RTEMS
7.0-rc1
bsps
arm
tms570
include
bsp
ti_herc
reg_i2c.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
/* The header file is generated by make_header.py from I2C.json */
12
/* Current script's version can be found at: */
13
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15
16
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17
18
* Czech Technical University in Prague
19
* Zikova 1903/4
20
* 166 36 Praha 6
21
* Czech Republic
22
23
* All rights reserved.
24
25
26
* modification, are permitted provided that the following conditions are met:
27
28
* 1. Redistributions of source code must retain the above copyright notice, this
29
* list of conditions and the following disclaimer.
30
* 2. Redistributions in binary form must reproduce the above copyright notice,
31
* this list of conditions and the following disclaimer in the documentation
32
* and/or other materials provided with the distribution.
33
34
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44
45
* The views and conclusions contained in the software and documentation are those
46
* of the authors and should not be interpreted as representing official policies,
47
* either expressed or implied, of the FreeBSD Project.
48
49
#ifndef LIBBSP_ARM_TMS570_I2C
50
#define LIBBSP_ARM_TMS570_I2C
51
52
bsp/utility.h
53
54
typedef
struct
55
uint32_t OAR;
/*I2C Own Address Manager*/
56
uint32_t IMR;
/*I2C Interupt Mask Register*/
57
uint32_t STR;
/*I2C Status Register*/
58
uint32_t CKL;
/*I2C Clock Divider Low Register*/
59
uint32_t CKH;
/*I2C Clock Control High Register*/
60
uint32_t CNT;
/*I2C Data Count Register*/
61
uint32_t DRR;
/*I2C Data Receive Register*/
62
uint32_t SAR;
/*I2C Slave Address Register*/
63
uint32_t DXR;
/*I2C Data Transmit Register*/
64
uint32_t MDR;
/*I2C Mode Register*/
65
uint32_t IVR;
/*I2C Interrupt Vector Register*/
66
uint32_t EMDR;
/*I2C Extended Mode Register*/
67
uint32_t PSC;
/*I2C Prescale Register*/
68
uint32_t PID11;
/*I2C Peripheral ID Register 1*/
69
uint32_t PID12;
/*I2C Peripheral ID Register 2*/
70
uint32_t DMACR;
/*I2C DMA Control Register*/
71
uint8_t reserved1 [8];
72
uint32_t PFNC;
/*I2C Pin Function Register*/
73
uint32_t
DIR
/*I2C Pin Direction Register*/
74
uint32_t DIN;
/*I2C Data Input Register*/
75
uint32_t DOUT;
/*I2C Data Output Register*/
76
uint32_t SET;
/*I2C Data Set Register*/
77
uint32_t CLR;
/*I2C Data Clear Register*/
78
uint32_t PDR;
/*I2C Pin Open Drain Register*/
79
uint32_t PDIS;
/*I2C Pull Disable Register*/
80
uint32_t PSEL;
/*I2C Pull Select Register*/
81
uint32_t pSRS;
/*I2C Pins Slew Rate Select Register*/
82
tms570_i2c_t
83
84
85
/*-----------------------TMS570_I2C_OAR-----------------------*/
86
/* field: OA - Own address */
87
#define TMS570_I2C_OAR_OA(val) BSP_FLD32(val,0, 9)
88
#define TMS570_I2C_OAR_OA_GET(reg) BSP_FLD32GET(reg,0, 9)
89
#define TMS570_I2C_OAR_OA_SET(reg,val) BSP_FLD32SET(reg, val,0, 9)
90
91
92
/*-----------------------TMS570_I2C_IMR-----------------------*/
93
/* field: AASEN - Address As Slave Interrupt Enable */
94
#define TMS570_I2C_IMR_AASEN BSP_BIT32(6)
95
96
/* field: SCDEN - Stop Condition Interrupt Enable */
97
#define TMS570_I2C_IMR_SCDEN BSP_BIT32(5)
98
99
/* field: TXRDYEN - Transmit Data Ready Interrupt Enable */
100
#define TMS570_I2C_IMR_TXRDYEN BSP_BIT32(4)
101
102
/* field: RXRDYEN - Receive Data Ready Interrupt Enable */
103
#define TMS570_I2C_IMR_RXRDYEN BSP_BIT32(3)
