RTEMS 7.0-rc1
stm32f4xxxx_otgfs.h
1/* SPDX-License-Identifier: GPL-2.0+-with-RTEMS-exception */
2
3/*
4 * Copyright (c) 2013 Chris Nott. All rights reserved.
5 *
6 * Virtual Logic
7 * 21-25 King St.
8 * Rockdale NSW 2216
9 * Australia
10 * <rtems@vl.com.au>
11 *
12 * The license and distribution terms for this file may be
13 * found in the file LICENSE in this distribution or at
14 * http://www.rtems.org/license/LICENSE.
15 */
16
17#ifndef LIBBSP_ARM_STM32F4_STM32F4XXXX_OTGFS_H
18#define LIBBSP_ARM_STM32F4_STM32F4XXXX_OTGFS_H
19
20#include <bsp/utility.h>
21
22#define USB_OTG_NUM_EPS 4
23#define USB_OTG_MAX_TX_FIFOS 4
24
25#define USB_FIFO_BASE 0x1000
26#define USB_FIFO_OFFS 0x1000
27
29 uint32_t gotgctl; // 0x00: Control and status register
30#define STM32F4_OTGFS_GOTGCTL_BSVLD BSP_BIT32(19) // B-session valid
31#define STM32F4_OTGFS_GOTGCTL_ASVLD BSP_BIT32(18) // A-session valid
32#define STM32F4_OTGFS_GOTGCTL_DBCT BSP_BIT32(17) // Debounce time
33#define STM32F4_OTGFS_GOTGCTL_CIDSTS BSP_BIT32(16) // Connector ID status
34#define STM32F4_OTGFS_GOTGCTL_DHNPEN BSP_BIT32(11) // Device HNP enable
35#define STM32F4_OTGFS_GOTGCTL_HSHNPEN BSP_BIT32(10) // Host set HNP enable
36#define STM32F4_OTGFS_GOTGCTL_HNPRQ BSP_BIT32(9) // HNP request
37#define STM32F4_OTGFS_GOTGCTL_HNGSCS BSP_BIT32(8) // Host negotiation status
38#define STM32F4_OTGFS_GOTGCTL_SRQ BSP_BIT32(1) // Session request
39#define STM32F4_OTGFS_GOTGCTL_SRQSCS BSP_BIT32(0) // Session request success
40
41 uint32_t gotgint; // 0x04: Interrupt register
42#define STM32F4_OTGFS_GOTGINT_DBCDNE BSP_BIT32(19) // Debounce done
43#define STM32F4_OTGFS_GOTGINT_ADTOCHG BSP_BIT32(18) // A-device timeout change
44#define STM32F4_OTGFS_GOTGINT_HNGDET BSP_BIT32(17) // Host negotiation detected
45#define STM32F4_OTGFS_GOTGINT_HNSSCHG BSP_BIT32(9) // Host negotiation success status change
46#define STM32F4_OTGFS_GOTGINT_SRSSCHG BSP_BIT32(8) // Session request status change
47#define STM32F4_OTGFS_GOTGINT_SEDET BSP_BIT32(2) // Session end detected
48
49 uint32_t gahbcfg; // 0x08: AHB configuration register
50#define STM32F4_OTGFS_GAHBCFG_PTXFELVL BSP_BIT32(8) // Periodic txfifo empty level
51#define STM32F4_OTGFS_GAHBCFG_TXFELVL BSP_BIT32(7) // Txfifo empty level
52#define STM32F4_OTGFS_GAHBCFG_GINTMSK BSP_BIT32(0) // Global interrupt mask
53
54 uint32_t gusbcfg; // 0x0C: USB configuration register
55#define STM32F4_OTGFS_GUSBCFG_CTXPKT BSP_BIT32(31) // Corrupt TX packet
56#define STM32F4_OTGFS_GUSBCFG_FDMOD BSP_BIT32(30) // Force device mode
57#define STM32F4_OTGFS_GUSBCFG_FHMOD BSP_BIT32(29) // Force host mode
58#define STM32F4_OTGFS_GUSBCFG_TRDT(val) BSP_FLD32(val, 10, 13) // USB turnaround time
59#define STM32F4_OTGFS_GUSBCFG_TRDT_GET(reg) BSP_FLD32GET(reg, 10, 13)
60#define STM32F4_OTGFS_GUSBCFG_TRDT_SET(reg, val) BSP_FLD32SET(reg, val, 10, 13)
61#define STM32F4_OTGFS_GUSBCFG_HNPCAP BSP_BIT32(9) // HNP-capable
62#define STM32F4_OTGFS_GUSBCFG_SRPCAP BSP_BIT32(8) // SRP-capable
63#define STM32F4_OTGFS_GUSBCFG_PHYSEL BSP_BIT32(6) // Full speed serial transceiver select
64#define STM32F4_OTGFS_GUSBCFG_TOCAL(val) BSP_FLD32(val, 0, 2) // FS timeout calibration
65#define STM32F4_OTGFS_GUSBCFG_TOCAL_GET(reg) BSP_FLD32GET(reg, 0, 2)
66#define STM32F4_OTGFS_GUSBCFG_TOCAL_SET(reg, val) BSP_FLD32SET(reg, val, 0, 2)
67
68 uint32_t grstctl; // 0x10: Reset register
69#define STM32F4_OTGFS_GRSTCTL_AHBIDL BSP_BIT32(31) // AHB master idle
