40#ifndef _RTEMS_SCORE_SMPLOCK_H
41#define _RTEMS_SCORE_SMPLOCK_H
43#include <rtems/score/cpuopts.h>
70#if defined(RTEMS_DEBUG)
79#if defined(RTEMS_DEBUG) || defined(RTEMS_PROFILING)
80#define RTEMS_SMP_LOCK_DO_NOT_INLINE
87 SMP_ticket_lock_Control Ticket_lock;
88#if defined(RTEMS_DEBUG)
103#if defined(RTEMS_PROFILING)
104 SMP_lock_Stats Stats;
113#if defined(RTEMS_DEBUG)
114 SMP_lock_Control *lock_used_for_acquire;
116#if defined(RTEMS_PROFILING)
117 SMP_lock_Stats_context Stats_context;
121#if defined(RTEMS_DEBUG)
122#define SMP_LOCK_NO_OWNER 0
128#if defined(RTEMS_DEBUG) && defined(RTEMS_PROFILING)
129 #define SMP_LOCK_INITIALIZER( name ) \
131 SMP_TICKET_LOCK_INITIALIZER, \
133 SMP_LOCK_STATS_INITIALIZER( name ) \
135#elif defined(RTEMS_DEBUG)
136 #define SMP_LOCK_INITIALIZER( name ) \
137 { SMP_TICKET_LOCK_INITIALIZER, SMP_LOCK_NO_OWNER }
138#elif defined(RTEMS_PROFILING)
139 #define SMP_LOCK_INITIALIZER( name ) \
140 { SMP_TICKET_LOCK_INITIALIZER, SMP_LOCK_STATS_INITIALIZER( name ) }
142 #define SMP_LOCK_INITIALIZER( name ) { SMP_TICKET_LOCK_INITIALIZER }
150static inline void _SMP_lock_Initialize_inline(
151 SMP_lock_Control *lock,
155 _SMP_ticket_lock_Initialize( &lock->Ticket_lock );
156#if defined(RTEMS_DEBUG)
157 lock->owner = SMP_LOCK_NO_OWNER;
159#if defined(RTEMS_PROFILING)
160 _SMP_lock_Stats_initialize( &lock->Stats, name );
175#if defined(RTEMS_SMP_LOCK_DO_NOT_INLINE)
176void _SMP_lock_Initialize(
177 SMP_lock_Control *lock,
181#define _SMP_lock_Initialize( lock, name ) \
182 _SMP_lock_Initialize_inline( lock, name )
190static inline void _SMP_lock_Destroy_inline( SMP_lock_Control *lock )
192 _SMP_ticket_lock_Destroy( &lock->Ticket_lock );
193 _SMP_lock_Stats_destroy( &lock->Stats );
203#if defined(RTEMS_SMP_LOCK_DO_NOT_INLINE)
204void _SMP_lock_Destroy( SMP_lock_Control *lock );
206#define _SMP_lock_Destroy( lock ) \
207 _SMP_lock_Destroy_inline( lock )
217static inline void _SMP_lock_Set_name(
218 SMP_lock_Control *lock,
222#if defined(RTEMS_PROFILING)
223 lock->Stats.name = name;
235#if defined(RTEMS_DEBUG)
236static inline uint32_t _SMP_lock_Who_am_I(
void )
242 return _SMP_Get_current_processor() + 1;
252static inline void _SMP_lock_Acquire_inline(
253 SMP_lock_Control *lock,
254 SMP_lock_Context *context
257#if defined(RTEMS_DEBUG)
258 context->lock_used_for_acquire = lock;
262 _SMP_ticket_lock_Acquire(
265 &context->Stats_context
267#if defined(RTEMS_DEBUG)
268 lock->owner = _SMP_lock_Who_am_I();
283void _SMP_lock_Acquire(
284 SMP_lock_Control *lock,
285 SMP_lock_Context *context
294static inline void _SMP_lock_Release_inline(
295 SMP_lock_Control *lock,
296 SMP_lock_Context *context
299#if defined(RTEMS_DEBUG)
300 _Assert( context->lock_used_for_acquire == lock );
301 context->lock_used_for_acquire = NULL;
302 _Assert( lock->owner == _SMP_lock_Who_am_I() );
303 lock->owner = SMP_LOCK_NO_OWNER;
307 _SMP_ticket_lock_Release(
309 &context->Stats_context
320#if defined(RTEMS_SMP_LOCK_DO_NOT_INLINE)
321void _SMP_lock_Release(
322 SMP_lock_Control *lock,
323 SMP_lock_Context *context
326#define _SMP_lock_Release( lock, context ) \
327 _SMP_lock_Release_inline( lock, context )
336static inline void _SMP_lock_ISR_disable_and_acquire_inline(
337 SMP_lock_Control *lock,
338 SMP_lock_Context *context
342 _SMP_lock_Acquire_inline( lock, context );
352void _SMP_lock_ISR_disable_and_acquire(
353 SMP_lock_Control *lock,
354 SMP_lock_Context *context
363static inline void _SMP_lock_Release_and_ISR_enable_inline(
364 SMP_lock_Control *lock,
365 SMP_lock_Context *context
368 _SMP_lock_Release_inline( lock, context );
379#if defined(RTEMS_SMP_LOCK_DO_NOT_INLINE)
380void _SMP_lock_Release_and_ISR_enable(
381 SMP_lock_Control *lock,
382 SMP_lock_Context *context
385#define _SMP_lock_Release_and_ISR_enable( lock, context ) \
386 _SMP_lock_Release_and_ISR_enable_inline( lock, context )
389#if defined(RTEMS_DEBUG)
398bool _SMP_lock_Is_owner(
const SMP_lock_Control *lock );
This header file provides the interfaces of the Assert Handler.
This header file provides interfaces of the SMP Support which are used by the implementation and the ...
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG and static analysis runs.
Definition: assert.h:96
#define _ISR_Local_disable(_level)
Disables interrupts on this processor.
Definition: isrlevel.h:76
#define _ISR_Local_enable(_level)
Enables interrupts on this processor.
Definition: isrlevel.h:93
uint32_t ISR_Level
Definition: isrlevel.h:60
This header file provides the ISR_Level related interfaces of the ISR Handler.
This header file provides the interfaces of the SMP Locks related to lock statistics.
This header file provides the interfaces of the SMP Locks related to ticket locks.
