RTEMS
7.0-rc1
bsps
include
libchip
ns16550_p.h
1
/* SPDX-License-Identifier: GPL-2.0+-with-RTEMS-exception */
2
8
9
* COPYRIGHT (c) 1998 by Radstone Technology
10
11
12
* THIS FILE IS PROVIDED TO YOU, THE USER, "AS IS", WITHOUT WARRANTY OF ANY
13
* KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE
14
* IMPLIED WARRANTY OF FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK
15
* AS TO THE QUALITY AND PERFORMANCE OF ALL CODE IN THIS FILE IS WITH YOU.
16
17
* You are hereby granted permission to use, copy, modify, and distribute
18
* this file, provided that this notice, plus the above copyright notice
19
* and disclaimer, appears in all copies. Radstone Technology will provide
20
* no support for this code.
21
22
* COPYRIGHT (c) 1989-2012.
23
* On-Line Applications Research Corporation (OAR).
24
25
* The license and distribution terms for this file may be
26
* found in the file LICENSE in this distribution or at
27
* http://www.rtems.org/license/LICENSE.
28
29
30
#ifndef _NS16550_P_H_
31
#define _NS16550_P_H_
32
33
#ifndef ASM
34
libchip/serial.h
35
#endif
36
37
#ifdef __cplusplus
38
extern
"C"
39
#endif
40
41
42
* Define NS16550_STATIC to nothing while debugging so the entry points
43
* will show up in the symbol table.
44
45
46
#define NS16550_STATIC static
47
48
#define NS16550_RECEIVE_BUFFER 0
49
#define NS16550_TRANSMIT_BUFFER 0
50
#define NS16550_DIVISOR_LATCH_L 0
51
#define NS16550_INTERRUPT_ENABLE 1
52
#define NS16550_DIVISOR_LATCH_M 1
53
#define NS16550_INTERRUPT_ID 2
54
#define NS16550_FIFO_CONTROL 2
55
#define NS16550_LINE_CONTROL 3
56
#define NS16550_MODEM_CONTROL 4
57
#define NS16550_LINE_STATUS 5
58
#define NS16550_MODEM_STATUS 6
59
#define NS16550_SCRATCH_PAD 7
60
#define NS16550_FRACTIONAL_DIVIDER 10
61
62
63
* Define serial port interrupt enable register structure.
64
65
66
#define SP_INT_RX_ENABLE 0x01
67
#define SP_INT_TX_ENABLE 0x02
68
#define SP_INT_LS_ENABLE 0x04
69
#define SP_INT_MS_ENABLE 0x08
70
71
#define NS16550_ENABLE_ALL_INTR (SP_INT_RX_ENABLE | SP_INT_TX_ENABLE)
72
#define NS16550_DISABLE_ALL_INTR 0x00
73
#define NS16550_ENABLE_ALL_INTR_EXCEPT_TX (SP_INT_RX_ENABLE)
74
75
76
* Define serial port interrupt ID register structure.
77
78
79
#define SP_IID_0 0x01
80
#define SP_IID_1 0x02
81
#define SP_IID_2 0x04
82
#define SP_IID_3 0x08
83
84
85
* Define serial port fifo control register structure.
86
87
88
#define SP_FIFO_ENABLE 0x01
89
#define SP_FIFO_RXRST 0x02
90
#define SP_FIFO_TXRST 0x04
91
#define SP_FIFO_DMA 0x08
92
#define SP_FIFO_RXLEVEL 0xc0
93
94
#define SP_FIFO_SIZE 16
95
96
97
* Define serial port line control register structure.
98
99
100
#define SP_LINE_SIZE 0x03
101
#define SP_LINE_STOP 0x04
102
#define SP_LINE_PAR 0x08
103
#define SP_LINE_ODD 0x10
104
#define SP_LINE_STICK 0x20
105
#define SP_LINE_BREAK 0x40
106
#define SP_LINE_DLAB 0x80
107
108
109
* Line status register character size definitions.
110
111
112
#define FIVE_BITS 0x0
/* five bits per character */
113
#define SIX_BITS 0x1
/* six bits per character */
114
#define SEVEN_BITS 0x2
/* seven bits per character */
115
#define EIGHT_BITS 0x3
/* eight bits per character */
116
117
118
* Define serial port modem control register structure.
119
120
121
#define SP_MODEM_DTR 0x01
122
#define SP_MODEM_RTS 0x02
123
#define SP_MODEM_IRQ 0x08
124
#define SP_MODEM_LOOP 0x10
125
#define SP_MODEM_DIV4 0x80
126
127
128
* Define serial port line status register structure.
129
130
131
#define SP_LSR_RDY 0x01
132
#define SP_LSR_EOVRUN 0x02
133
#define SP_LSR_EPAR 0x04
134
#define SP_LSR_EFRAME 0x08
135
#define SP_LSR_BREAK 0x10
136
#define SP_LSR_THOLD 0x20
137
#define SP_LSR_TX 0x40
138
#define SP_LSR_EFIFO 0x80
139
140
#ifdef __cplusplus
141
142
#endif
143
144
#endif
/* _NS16550_P_H_ */
serial.h
The generic libchip serial driver interface.
