RTEMS 7.0-rc1
stm32_i2c.h
1/* SPDX-License-Identifier: GPL-2.0+-with-RTEMS-exception */
2
9/*
10 * Copyright (c) 2013 Christian Mauderer. All rights reserved.
11 *
12 * The license and distribution terms for this file may be
13 * found in the file LICENSE in this distribution or at
14 * http://www.rtems.org/license/LICENSE.
15 */
16
17#ifndef LIBBSP_ARM_STM32F4_STM32_I2C_H
18#define LIBBSP_ARM_STM32F4_STM32_I2C_H
19
20#include <bsp/utility.h>
21
29typedef struct {
30 uint32_t cr1;
31#define STM32F4_I2C_CR1_SWRST BSP_BIT32(15)
32#define STM32F4_I2C_CR1_ALERT BSP_BIT32(13)
33#define STM32F4_I2C_CR1_PEC BSP_BIT32(12)
34#define STM32F4_I2C_CR1_POS BSP_BIT32(11)
35#define STM32F4_I2C_CR1_ACK BSP_BIT32(10)
36#define STM32F4_I2C_CR1_STOP BSP_BIT32(9)
37#define STM32F4_I2C_CR1_START BSP_BIT32(8)
38#define STM32F4_I2C_CR1_NOSTRETCH BSP_BIT32(7)
39#define STM32F4_I2C_CR1_ENGC BSP_BIT32(6)
40#define STM32F4_I2C_CR1_ENPEC BSP_BIT32(5)
41#define STM32F4_I2C_CR1_ENARP BSP_BIT32(4)
42#define STM32F4_I2C_CR1_SMBTYPE BSP_BIT32(3)
43#define STM32F4_I2C_CR1_SMBUS BSP_BIT32(1)
44#define STM32F4_I2C_CR1_PE BSP_BIT32(0)
45 uint32_t cr2;
46#define STM32F4_I2C_CR2_LAST BSP_BIT32(12)
47#define STM32F4_I2C_CR2_DMAEN BSP_BIT32(11)
48#define STM32F4_I2C_CR2_ITBUFEN BSP_BIT32(10)
49#define STM32F4_I2C_CR2_ITEVTEN BSP_BIT32(9)
50#define STM32F4_I2C_CR2_ITERREN BSP_BIT32(8)
51#define STM32F4_I2C_CR2_FREQ(val) BSP_FLD32(val, 0, 5)
52#define STM32F4_I2C_CR2_FREQ_GET(reg) BSP_FLD32GET(reg, 0, 5)
53#define STM32F4_I2C_CR2_FREQ_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)
54 uint32_t oar1;
55#define STM32F4_I2C_OAR1_ADDMODE BSP_BIT32(15)
56#define STM32F4_I2C_OAR1_ADD(val) BSP_FLD32(val, 0, 9)
57#define STM32F4_I2C_OAR1_ADD_GET(reg) BSP_FLD32GET(reg, 0, 9)
58#define STM32F4_I2C_OAR1_ADD_SET(reg, val) BSP_FLD32SET(reg, val, 0, 9)
59 uint32_t oar2;
60#define STM32F4_I2C_OAR2_ADD2(val) BSP_FLD32(val, 1, 7)
61#define STM32F4_I2C_OAR2_ADD2_GET(reg) BSP_FLD32GET(reg, 1, 7)
62#define STM32F4_I2C_OAR2_ADD2_SET(reg, val) BSP_FLD32SET(reg, val, 1, 7)
63#define STM32F4_I2C_OAR2_ENDUAL BSP_BIT32(0)
64 uint32_t dr;
65#define STM32F4_I2C_DR(val) BSP_FLD32(val, 0, 7)
66#define STM32F4_I2C_DR_GET(reg) BSP_FLD32GET(reg, 0, 7)
67#define STM32F4_I2C_DR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
68 uint32_t sr1;
69#define STM32F4_I2C_SR1_SMBALERT BSP_BIT32(15)
70#define STM32F4_I2C_SR1_TIMEOUT BSP_BIT32(14)
71#define STM32F4_I2C_SR1_PECERR BSP_BIT32(12)
72#define STM32F4_I2C_SR1_OVR BSP_BIT32(11)
73#define STM32F4_I2C_SR1_AF BSP_BIT32(10)
74#define STM32F4_I2C_SR1_ARLO BSP_BIT32(9)
75#define STM32F4_I2C_SR1_BERR BSP_BIT32(8)
76#define STM32F4_I2C_SR1_TxE BSP_BIT32(7)
77#define STM32F4_I2C_SR1_RxNE BSP_BIT32(6)
78#define STM32F4_I2C_SR1_STOPF BSP_BIT32(4)
79#define STM32F4_I2C_SR1_ADD10 BSP_BIT32(3)
80#define STM32F4_I2C_SR1_BTF BSP_BIT32(2)
81#define STM32F4_I2C_SR1_ADDR BSP_BIT32(1)
82#define STM32F4_I2C_SR1_SB BSP_BIT32(0)
83 uint32_t sr2;
84#define STM32F4_I2C_SR2_PEC(val) BSP_FLD32(val, 8, 15)
85#define STM32F4_I2C_SR2_PEC_GET(reg) BSP_FLD32GET(reg, 8, 15)
86#define STM32F4_I2C_SR2_PEC_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
87#define STM32F4_I2C_SR2_DUALF BSP_BIT32(7)
88#define STM32F4_I2C_SR2_SMBHOST BSP_BIT32(6)
89#define STM32F4_I2C_SR2_SMBDEFAULT BSP_BIT32(5)
90#define STM32F4_I2C_SR2_GENCALL BSP_BIT32(4)
91#define STM32F4_I2C_SR2_TRA BSP_BIT32(2)
92#define STM32F4_I2C_SR2_BUSY BSP_BIT32(1)
93#define STM32F4_I2C_SR2_MSL BSP_BIT32(0)
94 uint32_t ccr;
95#define STM32F4_I2C_CCR_FS BSP_BIT32(15)
96#define STM32F4_I2C_CCR_DUTY BSP_BIT32(14)
97#define STM32F4_I2C_CCR_CCR(val) BSP_FLD32(val, 0, 11)
98#define STM32F4_I2C_CCR_CCR_GET(reg) BSP_FLD32GET(reg, 0, 11)
99#define STM32F4_I2C_CCR_CCR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 11)
100#define STM32F4_I2C_CCR_CCR_MAX STM32F4_I2C_CCR_CCR_GET(BSP_MSK32(0, 11))
101 uint32_t trise;
102#define STM32F4_I2C_TRISE(val) BSP_FLD32(val, 0, 5)
103#define STM32F4_I2C_TRISE_GET(reg) BSP_FLD32GET(reg, 0, 5)
104#define STM32F4_I2C_TRISE_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)
106
109#endif /* LIBBSP_ARM_STM32F4_STM32_I2C_H */
This header file provides utility macros for BSPs.
Definition: stm32_i2c.h:29
