RTEMS 7.0-rc1
stm32h7xx_hal_conf.h
1
21/* Define to prevent recursive inclusion -------------------------------------*/
22#ifndef STM32H7xx_HAL_CONF_H
23#define STM32H7xx_HAL_CONF_H
24
25#ifdef __rtems__
26#include <bspopts.h>
27
28#define HSE_VALUE ((uint32_t)STM32H7_HSE_FREQUENCY)
29#endif /* __rtems__ */
30#ifdef __cplusplus
31 extern "C" {
32#endif
33
34/* Exported types ------------------------------------------------------------*/
35/* Exported constants --------------------------------------------------------*/
36
37/* ########################## Module Selection ############################## */
41#define HAL_MODULE_ENABLED
42#define HAL_ADC_MODULE_ENABLED
43#define HAL_CEC_MODULE_ENABLED
44#define HAL_COMP_MODULE_ENABLED
45#define HAL_CORDIC_MODULE_ENABLED
46#define HAL_CORTEX_MODULE_ENABLED
47#define HAL_CRC_MODULE_ENABLED
48#define HAL_CRYP_MODULE_ENABLED
49#define HAL_DAC_MODULE_ENABLED
50#define HAL_DCMI_MODULE_ENABLED
51#define HAL_DFSDM_MODULE_ENABLED
52#define HAL_DMA_MODULE_ENABLED
53#define HAL_DMA2D_MODULE_ENABLED
54#define HAL_DTS_MODULE_ENABLED
55#define HAL_DSI_MODULE_ENABLED
56#define HAL_ETH_MODULE_ENABLED
57#define HAL_EXTI_MODULE_ENABLED
58#define HAL_FDCAN_MODULE_ENABLED
59#define HAL_FLASH_MODULE_ENABLED
60#define HAL_GFXMMU_MODULE_ENABLED
61#define HAL_FMAC_MODULE_ENABLED
62#define HAL_GPIO_MODULE_ENABLED
63#define HAL_HASH_MODULE_ENABLED
64#define HAL_HCD_MODULE_ENABLED
65#define HAL_HRTIM_MODULE_ENABLED
66#define HAL_HSEM_MODULE_ENABLED
67#define HAL_I2C_MODULE_ENABLED
68#define HAL_I2S_MODULE_ENABLED
69#define HAL_IRDA_MODULE_ENABLED
70#define HAL_IWDG_MODULE_ENABLED
71#define HAL_JPEG_MODULE_ENABLED
72#define HAL_LPTIM_MODULE_ENABLED
73#define HAL_LTDC_MODULE_ENABLED
74#define HAL_MDIOS_MODULE_ENABLED
75#define HAL_MDMA_MODULE_ENABLED
76#define HAL_MMC_MODULE_ENABLED
77#define HAL_NAND_MODULE_ENABLED
78#define HAL_NOR_MODULE_ENABLED
79#define HAL_OPAMP_MODULE_ENABLED
80#define HAL_OSPI_MODULE_ENABLED
81#define HAL_OTFDEC_MODULE_ENABLED
82#define HAL_PCD_MODULE_ENABLED
83#define HAL_PWR_MODULE_ENABLED
84#define HAL_PSSI_MODULE_ENABLED
85#define HAL_QSPI_MODULE_ENABLED
86#define HAL_RAMECC_MODULE_ENABLED
87#define HAL_RCC_MODULE_ENABLED
88#define HAL_RNG_MODULE_ENABLED
89#define HAL_RTC_MODULE_ENABLED
90#define HAL_SAI_MODULE_ENABLED
91#define HAL_SD_MODULE_ENABLED
92#define HAL_SDRAM_MODULE_ENABLED
93#define HAL_SMARTCARD_MODULE_ENABLED
94#define HAL_SMBUS_MODULE_ENABLED
95#define HAL_SPDIFRX_MODULE_ENABLED
96#define HAL_SPI_MODULE_ENABLED
97#define HAL_SRAM_MODULE_ENABLED
98#define HAL_SWPMI_MODULE_ENABLED
99#define HAL_TIM_MODULE_ENABLED
100#define HAL_UART_MODULE_ENABLED
101#define HAL_USART_MODULE_ENABLED