104
105
/* field: ARDYEN - Register Access Ready Interrupt Enable */
106
#define TMS570_I2C_IMR_ARDYEN BSP_BIT32(2)
107
108
/* field: NACKEN - No Acknowledgement Interrupt Enable */
109
#define TMS570_I2C_IMR_NACKEN BSP_BIT32(1)
110
111
/* field: ALEN - Arbitration Lost Interrupt Enable */
112
#define TMS570_I2C_IMR_ALEN BSP_BIT32(0)
113
114
115
/*-----------------------TMS570_I2C_STR-----------------------*/
116
/* field: SDIR - Slave direction */
117
#define TMS570_I2C_STR_SDIR BSP_BIT32(14)
118
119
/* field: NACKSNT - No acknowledge sent */
120
#define TMS570_I2C_STR_NACKSNT BSP_BIT32(13)
121
122
/* field: BB - Bus busy */
123
#define TMS570_I2C_STR_BB BSP_BIT32(12)
124
125
/* field: RSFULL - Receiver shift full */
126
#define TMS570_I2C_STR_RSFULL BSP_BIT32(11)
127
128
/* field: XSMT - XSMT */
129
#define TMS570_I2C_STR_XSMT BSP_BIT32(10)
130
131
/* field: AAS - Address as slave */
132
#define TMS570_I2C_STR_AAS BSP_BIT32(9)
133
134
/* field: AD0 - Address zero status */
135
#define TMS570_I2C_STR_AD0 BSP_BIT32(8)
136
137
/* field: SCD - SCD */
138
#define TMS570_I2C_STR_SCD BSP_BIT32(5)
139
140
/* field: TXRDY - Transmit data ready interrupt flag */
141
#define TMS570_I2C_STR_TXRDY BSP_BIT32(4)
142
143
/* field: RXRDY - Receive data ready interrupt flag */
144
#define TMS570_I2C_STR_RXRDY BSP_BIT32(3)
145
146
/* field: ARDY - Register access ready interrupt flag */
147
#define TMS570_I2C_STR_ARDY BSP_BIT32(2)
148
149
/* field: NACK - No acknowledgement interrupt */
150
#define TMS570_I2C_STR_NACK BSP_BIT32(1)
151
152
/* field: AL - Arbitration lost interrupt flag */
153
#define TMS570_I2C_STR_AL BSP_BIT32(0)
154
155
156
/*-----------------------TMS570_I2C_CKL-----------------------*/
157
/* field: CLKL - Low time clock division factor */
158
#define TMS570_I2C_CKL_CLKL(val) BSP_FLD32(val,0, 15)
159
#define TMS570_I2C_CKL_CLKL_GET(reg) BSP_FLD32GET(reg,0, 15)
160
#define TMS570_I2C_CKL_CLKL_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
161
162
163
/*-----------------------TMS570_I2C_CKH-----------------------*/
164
/* field: CLKH - High time clock division factor */
165
#define TMS570_I2C_CKH_CLKH(val) BSP_FLD32(val,0, 15)
166
#define TMS570_I2C_CKH_CLKH_GET(reg) BSP_FLD32GET(reg,0, 15)
167
#define TMS570_I2C_CKH_CLKH_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
168
169
170
/*-----------------------TMS570_I2C_CNT-----------------------*/
171
/* field: CNT - Data counter */
172
#define TMS570_I2C_CNT_CNT(val) BSP_FLD32(val,0, 15)
173
#define TMS570_I2C_CNT_CNT_GET(reg) BSP_FLD32GET(reg,0, 15)
174
#define TMS570_I2C_CNT_CNT_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
175
176
177
/*-----------------------TMS570_I2C_DRR-----------------------*/
178
/* field: DATARX - Receive data */
179
#define TMS570_I2C_DRR_DATARX(val) BSP_FLD32(val,0, 7)
180
#define TMS570_I2C_DRR_DATARX_GET(reg) BSP_FLD32GET(reg,0, 7)
181
#define TMS570_I2C_DRR_DATARX_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
182
183
184
/*-----------------------TMS570_I2C_SAR-----------------------*/
185
/* field: SA - 7- or 10-bit programmable slave address */
186
#define TMS570_I2C_SAR_SA(val) BSP_FLD32(val,0, 9)
187
#define TMS570_I2C_SAR_SA_GET(reg) BSP_FLD32GET(reg,0, 9)
188
#define TMS570_I2C_SAR_SA_SET(reg,val) BSP_FLD32SET(reg, val,0, 9)
189
190
191
/*-----------------------TMS570_I2C_DXR-----------------------*/
192
/* field: DATATX - Transmit data */
