RTEMS 7.0-rc1
pgtable.h
1/* SPDX-License-Identifier: GPL-2.0+-with-RTEMS-exception */
2
3/*
4 * pgtable.h
5 *
6 * PowerPC memory management structures
7 *
8 * It is a stripped down version of linux ppc file...
9 *
10 * Copyright (C) 1999 Eric Valette (eric.valette@free.fr)
11 * Canon Centre Recherche France.
12 *
13 * The license and distribution terms for this file may be
14 * found in the file LICENSE in this distribution or at
15 * http://www.rtems.org/license/LICENSE.
16 */
17
18#ifndef _LIBCPU_PGTABLE_H
19#define _LIBCPU_PGTABLE_H
20
21/*
22 * The PowerPC MMU uses a hash table containing PTEs, together with
23 * a set of 16 segment registers (on 32-bit implementations), to define
24 * the virtual to physical address mapping.
25 *
26 * We use the hash table as an extended TLB, i.e. a cache of currently
27 * active mappings. We maintain a two-level page table tree, much like
28 * that used by the i386, for the sake of the Linux memory management code.
29 * Low-level assembler code in head.S (procedure hash_page) is responsible
30 * for extracting ptes from the tree and putting them into the hash table
31 * when necessary, and updating the accessed and modified bits in the
32 * page table tree.
33 *
34 * The PowerPC MPC8xx uses a TLB with hardware assisted, software tablewalk.
35 * We also use the two level tables, but we can put the real bits in them
36 * needed for the TLB and tablewalk. These definitions require Mx_CTR.PPM = 0,
37 * Mx_CTR.PPCS = 0, and MD_CTR.TWAM = 1. The level 2 descriptor has
38 * additional page protection (when Mx_CTR.PPCS = 1) that allows TLB hit
39 * based upon user/super access. The TLB does not have accessed nor write
40 * protect. We assume that if the TLB get loaded with an entry it is
41 * accessed, and overload the changed bit for write protect. We use
42 * two bits in the software pte that are supposed to be set to zero in
43 * the TLB entry (24 and 25) for these indicators. Although the level 1
44 * descriptor contains the guarded and writethrough/copyback bits, we can
45 * set these at the page level since they get copied from the Mx_TWC
46 * register when the TLB entry is loaded. We will use bit 27 for guard, since
47 * that is where it exists in the MD_TWC, and bit 26 for writethrough.
48 * These will get masked from the level 2 descriptor at TLB load time, and
49 * copied to the MD_TWC before it gets loaded.
50 */
51
52/* PMD_SHIFT determines the size of the area mapped by the second-level page tables */
53#define PMD_SHIFT 22
54#define PMD_SIZE (1UL << PMD_SHIFT)
55#define PMD_MASK (~(PMD_SIZE-1))
56
57/* PGDIR_SHIFT determines what a third-level page table entry can map */
58#define PGDIR_SHIFT 22
59#define PGDIR_SIZE (1UL << PGDIR_SHIFT)
60#define PGDIR_MASK (~(PGDIR_SIZE-1))
61
62/*
63 * entries per page directory level: our page-table tree is two-level, so
64 * we don't really have any PMD directory.
65 */
66#define PTRS_PER_PTE 1024
67#define PTRS_PER_PMD 1
68#define PTRS_PER_PGD 1024
69#define USER_PTRS_PER_PGD (TASK_SIZE / PGDIR_SIZE)
70
71/* Just any arbitrary offset to the start of the vmalloc VM area: the
72 * current 64MB value just means that there will be a 64MB "hole" after the
73 * physical memory until the kernel virtual memory starts. That means that
74 * any out-of-bounds memory accesses will hopefully be caught.