102#define HAL_WWDG_MODULE_ENABLED
103
104/* ########################## Oscillator Values adaptation ####################*/
110#if !defined (HSE_VALUE)
111#define HSE_VALUE (25000000UL)
112#endif /* HSE_VALUE */
113
114#if !defined (HSE_STARTUP_TIMEOUT)
115 #define HSE_STARTUP_TIMEOUT (100UL)
116#endif /* HSE_STARTUP_TIMEOUT */
117
122#if !defined (CSI_VALUE)
123 #define CSI_VALUE (4000000UL)
124#endif /* CSI_VALUE */
125
131#if !defined (HSI_VALUE)
132 #define HSI_VALUE (64000000UL)
133#endif /* HSI_VALUE */
134
139#if !defined (LSE_VALUE)
140 #define LSE_VALUE (32768UL)
141#endif /* LSE_VALUE */
142
143
144#if !defined (LSE_STARTUP_TIMEOUT)
145 #define LSE_STARTUP_TIMEOUT (5000UL)
146#endif /* LSE_STARTUP_TIMEOUT */
147
148#if !defined (LSI_VALUE)
149 #define LSI_VALUE (32000UL)
150#endif /* LSI_VALUE */
159#if !defined (EXTERNAL_CLOCK_VALUE)
160 #define EXTERNAL_CLOCK_VALUE 12288000UL
161#endif /* EXTERNAL_CLOCK_VALUE */
162
163/* Tip: To avoid modifying this file each time you need to use different HSE,
164 === you can define the HSE value in your toolchain compiler preprocessor. */
165
166/* ########################### System Configuration ######################### */
170#define VDD_VALUE (3300UL)
171#define TICK_INT_PRIORITY (0x0FUL)
172#define USE_RTOS 0
173#define USE_SD_TRANSCEIVER 0U
174#define USE_SPI_CRC 1U
176#define USE_HAL_ADC_REGISTER_CALLBACKS 0U /* ADC register callback disabled */
177#define USE_HAL_CEC_REGISTER_CALLBACKS 0U /* CEC register callback disabled */
178#define USE_HAL_COMP_REGISTER_CALLBACKS 0U /* COMP register callback disabled */
179#define USE_HAL_CORDIC_REGISTER_CALLBACKS 0U /* CORDIC register callback disabled */
180#define USE_HAL_CRYP_REGISTER_CALLBACKS 0U /* CRYP register callback disabled */
181#define USE_HAL_DAC_REGISTER_CALLBACKS 0U /* DAC register callback disabled */
182#define USE_HAL_DCMI_REGISTER_CALLBACKS 0U /* DCMI register callback disabled */
183#define USE_HAL_DFSDM_REGISTER_CALLBACKS 0U /* DFSDM register callback disabled */
184#define USE_HAL_DMA2D_REGISTER_CALLBACKS 0U /* DMA2D register callback disabled */
185#define USE_HAL_DSI_REGISTER_CALLBACKS 0U /* DSI register callback disabled */
186#define USE_HAL_DTS_REGISTER_CALLBACKS 0U /* DTS register callback disabled */
187#define USE_HAL_ETH_REGISTER_CALLBACKS 0U /* ETH register callback disabled */
188#define USE_HAL_FDCAN_REGISTER_CALLBACKS 0U /* FDCAN register callback disabled */
189#define USE_HAL_FMAC_REGISTER_CALLBACKS 0U /* FMAC register callback disabled */
190#define USE_HAL_NAND_REGISTER_CALLBACKS 0U /* NAND register callback disabled */
191#define USE_HAL_NOR_REGISTER_CALLBACKS 0U /* NOR register callback disabled */