193
#define TMS570_I2C_DXR_DATATX(val) BSP_FLD32(val,0, 7)
194
#define TMS570_I2C_DXR_DATATX_GET(reg) BSP_FLD32GET(reg,0, 7)
195
#define TMS570_I2C_DXR_DATATX_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
196
197
198
/*-----------------------TMS570_I2C_MDR-----------------------*/
199
/* field: NACKMOD - No-acknowledge (NACK) mode */
200
#define TMS570_I2C_MDR_NACKMOD BSP_BIT32(15)
201
202
/* field: FREE - Free running bit */
203
#define TMS570_I2C_MDR_FREE BSP_BIT32(14)
204
205
/* field: STT - Start condition */
206
#define TMS570_I2C_MDR_STT BSP_BIT32(13)
207
208
/* field: STP - Stop condition */
209
#define TMS570_I2C_MDR_STP BSP_BIT32(11)
210
211
/* field: MST - Master/slave mode bit */
212
#define TMS570_I2C_MDR_MST BSP_BIT32(10)
213
214
/* field: TRX - Transmit/receive bit */
215
#define TMS570_I2C_MDR_TRX BSP_BIT32(9)
216
217
/* field: XA - Expand address enable bit */
218
#define TMS570_I2C_MDR_XA BSP_BIT32(8)
219
220
/* field: RM - RM */
221
#define TMS570_I2C_MDR_RM BSP_BIT32(7)
222
223
/* field: DLB - Digital loop back enable bit */
224
#define TMS570_I2C_MDR_DLB BSP_BIT32(6)
225
226
/* field: nIRS - I2C reset enable bit */
227
#define TMS570_I2C_MDR_nIRS BSP_BIT32(5)
228
229
/* field: STB - Start byte mode enable bit (Master mode only) */
230
#define TMS570_I2C_MDR_STB BSP_BIT32(4)
231
232
/* field: FDF - Free data format enable bit */
233
#define TMS570_I2C_MDR_FDF BSP_BIT32(3)
234
235
/* field: BC - Bit count */
236
#define TMS570_I2C_MDR_BC(val) BSP_FLD32(val,0, 2)
237
#define TMS570_I2C_MDR_BC_GET(reg) BSP_FLD32GET(reg,0, 2)
238
#define TMS570_I2C_MDR_BC_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
239
240
241
/*-----------------------TMS570_I2C_IVR-----------------------*/
242
/* field: TESTMD - Reserved for internal testing. */
243
#define TMS570_I2C_IVR_TESTMD(val) BSP_FLD32(val,8, 11)
244
#define TMS570_I2C_IVR_TESTMD_GET(reg) BSP_FLD32GET(reg,8, 11)
245
#define TMS570_I2C_IVR_TESTMD_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
246
247
/* field: INTCODE - Interrupt Code Bits */
248
#define TMS570_I2C_IVR_INTCODE(val) BSP_FLD32(val,0, 2)
249
#define TMS570_I2C_IVR_INTCODE_GET(reg) BSP_FLD32GET(reg,0, 2)
250
#define TMS570_I2C_IVR_INTCODE_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
251
252
253
/*----------------------TMS570_I2C_EMDR----------------------*/
254
/* field: IGNACK - Ignore NACK mode */
255
#define TMS570_I2C_EMDR_IGNACK BSP_BIT32(1)
256
257
/* field: BCM - Backwards compatibility mode */
258
#define TMS570_I2C_EMDR_BCM BSP_BIT32(0)
259
260
261
/*-----------------------TMS570_I2C_PSC-----------------------*/
262
/* field: PSC - Prescale */
263
#define TMS570_I2C_PSC_PSC(val) BSP_FLD32(val,0, 7)
264
#define TMS570_I2C_PSC_PSC_GET(reg) BSP_FLD32GET(reg,0, 7)
265
#define TMS570_I2C_PSC_PSC_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
266
267
268
/*----------------------TMS570_I2C_PID11----------------------*/
269
/* field: CLASS - Peripheral class */
270
#define TMS570_I2C_PID11_CLASS(val) BSP_FLD32(val,8, 15)
271
#define TMS570_I2C_PID11_CLASS_GET(reg) BSP_FLD32GET(reg,8, 15)
272
#define TMS570_I2C_PID11_CLASS_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
273
274
/* field: REVISION - Revision level of the I2C */
275
#define TMS570_I2C_PID11_REVISION(val) BSP_FLD32(val,0, 7)
276
#define TMS570_I2C_PID11_REVISION_GET(reg) BSP_FLD32GET(reg,0, 7)
277
