RTEMS 7.0-rc1
pcmcia_ide.h
1/*
2 * RTEMS generic MPC5200 BSP
3 *
4 * RTEMS MPC5x00 PCMCIA IDE harddisk header file
5 * This file contains declarations for the PCMCIA IDE Interface.
6 */
7
8/*
9 * Copyright (C) 2003 IPR Engineering
10 * Copyright (C) 2005 embedded brains GmbH & Co. KG
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34#ifndef __PCMCIA_IDE_h
35#define __PCMCIA_IDE_h
36
37#include <bsp.h>
38
39#define GPIOPCR_ATA_CS_4_5 (1 << 24)
40
41/*#define DEBUG_OUT*/
42#define GET_UP_BYTE_OF_MPC5200_ATA_DRIVE_REG(val32) ((uint16_t)((val32) >> 24))
43#define SET_UP_BYTE_OF_MPC5200_ATA_DRIVE_REG(val8) ((uint32_t)((val8) << 24))
44#define GET_UP_WORD_OF_MPC5200_ATA_DRIVE_REG(val32) ((uint16_t)((val32) >> 16))
45#define SET_UP_WORD_OF_MPC5200_ATA_DRIVE_REG(val16) ((uint32_t)((val16) << 16))
46
47#define ATA_HCFG_SMR (1 << 31)
48#define ATA_HCFG_FR (1 << 30)
49#define ATA_HCFG_IORDY (1 << 24)
50#define ATA_HCFG_IE (1 << 25)
51
52#define COUNT_VAL(nsec) (((nsec) * (IPB_CLOCK / 1000000) + 999) / 1000)
53
54#define PIO_3 0
55#define PIO_4 1
56
57#define T0 0
58#define T2_8 1
59#define T2_16 2
60#define T4 3
61#define T1 4
62#define TA 5
63
64#define ATA_PIO_TIMING_1(t0,t2_8,t2_16) (((COUNT_VAL(t0)) << 24) | ((COUNT_VAL(t2_8)) << 16) | ((COUNT_VAL(t2_16)) << 8))
65#define ATA_PIO_TIMING_2(t4,t1,ta) (((COUNT_VAL(t4)) << 24) | ((COUNT_VAL(t1)) << 16) | ((COUNT_VAL(ta)) << 8))
66
67#endif