192#define USE_HAL_SDRAM_REGISTER_CALLBACKS 0U /* SDRAM register callback disabled */
193#define USE_HAL_SRAM_REGISTER_CALLBACKS 0U /* SRAM register callback disabled */
194#define USE_HAL_HASH_REGISTER_CALLBACKS 0U /* HASH register callback disabled */
195#define USE_HAL_HCD_REGISTER_CALLBACKS 0U /* HCD register callback disabled */
196#define USE_HAL_GFXMMU_REGISTER_CALLBACKS 0U /* GFXMMU register callback disabled */
197#define USE_HAL_HRTIM_REGISTER_CALLBACKS 0U /* HRTIM register callback disabled */
198#define USE_HAL_I2C_REGISTER_CALLBACKS 0U /* I2C register callback disabled */
199#define USE_HAL_I2S_REGISTER_CALLBACKS 0U /* I2S register callback disabled */
200#define USE_HAL_IRDA_REGISTER_CALLBACKS 0U /* IRDA register callback disabled */
201#define USE_HAL_JPEG_REGISTER_CALLBACKS 0U /* JPEG register callback disabled */
202#define USE_HAL_LPTIM_REGISTER_CALLBACKS 0U /* LPTIM register callback disabled */
203#define USE_HAL_LTDC_REGISTER_CALLBACKS 0U /* LTDC register callback disabled */
204#define USE_HAL_MDIOS_REGISTER_CALLBACKS 0U /* MDIO register callback disabled */
205#define USE_HAL_MMC_REGISTER_CALLBACKS 0U /* MMC register callback disabled */
206#define USE_HAL_OPAMP_REGISTER_CALLBACKS 0U /* MDIO register callback disabled */
207#define USE_HAL_OSPI_REGISTER_CALLBACKS 0U /* OSPI register callback disabled */
208#define USE_HAL_OTFDEC_REGISTER_CALLBACKS 0U /* OTFDEC register callback disabled */
209#define USE_HAL_PCD_REGISTER_CALLBACKS 0U /* PCD register callback disabled */
210#define USE_HAL_QSPI_REGISTER_CALLBACKS 0U /* QSPI register callback disabled */
211#define USE_HAL_RNG_REGISTER_CALLBACKS 0U /* RNG register callback disabled */
212#define USE_HAL_RTC_REGISTER_CALLBACKS 0U /* RTC register callback disabled */
213#define USE_HAL_SAI_REGISTER_CALLBACKS 0U /* SAI register callback disabled */
214#define USE_HAL_SD_REGISTER_CALLBACKS 0U /* SD register callback disabled */
215#define USE_HAL_SMARTCARD_REGISTER_CALLBACKS 0U /* SMARTCARD register callback disabled */
216#define USE_HAL_SPDIFRX_REGISTER_CALLBACKS 0U /* SPDIFRX register callback disabled */
217#define USE_HAL_SMBUS_REGISTER_CALLBACKS 0U /* SMBUS register callback disabled */
218#define USE_HAL_SPI_REGISTER_CALLBACKS 0U /* SPI register callback disabled */
219#define USE_HAL_SWPMI_REGISTER_CALLBACKS 0U /* SWPMI register callback disabled */
220#define USE_HAL_TIM_REGISTER_CALLBACKS 0U /* TIM register callback disabled */
221#define USE_HAL_UART_REGISTER_CALLBACKS 0U /* UART register callback disabled */
222#define USE_HAL_USART_REGISTER_CALLBACKS 0U /* USART register callback disabled */
223#define USE_HAL_WWDG_REGISTER_CALLBACKS 0U /* WWDG register callback disabled */
224
