RTEMS 7.0-rc1
schedulercbs.h
2
13/*
14 * Copryight (c) 2011 Petr Benes.
15 * Copyright (C) 2011 On-Line Applications Research Corporation (OAR).
16 *
17 * Redistribution and use in source and binary forms, with or without
18 * modification, are permitted provided that the following conditions
19 * are met:
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 * 2. Redistributions in binary form must reproduce the above copyright
23 * notice, this list of conditions and the following disclaimer in the
24 * documentation and/or other materials provided with the distribution.
25 *
26 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36 * POSSIBILITY OF SUCH DAMAGE.
37 */
38
39#ifndef _RTEMS_SCORE_SCHEDULERCBS_H
40#define _RTEMS_SCORE_SCHEDULERCBS_H
41
42#include <rtems/score/chain.h>
45#include <rtems/score/rbtree.h>
47#include <rtems/rtems/signal.h>
48#include <rtems/rtems/timer.h>
49#include <rtems/score/thread.h>
50
51#ifdef __cplusplus
52extern "C" {
53#endif
54
72#define SCHEDULER_CBS_ENTRY_POINTS \
73 { \
74 _Scheduler_EDF_Initialize, /* initialize entry point */ \
75 _Scheduler_EDF_Schedule, /* schedule entry point */ \
76 _Scheduler_EDF_Yield, /* yield entry point */ \
77 _Scheduler_EDF_Block, /* block entry point */ \
78 _Scheduler_CBS_Unblock, /* unblock entry point */ \
79 _Scheduler_EDF_Update_priority, /* update priority entry point */ \
80 _Scheduler_EDF_Map_priority, /* map priority entry point */ \
81 _Scheduler_EDF_Unmap_priority, /* unmap priority entry point */ \
82 SCHEDULER_DEFAULT_SMP_OPERATIONS \
83 _Scheduler_CBS_Node_initialize, /* node initialize entry point */ \
84 _Scheduler_default_Node_destroy, /* node destroy entry point */ \
85 _Scheduler_CBS_Release_job, /* new period of task */ \
86 _Scheduler_CBS_Cancel_job, /* cancel period of task */ \
87 _Scheduler_default_Start_idle /* start idle entry point */ \
88 SCHEDULER_DEFAULT_SET_AFFINITY_OPERATION \
89 }
90
91/* Return values for CBS server. */
92#define SCHEDULER_CBS_OK 0
93#define SCHEDULER_CBS_ERROR_GENERIC -16
94#define SCHEDULER_CBS_ERROR_NO_MEMORY -17
95#define SCHEDULER_CBS_ERROR_INVALID_PARAMETER -18
96#define SCHEDULER_CBS_ERROR_UNAUTHORIZED -19
97#define SCHEDULER_CBS_ERROR_UNIMPLEMENTED -20
98#define SCHEDULER_CBS_ERROR_MISSING_COMPONENT -21
99#define SCHEDULER_CBS_ERROR_INCONSISTENT_STATE -22
100#define SCHEDULER_CBS_ERROR_SYSTEM_OVERLOAD -23
101#define SCHEDULER_CBS_ERROR_INTERNAL_ERROR -24
102#define SCHEDULER_CBS_ERROR_NOT_FOUND -25
103#define SCHEDULER_CBS_ERROR_FULL -26
104#define SCHEDULER_CBS_ERROR_EMPTY -27
105#define SCHEDULER_CBS_ERROR_NOSERVER SCHEDULER_CBS_ERROR_NOT_FOUND
106
108extern const uint32_t _Scheduler_CBS_Maximum_servers;
109
111typedef uint32_t Scheduler_CBS_Server_id;
112
116);
117
121typedef struct {
123 time_t deadline;
125 time_t budget;
127
131typedef struct {
142
150
154typedef struct {
159
160 Priority_Node *deadline_node;
162
163
169
178 const Scheduler_Control *scheduler,
179 Thread_Control *the_thread,
180 Scheduler_Node *node
181);
182
193 const Scheduler_Control *scheduler,
194 Thread_Control *the_thread,
195 Priority_Node *priority_node,
196 uint64_t deadline,
197 Thread_queue_Context *queue_context
198);
199
209 const Scheduler_Control *scheduler,
210 Thread_Control *the_thread,
211 Priority_Node *priority_node,
212 Thread_queue_Context *queue_context
213);
214
223
239 Scheduler_CBS_Server_id server_id,
240 rtems_id task_id
241);
242
258 Scheduler_CBS_Server_id server_id,
259 rtems_id task_id
260);
261
269int _Scheduler_CBS_Cleanup (void);
270
288 Scheduler_CBS_Budget_overrun budget_overrun_callback,
289 rtems_id *server_id
290);
291
305);
306
321 Scheduler_CBS_Server_id server_id,
322 time_t *approved_budget
323);
324
338 Scheduler_CBS_Server_id server_id,
339 time_t *remaining_budget
340);
341
356 Scheduler_CBS_Server_id server_id,
357 time_t *exec_time,
358 time_t *abs_time
359);
360
374 Scheduler_CBS_Server_id server_id,
376);
377
390 rtems_id task_id,
391 Scheduler_CBS_Server_id *server_id
392);
393
408 Scheduler_CBS_Server_id server_id,
409 Scheduler_CBS_Parameters *parameters
410);
411
416
426 const Scheduler_Control *scheduler,
427 Scheduler_Node *node,
428 Thread_Control *the_thread,
429 Priority_Control priority
430);
431
432#ifdef __cplusplus
433}
434#endif
435
438#endif
439/* end of include file */
This header file provides the Timer Manager API.
