56#ifndef _RTEMS_RTEMS_TASKS_H
57#define _RTEMS_RTEMS_TASKS_H
62#include <sys/cpuset.h>
69#include <rtems/score/cpu.h>
178 void ( *storage_free )(
void * );
209#define RTEMS_CONFIGURED_MINIMUM_STACK_SIZE 0
219#define RTEMS_CURRENT_PRIORITY 0
303#define RTEMS_MAXIMUM_PRIORITY _RTEMS_Maximum_priority()
313#define RTEMS_MINIMUM_PRIORITY 1
331#define RTEMS_MINIMUM_STACK_SIZE STACK_MINIMUM_SIZE
341#define RTEMS_NO_PRIORITY RTEMS_CURRENT_PRIORITY
351#define RTEMS_SELF OBJECTS_ID_OF_SELF
365#define RTEMS_TASK_STORAGE_ALIGNMENT CPU_STACK_ALIGNMENT
383#if CPU_ALL_TASKS_ARE_FP == TRUE
384 #define RTEMS_TASK_STORAGE_SIZE( _size, _attributes ) \
385 ( ( _size ) + CONTEXT_FP_SIZE )
387 #define RTEMS_TASK_STORAGE_SIZE( _size, _attributes ) \
389 ( ( ( _attributes ) & RTEMS_FLOATING_POINT ) != 0 ? \
390 CONTEXT_FP_SIZE : 0 ) )
421#define RTEMS_YIELD_PROCESSOR WATCHDOG_NO_TIMEOUT
1846 const cpu_set_t *cpuset
This header file provides Classic API directive attributes.
This header file provides basic definitions used by the API and the implementation.
This header file provides the interfaces of the Context Handler.
#define RTEMS_NO_RETURN
Tells the compiler in a function declaration that this function does not return.
Definition: basedefs.h:386
uint32_t rtems_attribute
This type represents Classic API attributes.
Definition: attr.h:96
uint32_t rtems_mode
This type represents a Classic API task mode set.
Definition: modes.h:174
rtems_status_code
Definition: status.h:85
rtems_status_code rtems_task_suspend(rtems_id id)
Suspends the task.
Definition: tasksuspend.c:45
rtems_status_code rtems_task_set_scheduler(rtems_id task_id, rtems_id scheduler_id, rtems_task_priority priority)
Sets the home scheduler for the task.
Definition: tasksetscheduler.c:45
rtems_status_code rtems_task_construct(const rtems_task_config *config, rtems_id *id)
Constructs a task from the specified task configuration.
Definition: taskconstruct.c:120
rtems_status_code rtems_task_set_affinity(rtems_id id, size_t cpusetsize, const cpu_set_t *cpuset)
Sets the processor affinity of the task.
Definition: tasksetaffinity.c:47
rtems_task(* rtems_task_entry)(rtems_task_argument)
This type defines the task entry point of an RTEMS task.
Definition: tasks.h:239
rtems_status_code rtems_task_restart(rtems_id id, rtems_task_argument argument)
Restarts the task.
Definition: taskrestart.c:46
rtems_status_code rtems_task_resume(rtems_id id)
Resumes the task.
Definition: taskresume.c:45
bool(* rtems_task_visitor)(rtems_tcb *, void *)
Visitor routines invoked by rtems_task_iterate() shall have this type.
Definition: tasks.h:410
rtems_status_code rtems_task_is_suspended(rtems_id id)
Checks if the task is suspended.
Definition: taskissuspended.c:45
rtems_status_code rtems_task_wake_after(rtems_interval ticks)
Wakes up after a count of clock ticks have occurred or yields the processor.
Definition: taskwakeafter.c:46
void rtems_task_iterate(rtems_task_visitor visitor, void *arg)
Iterates over all tasks and invokes the visitor routine for each task.
Definition: taskiterate.c:45
rtems_status_code rtems_task_ident(rtems_name name, uint32_t node, rtems_id *id)
Identifies a task by the object name.
Definition: taskident.c:47
RTEMS_NO_RETURN void rtems_task_exit(void)
Deletes the calling task.