225/* ########################### Ethernet Configuration ######################### */
226#define ETH_TX_DESC_CNT 4U /* number of Ethernet Tx DMA descriptors */
227#define ETH_RX_DESC_CNT 4U /* number of Ethernet Rx DMA descriptors */
228
229#define ETH_MAC_ADDR0 (0x02UL)
230#define ETH_MAC_ADDR1 (0x00UL)
231#define ETH_MAC_ADDR2 (0x00UL)
232#define ETH_MAC_ADDR3 (0x00UL)
233#define ETH_MAC_ADDR4 (0x00UL)
234#define ETH_MAC_ADDR5 (0x00UL)
235
236/* ########################## Assert Selection ############################## */
241/* #define USE_FULL_ASSERT 1 */
242
243
244/* Includes ------------------------------------------------------------------*/
249#ifdef HAL_RCC_MODULE_ENABLED
250 #include "stm32h7xx_hal_rcc.h"
251#endif /* HAL_RCC_MODULE_ENABLED */
252
253#ifdef HAL_GPIO_MODULE_ENABLED
254 #include "stm32h7xx_hal_gpio.h"
255#endif /* HAL_GPIO_MODULE_ENABLED */
256
257#ifdef HAL_DMA_MODULE_ENABLED
258 #include "stm32h7xx_hal_dma.h"
259#endif /* HAL_DMA_MODULE_ENABLED */
260
261#ifdef HAL_MDMA_MODULE_ENABLED
262 #include "stm32h7xx_hal_mdma.h"
263#endif /* HAL_MDMA_MODULE_ENABLED */
264
265#ifdef HAL_HASH_MODULE_ENABLED
266 #include "stm32h7xx_hal_hash.h"
267#endif /* HAL_HASH_MODULE_ENABLED */
268
269#ifdef HAL_DCMI_MODULE_ENABLED
270 #include "stm32h7xx_hal_dcmi.h"
271#endif /* HAL_DCMI_MODULE_ENABLED */
272
273#ifdef HAL_DMA2D_MODULE_ENABLED
274 #include "stm32h7xx_hal_dma2d.h"
275#endif /* HAL_DMA2D_MODULE_ENABLED */
276
277#ifdef HAL_DSI_MODULE_ENABLED
278 #include "stm32h7xx_hal_dsi.h"
279#endif /* HAL_DSI_MODULE_ENABLED */
280
281#ifdef HAL_DFSDM_MODULE_ENABLED
282 #include "stm32h7xx_hal_dfsdm.h"
283#endif /* HAL_DFSDM_MODULE_ENABLED */
284
285#ifdef HAL_DTS_MODULE_ENABLED
286 #include "stm32h7xx_hal_dts.h"
287#endif /* HAL_DTS_MODULE_ENABLED */
288
289#ifdef HAL_ETH_MODULE_ENABLED
290 #include "stm32h7xx_hal_eth.h"
291#endif /* HAL_ETH_MODULE_ENABLED */
292
293#ifdef HAL_EXTI_MODULE_ENABLED
294 #include "stm32h7xx_hal_exti.h"
295#endif /* HAL_EXTI_MODULE_ENABLED */
296
297#ifdef HAL_CORTEX_MODULE_ENABLED
298 #include "stm32h7xx_hal_cortex.h"
299#endif /* HAL_CORTEX_MODULE_ENABLED */
300
301#ifdef HAL_ADC_MODULE_ENABLED
302 #include "stm32h7xx_hal_adc.h"
303#endif /* HAL_ADC_MODULE_ENABLED */
304
305#ifdef HAL_FDCAN_MODULE_ENABLED
306 #include "stm32h7xx_hal_fdcan.h"
307#endif /* HAL_FDCAN_MODULE_ENABLED */
308
309#ifdef HAL_CEC_MODULE_ENABLED
310 #include "stm32h7xx_hal_cec.h"
311#endif /* HAL_CEC_MODULE_ENABLED */
312
313#ifdef HAL_COMP_MODULE_ENABLED
314 #include "stm32h7xx_hal_comp.h"
315#endif /* HAL_COMP_MODULE_ENABLED */
316
317#ifdef HAL_CORDIC_MODULE_ENABLED
318 #include "stm32h7xx_hal_cordic.h"
319#endif /* HAL_CORDIC_MODULE_ENABLED */
320
321#ifdef HAL_CRC_MODULE_ENABLED