#define TMS570_I2C_PID11_REVISION_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
278
279
280
/*----------------------TMS570_I2C_PID12----------------------*/
281
/* field: TYPE - Peripheral type */
282
#define TMS570_I2C_PID12_TYPE(val) BSP_FLD32(val,0, 7)
283
#define TMS570_I2C_PID12_TYPE_GET(reg) BSP_FLD32GET(reg,0, 7)
284
#define TMS570_I2C_PID12_TYPE_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
285
286
287
/*----------------------TMS570_I2C_DMACR----------------------*/
288
/* field: TXDMAEN - Transmitter DMA enable */
289
#define TMS570_I2C_DMACR_TXDMAEN BSP_BIT32(1)
290
291
/* field: RXDMAEN - Receive DMA enable */
292
#define TMS570_I2C_DMACR_RXDMAEN BSP_BIT32(0)
293
294
295
/*----------------------TMS570_I2C_PFNC----------------------*/
296
/* field: PINFUNC - SDA and SCL Pin Function */
297
#define TMS570_I2C_PFNC_PINFUNC BSP_BIT32(0)
298
299
300
/*-----------------------TMS570_I2C_DIR-----------------------*/
301
/* field: SDADIR - SDA direction */
302
#define TMS570_I2C_DIR_SDADIR BSP_BIT32(1)
303
304
/* field: SCLDIR - SCL direction */
305
#define TMS570_I2C_DIR_SCLDIR BSP_BIT32(0)
306
307
308
/*-----------------------TMS570_I2C_DIN-----------------------*/
309
/* field: SDAIN - Serial data in */
310
#define TMS570_I2C_DIN_SDAIN BSP_BIT32(1)
311
312
/* field: SCLIN - Serial clock data in */
313
#define TMS570_I2C_DIN_SCLIN BSP_BIT32(0)
314
315
316
/*----------------------TMS570_I2C_DOUT----------------------*/
317
/* field: SDAOUT - SDA Data Output */
318
#define TMS570_I2C_DOUT_SDAOUT BSP_BIT32(1)
319
320
/* field: SCLOUT - SCL Data Output */
321
#define TMS570_I2C_DOUT_SCLOUT BSP_BIT32(0)
322
323
324
/*-----------------------TMS570_I2C_SET-----------------------*/
325
/* field: SDASET - Serial Data Set */
326
#define TMS570_I2C_SET_SDASET BSP_BIT32(1)
327
328
/* field: SCLSET - Serial Clock Set */
329
#define TMS570_I2C_SET_SCLSET BSP_BIT32(0)
330
331
332
/*-----------------------TMS570_I2C_CLR-----------------------*/
333
/* field: SDACLR - Serial Data Clear */
334
#define TMS570_I2C_CLR_SDACLR BSP_BIT32(1)
335
336
/* field: SCLCLR - Serial Clock Clear */
337
#define TMS570_I2C_CLR_SCLCLR BSP_BIT32(0)
338
339
340
/*-----------------------TMS570_I2C_PDR-----------------------*/
341
/* field: SDAPDR - SDA pin open drain enable */
342
#define TMS570_I2C_PDR_SDAPDR BSP_BIT32(1)
343
344
/* field: SCLPDR - SCL pin open drain enable */
345
#define TMS570_I2C_PDR_SCLPDR BSP_BIT32(0)
346
347
348
/*----------------------TMS570_I2C_PDIS----------------------*/
349
/* field: SDAPDIS - SDA pull disable */
350
#define TMS570_I2C_PDIS_SDAPDIS BSP_BIT32(1)
351
352
/* field: SCLPDIS - SCL pull disable */
353
#define TMS570_I2C_PDIS_SCLPDIS BSP_BIT32(0)
354
355
356
/*----------------------TMS570_I2C_PSEL----------------------*/
357
/* field: SDAPSEL - SDA pull select */
358
#define TMS570_I2C_PSEL_SDAPSEL BSP_BIT32(1)
359
360
/* field: SCLPSEL - SCL pull select */
361
#define TMS570_I2C_PSEL_SCLPSEL BSP_BIT32(0)
362
363
364
/*----------------------TMS570_I2C_pSRS----------------------*/
365
/* field: SDASRS - SDA Slew Rate select */
366
#define TMS570_I2C_pSRS_SDASRS BSP_BIT32(1)
367
368
/* field: SCLSRS - SCL Slew Rate select */
369
#define TMS570_I2C_pSRS_SCLSRS BSP_BIT32(0)
370
371
372
373
#endif
/* LIBBSP_ARM_TMS570_I2C */
utility.h
This header file provides utility macros for BSPs.
DIR
Definition:
ff.h:241
tms570_i2c_t
Definition:
reg_i2c.h:54
