flush_filter filter, Thread_queue_Context *queue_context) |
| | Unblocks all threads enqueued on the thread queue.
| void | _Thread_queue_Initialize (Thread_queue_Control *the_thread_queue, const char *name) |
| | Initializes the thread queue control to the given name.
| void | _Thread_queue_Object_initialize (Thread_queue_Control *the_thread_queue) |
| | Initializes a thread queue embedded in an object with identifier.
| const Thread_queue_Operations | _Thread_queue_Operations_default |
| | The default thread queue operations are used when a thread is not enqueued on a thread queue.
const Thread_queue_Operations | _Thread_queue_Operations_FIFO |
| | The FIFO thread queue operations are used when a thread is enqueued on a thread queue and provide FIFO ordering of enqueued threads.
const Thread_queue_Operations | _Thread_queue_Operations_priority |
| | The FIFO thread queue operations are used when a thread is enqueued on a thread queue and provide priority ordering of enqueued threads.
const Thread_queue_Operations | _Thread_queue_Operations_priority_inherit |
| | The FIFO thread queue operations are used when a thread is enqueued on a thread queue and provide priority ordering of enqueued threads with support for priority inheritance.
| const char | _Thread_queue_Object_name [] |
| | The special thread queue name to indicated that the thread queue is embedded in an object with identifier.
This header file provides interfaces of the Thread Queue Handler which are only used by the implementation.