322 #include "stm32h7xx_hal_crc.h"
323#endif /* HAL_CRC_MODULE_ENABLED */
324
325#ifdef HAL_CRYP_MODULE_ENABLED
326 #include "stm32h7xx_hal_cryp.h"
327#endif /* HAL_CRYP_MODULE_ENABLED */
328
329#ifdef HAL_DAC_MODULE_ENABLED
330 #include "stm32h7xx_hal_dac.h"
331#endif /* HAL_DAC_MODULE_ENABLED */
332
333#ifdef HAL_FLASH_MODULE_ENABLED
334 #include "stm32h7xx_hal_flash.h"
335#endif /* HAL_FLASH_MODULE_ENABLED */
336
337#ifdef HAL_GFXMMU_MODULE_ENABLED
338 #include "stm32h7xx_hal_gfxmmu.h"
339#endif /* HAL_GFXMMU_MODULE_ENABLED */
340
341#ifdef HAL_FMAC_MODULE_ENABLED
342 #include "stm32h7xx_hal_fmac.h"
343#endif /* HAL_FMAC_MODULE_ENABLED */
344
345#ifdef HAL_HRTIM_MODULE_ENABLED
346 #include "stm32h7xx_hal_hrtim.h"
347#endif /* HAL_HRTIM_MODULE_ENABLED */
348
349#ifdef HAL_HSEM_MODULE_ENABLED
350 #include "stm32h7xx_hal_hsem.h"
351#endif /* HAL_HSEM_MODULE_ENABLED */
352
353#ifdef HAL_SRAM_MODULE_ENABLED
354 #include "stm32h7xx_hal_sram.h"
355#endif /* HAL_SRAM_MODULE_ENABLED */
356
357#ifdef HAL_NOR_MODULE_ENABLED
358 #include "stm32h7xx_hal_nor.h"
359#endif /* HAL_NOR_MODULE_ENABLED */
360
361#ifdef HAL_NAND_MODULE_ENABLED
362 #include "stm32h7xx_hal_nand.h"
363#endif /* HAL_NAND_MODULE_ENABLED */
364
365#ifdef HAL_I2C_MODULE_ENABLED
366 #include "stm32h7xx_hal_i2c.h"
367#endif /* HAL_I2C_MODULE_ENABLED */
368
369#ifdef HAL_I2S_MODULE_ENABLED
370 #include "stm32h7xx_hal_i2s.h"
371#endif /* HAL_I2S_MODULE_ENABLED */
372
373#ifdef HAL_IWDG_MODULE_ENABLED
374 #include "stm32h7xx_hal_iwdg.h"
375#endif /* HAL_IWDG_MODULE_ENABLED */
376
377#ifdef HAL_JPEG_MODULE_ENABLED
378 #include "stm32h7xx_hal_jpeg.h"
379#endif /* HAL_JPEG_MODULE_ENABLED */
380
381#ifdef HAL_MDIOS_MODULE_ENABLED
382 #include "stm32h7xx_hal_mdios.h"
383#endif /* HAL_MDIOS_MODULE_ENABLED */
384
385#ifdef HAL_MMC_MODULE_ENABLED
386 #include "stm32h7xx_hal_mmc.h"
387#endif /* HAL_MMC_MODULE_ENABLED */
388
389#ifdef HAL_LPTIM_MODULE_ENABLED
390#include "stm32h7xx_hal_lptim.h"
391#endif /* HAL_LPTIM_MODULE_ENABLED */
392
393#ifdef HAL_LTDC_MODULE_ENABLED
394#include "stm32h7xx_hal_ltdc.h"
395#endif /* HAL_LTDC_MODULE_ENABLED */
396
397#ifdef HAL_OPAMP_MODULE_ENABLED
398#include "stm32h7xx_hal_opamp.h"
399#endif /* HAL_OPAMP_MODULE_ENABLED */
400
401#ifdef HAL_OSPI_MODULE_ENABLED
402 #include "stm32h7xx_hal_ospi.h"
403#endif /* HAL_OSPI_MODULE_ENABLED */
404
405#ifdef HAL_OTFDEC_MODULE_ENABLED
406#include "stm32h7xx_hal_otfdec.h"
407#endif /* HAL_OTFDEC_MODULE_ENABLED */
408
409#ifdef HAL_PSSI_MODULE_ENABLED
410 #include "stm32h7xx_hal_pssi.h"
411#endif /* HAL_PSSI_MODULE_ENABLED */
412
413#ifdef HAL_PWR_MODULE_ENABLED
414 #include "stm32h7xx_hal_pwr.h"
415#endif /* HAL_PWR_MODULE_ENABLED */
416