70#define STM32F4_OTGFS_GRSTCTL_TXFNUM(val) BSP_FLD32(val, 6, 10) // Tx fifo number
71#define STM32F4_OTGFS_GRSTCTL_TXFNUM_GET(reg) BSP_FLD32GET(reg, 6, 10)
72#define STM32F4_OTGFS_GRSTCTL_TXFNUM_SET(reg, val) BSP_FLD32SET(reg, val, 6, 10)
73#define STM32F4_OTGFS_GRSTCTL_TXFNUM_ALL STM32F4_OTGFS_GRSTCTL_TXFNUM(0x10)
74#define STM32F4_OTGFS_GRSTCTL_TXFFLSH BSP_BIT32(5) // TX fifo flush
75#define STM32F4_OTGFS_GRSTCTL_RXFFLSH BSP_BIT32(4) // RX fifo flush
76#define STM32F4_OTGFS_GRSTCTL_FCRST BSP_BIT32(2) // Host frame counter reset
77#define STM32F4_OTGFS_GRSTCTL_HSRST BSP_BIT32(1) // HCLK soft reset
78#define STM32F4_OTGFS_GRSTCTL_CSRST BSP_BIT32(0) // Core soft reset
79
80 uint32_t gintsts; // 0x14: Core interrupt register
81#define STM32F4_OTGFS_GINTSTS_WKUPINT BSP_BIT32(31) // Resume / remote wakeup detected interrupt
82#define STM32F4_OTGFS_GINTSTS_SRQINT BSP_BIT32(30) // Session request / new session detected interrupt
83#define STM32F4_OTGFS_GINTSTS_DISCINT BSP_BIT32(29) // Disconnect detected interrupt
84#define STM32F4_OTGFS_GINTSTS_CIDSCHG BSP_BIT32(28) // Connector ID status change
85#define STM32F4_OTGFS_GINTSTS_PTXFE BSP_BIT32(26) // Periodic TX fifo empty
86#define STM32F4_OTGFS_GINTSTS_HCINT BSP_BIT32(25) // Host channels interrupt
87#define STM32F4_OTGFS_GINTSTS_HPRTINT BSP_BIT32(24) // Host port interrupt
88#define STM32F4_OTGFS_GINTSTS_IPXFR BSP_BIT32(21) // Incomplete periodic transfer
89#define STM32F4_OTGFS_GINTSTS_IISOOXFR BSP_BIT32(21) // Incomplete isochronous OUT transfer
90#define STM32F4_OTGFS_GINTSTS_IISOIXFR BSP_BIT32(20) // Incomplete isochronous IN transfer
91#define STM32F4_OTGFS_GINTSTS_OEPINT BSP_BIT32(19) // OUT endpoint interrupt
92#define STM32F4_OTGFS_GINTSTS_IEPINT BSP_BIT32(18) // IN endpoint interrupt
93#define STM32F4_OTGFS_GINTSTS_EOPF BSP_BIT32(15) // End of periodic frame interrupt
94#define STM32F4_OTGFS_GINTSTS_ISOODRP BSP_BIT32(14) // Isochronous OUT packet dropped interrupt
95#define STM32F4_OTGFS_GINTSTS_ENUMDNE BSP_BIT32(13) // Enumeration done
96#define STM32F4_OTGFS_GINTSTS_USBRST BSP_BIT32(12) // USB reset
97#define STM32F4_OTGFS_GINTSTS_USBSUSP BSP_BIT32(11) // USB suspend
98#define STM32F4_OTGFS_GINTSTS_ESUSP BSP_BIT32(10) // Early suspend
99#define STM32F4_OTGFS_GINTSTS_GONAKEFF BSP_BIT32(7) // Global OUT NAK effective
100#define STM32F4_OTGFS_GINTSTS_GINAKEFF BSP_BIT32(6) // Global IN non-periodic NAK effective
101#define STM32F4_OTGFS_GINTSTS_NPTXFE BSP_BIT32(5) // Non-periodic TX fifo empty
102#define STM32F4_OTGFS_GINTSTS_RXFLVL BSP_BIT32(4) // RX fifo non-empty
103#define STM32F4_OTGFS_GINTSTS_SOF BSP_BIT32(3) // Start of frame
104#define STM32F4_OTGFS_GINTSTS_OTGINT BSP_BIT32(2) // OTG interrupt
105#define STM32F4_OTGFS_GINTSTS_MMIS BSP_BIT32(1) // Mode mismatch interrupt
106#define STM32F4_OTGFS_GINTSTS_CMOD BSP_BIT32(0) // Current mode of operation
107
108 uint32_t gintmsk; // 0x18: Interrupt mask register
109
110 uint32_t grxstsr; // 0x1C: Receive status debug read
111
112 uint32_t grxstsp; // 0x20: OTG status read and pop
113#define STM32F4_OTGFS_GRXSTSP_FRMNUM(val) BSP_FLD32(val, 21, 24) // Frame number
114#define STM32F4_OTGFS_GRXSTSP_FRMNUM_GET(reg) BSP_FLD32GET(reg, 21, 24)
115#define STM32F4_OTGFS_GRXSTSP_FRMNUM_SET(reg, val) BSP_FLD32SET(reg, val, 21, 24)
116#define STM32F4_OTGFS_GRXSTSP_PKTSTS(val) BSP_FLD32(val, 17, 20) // Packet status
117#define STM32F4_OTGFS_GRXSTSP_PKTSTS_GET(reg) BSP_FLD32GET(reg, 17, 20)
