RTEMS 7.0-rc1
scheduleredf.h
2
13/*
14 * Copryight (c) 2011 Petr Benes.
15 * Copyright (C) 2011 On-Line Applications Research Corporation (OAR).
16 *
17 * Redistribution and use in source and binary forms, with or without
18 * modification, are permitted provided that the following conditions
19 * are met:
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 * 2. Redistributions in binary form must reproduce the above copyright
23 * notice, this list of conditions and the following disclaimer in the
24 * documentation and/or other materials provided with the distribution.
25 *
26 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36 * POSSIBILITY OF SUCH DAMAGE.
37 */
38
39#ifndef _RTEMS_SCORE_SCHEDULEREDF_H
40#define _RTEMS_SCORE_SCHEDULEREDF_H
41
45#include <rtems/score/rbtree.h>
46
47#include <limits.h>
48
49#ifdef __cplusplus
50extern "C" {
51#endif
52
66#define SCHEDULER_EDF_ENTRY_POINTS \
67 { \
68 _Scheduler_EDF_Initialize, /* initialize entry point */ \
69 _Scheduler_EDF_Schedule, /* schedule entry point */ \
70 _Scheduler_EDF_Yield, /* yield entry point */ \
71 _Scheduler_EDF_Block, /* block entry point */ \
72 _Scheduler_EDF_Unblock, /* unblock entry point */ \
73 _Scheduler_EDF_Update_priority, /* update priority entry point */ \
74 _Scheduler_EDF_Map_priority, /* map priority entry point */ \
75 _Scheduler_EDF_Unmap_priority, /* unmap priority entry point */ \
76 SCHEDULER_DEFAULT_SMP_OPERATIONS \
77 _Scheduler_EDF_Node_initialize, /* node initialize entry point */ \
78 _Scheduler_default_Node_destroy, /* node destroy entry point */ \
79 _Scheduler_EDF_Release_job, /* new period of task */ \
80 _Scheduler_EDF_Cancel_job, /* cancel period of task */ \
81 _Scheduler_default_Start_idle /* start idle entry point */ \
82 SCHEDULER_DEFAULT_SET_AFFINITY_OPERATION \
83 }
84
85typedef struct {
90
94 RBTree_Control Ready;
96
100typedef struct {
105
110
116
124void _Scheduler_EDF_Initialize( const Scheduler_Control *scheduler );
125
135 const Scheduler_Control *scheduler,
136 Thread_Control *the_thread,
137 Scheduler_Node *node
138);
139
151 const Scheduler_Control *scheduler,
152 Thread_Control *the_thread
153);
154
164 const Scheduler_Control *scheduler,
165 Scheduler_Node *node,
166 Thread_Control *the_thread,
167 Priority_Control priority
168);
169
178 const Scheduler_Control *scheduler,
179 Thread_Control *the_thread,
180 Scheduler_Node *node
181);
182
191 const Scheduler_Control *scheduler,
192 Thread_Control *the_thread,
193 Scheduler_Node *node
194);
195
205 const Scheduler_Control *scheduler,
206 Priority_Control priority
207);
208
218 const Scheduler_Control *scheduler,
219 Priority_Control priority
220);
221
230 const Scheduler_Control *scheduler,
231 Thread_Control *the_thread,
232 Scheduler_Node *node
233);
234
245 const Scheduler_Control *scheduler,
246 Thread_Control *the_thread,
247 Priority_Node *priority_node,
248 uint64_t deadline,
249 Thread_queue_Context *queue_context
250);
251
261 const Scheduler_Control *scheduler,
262 Thread_Control *the_thread,
263 Priority_Node *priority_node,
264 Thread_queue_Context *queue_context
265);
266
267#ifdef __cplusplus
268}
269#endif
270
273#endif
274/* end of include file */
uint64_t Priority_Control
The thread priority control.
Definition: priority.h:91
void _Scheduler_EDF_Unblock(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Performs an unblocking of the thread.
Definition: scheduleredfunblock.c:46
void _Scheduler_EDF_Yield(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Executes a thread yield for the thread.
Definition: scheduleredfyield.c:44
void _Scheduler_EDF_Node_initialize(const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
Initializes an EDF specific scheduler node of the_thread.
Definition: scheduleredfnodeinit.c:44
void _Scheduler_EDF_Cancel_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
Cancels a job and removes the thread from the queue context.
Definition: scheduleredfreleasejob.c:106
void _Scheduler_EDF_Initialize(const Scheduler_Control *scheduler)
Initializes EDF scheduler.
Definition: scheduleredf.c:44
void _Scheduler_EDF_Release_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context)
Releases a EDF job.
Definition: scheduleredfreleasejob.c:69
void _Scheduler_EDF_Block(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Removes the blocking thread from the ready queue and schedules is only again if the thread is executi...
Definition: scheduleredfblock.c:44
Priority_Control _Scheduler_EDF_Map_priority(const Scheduler_Control *scheduler, Priority_Control priority)
Gets the mapped priority map of the priority control.
Definition: scheduleredfreleasejob.c:45
Priority_Control _Scheduler_EDF_Unmap_priority(const Scheduler_Control *scheduler, Priority_Control priority)
Gets the unmapped priority map of the priority control.
Definition: scheduleredfreleasejob.c:55
void _Scheduler_EDF_Update_priority(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Updates the priority of the scheduler node.
Definition: scheduleredfchangepriority.c:44
void _Scheduler_EDF_Schedule(const Scheduler_Control *scheduler, Thread_Control *the_thread)
Sets the heir thread to be the next ready thread in the rbtree ready queue.
Definition: scheduleredfschedule.c:44
This header file provides interfaces of the Priority Handler which are used by the implementation and...
This header file provides interfaces of the Red-Black Tree Handler which are used by the implementati...
This header file provides interfaces of the Deterministic Priority Scheduler which are used by the im...
This header file provides interfaces of the Scheduler Handler which are used by the implementation an...
The priority node to build up a priority aggregation.
Definition: priority.h:112
Red-black tree node.
Definition: rbtree.h:73
Scheduler context.
Definition: scheduler.h:318
Definition: scheduleredf.h:85
Scheduler_Context Base
Basic scheduler context.
Definition: scheduleredf.h:89
Definition: scheduleredf.h:94
Scheduler node specialization for EDF schedulers.
Definition: scheduleredf.h:100
The thread priority currently used for this scheduler instance.
Definition: scheduleredf.h:114
RBTree_Node Node
Definition: scheduleredf.h:109
Scheduler_Node Base
Basic scheduler node.
Definition: scheduleredf.h:104
Scheduler node for per-thread data.
Definition: schedulernode.h:94
Thread queue context for the thread queue methods.
Definition: threadq.h:217
Scheduler control.
Definition: scheduler.h:337
Definition: thread.h:837
