RTEMS 7.0-rc1
cpm.h
1/* SPDX-License-Identifier: GPL-2.0+-with-RTEMS-exception */
2
3/*
4 * cpm.h
5 *
6 * This include file contains definitions pertaining
7 * to the Communications Processor Module (CPM) on the MPC8xx.
8 *
9 * Copyright (c) 1999, National Research Council of Canada
10 *
11 * The license and distribution terms for this file may be
12 * found in the file LICENSE in this distribution or at
13 * http://www.rtems.org/license/LICENSE.
14 */
15
16#ifndef _MPC8260_CPM_H
17#define _MPC8260_CPM_H
18
19#ifdef __cplusplus
20extern "C" {
21#endif
22
23
24#define M8xx_BRG_1 (1U << 0)
25#define M8xx_BRG_2 (1U << 1)
26#define M8xx_BRG_3 (1U << 2)
27#define M8xx_BRG_4 (1U << 3)
28#define M8xx_BRG_5 (1U << 4)
29#define M8xx_BRG_6 (1U << 5)
30#define M8xx_BRG_7 (1U << 6)
31#define M8xx_BRG_8 (1U << 7)
32
33
34#define M8260_SCC_BRGS (M8xx_BRG_1 | M8xx_BRG_2 | M8xx_BRG_3 | M8xx_BRG_4)
35#define M8260_FCC_BRGS (M8xx_BRG_5 | M8xx_BRG_6 | M8xx_BRG_7 | M8xx_BRG_8)
36#define M8260_SMC1_BRGS (M8xx_BRG_1|M8xx_BRG_7)
37#define M8260_SMC2_BRGS (M8xx_BRG_2|M8xx_BRG_8)
38
39
40#define M8xx_CLK_1 (1U << 0)
41#define M8xx_CLK_2 (1U << 1)
42#define M8xx_CLK_3 (1U << 2)
43#define M8xx_CLK_4 (1U << 3)
44#define M8xx_CLK_5 (1U << 4)
45#define M8xx_CLK_6 (1U << 5)
46#define M8xx_CLK_7 (1U << 6)
47#define M8xx_CLK_8 (1U << 7)
48#define M8xx_CLK_9 (1U << 8)
49#define M8xx_CLK_10 (1U << 9)
50#define M8xx_CLK_11 (1U << 10)
51#define M8xx_CLK_12 (1U << 11)
52#define M8xx_CLK_13 (1U << 12)
53#define M8xx_CLK_14 (1U << 13)
54#define M8xx_CLK_15 (1U << 14)
55#define M8xx_CLK_16 (1U << 15)
56#define M8xx_CLK_17 (1U << 16)
57#define M8xx_CLK_18 (1U << 17)
58#define M8xx_CLK_19 (1U << 18)
59#define M8xx_CLK_20 (1U << 19)
60
61#define M8260_BRG1_CLKS (M8xx_CLK_3 | M8xx_CLK_5 )
62#define M8260_BRG2_CLKS (M8xx_CLK_3 | M8xx_CLK_5 )
63#define M8260_BRG3_CLKS (M8xx_CLK_9 | M8xx_CLK_15 )
64#define M8260_BRG4_CLKS (M8xx_CLK_9 | M8xx_CLK_15 )
65#define M8260_BRG5_CLKS (M8xx_CLK_3 | M8xx_CLK_5 )
66#define M8260_BRG6_CLKS (M8xx_CLK_3 | M8xx_CLK_5 )
67#define M8260_BRG7_CLKS (M8xx_CLK_9 | M8xx_CLK_15 )
68#define M8260_BRG8_CLKS (M8xx_CLK_9 | M8xx_CLK_15 )
69
70#define M8260_SCC1_CLKS (M8xx_CLK_3 | M8xx_CLK_4 | M8xx_CLK_11 | M8xx_CLK_12)
71#define M8260_SCC2_CLKS (M8xx_CLK_3 | M8xx_CLK_4 | M8xx_CLK_11 | M8xx_CLK_12)
72#define M8260_SCC3_CLKS (M8xx_CLK_5 | M8xx_CLK_6 | M8xx_CLK_7 | M8xx_CLK_8 )
73#define M8260_SCC4_CLKS (M8xx_CLK_5 | M8xx_CLK_6 | M8xx_CLK_7 | M8xx_CLK_8 )
74
75#define M8260_FCC1_CLKS (M8xx_CLK_9 | M8xx_CLK_10 | M8xx_CLK_11 | M8xx_CLK_12)
76#define M8260_FCC2_CLKS (M8xx_CLK_13 | M8xx_CLK_14 | M8xx_CLK_15 | M8xx_CLK_16)
77#define M8260_FCC3_CLKS (M8xx_CLK_13 | M8xx_CLK_14 | M8xx_CLK_15 | M8xx_CLK_16)
78
79#define M8260_TDM_RXA1 (M8xx_CLK_1 | M8xx_CLK_19 )
80#define M8260_TDM_RXB1 (M8xx_CLK_3 | M8xx_CLK_9 )
81#define M8260_TDM_RXC1 (M8xx_CLK_5 | M8xx_CLK_13 )
82#define M8260_TDM_RXD1 (M8xx_CLK_7 | M8xx_CLK_15 )
83#define M8260_TDM_TXA1 (M8xx_CLK_2 | M8xx_CLK_20 )
84#define M8260_TDM_TXB1 (M8xx_CLK_4 | M8xx_CLK_10 )
85#define M8260_TDM_TXC1 (M8xx_CLK_6 | M8xx_CLK_14 )
86#define M8260_TDM_TXD1 (M8xx_CLK_8 | M8xx_CLK_16 )
87
88#define M8260_TDM_RXA2 (M8xx_CLK_13 | M8xx_CLK_5 )
89#define M8260_TDM_RXB2 (M8xx_CLK_15 | M8xx_CLK_17 )
90#define M8260_TDM_RXC2 (M8xx_CLK_3 | M8xx_CLK_17 )
91#define M8260_TDM_RXD2 (M8xx_CLK_1 | M8xx_CLK_19 )
92#define M8260_TDM_TXA2 (M8xx_CLK_14 | M8xx_CLK_6 )
93#define M8260_TDM_TXB2 (M8xx_CLK_16 | M8xx_CLK_18 )
94#define M8260_TDM_TXC2 (M8xx_CLK_4 | M8xx_CLK_18 )
95#define M8260_TDM_TXD2 (M8xx_CLK_2 | M8xx_CLK_20 )
96
97
98
99/* Functions */
100
101void m8xx_cp_execute_cmd( uint32_t command );
102void *m8xx_dpram_allocate( unsigned int byte_count );
103
104#define m8xx_bd_allocate(count) \
105 m8xx_dpram_allocate( (count) * sizeof(m8260BufferDescriptor_t) )
106#define m8xx_RISC_timer_table_allocate(count) \
107 m8xx_dpram_allocate( (count) * 4 )
108
109
110
111int m8xx_get_brg_cd (int baud);
112int m8xx_get_brg(unsigned brgmask, int baud);
113void m8xx_free_brg(int brg_num);
114
115
116int m8xx_get_clk( unsigned clkmask );
117void m8xx_free_clk( int clk_num );
118
119
120#ifdef __cplusplus
121}
122#endif
123
124#endif
125/* end of include file */