118#define STM32F4_OTGFS_GRXSTSP_PKTSTS_SET(reg, val) BSP_FLD32SET(reg, val, 17, 20)
119#define PKTSTS_IN_DATA (0x2)
120#define PKTSTS_IN_COMPLETE (0x3)
121#define PKTSTS_TOGGLE_ERR (0x5)
122#define PKTSTS_HALTED (0x7)
123#define PKTSTS_OUTNAK (0x1)
124#define PKTSTS_OUT_DATA (0x2)
125#define PKTSTS_OUT_COMPLETE (0x3)
126#define PKTSTS_SETUP_COMPLETE (0x4)
127#define PKTSTS_SETUP_DATA (0x6)
128#define STM32F4_OTGFS_GRXSTSP_DPIG(val) BSP_FLD32(val, 15, 16) // Data PID
129#define STM32F4_OTGFS_GRXSTSP_DPID_GET(reg) BSP_FLD32GET(reg, 15, 16)
130#define STM32F4_OTGFS_GRXSTSP_DPID_SET(reg, val) BSP_FLD32SET(reg, val, 15, 16)
131#define STM32F4_OTGFS_GRXSTSP_DPID_DATA0 STM32F4_OTGFS_GRXSTSP_PKTSTS(0x0)
132#define STM32F4_OTGFS_GRXSTSP_DPID_DATA1 STM32F4_OTGFS_GRXSTSP_PKTSTS(0x1)
133#define STM32F4_OTGFS_GRXSTSP_DPID_DATA2 STM32F4_OTGFS_GRXSTSP_PKTSTS(0x2)
134#define STM32F4_OTGFS_GRXSTSP_DPID_MDATA0 STM32F4_OTGFS_GRXSTSP_PKTSTS(0x3)
135#define STM32F4_OTGFS_GRXSTSP_BCNT(val) BSP_FLD32(val, 4, 14) // Byte count
136#define STM32F4_OTGFS_GRXSTSP_BCNT_GET(reg) BSP_FLD32GET(reg, 4, 14)
137#define STM32F4_OTGFS_GRXSTSP_BCNT_SET(reg, val) BSP_FLD32SET(reg, val, 4, 14)
138#define STM32F4_OTGFS_GRXSTSP_CHNUM(val) BSP_FLD32(val, 0, 3) // Channel number
139#define STM32F4_OTGFS_GRXSTSP_CHNUM_GET(reg) BSP_FLD32GET(reg, 0, 3)
140#define STM32F4_OTGFS_GRXSTSP_CHNUM_SET(reg, val) BSP_FLD32SET(reg, val, 0, 3)
141#define STM32F4_OTGFS_GRXSTSP_EPNUM(val) BSP_FLD32(val, 0, 3) // Endpoint number
142#define STM32F4_OTGFS_GRXSTSP_EPNUM_GET(reg) BSP_FLD32GET(reg, 0, 3)
143#define STM32F4_OTGFS_GRXSTSP_EPNUM_SET(reg, val) BSP_FLD32SET(reg, val, 0, 3)
144
145 uint32_t grxfsiz; // 0x24: Receive FIFO size register
146#define STM32F4_OTGFS_GRXFSIZ_RXFD(val) BSP_FLD32(val, 0, 15)
147#define STM32F4_OTGFS_GRXFSIZ_RXFD_GET(reg) BSP_FLD32GET(reg, 0, 15)
148#define STM32F4_OTGFS_GRXFSIZ_RXFD_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
149#define STM32F4_OTGFS_GRXFSIZ_RXFD_MIN 16
150#define STM32F4_OTGFS_GRXFSIZ_RXFD_MAX 256
151
152 uint32_t dieptxf0; // 0x28: EP 0 transmit fifo size
153#define STM32F4_OTGFS_DIEPTXF_DEPTH(val) BSP_FLD32(val, 16, 31)
154#define STM32F4_OTGFS_DIEPTXF_DEPTH_GET(reg) BSP_FLD32GET(reg, 16, 31)
155#define STM32F4_OTGFS_DIEPTXF_DEPTH_SET(reg, val) BSP_FLD32SET(reg, val, 16, 31)
156#define STM32F4_OTGFS_DIEPTXF_DEPTH_MIN 16
157#define STM32F4_OTGFS_DIEPTXF_DEPTH_MAX 256
158#define STM32F4_OTGFS_DIEPTXF_SADDR(val) BSP_FLD32(val, 0, 15)
159#define STM32F4_OTGFS_DIEPTXF_SADDR_GET(reg) BSP_FLD32GET(reg, 0, 15)
160#define STM32F4_OTGFS_DIEPTXF_SADDR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
161
162 uint32_t resv2C;
163
164 uint32_t gi2cctl; // 0x30
165 uint32_t resv34; // 0x34
166
167 uint32_t gccfg; // 0x38: General core configuration register
168#define STM32F4_OTGFS_GCCFG_NOVBUSSENS BSP_BIT32(21) // Vbus sensing disable
169#define STM32F4_OTGFS_GCCFG_SOFOUTEN BSP_BIT32(20) // SOF output enable
170#define STM32F4_OTGFS_GCCFG_VBUSBSEN BSP_BIT32(19) // Vbus sensing "B" device
171#define STM32F4_OTGFS_GCCFG_VBUSASEN BSP_BIT32(18) // Vbus sensing "A" device
172#define STM32F4_OTGFS_GCCFG_PWRDWN BSP_BIT32(16) // Power down
173
174 uint32_t cid; // 0x3C: Product ID
175
176 uint32_t resv40[48]; // 0x40 - 0x9C
177
178 uint32_t hptxfsiz; // 0x100
179
180 uint32_t dieptxf[USB_OTG_MAX_TX_FIFOS]; // 0x104
181
182} __attribute__ ((packed));
183typedef struct stm32f4_otgfs_s stm32f4_otgfs;
184
