36#ifndef LIBBSP_AARCH64_RASPBERRYPI_4_SPI_H
37#define LIBBSP_AARCH64_RASPBERRYPI_4_SPI_H
40#include <bsp/rpi-gpio.h>
49#define RPI_SPICS_LEN_LONG BSP_BIT32(25)
50#define RPI_SPICS_DMA_LEN BSP_BIT32(24)
51#define RPI_SPICS_CSPOL2 BSP_BIT32(23)
52#define RPI_SPICS_CSPOL1 BSP_BIT32(22)
53#define RPI_SPICS_CSPOL0 BSP_BIT32(21)
54#define RPI_SPICS_RXF BSP_BIT32(20)
55#define RPI_SPICS_RXR BSP_BIT32(19)
56#define RPI_SPICS_TXD BSP_BIT32(18)
57#define RPI_SPICS_RXD BSP_BIT32(17)
58#define RPI_SPICS_DONE BSP_BIT32(16)
59#define RPI_SPICS_LEN BSP_BIT32(13)
60#define RPI_SPICS_REN BSP_BIT32(12)
61#define RPI_SPICS_ADCS BSP_BIT32(11)
62#define RPI_SPICS_INTR BSP_BIT32(10)
63#define RPI_SPICS_INTD BSP_BIT32(9)
64#define RPI_SPICS_DMAEN BSP_BIT32(8)
65#define RPI_SPICS_TA BSP_BIT32(7)
66#define RPI_SPICS_CSPOL BSP_BIT32(6)
67#define RPI_SPICS_CLEAR_TX BSP_BIT32(5)
68#define RPI_SPICS_CLEAR_RX BSP_BIT32(4)
69#define RPI_SPICS_CPOL BSP_BIT32(3)
70#define RPI_SPICS_CPHA BSP_BIT32(2)
71#define RPI_SPICS_CS(val) BSP_FLD32(val, 0, 1)
72#define RPI_SPICS_CS_SET(reg,val) BSP_FLD32SET(reg, val, 0, 1)
74#define RPI_SPIFIFO_DATA(val) BSP_FLD32(val, 0, 31)
75#define RPI_SPIFIFO_DATA_GET(reg) BSP_FLD32GET(reg, 0, 31)
76#define RPI_SPIFIFO_DATA_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
78#define RPI_SPICLK_CDIV(val) BSP_FLD32(val, 0, 15)
79#define RPI_SPICLK_CDIV_GET(reg) BSP_FLD32GET(reg, 0, 15)
80#define RPI_SPICLK_CDIV_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
82#define RPI_SPIDLEN_LEN(val) BSP_FLD32(val, 0, 15)
83#define RPI_SPIDLEN_LEN_GET(reg) BSP_FLD32GET(reg, 0, 15)
84#define RPI_SPIDLEN_LEN_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
86#define RPI_SPILTOH_TOH(val) BSP_FLD32(val, 0, 3)
87#define RPI_SPILTOH_TOH_GET(reg) BSP_FLD32GET(reg, 0, 3)
88#define RPI_SPILTOH_TOH_SET(reg, val) BSP_FLD32SET(reg, val, 0, 3)
90#define RPI_SPIDC_RPANIC(val) BSP_FLD32(val, 24, 31)
91#define RPI_SPIDC_RPANIC_GET(reg) BSP_FLD32GET(reg, 24, 31)
92#define RPI_SPIDC_RPANIC_SET(reg, val) BSP_FLD32SET(reg, val, 24, 31)
93#define RPI_SPIDC_RDREQ(val) BSP_FLD32(val, 16, 23)
94#define RPI_SPIDC_RDREQ_GET(reg) BSP_FLD32GET(reg, 16, 23)
95#define RPI_SPIDC_RDREQ_SET(reg, val) BSP_FLD32SET(reg, val, 16, 23)
96#define RPI_SPIDC_TPANIC(val) BSP_FLD32(val, 8, 15)
97#define RPI_SPIDC_TPANIC_GET(reg) BSP_FLD32GET(reg, 8, 15)
98#define RPI_SPIDC_TPANIC_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
99#define RPI_SPIDC_TDREQ(val) BSP_FLD32(val, 0, 7)
100#define RPI_SPIDC_TDREQ_GET(reg) BSP_FLD32GET(reg, 0, 7)
101#define RPI_SPIDC_TDREQ_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
110} raspberrypi_spi_device;
rtems_status_code
Definition: status.h:85
This header file provides utility macros for BSPs.
rtems_status_code raspberrypi_spi_init(raspberrypi_spi_device device)
Register a spi device.
Definition: raspberrypi-spi.c:506
Definition: raspberrypi-spi.h:47
