RTEMS
7.0-rc1
bsps
include
umon
monlib.h
1
10
/* Based upon code from MicroMonitor 1.17 from http://www.umonfw.com/
11
* which includes this notice:
12
13
14
* General notice:
15
* This code is part of a boot-monitor package developed as a generic base
16
* platform for embedded system designs. As such, it is likely to be
17
* distributed to various projects beyond the control of the original
18
* author. Please notify the author of any enhancements made or bugs found
19
* so that all may benefit from the changes. In addition, notification back
20
* to the author will allow the new user to pick up changes that may have
21
* been made by other users after this version of the code was distributed.
22
23
* Note1: the majority of this code was edited with 4-space tabs.
24
* Note2: as more and more contributions are accepted, the term "author"
25
* is becoming a mis-representation of credit.
26
27
* Original author: Ed Sutter
28
* Email: esutter@alcatel-lucent.com
29
* Phone: 908-582-2351
30
31
32
* Ed Sutter has been informed that this code is being used in RTEMS.
33
34
* This code was reformatted by Joel Sherrill from OAR Corporation and
35
* Fernando Nicodemos <fgnicodemos@terra.com.br> from NCB - Sistemas
36
* Embarcados Ltda. (Brazil) to be more compliant with RTEMS coding
37
* standards and to eliminate C++ style comments.
38
39
40
#ifndef _MONLIB_H_
41
#define _MONLIB_H_
42
43
umon/tfs.h
44
umon/cli.h
45
46
#ifdef __cplusplus
47
extern
"C"
48
#endif
49
66
extern
int
monConnect(
int
(*monptr)(
int
void
void
void
67
void
(*lock)(
void
void
(*unlock)(
void
68
extern
void
mon_getargv(
int
*argc,
char
***argv);
69
extern
void
mon_intsrestore(
unsigned
long
oldval);
70
extern
void
mon_appexit(
int
exit_value);
71
extern
void
mon_free(
char
*buffer);
72
extern
void
mon_profiler(
void
*pdata);
73
extern
void
mon_bbc(
char
*filename,
int
linenum);
74
extern
void
mon_warmstart(
unsigned
long
mask);
75
extern
void
mon_delay(
long
msec);
76
extern
void
mon_printpkt(
char
*buf,
int
size,
int
incoming);
77
extern
void
mon_printmem(
char
*mem,
int
size,
int
ascii);
78
79
80
extern
int
mon_com(
int
cmd,
void
*arg1,
void
*arg2,
void
*arg3);
81
extern
int
mon_timer(
int
cmd,
void
* arg);
82
extern
int
mon_setenv(
char
*varname,
char
*value);
83
extern
int
mon_putchar(
char
c);
84
extern
int
mon_getchar(
void
85
extern
int
mon_gotachar(
void
86
extern
int
mon_getbytes(
char
*buf,
int
count,
int
block);
87
extern
int
mon_restart(
int
restart_value);
88
extern
int
mon_tfsinit(
void
89
extern
int
mon_tfsunlink(
char
*filename);
90
extern
int
mon_tfslink(
char
*source,
char
*target);
91
extern
int
mon_tfsrun(
char
**arglist,
int
verbosity);
92
extern
int
mon_tfsfstat(
char
*filename,
struct
tfshdr
*tfp);
93
extern
int
mon_tfseof(
int
file_descriptor);
94
extern
int
mon_tfstruncate(
int
file_descriptor,
long
length);
95
extern
int
mon_tfsread(
int
file_descriptor,
char
*buffer,
int
size);
96
extern
int
mon_tfswrite(
int
file_descriptor,
char
*buffer,
int
size);
97