186 uint32_t dcfg; // 0x800
187#define STM32F4_OTGFS_DCFG_PFIVL(val) BSP_FLD32(val, 11, 12) // Periodic frame interval
188#define STM32F4_OTGFS_DCFG_PFIVL_GET(reg) BSP_FLD32GET(reg, 11, 12)
189#define STM32F4_OTGFS_DCFG_PFIVL_SET(reg, val) BSP_FLD32SET(reg, val, 11, 12)
190#define PFIVL_80 0
191#define PFIVL_85 1
192#define PFIVL_90 2
193#define PFIVL_95 3
194#define STM32F4_OTGFS_DCFG_DAD(val) BSP_FLD32(val, 4, 10) // Device address
195#define STM32F4_OTGFS_DCFG_DAD_GET(reg) BSP_FLD32GET(reg, 4, 10)
196#define STM32F4_OTGFS_DCFG_DAD_SET(reg, val) BSP_FLD32SET(reg, val, 4, 10)
197#define STM32F4_OTGFS_DCFG_NZLSOHSK BSP_BIT32(2) // Non-zero-length status OUT handshake
198#define STM32F4_OTGFS_DCFG_DSPD(val) BSP_FLD32(val, 0, 1) // Device speed
199#define STM32F4_OTGFS_DCFG_DSPD_GET(reg) BSP_FLD32GET(reg, 0, 1)
200#define STM32F4_OTGFS_DCFG_DSPD_SET(reg, val) BSP_FLD32SET(reg, val, 0, 1)
201#define STM32F4_OTGFS_DCFG_DSPD_FULL STM32F4_OTGFS_DCFG_DSPD(0x3)
202
203 uint32_t dctl; // 0x804
204#define STM32F4_OTGFS_DCTL_POPRGDNE BSP_BIT32(11) // Power-on programming done
205#define STM32F4_OTGFS_DCTL_CGONAK BSP_BIT32(10) // Clear global OUT NAK
206#define STM32F4_OTGFS_DCTL_SGONAK BSP_BIT32(9) // Set global OUT NAK
207#define STM32F4_OTGFS_DCTL_CGINAK BSP_BIT32(8) // Clear global IN NAK
208#define STM32F4_OTGFS_DCTL_SGINAK BSP_BIT32(7) // Set global IN NAK
209#define STM32F4_OTGFS_DCTL_TCTL(val) BSP_FLD32(val, 4, 6) // Test control
210#define STM32F4_OTGFS_DCTL_TCTL_GET(reg) BSP_FLD32GET(reg, 4, 6)
211#define STM32F4_OTGFS_DCTL_TCTL_SET(reg, val) BSP_FLD32SET(reg, val, 4, 6)
212#define STM32F4_OTGFS_DCTL_GONSTS BSP_BIT32(3) // Global OUT NAK status
213#define STM32F4_OTGFS_DCTL_GINSTS BSP_BIT32(2) // Global IN NAK status
214#define STM32F4_OTGFS_DCTL_SDIS BSP_BIT32(1) // Soft disconnect
215#define STM32F4_OTGFS_DCTL_RWUSIG BSP_BIT32(0) // Remote wakeup signalling
216
217 uint32_t dsts; // 0x808
218#define STM32F4_OTGFS_DSTS_FNSOF(val) BSP_FLD32(val, 8, 21) // Frame number of received SOF
219#define STM32F4_OTGFS_DSTS_FNSOF_GET(reg) BSP_FLD32GET(reg, 8, 21)
220#define STM32F4_OTGFS_DSTS_EERR BSP_BIT32(3) // Erratic error
221#define STM32F4_OTGFS_DSTS_ENUMSPD(val) BSP_FLD32(val, 1, 2) // Enumerated speed
222#define STM32F4_OTGFS_DSTS_ENUMSPD_GET(reg) BSP_FLD32GET(reg, 1, 2)
223#define STM32F4_OTGFS_DSTS_ENUMSPD_FULL STM32F4_OTGFS_DSTS_ENUMSPD(0x3)
224#define STM32F4_OTGFS_DSTS_SUSPSTS BSP_BIT32(0) // Suspend status
225
226 uint32_t unused4; // 0x80C
227
228 uint32_t diepmsk; // 0x810
229
230 uint32_t doepmsk; // 0x814
231
232 uint32_t daint; // 0x818
233#define STM32F4_OTGFS_DAINT_OEPINT15 BSP_BIT32(31) // OUT endpoint 15 interrupt
234#define STM32F4_OTGFS_DAINT_OEPINT14 BSP_BIT32(30) // OUT endpoint 14 interrupt
235#define STM32F4_OTGFS_DAINT_OEPINT13 BSP_BIT32(29) // OUT endpoint 13 interrupt
236#define STM32F4_OTGFS_DAINT_OEPINT12 BSP_BIT32(28) // OUT endpoint 12 interrupt
237#define STM32F4_OTGFS_DAINT_OEPINT11 BSP_BIT32(27) // OUT endpoint 11 interrupt
238#define STM32F4_OTGFS_DAINT_OEPINT10 BSP_BIT32(26) // OUT endpoint 10 interrupt
239#define STM32F4_OTGFS_DAINT_OEPINT9 BSP_BIT32(25) // OUT endpoint 9 interrupt
240#define STM32F4_OTGFS_DAINT_OEPINT8 BSP_BIT32(24) // OUT endpoint 8 interrupt
241#define STM32F4_OTGFS_DAINT_OEPINT7 BSP_BIT32(23) // OUT endpoint 7 interrupt
242#define STM32F4_OTGFS_DAINT_OEPINT6 BSP_BIT32(22) // OUT endpoint 6 interrupt
243#define STM32F4_OTGFS_DAINT_OEPINT5 BSP_BIT32(21) // OUT endpoint 5 interrupt
