39#ifndef _RTEMS_CONFDEFS_OBJECTSCLASSIC_H
40#define _RTEMS_CONFDEFS_OBJECTSCLASSIC_H
42#ifndef __CONFIGURATION_TEMPLATE_h
43#error "Do not include this file directly, use <rtems/confdefs.h> instead"
50#if CONFIGURE_MAXIMUM_BARRIERS > 0
54#if CONFIGURE_MAXIMUM_PORTS > 0
58#if CONFIGURE_MAXIMUM_MESSAGE_QUEUES > 0
62#if CONFIGURE_MAXIMUM_PARTITIONS > 0
66#if CONFIGURE_MAXIMUM_PERIODS > 0
70#if CONFIGURE_MAXIMUM_REGIONS > 0
74#if CONFIGURE_MAXIMUM_SEMAPHORES > 0
79#if CONFIGURE_MAXIMUM_TIMERS > 0
87#if CONFIGURE_MAXIMUM_BARRIERS > 0
91#if CONFIGURE_MAXIMUM_MESSAGE_QUEUES > 0
95#if CONFIGURE_MAXIMUM_PARTITIONS > 0
99#if CONFIGURE_MAXIMUM_PERIODS > 0
103#if CONFIGURE_MAXIMUM_PORTS > 0
107#if CONFIGURE_MAXIMUM_REGIONS > 0
111#if CONFIGURE_MAXIMUM_SEMAPHORES > 0
114 _CONFIGURE_SCHEDULER_COUNT
118#if CONFIGURE_MAXIMUM_TIMERS > 0
This header file provides data structures used by the implementation and the Application Configuratio...
This header file evaluates configuration options related to the scheduler configuration.
#define CONFIGURE_MAXIMUM_SEMAPHORES
This configuration option is an integer define.
Definition: appl-config.h:701
#define CONFIGURE_MAXIMUM_BARRIERS
Definition: appl-config.h:451
#define CONFIGURE_MAXIMUM_PORTS
Definition: appl-config.h:612
#define CONFIGURE_MAXIMUM_PARTITIONS
Definition: appl-config.h:532
#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES
Definition: appl-config.h:492
#define CONFIGURE_MAXIMUM_TIMERS
Definition: appl-config.h:802
#define CONFIGURE_MAXIMUM_PERIODS
Definition: appl-config.h:572
#define CONFIGURE_MAXIMUM_REGIONS
Definition: appl-config.h:652
#define BARRIER_INFORMATION_DEFINE(max)
Macro to define the objects information for the Classic Barrier objects.
Definition: barrierdata.h:80
#define DUAL_PORTED_MEMORY_INFORMATION_DEFINE(max)
Macro to define the objects information for the Classic Dual Ported Memory objects.
Definition: dpmemdata.h:84
#define MESSAGE_QUEUE_INFORMATION_DEFINE(max)
Macro to define the objects information for the Classic Message Queue objects.
Definition: messagedata.h:97
#define PARTITION_INFORMATION_DEFINE(_max)
Defines the Partition Manager objects information.
Definition: partdata.h:144
#define RATE_MONOTONIC_INFORMATION_DEFINE(max)
Macro to define the objects information for the Classic Rate Monotonic objects.
Definition: ratemondata.h:169
#define REGION_INFORMATION_DEFINE(max)
Macro to define the objects information for the Classic Region objects.
Definition: regiondata.h:83
#define SEMAPHORE_INFORMATION_DEFINE(max, scheduler_count)
Macro to define the objects information for the Classic Semaphore objects.
Definition: semdata.h:156
#define TIMER_INFORMATION_DEFINE(max)
Macro to define the objects information for the Classic Timer objects.
Definition: timerdata.h:94
This header file evaluates configuration options related to the unlimited objects configuration.