extern
int
mon_tfsopen(
char
*filename,
long
mode,
char
*buffer);
98
extern
int
mon_tfsclose(
int
file_descriptor,
char
*info);
99
extern
int
mon_tfsseek(
int
file_descriptor,
int
offset,
int
whence);
100
extern
int
mon_tfsgetline(
int
file_descriptor,
char
*buffer,
int
bufsize);
101
extern
int
mon_tfsipmod(
char
*name,
char
*buffer,
int
offset,
int
size);
102
extern
int
mon_addcommand(
struct
monCommand
*command_list,
char
103
extern
int
mon_docommand(
char
*cmdline,
int
verbosity);
104
extern
int
mon_getline(
char
*buffer,
int
max,
int
ledit);
105
extern
int
mon_decompress(
char
*src,
int
srcsize,
char
*dest);
106
extern
int
mon_heapextend(
char
*base,
int
size);
107
extern
int
mon_pcicfgwrite(
int
interface,
int
bus,
int
dev,
int
func,
int
reg,
108
unsigned
long
val);
109
extern
int
mon_tfsadd(
char
*filename,
char
*info,
char
*flags,
110
unsigned
char
*src,
int
size);
111
extern
int
mon_i2cwrite(
int
interface,
int
bigaddr,
unsigned
char
*data,
112
int
len);
113
extern
int
mon_i2cread(
int
interface,
int
bigaddr,
unsigned
char
*data,
114
int
len);
115
extern
int
mon_sendenetpkt(
char
*pkt,
int
len);
116
extern
int
mon_recvenetpkt(
char
*pkt,
int
len);
117
extern
int
mon_flashoverride(
void
*flashinfo,
int
get,
int
bank);
118
extern
int
mon_flasherase(
int
snum);
119
extern
int
mon_flashwrite(
char
*dest,
char
*src,
int
bytecnt);
120
extern
int
mon_flashinfo(
int
snum,
int
*size,
char
**base);
121
extern
int
mon_watchdog(
void
122
extern
int
mon_timeofday(
int
cmd,
void
*arg);
123
124
extern
char
*mon_getsym(
char
*symname,
char
*buf,
int
bufsize);
125
extern
char
*mon_getenv(
char
*varname);
126
extern
char
*mon_getenvp(
void
127
extern
char
*mon_version(
void
128
#ifdef MALLOC_DEBUG
129
extern
char
*mon_malloc(
int
size,
char
*file,
int
line);
130
extern
char
*mon_realloc(
char
*buf,
int
size,
char
*file,
int
line);
131
#else
132
extern
char
*mon_malloc(
int
size);
133
extern
char
*mon_realloc(
char
*buf,
int
size);
134
#endif
135
136
extern
long
mon_tfsctrl(
int
command,
long
arg1,
long
arg2);
137
extern
long
mon_tfstell(
int
file_descriptor);
138
extern
long
mon_portcmd(
int
cmd,
void
*arg);
139
140
extern
unsigned
short
mon_xcrc16(
char
*buffer,
long
length);
141
142
extern
unsigned
long
mon_intsoff(
void
143
144
extern
unsigned
long
mon_pcicfgread(
int
interface,
int
bus,
int
dev,
145
int
func,
int
reg);
146
147
extern
unsigned
long
mon_pcictrl(
int
interface,
int
cmd,
148
unsigned
long
arg1,
unsigned
long
arg2);
149
150
extern
unsigned
long
mon_i2cctrl(
int
interface,
int
cmd,
151
unsigned
long
arg1,
unsigned
long
arg2);
152
153
extern
unsigned
long
mon_assignhandler(
long
hnum,
154
unsigned
long
arg1,
unsigned
long
arg2);
155
156
extern
struct
tfshdr
*mon_tfsnext(
struct
tfshdr
*tfp);
157
extern
struct
tfshdr
*mon_tfsstat(
char
*filename);
158
159
160
* The external caller should see these as variable argument methods but
161
* they are not implemented that way, so let monlib.c prototype them internally
162
* when building that file.