244#define STM32F4_OTGFS_DAINT_OEPINT4 BSP_BIT32(20) // OUT endpoint 4 interrupt
245#define STM32F4_OTGFS_DAINT_OEPINT3 BSP_BIT32(19) // OUT endpoint 3 interrupt
246#define STM32F4_OTGFS_DAINT_OEPINT2 BSP_BIT32(18) // OUT endpoint 2 interrupt
247#define STM32F4_OTGFS_DAINT_OEPINT1 BSP_BIT32(17) // OUT endpoint 1 interrupt
248#define STM32F4_OTGFS_DAINT_OEPINT0 BSP_BIT32(16) // OUT endpoint 0 interrupt
249#define STM32F4_OTGFS_DAINT_IEPINT15 BSP_BIT32(15) // IN endpoint 15 interrupt
250#define STM32F4_OTGFS_DAINT_IEPINT14 BSP_BIT32(14) // IN endpoint 14 interrupt
251#define STM32F4_OTGFS_DAINT_IEPINT13 BSP_BIT32(13) // IN endpoint 13 interrupt
252#define STM32F4_OTGFS_DAINT_IEPINT12 BSP_BIT32(12) // IN endpoint 12 interrupt
253#define STM32F4_OTGFS_DAINT_IEPINT11 BSP_BIT32(11) // IN endpoint 11 interrupt
254#define STM32F4_OTGFS_DAINT_IEPINT10 BSP_BIT32(10) // IN endpoint 10 interrupt
255#define STM32F4_OTGFS_DAINT_IEPINT9 BSP_BIT32(9) // IN endpoint 9 interrupt
256#define STM32F4_OTGFS_DAINT_IEPINT8 BSP_BIT32(8) // IN endpoint 8 interrupt
257#define STM32F4_OTGFS_DAINT_IEPINT7 BSP_BIT32(7) // IN endpoint 7 interrupt
258#define STM32F4_OTGFS_DAINT_IEPINT6 BSP_BIT32(6) // IN endpoint 6 interrupt
259#define STM32F4_OTGFS_DAINT_IEPINT5 BSP_BIT32(5) // IN endpoint 5 interrupt
260#define STM32F4_OTGFS_DAINT_IEPINT4 BSP_BIT32(4) // IN endpoint 4 interrupt
261#define STM32F4_OTGFS_DAINT_IEPINT3 BSP_BIT32(3) // IN endpoint 3 interrupt
262#define STM32F4_OTGFS_DAINT_IEPINT2 BSP_BIT32(2) // IN endpoint 2 interrupt
263#define STM32F4_OTGFS_DAINT_IEPINT1 BSP_BIT32(1) // IN endpoint 1 interrupt
264#define STM32F4_OTGFS_DAINT_IEPINT0 BSP_BIT32(0) // IN endpoint 0 interrupt
265
266 uint32_t daintmsk; // 0x81C
267#define STM32F4_OTGFS_DAINTMSK_OEPM(val) BSP_FLD32(val, 16, 31) // OUT endpoint interrupt mask
268#define STM32F4_OTGFS_DAINTMSK_OEPM_GET(reg) BSP_FLD32GET(reg, 16, 31)
269#define STM32F4_OTGFS_DAINTMSK_OEPM_SET(reg, val) BSP_FLD32SET(reg, val, 16, 31)
270#define STM32F4_OTGFS_DAINTMSK_IEPM(val) BSP_FLD32(val, 0, 15) // IN endpoint interrupt mask
271#define STM32F4_OTGFS_DAINTMSK_IEPM_GET(reg) BSP_FLD32GET(reg, 0, 15)
272#define STM32F4_OTGFS_DAINTMSK_IEPM_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
273
274 uint32_t unused5[2]; // 0x820 - 0x824
275
276 uint32_t dvbusdis; // 0x828
277#define STM32F4_OTGFS_DVBUSDIS_VBUSDT(val) BSP_FLD32(val, 0, 15) // Device Vbus discharge time
278#define STM32F4_OTGFS_DVBUSDIS_VBUSDT_GET(reg) BSP_FLD32GET(reg, 0, 15)
279#define STM32F4_OTGFS_DVBUSDIS_VBUSDT_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
280
281 uint32_t dvbuspulse; // 0x82C
282#define STM32F4_OTGFS_DVBUSPULSE_DVBUSP(val) BSP_FLD32(val, 0, 15) // Device Vbus pulsing time
283#define STM32F4_OTGFS_DVBUSPULSE_DVBUSP_GET(reg) BSP_FLD32GET(reg, 0, 15)
284#define STM32F4_OTGFS_DVBUSPULSE_DVBUSP_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
285
286 uint32_t unused6; // 0x830
287
288 uint32_t diepempmsk; // 0x834
289#define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM15 BSP_BIT32(15) // IN endpoint 15 TxFIFO empty interrupt mask
290#define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM14 BSP_BIT32(14) // IN endpoint 14 TxFIFO empty interrupt mask
291#define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM13 BSP_BIT32(13) // IN endpoint 13 TxFIFO empty interrupt mask
