RTEMS 7.0-rc1
irq.c File Reference
Interrupt support. More...
#include <inttypes.h>
#include <bsp.h>
#include <bsp/irq.h>
#include <bsp/irq-generic.h>
#include <libcpu/isr_entries.h>
#include <rtems/bspIo.h>
rtems_status_code bsp_interrupt_get_attributes (rtems_vector_number vector, rtems_interrupt_attributes *attributes)
 Gets the attributes of the interrupt vector.
rtems_status_code bsp_interrupt_is_pending (rtems_vector_number vector, bool *pending)
 Checks if the interrupt is pending.
rtems_status_code bsp_interrupt_raise (rtems_vector_number vector)
 Causes the interrupt vector.
rtems_status_code bsp_interrupt_clear (rtems_vector_number vector)
 Clears the interrupt vector.
rtems_status_code bsp_interrupt_vector_is_enabled (rtems_vector_number vector, bool *enabled)
 Checks if the interrupt is enabled.
rtems_status_code bsp_interrupt_vector_enable (rtems_vector_number vector)
 Enables the interrupt vector.
rtems_status_code bsp_interrupt_vector_disable (rtems_vector_number vector)
 Disables the interrupt vector.
rtems_status_code bsp_interrupt_set_priority (rtems_vector_number vector, uint32_t priority)
 Sets the priority of the interrupt vector.
rtems_status_code bsp_interrupt_get_priority (rtems_vector_number vector, uint32_t *priority)
 Gets the priority of the interrupt vector.
void bsp_interrupt_facility_initialize (void)
 BSP specific initialization.
void bsp_interrupt_handler_default (rtems_vector_number vector)
 Default interrupt handler.
Interrupt support.