Definition: taskexit.c:44
rtems_status_code rtems_task_create(rtems_name name, rtems_task_priority initial_priority, size_t stack_size, rtems_mode initial_modes, rtems_attribute attribute_set, rtems_id *id)
Creates a task.
Definition: taskcreate.c:66
rtems_status_code rtems_task_start(rtems_id id, rtems_task_entry entry_point, rtems_task_argument argument)
Starts the task.
Definition: taskstart.c:46
rtems_status_code rtems_task_get_priority(rtems_id task_id, rtems_id scheduler_id, rtems_task_priority *priority)
Gets the current priority of the task with respect to the scheduler.
Definition: taskgetpriority.c:45
rtems_status_code rtems_task_mode(rtems_mode mode_set, rtems_mode mask, rtems_mode *previous_mode_set)
Gets and optionally sets the mode of the calling task.
Definition: taskmode.c:50
void rtems_task
This type defines the return type of task entry points.
Definition: tasks.h:230
rtems_status_code rtems_task_get_scheduler(rtems_id task_id, rtems_id *scheduler_id)
Gets the home scheduler of the task.
Definition: taskgetscheduler.c:44
rtems_id rtems_task_self(void)
Gets the task identifier of the calling task.
rtems_status_code rtems_task_wake_when(const rtems_time_of_day *time_buffer)
Wakes up when specified.
Definition: taskwakewhen.c:48
rtems_status_code rtems_task_set_priority(rtems_id id, rtems_task_priority new_priority, rtems_task_priority *old_priority)
Sets the real priority or gets the current priority of the task.
Definition: tasksetpriority.c:82
CPU_Uint32ptr rtems_task_argument
This integer type represents task argument values.
Definition: tasks.h:100
rtems_status_code rtems_task_get_affinity(rtems_id id, size_t cpusetsize, cpu_set_t *cpuset)
Gets the processor affinity of the task.
Definition: taskgetaffinity.c:47
rtems_status_code rtems_task_delete(rtems_id id)
Deletes the task.
Definition: taskdelete.c:46
uint32_t rtems_name
This type represents Classic API object names.
Definition: types.h:226
uint32_t rtems_task_priority
This integer type represents task priorities of the Classic API.
Definition: types.h:257
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
Watchdog_Interval rtems_interval
This type represents clock tick intervals.
Definition: types.h:114
rtems_task_priority _RTEMS_Maximum_priority(void)
Returns the maximum priority of the scheduler with index zero.
Definition: rtemsmaxprio.c:44
uintptr_t CPU_Uint32ptr
Definition: cpu.h:611
This header file provides types used by the Classic API.
This header file provides the task modes API of the Task Manager.
This header file provides the status codes of Classic API directives and support functions.
This header file provides interfaces of the Object Handler which are used by the implementation and t...
This header file provides interfaces of the Stack Handler which are used by the implementation and th...
This structure defines the properties of the Classic API user initialization task.
Definition: tasks.h:249
This member defines the entry point of the task.
Definition: tasks.h:273
This member defines the initial task priority.
Definition: tasks.h:263
rtems_name name
This member defines the task name.
Definition: tasks.h:253
rtems_mode mode_set
This member defines the initial modes of the task.
Definition: tasks.h:278
This member defines the attribute set of the task.
Definition: tasks.h:268
size_t stack_size
This member defines the task stack size in bytes.
Definition: tasks.h:258
This member defines the entry point argument of the task.
Definition: tasks.h:283
This structure defines the configuration of a task constructed by rtems_task_construct().
Definition: tasks.h:110
size_t maximum_thread_local_storage_size
This member defines the maximum thread-local storage size supported by the task storage area.
Definition: tasks.h:166
This member defines the initial priority of the task.
Definition: tasks.h:119
Definition: tasks.h:183
size_t storage_size
This member defines size of the task storage area in bytes.
Definition: tasks.h:141
void * storage_area
This member shall point to the task storage area begin.
Definition: tasks.h:133
rtems_attribute attributes
This member defines the attributes of the task.
Definition: tasks.h:188
rtems_name name
This member defines the name of the task.
Definition: tasks.h:114
This type represents Classic API calendar times.
Definition: types.h:266
This header file provides the interfaces of the Watchdog Handler related to watchdog ticks which are ...