292#define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM12 BSP_BIT32(12) // IN endpoint 12 TxFIFO empty interrupt mask
293#define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM11 BSP_BIT32(11) // IN endpoint 11 TxFIFO empty interrupt mask
294#define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM10 BSP_BIT32(10) // IN endpoint 10 TxFIFO empty interrupt mask
295#define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM9 BSP_BIT32(9) // IN endpoint 9 TxFIFO empty interrupt mask
296#define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM8 BSP_BIT32(8) // IN endpoint 8 TxFIFO empty interrupt mask
297#define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM7 BSP_BIT32(7) // IN endpoint 7 TxFIFO empty interrupt mask
298#define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM6 BSP_BIT32(6) // IN endpoint 6 TxFIFO empty interrupt mask
299#define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM5 BSP_BIT32(5) // IN endpoint 5 TxFIFO empty interrupt mask
300#define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM4 BSP_BIT32(4) // IN endpoint 4 TxFIFO empty interrupt mask
301#define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM3 BSP_BIT32(3) // IN endpoint 3 TxFIFO empty interrupt mask
302#define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM2 BSP_BIT32(2) // IN endpoint 2 TxFIFO empty interrupt mask
303#define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM1 BSP_BIT32(1) // IN endpoint 1 TxFIFO empty interrupt mask
304#define STM32F4_OTGFS_DIEPEMPMSK_INEPTXFEM0 BSP_BIT32(0) // IN endpoint 0 TxFIFO empty interrupt mask
305
306} __attribute__ ((packed));
308
310 uint32_t diepctl; // 0x900
311#define STM32F4_OTGFS_DIEPCTL_EPENA BSP_BIT32(31) // Endpoint enable
312#define STM32F4_OTGFS_DIEPCTL_EPDIS BSP_BIT32(30) // Endpoint disable
313#define STM32F4_OTGFS_DIEPCTL_SODDFRM BSP_BIT32(29) // Set odd frame
314#define STM32F4_OTGFS_DIEPCTL_SD0PID BSP_BIT32(28) // Set DATA0 PID / Set even frame
315#define STM32F4_OTGFS_DIEPCTL_SEVNFRM BSP_BIT32(28) // Set DATA0 PID / Set even frame
316#define STM32F4_OTGFS_DIEPCTL_SNAK BSP_BIT32(27) // Set NAK
317#define STM32F4_OTGFS_DIEPCTL_CNAK BSP_BIT32(26) // Clear NAK
318#define STM32F4_OTGFS_DIEPCTL_TXFNUM(val) BSP_FLD32(val, 22, 25) // TxFIFO number
319#define STM32F4_OTGFS_DIEPCTL_TXFNUM_GET(reg) BSP_FLD32GET(reg, 22, 25)
320#define STM32F4_OTGFS_DIEPCTL_TXFNUM_SET(reg, val) BSP_FLD32SET(reg, val, 22, 25)
321#define STM32F4_OTGFS_DIEPCTL_STALL BSP_BIT32(21) // Stall handshake
322#define STM32F4_OTGFS_DIEPCTL_EPTYP(val) BSP_FLD32(val, 18, 19) // Endpoint type - 00 = Control, 01 = Isoch, 10 = Bulk, 11 = Interrupt
323#define STM32F4_OTGFS_DIEPCTL_EPTYP_GET(reg) BSP_FLD32GET(reg, 18, 19)
324#define STM32F4_OTGFS_DIEPCTL_EPTYP_SET(reg, val) BSP_FLD32SET(reg, val, 18, 19)
325#define EPTYPE_CTRL 0
326#define EPTYPE_ISOC 1
327#define EPTYPE_BULK 2
328#define EPTYPE_INTR 3
329#define STM32F4_OTGFS_DIEPCTL_NAKSTS BSP_BIT32(17) // NAK status
330#define STM32F4_OTGFS_DIEPCTL_EONUM_DPID BSP_BIT32(16) // Data PID / Even/odd frame
331#define STM32F4_OTGFS_DIEPCTL_USBAEP BSP_BIT32(15) // USB active endpoint
332#define STM32F4_OTGFS_DIEPCTL_EP0_MPSIZ(val) BSP_FLD32(val, 0, 1) // Maximum packet size (bytes)
333#define STM32F4_OTGFS_DIEPCTL_EP0_MPSIZ_GET(reg) BSP_FLD32GET(reg, 0, 1)
334#define STM32F4_OTGFS_DIEPCTL_EP0_MPSIZ_SET(reg, val) BSP_FLD32SET(reg, val, 0, 1)
335#define EP0_MPSIZ_8 3
336#define EP0_MPSIZ_16 2
337#define EP0_MPSIZ_32 1
338#define EP0_MPSIZ_64 0