417#ifdef HAL_QSPI_MODULE_ENABLED
418 #include "stm32h7xx_hal_qspi.h"
419#endif /* HAL_QSPI_MODULE_ENABLED */
420
421#ifdef HAL_RAMECC_MODULE_ENABLED
422 #include "stm32h7xx_hal_ramecc.h"
423#endif /* HAL_RAMECC_MODULE_ENABLED */
424
425#ifdef HAL_RNG_MODULE_ENABLED
426 #include "stm32h7xx_hal_rng.h"
427#endif /* HAL_RNG_MODULE_ENABLED */
428
429#ifdef HAL_RTC_MODULE_ENABLED
430 #include "stm32h7xx_hal_rtc.h"
431#endif /* HAL_RTC_MODULE_ENABLED */
432
433#ifdef HAL_SAI_MODULE_ENABLED
434 #include "stm32h7xx_hal_sai.h"
435#endif /* HAL_SAI_MODULE_ENABLED */
436
437#ifdef HAL_SD_MODULE_ENABLED
438 #include "stm32h7xx_hal_sd.h"
439#endif /* HAL_SD_MODULE_ENABLED */
440
441#ifdef HAL_SDRAM_MODULE_ENABLED
442 #include "stm32h7xx_hal_sdram.h"
443#endif /* HAL_SDRAM_MODULE_ENABLED */
444
445#ifdef HAL_SPI_MODULE_ENABLED
446 #include "stm32h7xx_hal_spi.h"
447#endif /* HAL_SPI_MODULE_ENABLED */
448
449#ifdef HAL_SPDIFRX_MODULE_ENABLED
450 #include "stm32h7xx_hal_spdifrx.h"
451#endif /* HAL_SPDIFRX_MODULE_ENABLED */
452
453#ifdef HAL_SWPMI_MODULE_ENABLED
454 #include "stm32h7xx_hal_swpmi.h"
455#endif /* HAL_SWPMI_MODULE_ENABLED */
456
457#ifdef HAL_TIM_MODULE_ENABLED
458 #include "stm32h7xx_hal_tim.h"
459#endif /* HAL_TIM_MODULE_ENABLED */
460
461#ifdef HAL_UART_MODULE_ENABLED
462 #include "stm32h7xx_hal_uart.h"
463#endif /* HAL_UART_MODULE_ENABLED */
464
465#ifdef HAL_USART_MODULE_ENABLED
466 #include "stm32h7xx_hal_usart.h"
467#endif /* HAL_USART_MODULE_ENABLED */
468
469#ifdef HAL_IRDA_MODULE_ENABLED
470 #include "stm32h7xx_hal_irda.h"
471#endif /* HAL_IRDA_MODULE_ENABLED */
472
473#ifdef HAL_SMARTCARD_MODULE_ENABLED
474 #include "stm32h7xx_hal_smartcard.h"
475#endif /* HAL_SMARTCARD_MODULE_ENABLED */
476
477#ifdef HAL_SMBUS_MODULE_ENABLED
478 #include "stm32h7xx_hal_smbus.h"
479#endif /* HAL_SMBUS_MODULE_ENABLED */
480
481#ifdef HAL_WWDG_MODULE_ENABLED
482 #include "stm32h7xx_hal_wwdg.h"
483#endif /* HAL_WWDG_MODULE_ENABLED */
484
485#ifdef HAL_PCD_MODULE_ENABLED
486 #include "stm32h7xx_hal_pcd.h"
487#endif /* HAL_PCD_MODULE_ENABLED */
488
489#ifdef HAL_HCD_MODULE_ENABLED
490 #include "stm32h7xx_hal_hcd.h"
491#endif /* HAL_HCD_MODULE_ENABLED */
492
493/* Exported macro ------------------------------------------------------------*/
494#ifdef USE_FULL_ASSERT
503 #define assert_param(expr) ((expr) ? (void)0U : assert_failed((uint8_t *)__FILE__, __LINE__))
504/* Exported functions ------------------------------------------------------- */
505 void assert_failed(uint8_t *file, uint32_t line);
506#else
507 #define assert_param(expr) ((void)0U)
508#endif /* USE_FULL_ASSERT */
509
510#ifdef __cplusplus
511}
512#endif
513
514#endif /* STM32H7xx_HAL_CONF_H */
515
516
517