75 * The vmalloc() routines leaves a hole of 4kB between each vmalloced
76 * area for the same reason. ;)
77 *
78 * We no longer map larger than phys RAM with the BATs so we don't have
79 * to worry about the VMALLOC_OFFSET causing problems. We do have to worry
80 * about clashes between our early calls to ioremap() that start growing down
81 * from ioremap_base being run into the VM area allocations (growing upwards
82 * from VMALLOC_START). For this reason we have ioremap_bot to check when
83 * we actually run into our mappings setup in the early boot with the VM
84 * system. This really does become a problem for machines with good amounts
85 * of RAM. -- Cort
86 */
87#define VMALLOC_OFFSET (0x4000000) /* 64M */
88#define VMALLOC_START ((((long)high_memory + VMALLOC_OFFSET) & ~(VMALLOC_OFFSET-1)))
89#define VMALLOC_VMADDR(x) ((unsigned long)(x))
90#define VMALLOC_END ioremap_bot
91
92/*
93 * Bits in a linux-style PTE. These match the bits in the
94 * (hardware-defined) PowerPC PTE as closely as possible.
95 */
96#define _PAGE_PRESENT 0x001 /* software: pte contains a translation */
97#define _PAGE_USER 0x002 /* matches one of the PP bits */
98#define _PAGE_RW 0x004 /* software: user write access allowed */
99#define _PAGE_GUARDED 0x008
100#define _PAGE_COHERENT 0x010 /* M: enforce memory coherence (SMP systems) */
101#define _PAGE_NO_CACHE 0x020 /* I: cache inhibit */
102#define _PAGE_WRITETHRU 0x040 /* W: cache write-through */
103#define _PAGE_DIRTY 0x080 /* C: page changed */
104#define _PAGE_ACCESSED 0x100 /* R: page referenced */
105#define _PAGE_HWWRITE 0x200 /* software: _PAGE_RW & _PAGE_DIRTY */
106#define _PAGE_SHARED 0
107
108#define _PAGE_CHG_MASK (PAGE_MASK | _PAGE_ACCESSED | _PAGE_DIRTY)
109
110#define _PAGE_BASE _PAGE_PRESENT | _PAGE_ACCESSED
111#define _PAGE_WRENABLE _PAGE_RW | _PAGE_DIRTY | _PAGE_HWWRITE
112
113#define PAGE_NONE __pgprot(_PAGE_PRESENT | _PAGE_ACCESSED)
114
115#define PAGE_SHARED __pgprot(_PAGE_BASE | _PAGE_RW | _PAGE_USER | \
116 _PAGE_SHARED)
117#define PAGE_COPY __pgprot(_PAGE_BASE | _PAGE_USER)
118#define PAGE_READONLY __pgprot(_PAGE_BASE | _PAGE_USER)
119#define PAGE_KERNEL __pgprot(_PAGE_BASE | _PAGE_WRENABLE | _PAGE_SHARED)
120#define PAGE_KERNEL_CI __pgprot(_PAGE_BASE | _PAGE_WRENABLE | _PAGE_SHARED | \
121 _PAGE_NO_CACHE )
122
123/*
124 * The PowerPC can only do execute protection on a segment (256MB) basis,
125 * not on a page basis. So we consider execute permission the same as read.
126 * Also, write permissions imply read permissions.
127 * This is the closest we can get..
128 */
129#define __P000 PAGE_NONE
130#define __P001 PAGE_READONLY
131#define __P010 PAGE_COPY
132#define __P011 PAGE_COPY
133#define __P100 PAGE_READONLY
134#define __P101 PAGE_READONLY
135#define __P110 PAGE_COPY
136#define __P111 PAGE_COPY
137
138#define __S000 PAGE_NONE
139#define __S001 PAGE_READONLY
140#define __S010 PAGE_SHARED
141#define __S011 PAGE_SHARED
142#define __S100 PAGE_READONLY
143#define __S101 PAGE_READONLY
144#define __S110 PAGE_SHARED
145#define __S111 PAGE_SHARED
146#endif /* _LIBCPU_PGTABLE_H */