339#define STM32F4_OTGFS_DIEPCTL_EP0_MPSIZ_8 STM32F4_OTGFS_DIEPCTL_MPSIZ(EP0_MPSIZ_8)
340#define STM32F4_OTGFS_DIEPCTL_EP0_MPSIZ_16 STM32F4_OTGFS_DIEPCTL_MPSIZ(EP0_MPSIZ_16)
341#define STM32F4_OTGFS_DIEPCTL_EP0_MPSIZ_32 STM32F4_OTGFS_DIEPCTL_MPSIZ(EP0_MPSIZ_32)
342#define STM32F4_OTGFS_DIEPCTL_EP0_MPSIZ_64 STM32F4_OTGFS_DIEPCTL_MPSIZ(EP0_MPSIZ_64)
343#define STM32F4_OTGFS_DIEPCTL_MPSIZ(val) BSP_FLD32(val, 0, 10) // Maximum packet size (bytes)
344#define STM32F4_OTGFS_DIEPCTL_MPSIZ_GET(reg) BSP_FLD32GET(reg, 0, 10)
345#define STM32F4_OTGFS_DIEPCTL_MPSIZ_SET(reg, val) BSP_FLD32SET(reg, val, 0, 10)
346
347 uint32_t reserved_04;
348
349 uint32_t diepint; // 0x908
350#define STM32F4_OTGFS_DIEPINT_TXFE BSP_BIT32(7) // Transmit FIFO empty
351#define STM32F4_OTGFS_DIEPINT_INEPNE BSP_BIT32(6) // IN endpoint NAK effective
352#define STM32F4_OTGFS_DIEPINT_ITTXFE BSP_BIT32(4) // IN token received, TxFIFO empty
353#define STM32F4_OTGFS_DIEPINT_TOC BSP_BIT32(3) // Timeout condition
354#define STM32F4_OTGFS_DIEPINT_EPDISD BSP_BIT32(1) // Endpoint disabled
355#define STM32F4_OTGFS_DIEPINT_XFRC BSP_BIT32(0) // Transfer complete
356
357 uint32_t reserved_0C;
358
359 uint32_t dieptsiz; // 0x910
360#define STM32F4_OTGFS_DIEPTSIZ_EP0_PKTCNT(val) BSP_FLD32(val, 19, 20) // EP0 packet count
361#define STM32F4_OTGFS_DIEPTSIZ_EP0_PKTCNT_GET(reg) BSP_FLD32GET(reg, 19, 20)
362#define STM32F4_OTGFS_DIEPTSIZ_EP0_PKTCNT_SET(reg, val) BSP_FLD32SET(reg, val, 19, 20)
363#define STM32F4_OTGFS_DIEPTSIZ_EP0_XFRSIZ(val) BSP_FLD32(val, 0, 6) // EP0 transfer size
364#define STM32F4_OTGFS_DIEPTSIZ_EP0_XFRSIZ_GET(reg) BSP_FLD32GET(reg, 0, 6)
365#define STM32F4_OTGFS_DIEPTSIZ_EP0_XFRSIZ_SET(reg, val) BSP_FLD32SET(reg, val, 0, 6)
366#define STM32F4_OTGFS_DIEPTSIZ_MCNT(val) BSP_FLD32(val, 29, 30) // Multi count
367#define STM32F4_OTGFS_DIEPTSIZ_MCNT_GET(reg) BSP_FLD32GET(reg, 29, 30)
368#define STM32F4_OTGFS_DIEPTSIZ_MCNT_SET(reg, val) BSP_FLD32SET(reg, val, 29, 30)
369#define STM32F4_OTGFS_DIEPTSIZ_PKTCNT(val) BSP_FLD32(val, 19, 28) // Packet count
370#define STM32F4_OTGFS_DIEPTSIZ_PKTCNT_GET(reg) BSP_FLD32GET(reg, 19, 28)
371#define STM32F4_OTGFS_DIEPTSIZ_PKTCNT_SET(reg, val) BSP_FLD32SET(reg, val, 19, 28)
372#define STM32F4_OTGFS_DIEPTSIZ_XFRSIZ(val) BSP_FLD32(val, 0, 18) // Transfer size
373#define STM32F4_OTGFS_DIEPTSIZ_XFRSIZ_GET(reg) BSP_FLD32GET(reg, 0, 18)
374#define STM32F4_OTGFS_DIEPTSIZ_XFRSIZ_SET(reg, val) BSP_FLD32SET(reg, val, 0, 18)
375
376 uint32_t reserved_14;
377
378 uint32_t dtxfsts; // 0x918
379#define STM32F4_OTGFS_DTXFSTS_INEPTFSAV(val) BSP_FLD32(val, 0, 15) // IN endpoint TxFIFO space available
380#define STM32F4_OTGFS_DTXFSTS_INEPTFSAV_GET(reg) BSP_FLD32(reg, 0, 15)
381#define STM32F4_OTGFS_DTXFSTS_INEPTFSAV_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
382
383 uint32_t reserved_1C;
384
385} __attribute__ ((packed));
387
389 uint32_t doepctl; // 0xBx0: Endpoint control register
390#define STM32F4_OTGFS_DOEPCTL_EPENA BSP_BIT32(31) // Endpoint enable
391#define STM32F4_OTGFS_DOEPCTL_EPDIS BSP_BIT32(30) // Endpoint disable
392#define STM32F4_OTGFS_DOEPCTL_SD1PID BSP_BIT32(29) // Set DATA1 PID / Set odd frame
393#define STM32F4_OTGFS_DOEPCTL_SD0PID BSP_BIT32(28) // Set DATA0 PID / Set even frame
394#define STM32F4_OTGFS_DOEPCTL_SNAK BSP_BIT32(27) // Set NAK
395#define STM32F4_OTGFS_DOEPCTL_CNAK BSP_BIT32(26) // Clear NAK
396#define STM32F4_OTGFS_DOEPCTL_STALL BSP_BIT32(21) // Stall handshake