163
164
#ifndef _INSIDE_MONLIB
165
extern
void
mon_memtrace(
char
*fmt, ...);
166
extern
int
mon_printf(
char
*fmt, ...);
167
extern
int
mon_cprintf(
char
*fmt, ...);
168
extern
int
mon_sprintf(
char
char
*fmt, ...);
169
#endif
170
171
#ifdef __cplusplus
172
173
#endif
174
175
176
/* defines used by monConnect():
177
178
#define GETMONFUNC_PUTCHAR 1
179
#define GETMONFUNC_GETCHAR 2
180
#define GETMONFUNC_GOTACHAR 3
181
#define GETMONFUNC_GETBYTES 4
182
#define GETMONFUNC_PRINTF 5
183
#define GETMONFUNC_CPRINTF 6
184
#define GETMONFUNC_SPRINTF 7
185
#define GETMONFUNC_RESTART 8
186
#define GETMONFUNC_GETENV 9
187
#define GETMONFUNC_SETENV 10
188
#define GETMONFUNC_TFSINIT 11
189
#define GETMONFUNC_TFSADD 12
190
#define GETMONFUNC_TFSUNLINK 13
191
#define GETMONFUNC_TFSRUN 14
192
#define GETMONFUNC_TFSNEXT 15
193
#define GETMONFUNC_TFSSTAT 16
194
#define GETMONFUNC_TFSREAD 17
195
#define GETMONFUNC_TFSWRITE 18
196
#define GETMONFUNC_TFSOPEN 19
197
#define GETMONFUNC_TFSCLOSE 20
198
#define GETMONFUNC_TFSSEEK 21
199
#define GETMONFUNC_TFSGETLINE 22
200
#define GETMONFUNC_TFSIPMOD 23
201
#define GETMONFUNC_TFSCTRL 24
202
#define GETMONFUNC_ADDCOMMAND 25
203
#define GETMONFUNC_DOCOMMAND 26
204
#define GETMONFUNC_GETARGV 27
205
#define GETMONFUNC_CRC16 28
206
#define GETMONFUNC_CRC32 29
207
#define GETMONFUNC_PIOGET 30
/* NA (removed as of 1.0) */
208
#define GETMONFUNC_PIOSET 31
209
#define GETMONFUNC_PIOCLR 32
210
#define GETMONFUNC_INTSOFF 33
211
#define GETMONFUNC_INTSRESTORE 34
212
#define GETMONFUNC_APPEXIT 35
213
#define GETMONFUNC_MALLOC 36
214
#define GETMONFUNC_FREE 37
215
#define GETMONFUNC_GETLINE 38
216
#define GETMONFUNC_TFSFSTAT 39
217
#define GETMONFUNC_TFSEOF 40
218
#define GETMONFUNC_DECOMPRESS 41
219
#define GETMONFUNC_TFSTRUNCATE 42
220
#define GETMONFUNC_HEAPXTEND 43
221
#define GETMONFUNC_PROFILER 44
222
#define GETMONFUNC_TFSLINK 45
223
#define GETMONFUNC_BBC 46
224
#define GETMONFUNC_MEMTRACE 47
225
#define GETMONFUNC_TFSTELL 48
226
#define GETMONFUNC_VERSION 49
227
#define GETMONFUNC_WARMSTART 50
228
#define GETMONFUNC_PCICFGREAD 51
229
#define GETMONFUNC_PCICFGWRITE 52
230
#define GETMONFUNC_PCICONTROL 53
231
#define GETMONFUNC_I2CREAD 54
232
#define GETMONFUNC_I2CWRITE 55
233
#define GETMONFUNC_I2CCONTROL 56
234
#define GETMONFUNC_MONDELAY 57
235
#define GETMONFUNC_GETENVP 58
236
#define GETMONFUNC_REALLOC 59
237
#define GETMONFUNC_SENDENETPKT 60
238
#define GETMONFUNC_RECVENETPKT 61
239
#define GETMONFUNC_GETSYM 62
240
#define GETMONFUNC_PRINTPKT 63
241
#define GETMONFUNC_FLASHWRITE 64
242
#define GETMONFUNC_FLASHERASE 65
243
#define GETMONFUNC_FLASHINFO 66
244
#define GETMONFUNC_ASSIGNHDLR 67
245
#define GETMONFUNC_WATCHDOG 68
246
#define GETMONFUNC_PRINTMEM 69
247
#define GETMONFUNC_PORTCMD 70
248
#define GETMONFUNC_TIMEOFDAY 71
249
#define GETMONFUNC_TIMER 72
250
#define GETMONFUNC_FLASHOVRRD 73
251
252
#define CACHEFTYPE_DFLUSH 200
253
#define CACHEFTYPE_IINVALIDATE 201
254
255
#define CHARFUNC_PUTCHAR 300
256
#define CHARFUNC_GETCHAR 301
257
#define CHARFUNC_GOTACHAR 302
258
#define CHARFUNC_RAWMODEON 303
259
#define CHARFUNC_RAWMODEOFF 304
260
261
#define ASSIGNFUNC_GETUSERLEVEL 400
262
263
264
/* Defines used by mon_warmstart():
265
266
#define WARMSTART_IOINIT 0x00000001
267
#define WARMSTART_BSSINIT 0x00000002
268
#define WARMSTART_RUNMONRC 0x00000004
269
#define WARMSTART_MONHEADER 0x00000008
270
#define WARMSTART_TFSAUTOBOOT 0x00000010
271
#define WARMSTART_BOARDINFO 0x00000020
272
#define WARMSTART_ALL 0xffffffff
273
#endif
cli.h
Header file for Command Line Interface related stuff.
monCommand
Definition:
cli.h:54
tfshdr
Definition:
tfs.h:138
tfs.h
Header file for TFS transactions, used by both application and monnitor.