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
uint64_t Priority_Control
The thread priority control.
Definition: priority.h:91
int _Scheduler_CBS_Get_server_id(rtems_id task_id, Scheduler_CBS_Server_id *server_id)
Gets a thread server id.
Definition: schedulercbsgetserverid.c:46
Scheduler_CBS_Server _Scheduler_CBS_Server_list[]
void _Scheduler_CBS_Release_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context)
Releases a job.
Definition: schedulercbsreleasejob.c:44
int _Scheduler_CBS_Create_server(Scheduler_CBS_Parameters *params, Scheduler_CBS_Budget_overrun budget_overrun_callback, rtems_id *server_id)
Creates a new server with specified parameters.
Definition: schedulercbscreateserver.c:45
int _Scheduler_CBS_Cleanup(void)
Cleans up resources associated to the CBS Library.
Definition: schedulercbscleanup.c:44
void(* Scheduler_CBS_Budget_overrun)(Scheduler_CBS_Server_id server_id)
Definition: schedulercbs.h:114
int _Scheduler_CBS_Get_remaining_budget(Scheduler_CBS_Server_id server_id, time_t *remaining_budget)
Retrieves remaining budget for the current server instance.
Definition: schedulercbsgetremainingbudget.c:45
int _Scheduler_CBS_Get_approved_budget(Scheduler_CBS_Server_id server_id, time_t *approved_budget)
Retrieves the approved budget.
Definition: schedulercbsgetapprovedbudget.c:46
int _Scheduler_CBS_Detach_thread(Scheduler_CBS_Server_id server_id, rtems_id task_id)
Detaches from the CBS Server.
Definition: schedulercbsdetachthread.c:45
int _Scheduler_CBS_Destroy_server(Scheduler_CBS_Server_id server_id)
Detaches all tasks from a server and destroys it.
Definition: schedulercbsdestroyserver.c:44
void _Scheduler_CBS_Cancel_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
Cancels a job.
Definition: schedulercbsreleasejob.c:74
int _Scheduler_CBS_Get_execution_time(Scheduler_CBS_Server_id server_id, time_t *exec_time, time_t *abs_time)
Gets relative time info.
Definition: schedulercbsgetexecutiontime.c:45
void _Scheduler_CBS_Node_initialize(const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
Initializes a CBS specific scheduler node of the_thread.
Definition: schedulercbsnodeinit.c:44
const Thread_CPU_budget_operations _Scheduler_CBS_Budget
These are the CBS CPU budget operations.
Definition: schedulercbs.c:103
int _Scheduler_CBS_Attach_thread(Scheduler_CBS_Server_id server_id, rtems_id task_id)
Attaches a task to an already existing server.
Definition: schedulercbsattachthread.c:45
int _Scheduler_CBS_Initialize(void)
Definition: schedulercbs.c:109
void _Scheduler_CBS_Unblock(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Unblocks a thread.
Definition: schedulercbsunblock.c:48
int _Scheduler_CBS_Get_parameters(Scheduler_CBS_Server_id server_id, Scheduler_CBS_Parameters *params)
Retrieves CBS scheduling parameters.
Definition: schedulercbsgetparameters.c:46
Definition: schedulercbs.h:111
int _Scheduler_CBS_Set_parameters(Scheduler_CBS_Server_id server_id, Scheduler_CBS_Parameters *parameters)
Sets parameters for CBS scheduling.
Definition: schedulercbssetparameters.c:45
This header file defines the parts of the Signal Manager API.
This header file provides interfaces of the Priority Handler which are used by the implementation and...
This header file provides interfaces of the Red-Black Tree Handler which are used by the implementati...
This header file provides interfaces of the EDF Scheduler which are used by the implementation and th...
This header file provides interfaces of the Chain Handler which are used by the implementation and th...
This header file provides interfaces of the Scheduler Handler which are used by the implementation an...
This header file provides interfaces of the Thread Handler which are used by the implementation and t...
The priority node to build up a priority aggregation.
Definition: priority.h:112
Definition: schedulercbs.h:154
Scheduler_CBS_Server * cbs_server
Definition: schedulercbs.h:158
Scheduler_EDF_Node Base
Definition: schedulercbs.h:156
Definition: schedulercbs.h:121
time_t deadline
Definition: schedulercbs.h:123
time_t budget
Definition: schedulercbs.h:125
Definition: schedulercbs.h:131
Scheduler_CBS_Parameters parameters
Definition: schedulercbs.h:139
rtems_id task_id
Definition: schedulercbs.h:137
bool initialized
Indicates if this CBS server is initialized.
Definition: schedulercbs.h:148
Scheduler_CBS_Budget_overrun cbs_budget_overrun
Definition: schedulercbs.h:141
Scheduler node specialization for EDF schedulers.
Definition: scheduleredf.h:100
Scheduler node for per-thread data.
Definition: schedulernode.h:94
This structure contains operations which manage the CPU budget of a thread.
Definition: thread.h:188
Thread queue context for the thread queue methods.
Definition: threadq.h:217
Scheduler control.
Definition: scheduler.h:337
Definition: thread.h:837