397#define STM32F4_OTGFS_DOEPCTL_SNPM BSP_BIT32(20) // Snoop mode
398#define STM32F4_OTGFS_DOEPCTL_EPTYP(val) BSP_FLD32(val, 18, 19) // Endpoint type - 00 = Control, 01 = Isoch, 10 = Bulk, 11 = Interrupt
399#define STM32F4_OTGFS_DOEPCTL_EPTYP_GET(reg) BSP_FLD32GET(reg, 18, 19)
400#define STM32F4_OTGFS_DOEPCTL_EPTYP_SET(reg, val) BSP_FLD32SET(reg, val, 18, 19)
401#define STM32F4_OTGFS_DOEPCTL_NAKSTS BSP_BIT32(17) // NAK status
402#define STM32F4_OTGFS_DOEPCTL_EONUM_DPID BSP_BIT32(16) // Data PID / Even/odd frame
403#define STM32F4_OTGFS_DOEPCTL_USBAEP BSP_BIT32(15) // USB active endpoint
404#define STM32F4_OTGFS_DOEPCTL_MPSIZ(val) BSP_FLD32(val, 0, 10) // Maximum packet size (bytes)
405#define STM32F4_OTGFS_DOEPCTL_MPSIZ_GET(reg) BSP_FLD32GET(reg, 0, 10)
406#define STM32F4_OTGFS_DOEPCTL_MPSIZ_SET(reg, val) BSP_FLD32SET(reg, val, 0, 10)
407
408 uint32_t resv04;
409
410 uint32_t doepint; // 0xBx8: Endpoint interrupt register
411#define STM32F4_OTGFS_DOEPINT_B2BSTUP BSP_BIT32(6) // Back-to-back SETUP packets received
412#define STM32F4_OTGFS_DOEPINT_OTEPDIS BSP_BIT32(4) // OUT token received when endpoint disabled
413#define STM32F4_OTGFS_DOEPINT_STUP BSP_BIT32(3) // SETUP phase done
414#define STM32F4_OTGFS_DOEPINT_EPDISD BSP_BIT32(1) // Endpoint disabled interrupt
415#define STM32F4_OTGFS_DOEPINT_XFRC BSP_BIT32(0) // Transfer complete
416
417 uint32_t doeptsiz; // 0xBy0
418#define STM32F4_OTGFS_DOEPTSIZ_EP0_STUPCNT(val) BSP_FLD32(val, 29, 30) // EP0 SETUP packet count
419#define STM32F4_OTGFS_DOEPTSIZ_EP0_STUPCNT_GET(reg) BSP_FLD32GET(reg, 29, 30)
420#define STM32F4_OTGFS_DOEPTSIZ_EP0_STUPCNT_SET(reg, val) BSP_FLD32SET(reg, val, 29, 30)
421#define STM32F4_OTGFS_DOEPTSIZ_EP0_PKTCNT BSP_BIT32(19) // EP0 packet count
422#define STM32F4_OTGFS_DOEPTSIZ_EP0_XFRSIZ(val) BSP_FLD32(val, 0, 6) // EP0 transfer size
423#define STM32F4_OTGFS_DOEPTSIZ_EP0_XFRSIZ_GET(reg) BSP_FLD32GET(reg, 0, 6)
424#define STM32F4_OTGFS_DOEPTSIZ_EP0_XFRSIZ_SET(reg, val) BSP_FLD32SET(reg, val, 0, 6)
425#define STM32F4_OTGFS_DOEPTSIZ_RXDPID(val) BSP_FLD32(val, 29, 30) // Received data PID
426#define STM32F4_OTGFS_DOEPTSIZ_RXDPID_GET(reg) BSP_FLD32GET(reg, 29, 30)
427#define STM32F4_OTGFS_DOEPTSIZ_RXDPID_SET(reg, val) BSP_FLD32SET(reg, val, 29, 30)
428#define STM32F4_OTGFS_DOEPTSIZ_PKTCNT(val) BSP_FLD32(val, 19, 28) // Packet count
429#define STM32F4_OTGFS_DOEPTSIZ_PKTCNT_GET(reg) BSP_FLD32GET(reg, 19, 28)
430#define STM32F4_OTGFS_DOEPTSIZ_PKTCNT_SET(reg, val) BSP_FLD32SET(reg, val, 19, 28)
431#define STM32F4_OTGFS_DOEPTSIZ_XFRSIZ(val) BSP_FLD32(val, 0, 18) // Transfer size
432#define STM32F4_OTGFS_DOEPTSIZ_XFRSIZ_GET(reg) BSP_FLD32GET(reg, 0, 18)
433#define STM32F4_OTGFS_DOEPTSIZ_XFRSIZ_SET(reg, val) BSP_FLD32SET(reg, val, 0, 18)
434
435 uint32_t resv14[3];
436} __attribute__ ((packed));
438
440 uint32_t pcgcctl; // 0xE00: Power and clock gating control register
441#define STM32F4_OTGFS_PCGCCTL_PHYSUSP BSP_BIT32(4) // PHY suspend
442#define STM32F4_OTGFS_PCGCCTL_GATEHCLK BSP_BIT32(1) // Gate HCLK
443#define STM32F4_OTGFS_PCGCCTL_STPPCLK BSP_BIT32(0) // Stop PHY clk
444} __attribute__ ((packed));
446
447#endif /* LIBBSP_ARM_STM32F4_STM32F4XXXX_OTGFS_H */
This header file provides utility macros for BSPs.
Definition: xnandpsu_onfi.h:185
Definition: stm32f4xxxx_otgfs.h:185
Definition: stm32f4xxxx_otgfs.h:309
Definition: stm32f4xxxx_otgfs.h:388
Definition: stm32f4xxxx_otgfs.h:439
Definition: stm32f4xxxx_otgfs.h:28
